Cheie Passat B6
Alex Deliu
Procedura e in manual, iar pentru Burady , desfa carcasa cheii,si scrie in interior ce frecventa ai. Bafta.
  Burady a scris:
cod 3C0 959 752 AP cu frecv 315MHz
sau
cod 3C0 959 752 AL cu frecv 434MHz
Bun, atunci eu vin cu o intrebare simpla (de tip Bula)
Daca iau o cheie cu o frecventa mai mare decat celelalte 2 care le am, ce se intampla ?! :icon_thumright:
O iei degeaba ca nu o sa mearga pe masina ta.
  teo0605 a scris:
Multumesc, incerasem deja aceasta procedura dar din cauza unei probleme la incuietoarea usii soferului nu pot sa deschid cu cheia mecanica. Ma gandeam ca poate exista o alta varianta, eventual o interventie prin VAG-COM pt reinitializarea si sincronizarea cheilor (daca spun o prostie nu o luati in seama, sunt afon in acest domeniu), dar care sa nu implice o deplasare la dealerul VW.
Uite ceva cum se face din VAG poate te ajuta.
Invatare cheie noua
Select]
[17 - Instruments]
[Login - 11]
[use 7-digit PIN/SKC]
Enter the 7-digit PIN, Date on which the PIN was generated by the dealer, along with the Workshop Code (WSC) and the Importer number of the dealer that generated the code.
[OK]
VAG-COM will validate the data you have entered and return you to the Login screen, where the Login Code will show as "XXXXX".
[Do It!]
[Adaptation - 10]
Enter 21 in "Channel Number"
[Read]
The "Stored Value" is the number of keys currently matched.
Enter "new value" of 0
[save]
This clears out the old key-matchings.
Enter a "new value" corresponding to the total number of keys to be matched, including any existing keys
[save]
[Done, Go Back]
[Close Controller, Go Back - 06]
Switch ignition off and remove key
Insert next key to ignition and switch ignition on again. The warning light for the Immobilizer will light up for ~2 seconds, then go out. Switch ignition off and remove key
Repeat step 16 with each key until all keys have been matched
completare:
adaptarea se mai poate face pe 25 sau 05.
la unele modele B6 [depinde de echipare] - vag-com are probleme .
atunci , ramane sa mergi la reprezentanta !
Ma ajuta cineva cu o descriere a procedurii de desfacere a carcasei cheii?
Citind aici pe forum nu am gasit inca clarificari referitoare la acest lucru.
Modificat de Burady
sunt nou pe forum si nu stiu daca s-a mai discutat, cel putin pe aici nu am gasit si nici nu stiu cum se face.
Am doua chei "mari" si doar una "mica" ( este asta o problema ? )....cu a doua cheie ( cu cea mica introdusa sau fara, este acelasi lucru )cand o introduc in contact, apare in bord acel "volan" de culoare galbena, pe semne ca o recunoaste ( corect ? ), dar cand incerc sa pornesc nu face nimic, imi apare in bord "Immobilizer active"....ce inseamna asta ? ce s-a intamplat cu cheia respectiva ? cum se poate remedia ?
va rog sa ma ajutati cu detalii sa o pot remedia.
multumesc anticipat,
cheia respectiva nu mai este recunoscuta de computer daca nu ma insel. trebuie recodat computerul sa o recunoasca.
Modificat de Seby19
Incearca sa deschizi masina cu cheia mecanica, adica usa de la sofer si dupa aia vezi daca porneste cu cheia care zici ca e defecta. Daca porneste ,opresti motorul te dai jos si incui tot cu acea cheie din telecomanda. Dupa care descui tot din tlecomanda si pornesti tot cu ea. Daca a mers, asta e tot.
cand voi ajunge acasa voi incerca aceasta varianta....in cazul in care nu merge, care mai poate fi problema ? rezolvarea ?
Modificat de D@ny
  On 03.02.2011 at 5:59, teo0605 a scris:
am incercat si varianta aceasta....nu merge, se pare ca am primit a2-a cheie care nu este a masinii :( .
cum o pot ( daca se poate ) sincroniza cu cea buna ? nu vreau sa o am doar ca "bibelou", plus ca nu am nici cheita mica in caz de urgenta.
va rog sfaturi.....
@cridaia: ai incercat sa urmezi sfatu' colegului Seby19 ?
  On 02.02.2011 at 17:24, Seby19 a scris:
(...) trebuie recodat computerul sa o recunoasca.
Adica sa re-inveti cheiile cu masina cu ajutorul VCDS-ului ?! :icon_thumright:
si imi puteti spune mai exact cum se face asta ? am cu ce sa fac, numai ca nu stiu "pasii exacti" cum se face. :huh:
am sunat la unul din Service-uri la Timisoara si preturile sunt urmatoarele:
cheita noua - 187 lei
telecomanda reinvatata - 130 lei
telecomanda noua - 525 lei
  On 06.02.2009 at 17:03, criv a scris:
  victor blackedition a scris:
[criv - incearca sa sincronizezi cheia astfel: scoti capacelul de la clanta usii soferului, deschizi geamul de la sofer. Te urci in masina. Apesi pe butonul deschis de la telecomanda (cheia electronica). Scoti din telecomanda cheia mecanica si cu mana scoasa pe geam incui masina mecanic, introducand cheia in broasca. Pe urma pui la locul ei cheia mecanica (in interiorul telecomenzii). Introduci cheia ca si cum ai dori sa pornesti masina si o lasi acolo pana se sting martorii de la bord. Cu cheia electronica nemiscata, apesi pe lateralul telecomenzii si scoti din ea cheia mecanica... Gata! Cheia este sincronizata.
aceasta operatie nu se poate aplica la mine pentru ca nu am cheita cu care se poate deschide mecanic. Imi ramane doar varianta de reprogramare cu VCDS-ul, dar ajutatima cum se face.
