Elanul
Nu se gasesc acolo.... trebuie sa caute cineva care are etka. Merci oricum, astept poate ma ajuta altcineva cu un cod
Erau... http://www.partsbase.org/vw/passat-4motion-santana-pa-eu-2009-82520-trim-bottom-plate/#p-vw-3c0825201f pozitiile 18 si 19.
  • Replies 5k
  • GABIVVX
    1104
  • Kostas
    155
  • Dolfin
    129
  • iuliu1984
    89
sall am si eu un passat din 2009 2.0 tdi 110 cp si am urmatoarele erori dar nu imi dau seama care este problema la motor ma puteti ajutaa ???
Thursday,14,January,2016,11:57:31:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ3CZAE029824   License Plate:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 69 77
01-Engine -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CBD)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 BT    HW: 03L 907 309
   Component: R4 2,0L EDC G000SG  6214
   Revision: 13H02---    Serial number: VWZCZ000000000
   Coding: 0000071
   Shop #: WSC 05311 000 08193
   VCID: 78FF0E6B0B2690DEAC3-802D
3 Faults Found:
009254 - Exhaust Gas Recirculation Cooling Valve Control Circuit
               P2426 - 000 - Short to Ground - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 163177 km
                    Time Indication: 0
                    Date: 2009.14.03
                    Time: 18:32:17
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Temperature: 41.4°C
                    Absolute Pres.: 999.6 mbar
                    (no units): 0.0
                    (no units): 3.97
                    Temperature: 81.9°C
000071 - Boost Pressure Control Valve/Solenoid (Bank 1)
               P0047 - 000 - Short to GND - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 163177 km
                    Time Indication: 0
                    Date: 2009.14.03
                    Time: 18:32:17
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Load: 9.8 %
                    Lambda: 12.6 %
                    Temperature: 41.4°C
009754 - Coolant Pump 2
               P261A - 000 - Open circuit - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 25
                    Reset counter: 255
                    Mileage: 163177 km
                    Time Indication: 0
                    Date: 2009.14.03
                    Time: 18:32:18
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Voltage: 12.31 V
                    Lambda: 0.0 %
                    Bin. Bits: 10011110
                    Bin. Bits: 00000001
                    Temperature: 80.1°C
Readiness: 1 3 0 0 1
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
   Component: J104    C4 440 V2   0015
   Revision: --025---    Serial number: 00000795361968
   Coding: 0000260
   Shop #: WSC 05311 000 00000
   VCID: 62CB4C03BDBA6A0EE27-8037
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No SW: 1K0 820 047 JP    HW: 1K0 820 047 JP
   Component: Climatic PQ35   143 1515
   Revision: 00143034    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 7BF511673A10BBC6C11-802E
1 Fault Found:
01271 - Positioning Motor for Temperature Flap (V68)
            000 - - - Intermittent
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
   Component: Bordnetz-SG     H54 2602
   Revision: 00H54000    Serial number: 00000003202235
   Coding: E1888F0700041A00470A00000F00000000095D435C000120000000000000
   Shop #: WSC 05124 000 00000
   VCID: 3365F94752C0B386591-8066
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 150609 004  0206
   Coding: 00046997
   Shop #: WSC 05124
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     050809 054  0402
   Coding: 00208936
   Shop #: WSC 05124
3 Faults Found:
01505 - Bulb for Blinkers; Rear Right (M8)
             Freeze Frame:
                    Fault Status: 00111100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 318749 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.35 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
00988 - Lamp for Brake Light; Right (M10)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 14
                    Mileage: 318749 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.05 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
00985 - Right Tail Light (M2)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 318749 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.05 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__00H VW10 HI   1916
   Revision: 20013000    Serial number: 003E2PE22BQD
   Coding: 0012360
   VCID: 4487AA9B076E043EF0B-8011
   Subsystem 1 - Serial number: 6332MTS671331989
   Subsystem 2 - Serial number: 6342MTS638421849
   Subsystem 3 - Serial number: 6351HTS6VCB1V8KJ
   Subsystem 4 - Serial number: 6361HTS69ED3V8KR
   Subsystem 5 - Serial number: 00000000000000000
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 BA    HW: 3C0 953 549 BA
   Component: J0527               0030
   Revision: 00034000    Serial number: 3C9953507CL
   Coding: 0000014
   Shop #: WSC 05314 000 00000
   VCID: 6CD7223B4F7E2C7E58B-8039
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C0 920 872 B    HW: 3C0 920 872 B
   Component: KOMBI         H02 0206
   Coding: 161F00
   Shop #: WSC 05314 115 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 24470A1B2F2E243ED0B-8071
Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P09804047E
   Coding: F9801F46000602002002
   VCID: 2A5BE423850AF24EEA7-807F
Address 25: Immobilizer
Cannot be reached
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 AR    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1501
   Revision: 72009005    Serial number: 00000654498722
   Coding: 0000053
   VCID: 7EF318732902AEEEE6F-802B
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
             Freeze Frame:
                    Fault Status: 00100101
                    Fault Priority: 6
                    Fault Frequency: 16
