Probleme cutie tiptronic
Horikka
Ieri toate bune a mers unsa bordu tot dar azi dimineața problema e ca nu mai imi indica motorina si apa ce poate fi are vrun releu vro siguranța m-a poate ajuta cineva ..?????
Sau poate fi de la ABS ca nu e codat corespunzător ???? Da totuși ieri am facut 600 km si nimic fără probleme.
F l o r i n
fa o scanare sa vad erorile stocate. Ma intereseaza pe Engine si pe ABS. Scaneaza si 17-Instruments
Ok diseara fac si le trimit idea e ca ABS nu am reușit sal codez
Dacă e ceva te pot suna pa nr de la profil ?????? Tiam dat sms duminica
F l o r i n
da, ma poti suna
Monday,04,May,2015,21:09:25:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Mileage: 250630km-155734mi Repair Order:
Chassis Type: 3B - VW Passat B5 (1997 > 2005)
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 250630km/155734miles
Address 01: Engine Labels: 038-906-019-AJM.lbl
Part No: 038 906 019 AJ
Component: 1,9l R4 EDC 0200SG 1305
Coding: 00002
Shop #: WSC 13469
VCID: 5FCD45F7DDC847E6CD9-4A9C
18057 - Powertrain Data Bus
P1649 - 35-00 - Missing Message from ABS Controller
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 D
Component: ABS/ESP front D46
Coding: 00000
Shop #: WSC 00000
VCID: 3467FA5B04CEB4BE40B-5000
3 Faults Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
01044 - Control Module Incorrectly Coded
35-00 - -
00778 - Steering Angle Sensor (G85)
66-10 - Not Matched - Intermittent
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 D
Component: CLIMATRONIC D2.3
Coding: 05000
Shop #: WSC 00028
VCID: 224B0C03AE3A2A0EA27-5072
00792 - A/C Pressure Switch (F129)
35-10 - - - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 B
Component: 05 AIRBAG VW5 0004
Coding: 12341
Shop #: WSC 00028
VCID: 3663C05312B2A6AE7EF-4A3A
No fault code found.
Address 17: Instruments Labels: 3B0-920-xx2-17.lbl
Part No: 3B0 920 842 A
Component: B5-KOMBIINSTR. VDO V25
Coding: 21145
Shop #: WSC 00006
VCID: 1F4D05F79D4807E68D9-5000
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0Y2590972
IMMO-IDENTNR: VWZ7Z0Y2590972
2 Faults Found:
00771 - Fuel Level Sensor (G)
30-00 - Open or Short to Plus
01315 - Transmission Control Module
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00005
Shop #: WSC 00125
VCID: F0EFB64BB056489EE43-5072
2 Faults Found:
35-00 - -
Address 37: Navigation Labels: 3B0-919-887.lbl
Part No: 3B0 919 887 D
Component: Navigation BNO 0201
VCID: 3365F94701C0B386591-4A3A
00481 - Control Module for Traffic Radio (J559)
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 Q
Component: 38 Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 00028
VCID: 4C9782BB7C3ECC7E38B-4A3A
Subsystem 1 - Part No: 1J1959801D
Component: 38 Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802E
Component: 38 Tõrsteuerger. BF0002B
Subsystem 3 - Part No: 1J4959811D
Component: 38 Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812D
Component: 38 Tõrsteuerger. HR0002r
00912 - Window Regulator Switch; Front Left (E40)
Address 56: Radio Labels: 3B0-035-186.lbl
Part No: 3B0 035 186 D
Component: Radio BNO 0201
Coding: 04024
Shop #: WSC 00000
VCID: 204F060BA036381EB43-4A3A
End ---------------------------------------------------------------------
F l o r i n
din pacate nu ai reusit sa faci codarea la pompa ABS.
Da stiu m-a poti ajuta cu codurile necesare codarii ..... Cât despre instrumente ce zici
F l o r i n
intai le desfaci, dupa care vezi daca ai ars ceva pe placa de baza sau nu.... in functie de asta pot zice ceva.
aici ai toata documentatia necesara, sa finalizezi codarea pompei ABS - vezi la capitolul Brake Electronics
http://wiki.ross-tech.com/wiki/index.php/VW_Passat_(3B)
  • 5 weeks later...
