Lampa spate numar - probleme
john1986
salutare. am si eu o problema la golfuletul meu: De ceva vreme am vazut ca becurile care lumineaza nr din spate nu se mai aprind. le-am dasfacut si m-am uitat la ele si cred ca nu sunt arse aveau filamentul acela untreg neintrerupt. Stie cineva daca o fi de la sigurante sau care ar fi cauza? si daca e de la sigurante care este aceea k eu am incercat sa inlocuiesc pe cele care aveau niste beculete (simboluri)dar n-a mers. astept raspunsurile voastre
De multe ori filamentul becurilor este inselator.Verifica totusi cu un bec nou.Daca nu uite mai jos lista cu sigurantele si numarul de ordine al acestora
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 (5A).
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A).
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A).
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A).
Fuse arangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A).
Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A).
iti multumesc mult. ma gandesc acum ca daca era se ardea unu si nu ambele. o sa verific totusi unu pe o baterie sa vad daca se aprinde.salutare!
Mai poti sa verifici cu un aparat de masura daca ai curent pe soclu (lamele) unde pui becul :icon_thumright:.
verifica si firele care vin la lampile ptr nr
si eu am problema asta .. dar nu la amandoua ci doar la una dintre lampi .. Am mutat lampa care merge in celalalt soclu si nu mergea.. am desfacut soclul si surpriza.. Firele sunt rupte chiar la intrarea in soclu :) .. Am sa ma chinui cumva sa le lipesc cu cositor.. ca nu a ramas deloc fir la iesirea din soclu .. nici macar ca sa am de unde ciupi umpic. S-ar putea sa ai si tu problema asta.. asa ca incearca sa-ti desfaci si soclul sa vezi daca ai firele prinse
aceeasi problema am avut-o si eu . becurile erau arse amandoua dar filamentul era intact . le-am inlocuti cu 2 becuri noi( vezi ca are in corra) si au mers bafta
  • 6 months later...
cum schimb si eu un bec la lampa din spate la un golf V ? trebuie sa dau mocheta la o parte? am incercat asta ..dar mai aveam oleaca si o rupeam :icon_cool: ......stie careva ??
Aici e aria "Golf IV & Bora".
De ce nu incerci o intrebare pe aria "Golf V" ?
Ma gandesc ca cei care utilizeaza Golf V stiu mai bine decat noi despre ce este vorba. :icon_cool:
auzi john1986, dar cum se numeste becul? are o denumire sau asa? cat te-au costat la Cora?
urgent va rog...siguranta lampi nr de inmatriculare golf IV, 1.9 sdi, aqm, 2002, unde o gasesc ??
multumesc !
scuze daca am postat gresit dar sunt disperat, mi-am luat deja o amenda.
Incearca pozitia F22 sau F23 daca nu sunt arse (nu sunt sigur daca alea sunt), iar daca nu sunt alea incearca atunci sa le verifici pe toate cu un aparat, iar o alta varianta ar fi sa inlocuiesti becul cu pricina ca poate ii ars. Sper ca ti-am fost de ajutor.
http://yfrog.com/ca37624258j
Daca e la fel ca la Passat, iluminatul la numar porneste de pe acelasi pin din blocul de lumini cu iluminatul interior.
Deci daca iti merge iluminatul interior, ai tensiune si la lampile de la numar.
Si mie imi este ars unul din beculetele din spate de la numar. De unde pot cumpara altul si ce tip e?
Becul il gasesti sub denumirea de C5W , la orice magazin de piese auto.
Sau la orice benzinarie. Aici gasiti informatiile necesare despre becurile oricarui tip de autoturism.
Salutare. Am avut si eu problema asta cu becurile de la numar. In prima faza le-am schimbat....au mers ok 2 luni dupa care s-au ars iar amandoua. Am fost la doctor(electrician) si i-am schimbat cablul de la mufa (care sa alfa pe partea soferului sub stopul de pe spate) pana la soclul becului si surpriza....dupa 1 an si inca mai functioneaza fara probleme. Daca nu va iese din sigurante si becuri schimbate...cautati firul cu pricina, este posibil sa faca un scurt pe undeva.
Toate cele bune
De ce nu incerci direct cu leduri?! Arata bestial!! :blah_:
Eram atat de invidios pe cei cu audi care aveau lumini albe la numar!!
Acum mi-am pus si eu leduri...si sunt super incantat de cum arata estetic...si lumineaza si mai puternic.
Salut... La mine una din lampi nu mai sta prinsa in surub, oricat l-as infileta surubul tot cade, probabil s-a "mancat" si nu mai are pe ce sa prinda;
M-am gandit si eu sa le schimb cu leduri... dar nu stiu cum se monteaza... cum vin puse..... de unde le-ai luat si cat te-a costat... poate dezvoti putin si pui si niste poze, merci anticipat
@GabryEL
am facut asta seara o poza. nu este ea prea reusita...dar sper sa vezi ce este de vazut.
pretul a fost undeva pe la 15-20lei bucata (sincer...nu mai stiu exact...deoarece am pus si la tot interiorul-plafoniere laterale usi si centrala, parasolare).
mi le-a pus un coleg de pe forum. sincer...nu as vrea sa fac reclama unuia sau altuia direct aici. daca vrei neaparat...da-mi pm si iti spun acolo cine este colegul :)
Gabryel, led-urile vin in soclu C5W, doar ul pui direct in locul celora existente si gata, how hard can it be? :)
Aceeasi problema am avut si eu, aveam o lampa arsa de la numar spate, era cam topita carcasa de plastic intr-o parte si astfel se infiltra apa.
Din acest motiv mi s-a ars.
Am inlocuit soclul si am pus lampi noi, dar pe led (au exact aceeasi marime, numai ca in loc de filament sunt 3 leduri)
O sa ma uit prin garaj sa vad daca mai am cutia de la lampi, ca nu mai stiu marca si modelul.
Lampile le-am luat din Pitesti, pe Dumbravei cu 15 lei si arata foarte bine, la fel ca-n poza pusa de marius1982.11
Adimar - merci... se vade ok... o sa te contactez pentru alte detalii
marius1982.11 - probabil ca nu estew greu de montat.... am crezut ca e ceva mai complicat (mi-am mai taiat eu degetele incercand sa fac pe electricianul:D) ... merci mult pentru precizar
  • 11 months later...
si eu am aceeasi problema. observasem ca nu imi mai functioneaza una din lampi si am decis sa cumpar niste leduri. numai ca atunci cand le-am montat, nu s-au aprins. ledurile sunt verificate, functioneaza. un prieten mi-a spus ca VW are probleme la capitolul asta si ca e recomandat sa fie montate beuri originale tip "SOFIT" (nu stiu daca am scris bine, am scris fonetic). Un astfel de bec costa 1 LEU.
Urmeaza acum sa merg la un electrician si sa verific firele si daca am curent in "instalatie" :)))
o sa revin cu constatarile si rezolvarea.
