RNS 510 - Columbus - Update FW si harti
florin.petre
Referitor la schimbarea codului navigatiilor (o discutie inceputa cu o pagina in urma) am gasit ceva interesant
  Citat:
1Z0 035 680 A - hardware C3/C4A which is called revision A. Latest official firmware is 1024, unofficial - 2684, modified - 3814
3T0 035 680 - hardware C6/C7, revision B. Latest official firmware is 1404, unofficial - 3984
3T0 035 680 A - hardware C8/C9, revision C. Latest official firmware is 2844, unofficial - 3984
3T0 035 680 B/C/D/E/F - hardware C10/C11, revision D. Different ending letter in the part number specifies the type of map preloaded in the factory (none/West/East). Latest official firmware is 4024.
Latest "official" means firmware which is available at the dealar, "unofficial" means firmware which is available in the internet. There are also some 41xx development versions which unofficially support revision B and C units, so we can only hope that VW will release them to the public.
Regarding the version information in VCDS - all version info there can be falsified, you can trust only the version information displayed in hidden Testmode menu under Version Info:
HW Vehicle: 0xC001, HW Radio: 0003 - revision A
HW Vehicle: 0xC201, HW Radio: 0004 - revision B
HW Vehicle: 0xC801, HW Radio: 0006 - revision C
HW Vehicle: 0xCA01, HW Radio: 0006 - revision D
Modificat de Clodius
@Clodius:
N-are cum sa fie de la antena din 2 motive (cat se poate de non-informatice): 1. initial n-am avut aceasta problema in sensul ca eram exact pe harta unde eram si exact fizic si 2. antena GPS era aceeasi si cand imi mergea bine si este aceeasi si acum (cea din fabrica). Am mai auzit si teoria cf. careia din cauza ca antena este in partea din spate a masinii se intampla acest lucru insa din pct. meu de vedere pica si aceasta teorie intrucat intre extremitatea din fata a masinii (botul) si locul unde este antena sunt cca. 3 metri si nu 20.
In alta ordine de idei, am intrebat azi la Midocar Vitan daca se poate face un update de soft (si firmware...sau cum ii zice si versiunea de harta) si, fara sa fiu intrebat ce versiuni am pe masina, mi s-a zis ca softul aparatului nu se poate updata, iar o noua versiune de harta apare abia in iulie :ceuameni: . Si cum n-as vrea sa umblu la ea cat timp inca este in garantie...m-am scos bine de tot.
octavia 4ever
Salutare, un prieten de-al meu si-a cumparat un passat CC cu navi mare (nu stiu ce model e ) masina e din 2009. Cum fac sa ii mearga navigatia ? trebuie cumparat CD de la reprezentanta sau pot sa iau si de la smecheri cu 100 -200 ron ? trebuie modificat ceva la navigatie sa mearga CD neoriginal ?
Poti sa cumperi de la reprezentanta.V8 7691 pentru Europa de Est.Nu trebuie sa modifici nimic,introduci dvd-ul cu harta,poti sa-l copiezi pe hard si astepti pana ti se insaleaza sau sa iti ruleze navigatia de pe dvd.
Modificat de forceturbo
Soft nelicentiat
Instalat FW 4020 + Harti Est 7693.
Selectezi detaliile de harta (spitale, benzinarii, radare fixe etc) si dupa repornirea aparatului acesta nu le tine minte, trebuie sterse si selectate din nou.
Desi sunt selectate initial (setup/detalii harti),acestea nu apar pe harta decat daca le stergi si le selectezi din nou. Dupa oprire/repornire navigatie - acelasi lucru, le arata selectate, insa nu apar pe harta!
A mai patit cineva, sau e normal sa se intample asa?
Eu m-am resemnat cu gandul ca nu am ce-i face si nici altcineva din acest topic nu are rezolvare(deoarece am postat despre aceasta problema in postul #597 acum 3 luni si nu am primit nici un raspuns pana acum) :( asa ca folosesc navi doar pentru a ajunge la destinatie si atat; fara afisare camere, POI
...Imi lipsesc POi-urile pe care mi le arata vechiul MFD 2DVD.
Acum cateva zile am instalat FW 4020 in speranta ca poate e ceva mai bine dar tot la fel se intampla, in plus am observat ca dureaza mai mult sa se incarce partea de navi decat inainte cu FW 3970.
Bafta! si daca gasesti vreo rezolvare fii te rog amabil si posteaza solutia gasita deoarece sunt sigur ca va mai ajuta si pe altii. :icon_cheesygrin:
POI-u rile trebuie activate din meniul navigatiei..... si vin automat cu v8 la harti....dar tot trebuie activate...
Trebuie activate de fiecare data, sau atunci cand faci un traseu, sau cum?
Tin minte ca la FW vechi si hartile vechi, setai o singura data ce sa-ti arate, si le arata fara sa ai vreun traseu.
De fiecare data cand porneai navi, apareau pe harta, fara sa le mai setezi.
Acum le setezi, apar alese in setup/harti/detalii, insa la fiecare repornire trebuie resetate (desi in meniu/setup apar ca sunt selectare, dar nu se vad pe harta).
Quote inutil
Am marea rugaminte, daca cineva are manualul in limba romana la calitate foarte buna, sa-l posteze scanat...
Poate exista un manual cu textele in limba engleza, nu in germana (textele din meniul navigatiei - fotografiile din manual).
