RNS 510 - Columbus - Update FW si harti
florin.petre
9w2 bluetooth from Jetta, Golf, or Sportwagen (wagon) TDI
9w2 bluetooth lets you talk and receive but there is no phone book capability. You can still use voice control through your mobile phone to place outgoing calls, if equipped. It also has A2DP (bluetooth streaming music capability). An example of A2DP is wirelessly playing music directly from your iphone over the stereo. These were commonly found on 2010 and newer Golf and sport wagon (sportwagen).
When combined with the RNS 510 GPS it does not display the phonebook over the touchscreen display.
Some part numbers for the 2010+ (white MFD) are 1k8 035 730 c (1k8035730c) and 1k8 035 730 d (1k8035730d)
The bluetooth antenna is internal.
nu, nu afiseaza.... e numai pt voce
Imi puteti spune un nr de modul compatibil cu a2dp si sa afiseze agenda?!
Orice modul 9w7 / 9wz adica cele care incep cu 7P6 / 3C8.
sau 5K0 . dar toate astea afiseaza doar pe IC BAP respectiv pe unitate radio cu touch.
ok, pe a mea Columbus am firmware 2724, pot face update la ceva mi nou? Delivery part 3t0035680a
EDIT:sa incerc 4120?
Modificat de czsilviu
Ars acea imagine pe dvd si primesc eroare dupa appl update la 100% error 010302...
Si o ia de la capat de fiexare data, help...
Iar acum dupa ce am scos dvd.ul error apps library load failure
A swl error ocurred and now the maximum swl error count has been reached
Rezolvat, acolo eram si eu! Acum caut hartile..8040 nu reuseste sa le instaleze pe hdd! Multumesc!
Am facut o prostie mare...am luat de pe un site un link postat de josi (1200_gw_all), am facut downgrade din cauza can-ului, l-a terminat cu suces, s-a restartat, dar nu mai porneste display-ul, touch-ul merge. Este functional tot, mai putin display-ul. Poate fi de la soft sau hardware?
Am incercat toate reseturile, scos siguranta, swl fix dar din pacate nu vad ce sa apas.
HELP ME PLEASE!!!
Detalii:
Wednesday,19,December,2012,11:33:49:37412
VCDS Version: Release 11.11.0
                Address 37: Navigation
Control Module Part Number: 1T0 035 680 D
  Component and/or Version: RNS-MID       H71 4120
           Software Coding: 00000400000000200000
            Work Shop Code: WSC 12345
                      VCID: 2F6762187E06536
Advanced Identification
     Serial number: VWZ6Z7N5227101
     Identification: VD1----
     Revision: AB001001
     Date: 15.08.13
     Manufacturer number: 0004
     Test stand number: 1767
Flash Status
Misc.
     Hardware number: 1T0 035 680 C
     Workshop System Name: J0506
     Equipment/PR Code: 0000000000000000
     ASAM Dataset: -------------------------
     ASAM Dataset Revision: ------
VCDS Info:
       Labels: 1T0-035-680.clb
       ROD: ERROR - ------------------------- ------ ()
Modificat de KLAU
da, a rezolvat-o cu upgrade parca.... si upgrade la can gateway.
De cateva zile intampin probleme cu navigatia la un RNS 510 pe un Passat CC. A fost schimbat in 2012 la reprezentanta in Germania
SW: 2840
HW: H61
Versiune RNS 510 : 1T0 035 680 C
Ma localizeaza pe camp de 4 zile, se misca sageata.
Ieri dimineata ma localiza in Germania (gen sindrom regensburg), doar ca singromul acela isi revine dupa cateva minute de la pornire si la mine nu si-a revenit. Doar pe seara a mers pentru 30 min si apoi...pa
Azi dimineata ma localizat in Romania, dar la 2 KM distanta de locatia mea si nu si-a revenit.
Am incercat resetare din butoane, revenire la setari din fabrica, l-am scos si l-am remontat....nimik :(
Vre-un sfat ce sa ii fac?
Modificat de tigrulus
Este posibil sa fie iesita antena din unitate, sau undeva pe traseu intre unitate si antena, sau poate chiar intrerupt cablul pe undeva.
L-am demontat si nu era iesita antenna din unitate.
Acum nu stiu sa refac traseul sa verific.
Aripioara de rechin este pe plafon. Primul lucru a fost sa verific ca nu mi-a disparut.
