RNS 510 - Columbus - Update FW si harti
florin.petre
  On 18.02.2013 at 9:58, humerg a scris:
Noteza-ti ce versiune ai acuma, si daca nu merge pui verisiunea de acuma.
Sau pui 2760, aia merge c-am pe toate RNS510.
Eu la cate am incercat, tot timpul a mers 2760.
Am pus 3810 dupa care am pus 4120 versiunea custom care are HDD impartit 70/25/5 spre deosebire de cea standard cu 50/25/25. Am 20 GB pentru mp3-uri :)
Multumesc pentru suportul acordat :icon_thumleft:
Modificat de Twinsen
Sal.,
A instalat careva din voi noul SW-5218 ?
Eu am versiunea F dar as vrea sa stiu inainte daca-mi sterge cumva hartile .
Multumesc,
O zi buna .
Modificat de @DRI@N
@DRI@N
5218 e pentru unit-uri cu DAB+
nu fa prostia care am facut o eu, si am bulit o navigatie.., recomand 4020 tuturor,
in plus cu 5218 nu mai arata POI urile decat cu harta originala, fara speedcams si traffic lights
Am pus la unii si merge, dar nu stiu daca mai poti sa faci upgrade, downgrade dupa.., eu am incercat sa fac downgrade si l am bulit..
Am pus in aceasta saptamana la 2 masini cu RNS 510 B, 4020 modificat special pt vers A/B/C, merge fara probleme.
up to 5xxx softwares are for DAB+-Units. You can use also the 4020
modified or 4120 modified for your Unit. By the way if you use the 5218
and you had old 003 Radio board, your radio board will be half damaged and you get no more sound!
Maybe it works on standards. but when no coding is done other devices
will not work or work properly leik RFC and so on. So coding is needed to work properly.
@ florin r.
Uite ce aduce nou 4020
Version 4020/4024/4026/4028 firmware for the Volkswagen RNS 510 and the Skoda Columbus has been released.
  • Voice Control (requires microphone – see Volkswagen RNS 510 Microphone Connection for voice control)
  • NEW Faster navigation and user interface
  • NEW Automatic illumination control
  • NEW Enhanced destination input
  • NEW hold down the setup button
    for 30 seconds and get the following menus: FM, AM and the new VERSION
    INFO (map version and type, hw and sw versions)
  • NEW Compass
  • NEW POI- see Volkswagen RNS 510 Maps POI – New Features with firmware 3xxx
  • NEW Languages – Arabic,  Russian, Turkish and Polish
  • Speed Limit Display
  • Stability Improvements
  • Faster Startup (this has been improved on 2720)
  • Display OPS and RVC at the same time
  • SDHC 32 GB Support (HW04 and above)
  • Display Off on extras tab
  • Climatronic control if approriate climatronic fitted
  • Clock display if RNS 510 swtiched off
  • Excluded roads (under route options)
  • GPS coordinates entry
  • Additional adjustments for video
  • Larger RVC screen with transparent menus at the side
Modificat de mark21
Multuimesc Dragos, dar intrebarea mea era ce aduce nou 5218 in comparatie cu 4020.
citeste mai sus, si o sa vezi, ca nu e pt unit urile fara dab+
oricum aduce nou sigur:
RADIO TEXT, selectat din extras
si un improvement la touch
oricum e pre-relase, beta 5218, cica 4120 ar fi final, eu cand am vrut sa fac downgrade la 4120 am bulit navi..
Help! Mi s-a dezactivat video in motion pe RNS 510 fara sa-i fi facut nimic (cel putin asa cred). Stie cineva cum il pot reactiva, sau motivul ptr care s-a dezactivat?
mark21 cum ti s-a bulit rns-ul ?
Ireversibil ?
Confirm ca 4120 merge impecabil, si din cate am vazut, merge pe toate rns-urile.
Are si VIM activat, si Secret Menu.