Am tiparit cel existent pe forum, insa se vede foarte greu in multe locuri.
Modificat de Nutu2009
salutare , am cumparat si eu un passat b6 din 13.12.2008 anu fabricatiei si vanduta in 2009 , am pe el RNS510 din fabrica si nu pot intra in meniul secret nici daca tin 30sec pe setup , mi sa dat un cd/dvd cu Eu vest v3 , si vreau sa instalez hartile si pt Eu est , acuma downloadez CD7693 , nu stiu daca sunt bune , nu stiu nici FW care este , functioneaza totul perfect , comenzi vocale am doar cand conectez telefonu la el doar formare numar si apelare din agenda, ce FW ar trebui sa instalez sa imi accepte comenzi vocale si sa nu o busesc , card SD mai mare de 2GB nu vede si nici CDcu track-uri scrise pe calc nu vede , dvd cu film pornest scris pe pc, multumesc
meniul secret trebuie activat cu VCDS, iar ca FW poti pune si 4020 (ultimul - il gasesti daca dai un search pe google) sau mergi la reprezentanta si-ti fac ei update (insa o sa te coste)
Am o problema foarte ciudata. I-am dat unui prieten un RNS 510 (3T0... B) FW 3814 insa CAN-ul (1K0 907 530 L) nu-l vede/nu comunica.
Mai mult decat atat nu pot intra cu VCDS pe modulul 37 sau 56.
De la ce sa fie? Am sa incerc sa pun navigatia pe masina mea (am ultimul model de CAN) sa vedem ce se intampla.
Volkswagen RNS 510 Firmware Upgrade to version 4020 / 4024 / 4026 / 4028
<p class="post-bodycopy clearfix">
Version 4020/4024/4026/4028 firmware for the Volkswagen RNS 510 and the Skoda Columbus has been released.
  • Voice Control (requires microphone)
  • NEW Faster navigation and user interface
  • NEW Automatic illumination control
  • NEW Enhanced destination input
  • NEW hold down the setup button for 30 seconds and get the following menus: FM, AM and the new VERSION INFO (map version and type, hw and sw versions)
  • NEW Compass
  • NEW POI
  • NEW Languages – Arabic, Russian, Turkish and Polish
  • Speed Limit Display
  • Stability Improvements
  • Faster Startup (this has been improved on 2720)
  • Display OPS and RVC at the same time
  • SDHC 32 GB Support (HW04 and above)
  • Display Off on extras tab
  • Climatronic control if approriate climatronic fitted
  • Clock display if RNS 510 swtiched off
  • Excluded roads (under route options)
  • GPS coordinates entry
  • Additional adjustments for video
  • Larger RVC screen with transparent menus at the side
Units that can be upgraded include (still being compiled may not be 100%)
  • All D and later versions.
  • 1T0 035 680 C (1T0035680 C) from software version 1000, 800, 900, 1100 , 2660 and 2700 to version 3810.
  • 3T0 035 680 A (3T0035680A) to version 2704.
  • 7F0 035 680 (7F0035680) to version 2700.
  • 7E0 035 680 (7E0035680) to version 2700.
  • Revision B and C units can be upgraded however there may be issues (A units may be upgraded but not recommended).
  On 10.04.2012 at 16:20, Nutu2009 a scris:
am manualul in limba romana cu ultima actualizare in 2010 sau 2011 daca imi aduc bine aminte....insa nu am unde sa o scanez.
Uite manualul pentru navigatia Columbus (RNS 510 care echipeaza masinile Skoda). Este in limba engleza, dar si pozele sunt tot in engleza. Calitatea este mult mai buna...
Columbus.pdf
Foarte buna calitatea, daca ar exista unul si in limba romana ar fi perfect.
Banuiesc ca e 100% identic cu RNS 510 pt VW...cel putin pe partea de navi, media, radio...
Dupa instalarea fw 4020 si fix-ul lui Josi pt gatewayurile vechi, nu mai apar POI-urile pe harta...
A mai patit cineva asta, sau are vreo rezolvare?
Ai avut rabdare sa citesti posturile incepand macar din susul paginii curente? Exact problema asta se discuta! :rules:
cum ai instalat tu 4200+fix ??
fixul de la josi se aplica la maxim 2760.....
so???
Salutare,am si eu cateva probleme cu un rns510 columbus pe care l-am montat de curand..
1. pornesc navigatia adaug adresa imi calculeaza traseul si il indica pe harta insa nu primesc nici un fel de comanda vocala, iar daca ma abat de la traseu nu il reconfigureaza
2. nu se aprind luminiele de la butoane decat pentru cateva secunde la pornire si nu merge nici dimmerul... (asta cred ca este o problema din can ,al meu avand terminatia k)
Modificat de tece
Nu comunica cu CAN-ul. Poti intra in meniul secret al RNS-ului ca sa verifici asta
pentru cea de-a doua problema sunt de acord cu tine dar pt prima cea cu navigatia nu vad ce legatura sa aiba...
Aceeasi problema am patit-o cu I-Go, pe alta navigatie. Verifica sa nu fii planificat un traseu cu punctul initial altul decat locul in care te aflai.
La mine asta a fost rezolvarea.
  • Aerofan changed the title to RNS 510 - Columbus - Update FW si harti
  • Bebeee pinned şi locked this topic
  • Bebeee unlocked şi locked this topic
  • Bebeee a deschis acest topic
