Consumul meu e normal?
alex_puiulet
Eu consum in bucuresti[cutie tiptronic], pe traseul buc noi-big la ore de trafic-9,8[asta arata calculatorul 2]la 2000 km facuti pe acest traseu.Afara la 140 la ora 7,3.
  • Replies 835
  • C o s m i n
    59
  • F l o r i n
    51
  • clpos
    22
  • Totalsender
    18
Se pare ca asta e consumul real in Bucuresti. La fel consum si eu, dar totusi am cutie manuala in 6.
Mie in Bucuresti imi ia cam 11-12 , in general schimb viteza intre 2 si 3000 rpm :unsure: Ma asteptam sa scada odata cu incalzirea vremii,dar se pare ca n-a influentat prea mult.
Am inteles ca la PD nu se poate regla nimic , am I right ?
P.S. Ce e EGR ?
http://www.google.com/search?hl=en&lr=&q=d...egr&btnG=Search
http://en.wikipedia.org/wiki/EGR
Exhaust gas recirculation (EGR) is an NOx (nitrogen oxide and nitrogen dioxide) reduction technique used in most gasoline and diesel engines.
EGR works by recirculating a portion of an engine's exhaust gas back to the engine cylinders. Intermixing the incoming air with recirculated exhaust gas dilutes the mix with inert gas, lowering the peak combustion temperatures and (in diesel engines) reducing the amount of excess oxygen. Because NOx formation progresses much faster at high temperatures, EGR serves to limit the generation of NOx. NOx is primarily formed due to the presence of oxygen and high temperatures.
Revin, mi-a scazut consumul cu aprox 1-1,5 L in Bucuresti, si cam cu 0,5 in afara, alimentand cu E4, la RP. Si probabil ca s-a incalzit, dar totusi din cauza motorinei, am mai facut un plic cu E3, sa ma conving, si intr-adevar, consuma mai mult.
Ceau,
la un drum Timisoara -Focsani 700 km. am avut un consum mediu de 5.5 la suta am mers destul de tare 130-160 km\ora . Super multumit :D .
consum:- in oras 9-10 l/100 km (40-120km/h)
-7-9 l / 100 km in afara (130-200km/h)
mai baieti ........vad ca toata lumea se intrece in cele mai mici valori ale consumului masini : ba 4.2 ba 5 ba 6 l
sa aud si in ce situatii va consuma cel mai mult ????
de exemplu mie mi-a consumat odata 21 l /100 km asta a fost media ,acum haideti sa va spun cand si unde : mai precis pe o strada foarte foarte aglomerata unde pe o parte se asfalta cu smoala incinsa pe de alta parte erau 10 troleibuze pietonii zburau din toate partile parca era jungla acolo infine ...uite asa am scos un consum de ma iau cu mainile de cap =)) !
eu cred ca asta a fost media pentru cateva secunde, m-ar mira sa fie o medie constanta... poate daca ai mers cu masina supraturat... altfel...???!!! :)
mai baieti, nu ne derutati, hai sa precizam daca suntem din bucuresti sau nu, ca la timisoara o fi altceva.azi am plecat pe la 2 de la municipal, m-am dus pana la dristor, m-am intors pe la unirea si apoi pe dealul filaretului, rahova-sebastian, intr-o aglomeratie de nedescris, clima mergand non stop si mi-a luat 18 la suta.clar, nu e nimic instantaneu, totul a durat vreo ora si jumate, cred, cu mers treptele 1 si 2 fooaarte mult timp, asa ca cifra de 21 nu mi se pare exagerata !
pe de alta parte, acum trei saptamani am facut buc-oradea, 600 km, 4 oameni mari in masina, portbagajul plin, clima non stop : la dus, motorina mol, mai canicular, 6,8%, mers tare 160 pe autostrada si 130-40 pe unde se putea, la intors, mai racoare, 6,3 %, cu motorina OMV de-aia buna.
Cu cauciucuri 205*65*15 : 8.5l/100km in oras ; 7.2l/100km afara.Cu cauciucuri 195*65*15 (atentie!) : 7.0l/100km in oras ; 5.8-6.0l/100km afara. In aceleasi conditii (climatronic, faruri aprinse);condus normal.
Galati - Braila - Slobozia - Constanta - Albena si retur (aprox. 1000 km): consum mediu 6,4 l /100 km cu 4 persoane, mers obisnuit in general dar si cateva reprize peste 150.
In oras 9 - 9,5 l / 100 km, iar cand ma uit la consumul instantaneu ma ingrozesc... :scratch:
Am consumat in Bucuresti la 380 Km 38 de litri. Toti acesti km i-am facut cu climatronicul pornit, mers normal.As mentiona ca mare parte din cei 380 sunt facuti insumand cate 4-5 km.
