Eroare Aparuta Pe Bc
Fritz
  • Replies 87
  • Fritz
    20
  • silkworm
    8
  • F l o r i n
    6
  • ct29lnr
    6
Exact la fel face si la mine...deci nu imi mai fac nici un fel de problema...
florin_andrey86
sal, am un audi A4(B5) din 1995, 1.9 tdi, 90 de CP, si de la ceva vreme cand pornesc masina in locul Km de zi imi pare scris ceva de genu " In I" si clipaceste timp de 30-40 de sec dupa care reapare Km de zi, am verificat problema cu Vagcom 705 dar nu-mi da nici o eroare, am atasat o poza sa vedeti despre ce e vb, ms de ajutor..... :lol:
florin_andrey86
am incercat ceea ce mi-ai zis, dar nu am avut nici un rezultat, am incercat sa resetez cu vagcomu sevice remainderu dar imi da eroare
"Select
Service reminder-ul se reseteaza de la Aplication -> SRI Reset...de acolo se reseteaza service-ul
Bafta
Pre-1998 models ... or if Channel 02 is not available:
[select]
[17 - Instruments]
[Adaptation - 10]
Enter the correct channel from the list below in "Channel Number"
[Read]
The "Stored Value" is the current value for that channel.
Enter the "New" value of from the list below.
[Test]
[save]
Channel 05 should be the distance until the next Oil Service.
It is in thousands of kilometers. Let's say you want the Oil Service light to come on in 5000 miles. That would be 8000 km.
Put the value 8 into channel 05. The "standard value" used by the US dealers would be 12 (7500 miles).
Channel 06 should be the distance until the next In-1 Service.
Same units as above. Standard value would be 24 (15,000 miles).
Channel 07 should be the time until the next In-1. In-1 lights up based on time or distance, whichever comes first. This is in 10's of days. Standard value would be 36 for 360 days.
Channel 08 would be time until the next In-2. In-2 is based strictly on time. Standard value is 72 for 720 days (about two years).
Vin si eu cu o nedumerire ....
pe un A4 din 2005 1.9TDI 131 CP s-a aprin in bord in timp ce mergea martorul care iti arata ca placutele trebuie schimbate iar in acelasi timp Oil Pressure .
Omul a oprit masina a verificat uleiul si a completat deoarece era sub nivel ....
Dupa ce uleiul si-a revenit la nivel ...a pornit masina , dar la punerea contactului i-a aparut din nou in bord martorul galben de placute frana .
Sa fie oare o coincidenta sau acel martor tine loc si de atentionare presiune scazuta a uleiului ?
Daca ii da Check .... cand face scan-ul deasupra simbolului de uleui ii apare acel martor galben .... iar la sfarsit ii da OK-ul :))
La scanare nu a adat nici o eroare pe Engine sau ABS ....
Ce parere aveti ?
Multumesc anticipat !
eu zic ca e de la placute.... nu e greu de verificat.... faci un strap si vezi daca dispare
Postez si eu 3 poze cu problema care o am de ceva vreme:
Se face alb display-ul dintre ceasuri (el fiind color) iar daca ciocanesc putin in partea de sus ori isi revine ori se face pe jumatate ok si apoi incepe sa se albeasca. Spre exemplu aseara am mers cu masina nu mergea si il tineam inchis si la un moment dat l-am deschis si el isi revenise...a mers cca. 15-20 min am oprit si cand am plecat el tot alb era.
Modificat de Fritz
pana la urma nimeni nu a mai intampinat aceasta problema pentru a-mi putea da un sfat o indrumare ce sa fac ...mentionez k ba merge ba nu merge...nush ce sa mai fac :|
contact imperfect la display
ti-a pornit dupa ce a stat inchis deoarece s-a racit si s-a contractat refacandu-se contactul
Se prea poate sa o rezolvi doar prin schimbarea clusterului......
