Trepidatii A4
vicos
Nu stiu ce naiba are dar chair acum cand vreau sa plec la munte cu ea trepideaza de zici ca e caruta.
Chiar si cand stau pe loc cu motorul pornit trepideaza.
La curba spre dreapta aud si un zgomot ciudat, o bataie ca de planetara defecta.
Am bagat VAG-COM 303.1 dar nu am descoperit care e treaba. Iata listingul:
VAG-COM Version: Release 303.1
Chassis Type: 8D - B5 Audi A4
Scan: 01,02,03,08,15,17,25,35,45,46,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 AN
Component: 0000SG 1301
Coding: 00002
Shop #: WSC 06435
0 Faults Found:
Address 03 -------------------------------------------------------
Controller: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00012
Shop #: WSC 06435
0 Faults Found:
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 Q
Component: A4 KLIMAAUTOMAT D58
Coding: 00043
Shop #: WSC 06435
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 900 M
Component: KOMBI+WEGFAHRS. M73 D56
Coding: 00040
Shop #: WSC 38083
XXXXXXXXXXXXXXXXX AUZ5Z0E2078142
0 Faults Found:
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 B
Component: ZV-Pumpe, Funk D16
Coding: 14913
Shop #: WSC 06435
2 Faults Found:
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 46 -------------------------------------------------------
Controller: 8D0 919 283 P
Component: arkingsystem A4 RDW D05
Coding: 00104
Shop #: WSC 06435
1 Faults Found:
01545 - Sensor for Parking Aid: Rear Left (G203)
37-00 - Faulty
Address 56 -------------------------------------------------------
Controller: 8D0 035 195
Component: Radio D00
Coding: 00200
Shop #: WSC 06435
0 Faults Found:
End -------------------------------------------------------
AVETI vreo idee sugestie ceva?
Va rog un sfat!
Chestia cu tremuratul s-a mai discutat. Ia vezi, topicul ASTA te ajuta? Mai ai in el un link catre alt topic.
tocmai a patit un prieten o chestie similara (fara bataia gen planetara) si anume turatia sta perfect constanta la relanti (882rpm), nu apar niciun fel de erori pe vag-com dar motorul tremura groaznic (si cu el toata masina, mai ales la relanti). Am pus masina mea si a lui una langa alta cu capotele deschise iar diferenta de miscare intre motoare este mai mult decat sesizabila. Deocamdata nu s-a rezolvat problema, dar cateva minute inainte sa apara asta, a dat intr-o groapa mare. Eu banuiesc un suport de la motor rupt...
Este o explicatie la gropile care sunt la noi.
Daca afli ceva spune-mi si mie te rog.
Modificat de Rapier
Te rog nu mai da "quote" la mesajul anterior daca nu este nevoie. Multumesc
Suportii de la motor pot fi intr-adevar un motiv. Din ce stiam insa, acestia sunt hidraulici si au si ceva senzori pe ei. Daca ar fi rupt vre-unul, nu ar trebui sa dea un mesaj de eroare? Poate nu este insa rupt de tot si doar nu mai merge cum trebuie
Asa este. Confirm ca acei suporti sunt asistati electronic, insa pot da trepidatii fara sa-ti dea mesaj de eroare in bord (in caz ca nu sunt avariati total)... insa nu pot fi sigur, ca, in cazul tau asta este raspunsul... acel suport in Germania a costat 100 euro( buc + manopera service) din proprie experienta iti spun.
Bafta si asteptam sa ne spui care a fost rezolvarea.
suport asistati electronic????))))))))) nu ma pot aptine sa nu ma stric de ras (sory) dar e o maisna nu apolo 13
eo mam auzit pana acuama de asa ceva daca ati descoperit voi LUMINATIMA SI PE MINE (ca poate oi fi eo mai in urma cu tehnicile moderne)
salut,
un prieten a avut la fel la un bmw si era de la un suport motor hidraulic.
l-a costat 3 mil suportul si 1 mil manopera
ionut2500tdi, daca nu stii tu ceva, nu inseamna ca nu exista. Te rog sa te mai informezi si dupa aceea sa postezi in bascalie. Daca nu stiai, suportii de motor sunt hidraulici si au senzori electronici. Si asta nu numai la masinile grupului VAG. Am vazut chiar postat pe acest forum log de eroare scos din VAG-COM in care era un cod de eroare dat de un astfel de suport. Pretul unuia este de peste 300 RON, comparabil cu cei 100 EUR cat spune BogdanChipaila ca a costat in Gemania. La masinile vechi (gen VW broscuta) existau suporti (sau tampoane) de motor facuti din cauciuc special, intre timp s-au mai schimbat lucrurile.
totusi, si eu am avut un suport de motor defect (cum te uiti la motor din fata masinii cel din dreapta-se vede si senzorul cu firele) - dar a aparut defect la scanarea cu vag-com...sa nu fie altceva...
revin
am citit postarea si apare doar un senzor de parcare defect...
Coding: 00104
Shop #: WSC 06435
1 Faults Found:
37-00 - Faulty
trebuie studiata problema... :)
Modificat de pmrazvan
Din ce stiu eu(am avut si eu unul rupt) au senzor doar suportii de la motoarele de 2.5.
Nu stiu daca si la 1.9 sunt cu senzor.Acel senzor are rolul sa-ti semnalizeze atunci cind suportul motor este rupt iar lichidul din el s-a scurs.
Asa este,nu da semnal intodeauna,la mine s-a rupt ciuperca de metal pe care este vulcanizat tamponul si nu mi-a semnalizat nimic la bord,desi era cu senzor.
Sincer sa fiu,nici nu stiu ce ar fi trebuit sa se aprinda pe bord in cazul asta.
Luigi Vicol
In bord nu se aprinde nimic. Doar pe VAG-COM apare eroare daca e sa apara ceva
Problema prietenului meu s-a elucidat, era vorba de blocanta care s-a blocat si s-a intamplat "nu-stiu-ce", n-a inteles prea bine de la mecanic si ca atare io va zic ce mi-a zis el :icon_thumright: A trebuit schimbata volanta si kitul de ambreiaj, cost piese 2200RON, de la volksman. Motorul era un AWX.
Referitor la problema tampoanelor, doar cel din stanga e cu hidraulic senzor, cel din dreapta e doar hidraulic, deci, daca cel din dreapta se defecteaza nu va da nici o eroare la scanare. Trepidatiile motorului insa nu cred ca vin de acolo, eu am umblat cam 3 luni cu el defect dar nu am simtit nici o diferenta notabila dupa schimbarea lui.
In fisierul atasat gasiti schita+codurile(diesel)
Tampoane_A4.doc
Modificat de Scorpion
Am rezolvat problema. Aveam noroi pe roti si am facut o echilibrare. Acum e ok cu trepidatiile. In schimb a ramas problema cu zgomotele acelea ciudate cand iau curbe. Am fost la tuning la dnul Voinea si dupa parerea lor este de la burduful de la planetare. Mi-au recomandat o inspectie tehnica la un service. Stiti vreunul bun in Bucuresti???
te duci la domnul spirescu 0744 88 71 12 repara vw audi e tare omul doar ca a mutat service ul tocmai in berceni langa IMGB
Am curajul sa-ti recomand mecanicul meu, dezavantajul este ca trebuie sa ajungi pe sos. Giurgiului ... dar .... crede-ma ca merita.
Daca doresti detalii da-mi un PM.
Modificat de BogdanChipaila