Am avut aceiasi problema ca si tine cu aceleasi simptome, initial am verificat la iesire din unitate si era ok, mai tarziu am demontat capitonajul plafonului si era iesit de acolo, nu stiu daca tot acolo este si la tine problema dar incearca mai intai cu orice antena de proba, daca merge cu cea de proba atunci undeva pe traseu este problema, daca tot nu merge inseamna ca din unitate se trage.
Recunosc ca am un traseu plin de gropi si m-am gandit ca e posibil asta sa fie cauza.
Imi poti spune cum sa demontez capitonajul?
Nu vad de unde sa incep, adica vreo parte demontabila.
Eu am aceasta unitate pe un golf 5 respectiv pe un golf 6 dar ma gandesc ca si la tine poate fi la fel.
Am deschis hayonul, are o mica bucata de completare de care pur si simplu am tras in jos (este prinsa in cleme), am tras de plafon cu grija in jos si am lucrat in spatiul oferit de 10-15 cm al despartiturii fara sa stric plafonul care este destul de sensibil, si fara sa ma apuc sa desfac manerele de pe plafon sau alte nebunii ca sa l desprind complet.
Buna ziua,
Sunt un membru nou, am citit in mare topicul si as avea nevoie de un sfat.
Am achizitionat recent un passat cu navigatie rns 510, mentionez ca navigatia nu a fost a masinii ci pusa mai tarziu, banuiesc ce e sh.
In meniul secret aparea : Delivery part nr.  1T0 035 680 A
                                                           HW:  H 04
                                              SW Version:  0520 iar pe aparat apare SW 1000
                                        SV SW-Version:  C_EU_5.130_t310
Am incercat un update la firmware la versiunea 4020a si am constatat ca nu mai merge ecranul tactil si nu se mai opreste din buton si dupa pornirea masinii nu mai are sonor, trebuie sa scot mufa din spate si sa o bag la loc ca sa am sunet. Ce ma Sfatuiti, sau cui sa ma adresez pentru remediere? Va multumesc.
Pai nu ai procedat corect cu upgrade-ul .
Nu faci asa direct de la SW 1000 la SW 4020 .
Fa downgrade la un soft cu 2XXX dupa care lasia sa mearga un timp O LUNA sau DOUA si faci iar upgrade la unul cu 3XXX (ai grija sa cauti numai soft modificat de JOSI de pe GPS UNDERGROUND sau MY GTI si sa fie unul care face si repartitionarea HDD-ului) .
E cam vechi RNS-ul ca sa pui soft-uri asa de noi dar poti incerca .
Revin cu aceeasi problema.
Am incercat fw 1020 , dar a aparut eroare 202.
Am folosit apoi SWL - Fix. si acelasi lucru, nu se inchide, nu merge ecranul tactil etc.
Am incercat si 1200_GW-all si acesta nici nu fuctioneaza. Ce sa mai fac?
Astazi am facut update de FIrmeware la 3810.
A durtat o ora.
Dupa update , in cam 5 minute m-a localizat , dar exista un decalaj de cativa zeci de metri intre locatia mea si ce arata navigatia.
Decat deloc, merge si asa.
La starea antenei, in alea 5 minute aparea deconectat, apoi conectat.
Nu fac update la verisune mai noua de 3810 ca am vazut ca au probleme pe varianta mea de RNS 510.
In rest, totul functioneaza ok.
Salutare ! In urma problemei avute cu bcm-ul , respectiv byte 19, data peste cap alimentarea, transmitea semnal intrerupt si palpaiau toate becurile de la interiorul/exteriorul masinii ! Am trecut pana la urma la un Bcm 087R din 2011. Problema care o intimpin acum la Rns> mi-a ramas blocat in germana, iar inafara de navigatie si afisaj climatronic/park nu mai merge nimic, nici sunet, nici radio. Am inteles ca ar trebui sa-i fac un upgrade la rns respectiv la Can ?! Ceva pareri .
RNS : 1T0 035 680 F HW: H61 SW : 3970.
Salut! Codul de securitate unde este trecut? N-am probleme, dar daca voi avea, sa il am.
  • Aerofan changed the title to RNS 510 - Columbus - Update FW si harti
  • Bebeee pinned şi locked this topic
  • Bebeee unlocked şi locked this topic
  • Bebeee a deschis acest topic