Cu riscul de a supara cativa colegi care au mai vorbit despre problema asta (si imi cer scuze), vreau sa revin la VIM. Am o nav. versiunea B si as vrea sa activez optiunea, dar mi-e foarte frica sa nu stric navigatia. A intampinat cineva probleme (exceptandu-l pe cristi_van) la aceasta activare, sau exista vreun risc... Daca nu, imi puteti da un link de unde sa iau fisierul? Va multumesc.
Modificat de aLeXu'
Var.1 - Este o imagine ISO care se arde pe Cd, se pune in RNS sin 2 min ai VIM activat.
Var. 2 - Sau pui imaginea ISO cu Firmware 4120 pe DVD, pui in RNS, si in 1 ora ai activat si VIM si SecretMenu.
La VIM nu este nici un risc, sau cel putin nu am patit eu pana acuma.
4120 stiu ca e ultima versiune de firmware care merge pe toate rns-urile, fara riscuri.
Am instalat pe RNS pe care 4020 a dat erroare, si 4120 a mers impecabil.
Eu am din fabrica vers B si soft 0900 si nu as vrea sa umblu la firmware, nu ma intereseaza update-uri sau ceva de genul, doar VIM. Si mi-era frica sa nu o stric. Imi poti da te rog un link de unde sa iau fisierul? Eu am descarcat de pe vreo doua link-uri, dar totusi as vrea unul care a mai fost folosit.
De la versiunea aia poti linisitit sa faci update la 4120.
Am inteles ca trebuie rescris flash-ul.
L-am trimis la carsystem.pl . A mai reparat un coleg de forum, de fapt e o rescriere de flash, bootloader, firmware, cu un programator care costa 1000 euro, problema e ca trebuie sa ai dump dintr o navigatie asemnatoare ca si HW, a mea e HW 64.
  On 22.02.2013 at 7:11, humerg a scris:
Ireversibil ?
4120 nu apare pe my-gti.com, ultimul e 4020. L-am gasit in alta parte ,dar ma intrebam de ce nu apare si acolo, doar e din sept.2012, dupa cum vad.
Sau nu l-am vazut eu?
E un forum si ala, nu e nimic oficial, si poate nu a postat nimeni.
Eu de aici l-am luat: http://www.rnsfirmware.com/ (a nu se considera reclama).
Merge impecabil, si chear e modificata partia super util !
Asta are inclus si VIM si SecretMenu !
Am reusit si am reactivat vim-ul la loc. Cine e curios ii zic cum sa faca.
Se poate schimba doar sticla display-ului la RNS? Daca da, stiti vreun service?
  On 22.02.2013 at 16:44, cristi_van a scris:
Si nu spui si la altii? poate au si altii aceeasi problema? Sau vrei sa te rugam frumos? :ceuameni:
Pai nu a parut nimeni interesat. De ce sa postez ceva ce poate nu intereseaza pe nimeni? :) Aici am gasit foarte explicit
Activarea din butoane nu e permanenta.Daca ai umblat la volum, gata, ecran negru.
Asta se stia mai de mult.
Daca vrei VIM, cauta pe net imaginea: VIM_Berto89.iso
O arzi pe un cd, bagi in RNS, si in 2 min ai activat VIM.
Am inteles. Pe urma am constatat si eu ca nu mai mergea dupa e umblam la comenzi. Credeam ca am rezolvat-o. Am sa caut imaginea aia. Exista vreun risc sa fac alta trasnaie?
Vezi ca a postat cineva un link cu un soft modificat,care are si vim activ
salutare , ieri cand am schimat IC RNS-ul imi cere codul de pornire , eu nu am , este de fabrica , daca ma duc la reprezentanta cu talonu masinii ca sa-l obtin trebuie neaparat sa fie si masina la ei sau ajunge talonu si actul de identitate ca sa demonstrez ca sunt propietar ? si este contra cost acest cod ?
Uita-te in cartea service. Trebuie sa fie scris undeva pe primele pagini.
  • Aerofan changed the title to RNS 510 - Columbus - Update FW si harti
  • Bebeee pinned şi locked this topic
  • Bebeee unlocked şi locked this topic
  • Bebeee a deschis acest topic