                    Reset counter: 41
                    Mileage: 0 km
                    Time Indication: 0
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Part No SW: 3C0 959 433 AQ    HW: 3C0 959 433 AQ
   Component:    KSG PQ46 ELV 044 0612
   Revision: 00044000    Serial number: VWZCZ000000000
   Coding: 0091020851030E763004941570084B0E703C01
   VCID: 79F90B6F302C89D6D3D-802C
   Subsystem 1 - Part No: 1K8 951 605
   Component: LIN BACKUP HORN H09 9002
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 4
                    Fault Frequency: 4
                    Reset counter: 9
                    Time Indication: 0
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1K0 959 702 AR    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1501
   Revision: 72009005    Serial number: 00000876098722
   Coding: 0000052
   VCID: 7F0DE5772E08A7E6ED9-802A
1 Fault Found:
00097 - Front Passengers Central Locking (Safe) Motor (V162)
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 19
                    Mileage: 318689 km
                    Time Indication: 0
                    Date: 2008.14.18
                    Time: 10:58:15
Address 53: Parking Brake        Labels: 5N0-907-801.clb
   Part No SW: 3C8 907 801 C    HW: 3C8 907 801 C
   Component: J540 EPB3  VW-13618 0005
   Revision:   010       Serial number: 00000000057733
   Coding: 0000057
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  013 0036
   Revision: 00000000    Serial number: VWZ1Z2I6614540
   Coding: 0500040004
   VCID: 65C1571F6C941D36075-8030
2 Faults Found:
00870 - Bass Speaker Front Left (R21)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 57
                    Mileage: 307021 km
                    Time Indication: 0
                    Date: 2005.14.23
                    Time: 07:18:57
00874 - Treble Speaker Front Left (R20)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 89
                    Mileage: 292210 km
                    Time Indication: 0
                    Date: 2002.14.28
                    Time: 11:38:14
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H08 0080
   Revision: 3A002002    Serial number: 00000120392863
   Coding: 4100000100000000
   VCID: 2F6DF5377EE897663D9-807A
1 Fault Found:
16355 - Control Module - Watchdog Timer
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 133
                    Mileage: 176560 km
                    Time Indication: 0
                    Date: 2044.14.29
                    Time: 08:30:44
Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
   Part No SW: 1K8 035 730 C    HW: 1K8 035 730 C
   Component: Telefon       H08 6600
   Revision: 00008000    Serial number: 20389520188415
   Coding: 012120
   VCID: 29591B2F400CF956E3D-807C
End   ---------------------------------------------------------------------
Multumesc baieti pentru ajutor. Toate cele bune !
scuze sunt mai nou pana invat dureaza ceva
Salutare, ma poate ajuta cineva cu o lista de coduri de piesa ale bordurilor compatibile cu :
WVWZZZ3BZ1E120351 ?
bbogdanmircea
Tablou bord negru/negrusatinat: 3B1.857.002.BM.LWE
am un prieten caruia i-a picat ECU de la motor de la un Audi A6, 3.0 TDI Avant Quatro.Codul mare de pe calculator este 4F0 910 402 E,iar unul scris mai mic este 4F0 907 401 C pe Bosch.Intrebarea e daca se mai gaseste si pe alte modele de audi cu motorizare 3.0 sau doar pe A6?si trebuie sa cumpere unul cu exact acelasi cod sau ..?
Modificat de iuliu1984
Salutare!
Gabi te rog spune-mi codurile pt amortizoare fata (ulei) , spate (gaz) pt Monroe si Bilstein.
WVWZZZ1JZ1D170213
Salut Gabi, spune-mi te rog codurile pt grilele laterale fără proiectoare. Wvwzzz1kz7w016444
1K0 853 665 AB 9B9 + 1K0 853 665 AB 9B9  grila  bara fata  model GT fara proiector.
Imi poate spune si mie cineva codurile de piesa a cadioptrilor din bara spate care se regasesc pe Golf 6 R sau Golf 6 R-Line ?
Stanga - 5K0 945 105J
Dreapta - 5K0 945 106J
Codurile sunt pentru RLine fabricat dupa 13.12.2010
Wow ... 200 ron pentru un rahat de plastic reflectorizant ... wow .. asta da jacmaneala !
Modificat de ShadoWzZ
salutare
Am si eu o problema cu pompa de inalte ,pierde motorina si nu imi dau seama de la ce producator este si nu-mi dau seama nici cum sa gasesc un cod pe ea....
Pe ea mai era lipit ceva dar s-a sters scrisul
Ma puteti indruma cum as putea sa-mi dau seama de cine e facuta pompa sau un cod ceva?
Se poate vedea dupa VIN ? sau cu cu VCDS?
Va multumesc de ajutor !
oare un cod de semnalizator de oglinda de passat 2004? exista si model cu sticla fumurie?
Salutare, mă poți ajuta te rog cu,codul si pretul pt cilindru ambreiaj audi a3 8p 1.9 105 cp bkc 2004 ? Ms mult mă interesează doar pe Sachs.wauzzz8p84a163799
Modificat de fragrances09
Salut.
Ma poti ajuta te rog cu un cod radiator ac pentru Passat 1.6/2002-WVWZZZ3BZ3P262971?
1 minute ago, GABIVVX said:
3B0 260 401 B condensor
Multumesc mult!
Va salut.
Domnilor, ma puteti ajuta cu codurile originale pentru reperele pe care le-am marcat in fotografie? Sunt aproape convins ca sunt coduri pentru fiecare element in cazul bandourilor, dar in cazul ornamentelor de pe portiera stau la fel lucrurile?
Masina in cauza este un Superb 1 (3U4), iar seria de sasiu este TMBDC23U289015769
andreidumitru
Ma puteti ajuta cu coduri pentru urmatoarele piese (eventual si un pret aproximativ): VIN: WVWZZZ1JZ3W080717
- bieleta de directie dreapta fata
- cabluri frana de mana
- cele 2 O-ringuri de la tubulatura turbo (partea de jos ce intra in intercooler)
- supapa EGR
- capac aerisitor roata stanga fata
- bride fixare bara stabilizatoare + bucse
Stie cineva daca codul 3C0998225 este bun si pt far cu xenon sau nu se potriveste (kit reparatie far passat b6 2007) ?
  • cogdao a închis acest topic
  • Marian a deschis acest topic