1. Daca ma ajutati cu un sfat sau o indrumare de unde sa iau un cluster color v-asi fi recunoscator.
2. In aceasta seara mi s-a aprins o eroare pe display dar fiind alb nu pot vedea ce eroare am...Aveti idee in vag-com unde asi putea sa vad eroarea aparuta pe display.
Va multumesc anticipat :D
Salut, intampin urmatoare problema:
Dupa ce am scos bateria si am facut reconectarea, a trebuit sa bag codul in navigatie. Acum intervine problema, pe computerulde bord nu imi mai apare al doilea computer; de ex primul indica cate ore s-au scurs de cand am pus contactul la masina, iar al doilea era permanent. Acum, am doar unul singur.
Ce s-a intamplat si cum pot sa rectific?
hangyouridols
Am patit si eu asta si trebuie recodat din nou cu vag com-ul;daca nu ma insel pe Instruments se face,oricum interfetele sunt intuitive si-ti spune ce si cum trebuie codat.
Am inteles, poate sa o faca cineva la intalnire care are vagcom?
  • 9 months later...
Fritz: ai rezolvat cu displayul ?
da...da s-a rezolvat cu display-ul...Multumesc lui Silviu WOW din Bacau...Nush ce a facut dar a fost plecat du tot IC in casa pentru 20 min si cand a revenit totu era k la inceput.
Acuma am alta problema ...
Cand imi citeste usa din dreapta spate...cand nu...cand merge sa o incui cand nu, marea nelamurire este ca m-i s-a intamplat sa nu mearga si geamul sa nu ramana memorat dar am patit-o sa nu mearga si geamul sa raman memorat.
Postez si cateva din erorile gasite:
Sunday,24,March,2013,15:51:05:26365
VCDS Version: Release 805.0
                Address 46: Central Conv.
Control Module Part Number: 8E0 959 433 L
  Component and/or Version: Komfortgerát T03    0112
           Software Coding: 06752
            Work Shop Code: WSC 63351
           Additional Info: 8E1959801B     Tõrsteuer.FS BRM 4.11
           Additional Info: 8E1959802B     Tõrsteuer.BF BRM 4.11
           Additional Info: 8E0959801A     Tõrsteuer.HL BRM 4.10
           Additional Info: 8E0959802A     Tõrsteuer.HR BRM 4.10
5 Faults Found:
01334 - Door Control Module; Rear Right (J398)
01559 - Drivers Door
        61-10 - Won't De-Safe - Intermittent
00914 - Window Regulator Switch; Rear Left; Driver (E53)
01560 - Passenger Door
01561 - Left Rear Door
Daca are cineva vreo idee si ma poate ajuta cu vreo informatie astept cu mare placere.
Am rezolvat si eu cu ceasurile color ... a trebuit sa schim modulul de airbag cu un altul din 2002, pentru ca aveam eroare de comunicare ..
Acum totul e perfect :)
De ceva vreme tot imi apare eroarea "CENTRE BRAKE LIGHT". Daca iau contactul si il pun inapoi dispare. Cam o data pe zi imi da eroarea asta. Din ce am citit pe aici nu am aflat nicio rezolvare concreta a preblemei. Stie totusi cineva care sa fie cauza defectiunii si cum poate fi remediata?
Merge stopul de pe luneta?
Sent from my GT-I8190 using Tapatalk 2
Da merge. Asta e ciudat...
Chestia e ca in urma cu cateva saptamani am schimbat placutele de frana si tot lichidul de frana din instalatie a fost inlocuit. Oare sa aiba asta vreo legatura?
Modificat de Cristi_KWJ
salut! poate ma ajuta cineva cu un sfat.. inca nu am ajuns la un service... intampin o problema de cateva zile, de cand au scazut temperaturile... imediat dupa pornire se aprinde in bord becul de la esp si imi apare mare pe ecrean "brake" cu rosu, bipaie de 3 ori si apoi se stinge... si apoi totul e normal in bord.. mentionez ca nu se intampla de fiecare data ... sa fie bateria slaba...  e bateria originala... sau switch-ul de frana... in rest masina functioneaza normal. multumesc
