Air Intake Filtre...inductie...mai multi "ponei"
moosct
Cat despre intercooler doar un pulverizator de apa pe exteriorul lui ar fi util, dar nici ala nu face minuni decat cand este supraincalzit
De sistemul nitro pentru racire intercooler, NX N-tercooler ce parere aveti? Aduce ceva la TDi?
Ei zic ca aduce o crestere de putere de multi cai
NEX-20000-00.jpg!
The N-tercooler from Nitrous Express will kick up to 50 more horsepower out of your air-to-air intercooled ride. The efficiency boosting effect of the N-tercooler is awesome. If you want more, this is it! The NX N-tercooler kit includes everything you need to add a nitrous oxide or CO2 intercooler refrigeration system to your vehicle. Great for turbocharged or supercharged vehicles where nitrous injection is not an option, the N-tercooler is a great alternative. The oval jet tubing mounts to the front of your intercooler or radiator and sprays a super-cooled fog of gas to help reduce intake or engine temperatures. Using either nitrous oxide or CO2, this system can reduce air inlet temperatures dramatically. In a recent dyno test, a turbocharged Honda equipped with an NX N-tercooler increased its baseline power by an astounding 52 horsepoower! It's like A/C for your intake. Complete kit includes 5 lb. nitrous oxide bottle, oval nitrous rail with integrated fogger jets, stainless steel tubing, activation solenoid, activation switch, wiring, and installation hardware. The included nitrous oxide bottle can also be used for a full-blown nitrous oxide injection system.
Features
Can Be Installed on Virtually Any Car, Truck, or SUV
Great for Turbocharged or Supercharged Vehicles
Can Reduce Intake Temperatures Dramatically
Add Real Horsepower – Especially on Hot-Running Race Engines
Works with Nitrous Oxide or Carbon Dioxide (CO2)
Oval Jet Tubing Mounts To Intercooler or Radiator
Complete Kit Includes:
5 lb. Nitrous Oxide Bottle (shipped empty)
Oval Nitrous Rail with Integrated Fogger Jets
Heavy-Duty Activation Solenoid
Stainless Steel Nitrous Supply Lines
Installation Hardware
Activation Switch and Wiring
Detailed Installation Instructions
Inclin sa cred ca da. O simt pe cehoaica mea cum se-ncoarda cand e mai racoare pe-afara. Am vazut un BMW de Bihor care se pare ca are asa ceva (nu e foarte clar in poza, sorry).
Cred ca solutia cu CO2 este eleganta si probabil mai usor de aplicat la noi, desi se poate ca racirea data sa nu fie chiar ca cea cu protoxid de azot.
Cistigul cel mai mare se va gasi la masinile pe benzina pentru ca fiecare molecula de oxigen ce intra in motor este automat insotita de adaos de benzina (ECU trebuie sa mentina amestecul stoechiometric)
La diesel poti sa bagi cit aer vrei ca daca nu modifici mapele din ecu peste un anumit punct nu mai primesti motorina.