Salut. Sunt nou pe acest forum, deoarece doar de curand mi-am achizitionat un Passat B6. L-am cumparat SH si am primit doar o cheie cu telecomanda si o alta cheie simpla. Mentionez ca cea simpla nu e de plastic precum cea ce se introduce in telecomanda. Intrebarea mea este: pot face o alta cheie cu telecomanda?
Modificat de D@ny
nicolae.adryan
portbagajul nu se inchide, daca uiti cheia acolo .probabil stie asta . nici porbagajul nu il poti descuia manual daca masina este inchisa de la telecomanda.am incercat si eu sa inchid si sa deschid cu cheia de urgenta de inchis vrea :) de deschis nici vorba.mai incerc maine :)
  On 31.03.2011 at 14:21, briciu19 a scris:
La reprezentanță, pe baza actelor doveditoare că ești proprietarul autovehiculului se poate face o altă cheie.
  On 10.04.2011 at 10:57, nicolae.adryan a scris:
Vezi că ai sistem Kessy, de asta nu se
nicolae.adryan
am incercat de cateva ori dar nici vorba sa pot deschide usa de la sofer cu cheia de urgenta se inchide dar nu se deschideo sa incerc sa vad daca pot unge ceva pe acolo un spray sa dau mi-e frica sa nu o rup daca o fortez :(
Florin Mandras
Poti sa iti faci o noua cheie fara nicio problema. Pe langa actele doveditoare sa iti mai pregatesti si vreo 800 lei minim :icon_thumright: ... eu am schimbat cheia de curnad si cam atat m-a costat (cheita mecanica + telecomanda + soncronizare cu masina).
Bafta
Da, stiu ca se poate face alta cheie la reprezentanta Ottoflo, idea era daca o pot face cumparand eu carcasa(telecomanda), cheiata de plastic modelata ulterior dupa cea pe care o posed si setata cu vag com? Ma gandeam ca poate a incercat cineva si asa. Multumesc oricum.
nicolae.adryan
dupa ce am dat cu umpik de spray pe la yale am reusit in sfarsit sa deschid si sa inchid cu cheia de urgenta.la mine toate 4 usile se pot deschide cu cheita manual :icon_thumright:
referitor la cheie daca tot am invatat cum se deschide sa pui alta baterie ,am luat amandoua cheile cu mine si am mers la un prieten bun ceasornicar care mi-a zis ca are baterie pentru ele.ok .am mers la el,cu bateriile montate,si-a luat binoclu ala lung pe ochii,si interesant ce a facut fata de ce am vazut eu pe aici pe forum si pe you tube a scos capacul a introdus un mic obiect ascutit inauntru dar nu a fortat sa ridice capacul si a introdus lateral obiectul acela si miscat umpik si sa desfacut .ce a urmat este mai interesant.a luat amndoua bateriile le-a pus pe aparatul lui de masura ,si imi zice ca nici bateriile lui noi nu sunt mai incarcate ca si ale mele:))poi zik tipul care mia dat masina nu lea schimbat niciodata in 4 ani mai a stat la mine 1 an jumate .. raman perplex..:)))) acum intreb si rog daca stie cineva oare se incarca se regenereaza bateriile din cheie in timpul mersului ?ca oricum este mult prea mult sa tina si sa mai si fie exact ca noua o baterie dupa 6 ani.... :icon_thumright:
Am intalnit urmatoarea problema la Passat B6: functia Confort functioneaza NUMAI pe una din telecomenzi. Mai pe larg spus, o telecomanda poate inchide/deschide geamurile si trapa cand se tin apasate butoanele, cealalta nu poate face operatiunea. Mentionez ca ambele telecomenzi au baterii absolut noi GP (garantate pana in 2020) iar, inchiderea centralizata a masinii functioneaza OK pe ambele chei. Care poate fi problema?
Fiecare cheie are propria ei memorie. Cu alte cuvinte cand folosesti cheia 1 stie tot ce enumeri tu acoolo, pe cand cheia 2 are cu totu alte setari(pana si limba in care e afisat BC, unde e cazul)Asa am patit si eu cu masina cand am venit cu ea in tara. Toate bune si frumoase pana am bagat cheia de rezerva si displayul era in limba germana, plus alte setari cum sa se inchida usile, etc...m-am si speriat. Rezolvarea este: baga cheia care nu stie mare lucru si refa setarile in BC identic cu ce ai pe prima.
Modificat de Caal-Shto
unde gasesc si eu sa cumpar o cheie passat b6?
