Active Brake Differential pe LT35
lucky900
ce inseamna ABD la un lt 35?????? ce face exact? doresc sa stiu mai multe....ms
Active Brake Differential - este denumirea Porsche data echipamentului care piloteaza electronic diferentialul.
What is claimed is:
1. A method of operation for an active brake control on a vehicle having first and second driven wheels on first and second sides of the vehicle that are braked by the active brake control independent of driver braking effort during a detected condition of lateral instability, and first and second un-driven wheels on the first and second sides of the vehicle that are braked in proportion to driver braking effort during the condition of lateral instability, the method comprising the steps of:
determining a desired differential wheel speed for improving lateral stability of the vehicle by braking the driven wheels such that a selected one of such wheels is driven slower than the other of such wheels;
measuring the speeds of the first and second un-driven wheels;
determining a target speed for the first driven wheel based on the measured speed of the first un-driven wheel during driver braking of the vehicle;
determining a target speed for the second driven wheel based on the measured speed of the second un-driven wheel during driver braking of the vehicle;
reducing the target speed of the selected driven wheel by the desired differential wheel speed; and
braking the first driven wheel to regulate a speed of such wheel at its target speed, and braking the second driven wheel to regulate a speed of such wheel at its target speed, thereby to improve the lateral stability of the vehicle while maintaining brake effort proportioning between said driven wheels and said un-driven wheels.
2. The method of operation of claim 1, including the step of:
detecting a condition of driver braking of the vehicle by using the measured speeds of the un-driven wheels to determine a deceleration value, and comparing the deceleration value to a threshold deceleration.
3. A method of operation for an active brake control on a vehicle having left and right driven wheels on left and right sides of the vehicle that are braked by the active brake control independent of driver braking effort during a detected condition of lateral instability, and left and right un-driven wheels on the left and right sides of the vehicle that are braked in proportion to driver braking effort during the condition of lateral instability, the method comprising the steps of:
determining a desired differential wheel speed for improving lateral stability of the vehicle by differentially braking the driven wheels to produce a desired clockwise or counter-clockwise yaw moment;
measuring the speeds of the left and right un-driven wheels;
determining a left target speed for the left driven wheel during driver braking of the vehicle based on the measured speed of the left un-driven wheel, less the desired differential wheel speed if a counter-clockwise yaw moment is desired;
determining a right target speed for the right driven wheel during driver braking of the vehicle based on the measured speed of the right un-driven wheel, less the desired differential wheel speed if a clockwise yaw moment is desired; and
braking the left driven wheel to regulate its speed at the left target speed, and braking the right driven wheel to regulate its speed at the right target speed, thereby to improve the lateral stability of the vehicle while maintaining brake effort proportioning between said driven wheels and said un-driven wheels.
4. The method of operation of claim 3, including the step of:
5. A method of operation for an active brake control on a vehicle having first and second driven wheels on first and second sides of the vehicle that are braked by the active brake control independent of driver braking effort during a detected condition of lateral instability, and first and second un-driven wheels on the first and second sides of the vehicle that are braked in proportion to driver braking effort during the condition of lateral instability, the method comprising the steps of:
determining a desired differential wheel speed for improving lateral stability of the vehicle by braking the driven wheels such that a selected one of such driven wheels is driven slower than the other of such wheels;
determining if driver braking is present;
if driver braking is not present, determining a first target speed for the selected one of the driven wheels based on the speed of the other of the driven wheels, and braking the selected driven wheel to regulate its speed at said first target speed;
if driver braking is present, determining a second target speed for the selected one of the driven wheels based on a speed of the un-driven wheel on the same side of the vehicle as the selected driven wheel, less the desired differential wheel speed, determining a third target speed for the other of the driven wheels based on a speed of the un-driven wheel on the same side of the vehicle as such other driven wheel, and braking the selected and other driven wheels to regulate their speeds at the second and third target speeds, respectively, thereby to improve the lateral stability of the vehicle while maintaining brake effort proportioning between said driven wheels and said un-driven wheels.
6. The method of operation of claim 5, wherein the step of determining if driver braking is present comprises:
measuring the speeds of the un-driven wheels to determine a deceleration value;
comparing the determined deceleration value to a threshold deceleration; and
determining that driver braking is present if the determined deceleration value exceeds the threshold deceleration.
7. A method of operation for an active brake control on a vehicle having first and second driven wheels on first and second sides of the vehicle that are braked by the active brake control independent of driver braking effort during a detected condition of lateral instability, and first and second un-driven wheels on the first and second sides of the vehicle that are braked in proportion to driver braking effort during the condition of lateral instability, the method comprising the steps of:
determining a target speed for the first driven wheel based on the measured speed of the first un-driven wheel;
determining a target speed for the second driven wheel based on the measured speed of the second un-driven wheel;
controlling the first driven wheel to regulate a speed of such wheel at its target speed, and controlling the second driven wheel to regulate a speed of such wheel at its target speed, thereby to improve the lateral stability of the vehicle.
  • 4 years later...
Buna. Sunt nou pe acest forum, dat fiind faptul ca nu pot incepe un topic nou am sa imi incerc norucul in cadrul acestui topic, poate ma ajuta cineva.
Am un T5 din 2004, motor 1,9 TDI. Problema este in legatura cu martoru de Airbag care s-a aprin de o zi. Mentionez ca pana acuma nu a avut probleme in legatura cu airbag-ul, dar de ieri sta aprin martorul de airbag. Testerul spune ca ar fi declansatoarele acelea din bara(3 la numar mai exact), dar e ciudat ca pana acuma nu a a dat aceasta eroare, si nici nu era aprin martorul.
Daca cineva a mai patit aceasta treaba, va rog frumos sa ma ajutati si pe mine cu un sfat, unde anume sa caut o solutie la rezolvarea problemei.
Inca odata imi cer scuze, daca am postat gresit.
Va multumesc frumos, si astept un raspuns cat mai repede posibil.