 Salutare tuturor in urma cu 6 luni am schimbat uleiul la cutie automata tiptronic . In prezent am 5000 km si am constatat cu stupoare ca uleiul este maroniu dar parca nu miroase a ars . Cei drept am folosit dextron 3 pt ca a fost recomandat dupa seria de sasiu dar dupa codul de cutie trebuia folosit un ulei original audi gresala am descoperito la o saptamana dupa schimbul de ulei si nu mai aveam nici bani si nici timp iar daca masina a functionat si inca functioneaza nu mi am mai batut capul .  Intrebarea ar fi :      Este normal ca uleiul sa arate atat de rau ?
A mai schimbat cineva in ultimul timp uleiul din cutia tiptronic?
Au trecut deja 7 ani de la ultimul schimb (80.000 km) si m-as gandi sa-l schimb si eu din nou si as prefera sa merg la cineva recomandat.
Probleme nu am deloc, doar o singura chestiune. Cand bag in R si iau piciorul de pe frana si instant apas pe acceleratie parca are o poticneala asa de 1,2 secunde (un fel de hâc), apoi accelereaza normal.
Daca iau piciorul de pe frana o las 1-2 secunde fara acceleratie si apoi accelerez nu mai manifesta aceasta problema si accelereaza repede si normal. Daca o las sa mearga linistita in R nu imi face probleme.
Nu imi dau seama daca ar fi de la cutie sau altceva (gen turbo, MAF etc).
:) Multumesc si Tiptronic placut tuturor!
Modificat de Executron
Eu m-am dus la Samer Zakzak in Timisoara, a reparat. Va las numarul. 0722620339
Totusi, sunt sigur ca exista "mesteri" si in Bucuresti, n-as duce masina la Timisoara doar pt o reparatie.
Eu zic sa o duci. Vezi pe fb Reparatii Cutii Automate Timisoara. Multe multe din gama VW. Am un amic cu un GTI 5 a fost zilele trecute
Dap, am tot auzit de domnul respectiv. Pentru un diagnostic si pentru un schimb de ulei n-as bate drumul pana acolo. Si eu tot nu pot sa cred ca nu e niciun mester bun de automate in Bucuresti.
Sal
Are cineva schema electrica de la un passat b5 an 2000 motor 1.9 tdi ATJ cutie automata tiptronic
Se pare ca am un scurt pe undeva și mi-ar fi de mare ajutor
Ms!
Sal
Ms!
Salutare,detin de putin timpun Passat 2.5 V6 TDI 4 Motion din 2002 cod motor AKN,am circa 4500 km in 2 luni de cand il am si nu am schimbat nici ulei,filtre sau distributia care este cel mai important,l-am inscris pe BG masina fiind pe Germania si am cam ramas fara bani,urmand in perioada urmatoare sa fac cele mentionate dar pana una alta ma nelinisteste cutia. Mai exact simptomele fiind: cand schimba din treapta 2 in 3 parca ar schimba de 2 ori sa zic asa si un pic de zvac,iar la treapta 4 in 5 un pic de zvac dar asta nu mereu. Astept cateva sfaturi in ceea ce priveste aceasta problema si curand sa revin cu alte postari despre masina cu ce am mai facut pe la ea atat tehnic cat si estetic. Multumesc anticipat :)
Fa-i o scanare pe 02-autotrans. In bord arata cum schimba? Simti ezitari la schimbare? Uleiul a fost schimbat la cutie?
imi arata cand schimba...am precizt exact ce se intampla la ce trepte si in ce fel. atat . in rest nimic altceva.
poti incerca sa ii schimbi uleiul - cel mai bine este sa vb cu un specialist in cutii automate.
Buna ziua,
Am o problema la cutie tiptronic pe un passat B5 din 2000,
La pornirea de pe loc nu mai recunoaste viteza 1 si 2 , pleaca cu a 3-a de pe loc...
A intampinat careva aceasi problema?
Se poate repara sau trebuie schimbata cutia ?
Mersi
FA o diagnoza si vezi ce apare .
Modificat de Al Bundy
salut,
Am scanat si imi da
cod 17142 supapa cuplare 2 , eroare circuit , permanent
cod 17140 valva schimbare 2 , circuit intrerupt / scurt la masa, permanent
