Skoda Octavia 2 1.9 Tdi Elegance
B_U_T
garantie la vopsea?nu o sa te ajute la nimic,degeba tii de ea. daca zici de garantia aia de 10 ani, e valabila la coroziune si la perforari de la interior spre exterior. daca tie iti sare vopseaua,nu se va aplica, pt ca e vorba de factori externi..
Modificat de paul_e88
  • Replies 319
  • B_U_T
    156
  • TIBI_84
    19
  • Georgik
    13
  • gbrgeorge
    13
N-am uitat domne',n-am uitat.
Intre timp i-am facut revizia si masina iar ne-a surprins placut prin felul in care merge.
I-am cumparat o statie si un subwoofer Hifonics.
Statia are urmatoarele caracteristici :
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 100 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 400 watts x 2 channels
Total Peak Power Output 800 watts
Maximum Input Gauge Size 4
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power N/A
Speaker Level Inputs Yes
Preamp Outputs 1 pair
Built-in Crossover Low-pass (LP)
High-pass (HP)
Full (AP)
High-Pass Crossover Frequency 60 - 1200 Hz
Low-Pass Crossover Frequency 30 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 9 dB
Fan Cooled No
Fuse Rating 30A x 1
CEA-2006 Compliant No
Iar caracteristicile subwoofer-ului sunt (sper ca le-am gasit pe cele corecte pt ca nu stiu exact modelul) :
subwoofer 12"
diametru difuzor: 30cm
tip incinta: bassreflex
putere RMS: 400W
putere Max: 800W
incinta solida din MDF
impedanta: 4 ohmi
dimensiuni 47x37x47/25 cm
La inceputul lunii februarie sper sa reusesc sa strang banii necesarii pt un tuning la motor si pt montarea de tipsuri cromate.
Va astept cu pareri/critici/sfaturi in legatura cu ce am cumparat. O seara buna !
post-20287-0-09995300-1295733605_thumb.j
post-20287-0-47485700-1295733651_thumb.j
Modificat de B_U_T
Salut ! cum ai legat "sculele" la playerul stream ?? Si eu as vrea sa imi pun un subwoofer dar mi s-a recomandat sa imi pun un player cu iesire pentru subwoofer.
@Claudiu - Nu cred ca geamurile sunt in pericol..bass-ul nu e f puternic tocmai pt ca am HU si boxe OEM.
@Octavia4ever - "Sculele" vor fi legate la o boxa din spate. Montajul nu l-am facut inca.
O seara buna!
Cablurile se la statie se leaga la firele din spatele stream-ului. Eu le-am legat la cele ce duc la boxele spate. O sa-ti trebuiasca si un adaptor hi/lo.
Felicitari pentru upgrade-uri.
Multi km fara probleme.
Alimentarea(plusul) ar fi bine sa o iei de la baterie.
Mergi la Sinvex si-ti vor face ei montajul,se pricep.
Daca alegi sa nu schimbi HU cu unul AM,o sa ai tot timpul subwooferul pornit,nu mai zic cat de limitat in reglaje este cel original(de fabrica).
Spor la modificat :icon_thumright:
Ar putea pune un buton pe firul de remote ca sa-l poata opri atunci cand vrea.
post-12745-0-40872300-1295878860_thumb.j
Am sunat acum la Beloud si mi-au cerut 280 RON montaj+fire+adaptor hi/low,la Sinvex mi-au cerut 250RON iar la Falcon mi-au cerut 616 RON :))
@Tibi - Stiu ca HU AM sunt mai bune d.p.d.v al calitatii sunetului dar mi se pare ca daca imi pun rama adaptoare si un Mp3 player normal am stricat tot interiorul..la B5.5 arata bine dar daca fac asta la Octavia va arata groaznic..
@Sorin - Si eu vreau sa-mi puna un buton on/off pt atunci cand nu vreau sa le folosesc cel mai probabil miercuri ma voi duce la beloud pt ca sunt in sesiune si nu pot sa ajung la Ploiesti..
Va multumesc pt sfaturi si urari.Drum bun!
Modificat de B_U_T
Vezi si la cei de la Booster :icon_thumright:
Modificat de TIBI_84
Abia astept sa vad cum ai reusit sa iti instalezi subwooferul si amplificatorul si daca esti multumit de ele . Daca sunt bune sculele imi cumpar si eu numai sa scap de sesiune :somnmare: . Apropo , le-ai cumparat de la be-loud ?
Sunt cumparate de la be-loud in 2008 si au mai fost montate pe un Golf5 cateva luni.Le-am cumparat de la un prieten care mi le-a dat aproape gratis..iti imaginezi ca si eu abia astept sa le pun..cred ca doua saptamani o sa-mi pacane creieru' dupa ce ma dau jos din masina :))
Azi le-am montat la Be loud si sunt foarte incantat de rezultat.Am montat si un buton on/off pe care l-am pus in compartimentul de sub blocul de lumini. Este exact ce ii lipsea sa aibe un sunet curat si puternic. De asemnea arata si foarte bine statia cu logo-ul iluminat. Va pun si o poza. Sa auzim de bine si drum bun!
P.S Cablul care vine de la baterie are 20".
post-20287-0-75094900-1296057713_thumb.j
Uau :)) Cum e cu senzatie majora cu 40 la ora ? =))=))=)) Frumos :P Deci se poate lega subwoofer si statie la stream , exemple fiind pe a ta si a lui sorin balan .
Senzatia chiar e majora..la stop daca stau cu geamurile inchise si muzica pe la 16-17 se uita cei din jurul meu de unde se aude :))
Se pot lega fara probleme la Stream dar iti trebuie un adaptor HI/LOW.Se aude mai mult decat bine,sunt foarte multumit mai ales ca o pot opri cand merg cu tata in masina (pt ca nu a aflat inca :blink: )
Modificat de B_U_T
:lol: :lol: Viata asta de student :lol: :lol: Stiu cum e cu tata si eu am patit-o
Sa le folosesti cu placere!(,,instrumentele")
Modificat de Adrian_S
Exact in situatia ta voi fi si eu :)) . Tatal meu nu suporta Bassul . Ma gandeam sa imi iau ceva micut pe care sa il pot da jos cand ma duc acasa in weekend sa nu vada :P . Asta e, cand o sa avem masinile pe banii nostri o sa facem ce vrem cu ele :)) . Bafta in continuare cu modificarile :)
@Adrian- Chiar ca viata de student..ziua inveti noaptea te plimbi :P
@Octavia4ever - Stai linistit ca daca nu vede sub-ul vede statia..si ai mei sunt conservatori in ceea ce priveste masina dar dupa ce mai fac cate o chestie la ea zambesc si imi zic sa le folosesc sanatos chiar daca la inceput nici nu vroiau sa auda :))
  • 6 months later...
Rog inchiderea topicului.Multumesc.
P.S Masina nu am vandut-o dar nu mai am eu grija de ea.
Modificat de B_U_T
