Log Vag-com Pe A4 8e
Phoenix
M-a rugat un prieten sa-i scanez un a4 8e caruia i-au aparut tot felul de probleme, deodata. Geamurile nu mai merg, incuietorile la fel, climatronicul se inchide/deschide de unul singur, semnalizarea, stergatoarele etc. Atasez aici logul.
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 038 906 019 FP
Component: 1,9l R4 EDC 0000SG 1467
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E12A061353 AUZ6Z0A0156041
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
65535 - Internal Control Module Memory Error
00-00 - -
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 A
Component: A4 Klimaautomat 0711
Coding: 00000
Shop #: WSC 63351
6 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
01330 - Central Control Module for Central Convenience (J393)
00466 - Control Module for Steering Column Electronics (J527)
00457 - Control Module for Network (J519)
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
00474 - Control Module for Immobilizer
49-00 - No Communications
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 B
Component: int. Lastmodul RDW 1512
Coding: 00001
Shop #: WSC 63351
No fault code found.
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenks
Masina mai merge? :( .. prima chestie ar fi de vazut bateria, apoi daca cu motorul pornit tensiunea e peste 14V ( adica sa vezi daca incarca ),
apoi poate se pierde curent pe undeva.. cabluri pleznite..etc
In primul rand ce interfata ai folosit pentru SCANARE ? VAG-COm pe CAN sau pe k--l line ?
Pentru masina ta inerfata pe CAN e buna.
1) motorul nu are nici o eroare.
2)Sensor for Steering Angle (G85): Supply Voltage Terminal 30.
Eroarea asta se refera la terminalul de plus permanent. Vezi ca la baterie sunt pe ea cateva fire rosii ce se conecteaza la borna. Incearca sa le verifici daca sunt oxidate, slabite.
Din cate observ, la cate erori ai e posibil sa incarce prea mult alternatorul sau bateria sa fie pe 'gata'.
Schimba bateria . Macar de proba.
pai am scanat cu kline...
o sa incerc cu bateria de pe alta masina, de proba.
Aveti idee cum sa identific un consumator?
Foloseste interfata cu CAN- BUS. S-ar putea de la asta sa se traga.
Nu vad legatura.. a4 2003 nu e CAN din cate stiu eu :P Altfel nu mergea scanarea cu kkl. Ce legatura au erorile cu interfata de scan?
Offtopic, ma poti ajuta cu decodarea unui vdo cdr2005?
Am si eu o problema asemenatoare la un Audi A4 2.0 benzina (doar ca, nu merg deloc componentele: semnalizare, geamuri, oglinzi, claxon, stergatoare). Din cercetarile facut pana acum, problema pare sa fie de la Steering Column Electronics (J527) - care probabil este arsa.
Problema a aparut dupa ce am lasat masina 3-4 zile cu bateria deconectata. Problemele nu au nici un motiv "mecanic" (de genul oxidare, fire rupte etc) ci doar, durata de viata a circuitelor electronice...
Tu ai rezolvat problema intre timp ?
  • 3 years later...
Mai mult ca sigur ai ars modulul care se afla in spatele panoului cu sigurante ,el tine toate luminile ,geamurile clacsonul dezaburirea si stergatoarele stiu asta deoarece am si eu problema asta dar mie mi sa ars doar partea cu stergatoarele ,am rezolvat momentan la electrician mia pus un buton pe direct ,de ars sa ars datorita infiltratiei de APA pe langa cpu