Atunci cand am deschis acest topic aveam o mare problema cu consumul. Acum dupa ce am schimbat toamna trecuta distributia, am invatat si aplicat unele reguli de condus economic si am intervenit prin Vag-Com la cantitatea de motorina injectata pot sa ma "mandresc" cu urmatoarele date (toate fara clima, doar cu ventilatie):
- oras - 7-7.5 l/100
- afara - 5 l/100 (recordul a fost acum o luna pe traseul Sibiu-Bucuresti de 4.3 l/100 ! inclusiv mers pe autostrada cu 120 km/ora)
Parerea mea legata de consum e urmatoarea : conteaza extrem de mult mai multi factori si anume
1. cum conduci - sportiv sau mai batraneste
2. zona in care conduci - cat de aglomerata e si cat de bun e drumul din aacea zona
3. pneurile care le ai pe masina - daca suprafata de contact cu solul e mai mare -> clar creste consumu
4. daca folosesti sau nu clima sau climatronicul
5. calitatea combustibilului
6. viata filtrelor de ulei, combustibil si aer - adica daca esti la juamtea schimbului sau sunt noi, daca sunt noi e mai scazut consumul daca sunt aproape de schimb clar o sa ai un consum mai ridicat
7. mediul in care conduci +30 de grade sau - 10 .
si deja sunt destule :251:
eu sincer sunt din arad si am un consum de 6,5 /100 in oras cu tot cu ore de varf si afara in jur de 5,5-6
depinde cum ii dau sa ,,pape'' :D
Modificat de Red
[pot sa ma "mandresc" cu urmatoarele date (toate fara clima, doar cu ventilatie):
fratilor. la ce v-ati luat masina cu clima, sa n-o folositi de dragul unui litru in minus?..poate nici atat...
mai bine imi luam Passat.Sunt invidios pe unele consumuri.
Modificat de pustyuG4
nu stiu daca pana la urma se poate stabili un consum mediu standard.difera si modul de condus al fiecaruia si faptul ca o influenta mare o are si temperatura de afara(iarna nu-i ca vara :)) )
131cp tdi tiptronic bucuresti 12,afara 7,5
101 cp tdi 5vmanul bucuresti 10 afara 6.5
131 cp tdi 6 viteze bucuresti 11-11,5 afara 7.5
asta in regim de mers normal cu 3 masini diferite.
Octavia de 90 ia 4,5 afara fara ac si in oras 5,3-5,6 tot fara ac. Asta arata BC. Cauciucuri de iarna.
Passatu' ia 5,5 afara si 7 in oras cu clima.
:D Fordu' in schimb ... :D
Cred ca ne-am facut o idee si despre cum trebuie sa le conducem corect si despre cat consuma TDI-urile noastre. Mie cel putin mi-a fost foarte folositor topicul. Am citit toate paginile si am invatat destule.
eu am un passat de 131 cp motor AVF.la mine consumul de motorina este urmatorul:
in oras (sunt din Iasi) imi ia cam 8-9 mers normal maxim 3000 ture, iarna maxim 10.Nu zic imi ia cateodat si 7 in oras dar trebuie sa prind toate semafoarele pe verde si strada libera fara opriri prea multe si mers subturat.
in exterior imi ia cam 5.5 (chiar saptaman asta am facut 3300 km prin tara si mi-a luat 5.7, mers si pe autostrada viteza max 160, urcat transfagaraseanul,defileul jiului etc mers cat de cat normal).Si sa nu-mi spuna mie cineva ca scoate mai putin de 5 cu un passat de 131 CP in afara ca i-l dau pe al meu gratis.Da scoti 5 dar stiti cum?Pe autostrada in treapta 6 max 95 km/h pe pilot automat.Da si rad toate loganurile de tine.Sa fim seriosi domnilor am citit tot topicul asta si am vazut la unul consum de 6 in oras.
Consumul l-am facut numai la plin ochi (motorina aproape curgea din rezervor).Apropo la 3300 km CB arata 5.8 iar din calcule pe hartie mi-a iesit 5.643 tot pe acolo zic eu.
scuze 2300 km si precizez ca nu sunt vitezoman.este masina mea personala si nu o calc mai mult de 3000 ture.Chiar cateodata merg subturat (la 60-70 km/h treapta 6).In afara am avut si consum de 8 dar mers nu gluma ( viteza maxima 210 km/h) si chimbat vitezele numai la 4000 ture vreo 400 km (Iasi-Bucuresti 3:40)
Am o problema destul de mare:
De o saptamana am achizitionat un Passat Variant 1,9 TDI, 101CP, PD, 2003.
Consumul pe care l-am obtinut in Cluj, nu scade sub 10-11 l/100km, sub nici o forma. Am facut test cu VAS si cu VAG (statice) si nu a dat nici o eroare. Am nevoie (cred eu) de un test VAG in dinamica.
Unde credeti ca pot realiza asa ceva in Cluj ?
apropo de consum(avem acelasi motor si eu mai am cip pe el) eu am scos consum real... nu pe bc.... de 12 % in bucuresti cu un mers fff sportiv... deci nu cred ca 11% in cluj e un consum real, fa cum a zis andrei si vezi intr-adevar ce si cum
