Martori luminosi aprinsi
cipi2ooo
  • Replies 243
  • Cristian
    29
  • liviu85
    27
  • iulians
    12
  • adilabv
    11
Aici poti afla cine are VAGCOM in Pitesti.
si incearca sa iti completezi profilul.
sa ne spui si ce a avut.
Cam asa a sunat mesajul de eroare:
Control Module Part Number: 036 906 034 GM
Component and/or Version: MARELLI 4MV 5159
Software Coding: 0000071
Work Shop Code: WSC 06441
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 000 - - - Intermittent
Faza ciudata este ca procesul s-a repetat sambata dupa amiaza. Sambata seara totul era curat la bord.
M-am tot holbat eu pe acolo dar nu pare a fi nimik in neregula (dpdv al unui neprofesionist).
Asa ca nu vad alta solutie decat mersul la un service specializat.
Daca te ajuta cu ceva.... :rolleyes:
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
Evaporative Emission (EVAP) Canister Sealing faulty
Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
Perform Output Test
Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
Perform Basic Setting
Check Pipes between Tank Breathing and Throttle Body
Am gasit ceva pe net de Audi.
Sper sa fie la fel si la VW si Seat.
1-EVAP canister
2-From fuel tank
3-Evaporative Emission (EVAP) canister purge regulator valve -N80-
4-Check-valve for EVAP canister
5-Air cleaner
6-Turbocharger
7-Combination valve for secondary air injection (AIR)
8-Fuel pressure regulator
9-To power brake booster
10-Check valve
11-Vacuum booster
12-To Leak Detection Pump (LDP)
13-Vacuum reservoir
14-Distributor piece
15-Check valve
16-Secondary Air Injection (AIR) solenoid valve -N112-
17-Crankcase vent
18-Check valve
19-To tank Leak Detection Pump (LDP) -V144-
20-Check valve
21-Charge air cooler
22-Throttle valve control module -J338-
23-Recirculating valve for turbocharger -N249-
24-Intake manifold
25-Pressure unit for boost pressure regulation
26-Wastegate bypass regulator valve -N75-
27-Mechanical recirculation valve
28-Pressure control valve for crankcase ventilation
29-Secondary Air Injection (AIR) pump motor -V101
Apropo de martorul luminos de la motor, poate m
Ce parere aveti de benzina Efix de la Rompetrol? merita banii?
Sa va spun si ce a avut.
Am citit erorile dupa fiecare aprindere a marorului luminos (de doua ori).
Prima data a fost eroarea aceea de EVAP mentionata mai sus in topic +
17851 - Potentiometer for EGR (G212): Signal too Low
P1443 - 000 - - - Intermittent
17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
P1156 - 000 - - - Intermittent
si a doua ora a fost eroarea:
17961-barometric/manifold pressure signals: impausible correlation
p1553-35-10--- intermittent
Rezolvare (asa sustine mecanicul):
S-a uitat pe acolo pe la motor si mi-a spus ca este din cauza benzinei si sa incerc sa folosesc un aditiv.
Personal nu prea cred.
Voi ce parere aveti!?
Iulian
Iulian
[/quote
Am patit la fel (Cordoba 1,4 benzina). Este colmatat un recuperator de gaze (care ar fi trbuit curatat la revizie). Am fost la multe service-uri VAG, care mi-au spus si mie textul cu benzina.Am rezolvat la Metrotehnica din soseaua Giurgiului (persoana de contact Dl Gigel Carlig). Bafta!
@Dibaciu2007: Merci de raspuns. M-am mai linistit putin. Eu nu sunt din Bucuresti, nu ca ar fi prea departe de mine, dar pb este ca masina nu mai este in garantie si reviziile le fac pe la service-urile din Pitesti. Si am fost la doua dintre ele si nici unul nu s-a legat de asa ceva. Imi poti spune de ce furtun este vorba?
Dar pt mine nedumerirea cea mare ramane de ce s-a aprins EPC-ul si ce legatura ara asta cu benzina si alte furtune colamatate!?
Multam
Iulian
Pentru prima eroare, sunt de acord cu "rezolvarea" - te referi la valva EGR :( - dar, ma indoiesc ca ai avut toate cele trei erori si s-au rezolvat doar prin curatarea valvei respective. :Driver:
Oricum, sfatul meu prietenesc ar fi sa isi cumpere o interfata VAG com, ca pana scapa de erorile alea o sa mai aiba bataie de cap si il va costa prea mult altfel..
Mda. Si eu cred ca erorile nu au venit doar de acolo. Si cred ca a fost facuta o chestie de mantuiala la acel service.
Cat despre curatirea valvei, nici macar nu s-au atins de ea. Au curatit doar un contat electric pe la ea.
Singurul lucru care am putut sa-l fac dupa a fost sa schimb benzina cu ceva mai de 'top' si am bagat un aditiv.
Sa vad cum se va comporta masina in continuare in concediul ce va urma.
@I_am_Stealth: Ai perfecta dreptate. Asta intentionez sa fac si eu. Am vb cu un amic care lucreaza in proiectare electronica, sa-mi fac o interfata VAG. Sper sa si iasa. ;)
Va multumesc de sfaturi!
"Cat despre curatirea valvei, nici macar nu s-au atins de ea. Au curatit doar un contat electric pe la ea".
Au procedat corect; citeste cu atentie "explicatia" codului de eroare. Valva EGR are un potentiometru (incorporat) prin care informeaza ECU despre starea/pozitia ei. Defectul avand caracter intermitent, este posibil sa fie o problema de contact imperfect (desigur, nu sunt excluse si alte defecte ale potentiometrului,s.a.).
Pentru celelalte 2 erori, ai putea sa incepi cu verificarea MAP-ului (adica, acel senzor similar cu MAF/debitmetru, care masoara "cantitatea" de aer din admisie). Verifica contactele sau, inlocuieste senzorul. Benzina nu este vinovata pentru aceste erori! ;)
PS: ai putea sa descrii si comportamentul motorului?
Salutare!
Inainte sa plec in CO, am facut si eu ce a facut nea' mecanicul. Adica am luat putin gaz si pe unde am vazut contacte electrice, am scos mufele si le-am curatit.
Am facut in total 1800KM si totul este ok pana acum.
Cat despre comportamentul motrului pot spune ca este ok. Mai ales dupa ce am alimentat numai cu 99+
Dupa parerea mea, ruleaza f frumos si la 170km/h dar si la 20km/h.
@xxnelu: ma tot starduiesc sa gasesc un manual de service sa imi dau seama pe unde sunt partile compunente sa-mi fie mai usor sa le gasesc. Sper sa gasesc acel MAP. Multam!
O zi buna!
Modificat de iulians
Salutare.
Incepe sa se repete istoria.
De adata aceasta cu:
17550 - Load Calculation Cross Check: Lower Limit Exceeded
P1142 - 35-10 - - - Intermittent
Readiness: 0000 0000
Astept sfaturi.
si eu la vechea ibiza am avut o problema asemanatoare adica cand statea epcul si cel de diagnoza fie doar cel de diagnoza am fost cu ea la secrice si miau schimbat un switch de la frana care cica avea o eroare doar in rest fuctiona si + am schimbat benzina bagam numai omv 100 si atunci in perioada cu buba am alimentat de la mol parca 98 la revenirea la omv100 nu am mai avut nici o problema si sper sa nu ii mai apara nici celui care a cumparato si nici la cea noua care nu are decat 100KM :rolleyes:
Modificat de victor_wts
Am facut teste si super teste cu benzina de toate felurile + aditivii lui cuc.
Asta imi apare, din cate am observet eu, numai atunci cand masina este in treapta 1-a de viteza sau marsarrier si este mai putin turata si am ambreiajul apasat. Niciodata cand este in treapta superioara de viteza nu imi apra asa ceva.
Am trecut pe la un service si mi-a spus ca am probleme cu injectoarele, ca trebuie curatite si sa ma prezint cu 200lei sa le curete ei cu nu stiu ce solutie.
Dar nu am deloc incedere. Asa sa fie oare?
Salutare la toti!
Am cautat pe forum dar din pacate nu am gasit decat topic-uri cu aprindere martor ABS (fara martorul de frana, in acelasi timp)... asa ca am decis sa va intreb...
Ieri seara cand am ajuns de la lucru, am intors masina s-o parchez in fata blocului. In timpul manevrei mi s-au aprins concomitent martorii de ABS si martorul cel rosu de frana (nu eram in vreo panta sau orice ce sa afecteze nivelul lichidului). Cel de ABS a ramas aprins si cel de frana a inceput sa clipeasca (... nu mai stiu sigur exact care clipea si care era aprins din pacate). Am oprit motorul si l-am pornit din nou. Nu a mai ramas aprins nimic, adica si-au facut testele si s-au stins. Intrebarea este acum: care poate fi cauza ca din ce am mai vazut pe forum f putine sunt cazurile cand se aprinde un martor si nu e nici o problema? As vrea sa stiu la ce sa ma astept ... de lichid de frana nu e vb ca l-am verificat imediat ce am parcat masina ...
P.S. Ca o curiozitate: e un cablu negru sub scaunul soferului care intra in podeaua masinii si e bagat in nu stiu ce mufa de sub scaun ... stie cineva ce rol are cablul ala?
Da, ala e cablul de la airbagul lateral. Fa o scanare cu Vag-Com, sa vezi ce erori au ramas stocate.
FIX acelasi scenariu am patiti azi dimineata, in momentul in care incercand sa caut un loc de parcare am mers cam 50m in marsarier si cu viteza mica. La fel, martorii s-au comportat normal dupa ce am oprit si repornit motorul.
Tu ai ceva noutati in problema asta? Eu nu stiu cat de repede pot sa ajung sa fac o scanare.
Adrian
