Coduri Pr La Modelele Vag
Marian
Buna ziua ! puteti sa ma ajutati sa identific ce dotari are masina mea un vw turan2.0 highl 103 kw tdi ag6 vin 1T5W121812 1 care are eticheta din interior in mare parte distrusa?  Daca am gresit topicul va rog sa ma indrumati unde trebuie sa postez. Multumesc.
  • Replies 86
  • Marian
    9
  • xyboox
    3
  • Roger
    3
  • chicken
    3
DACA stiti, va rog sa-mi traduceti urmatoarele coduri:
L03 = Suspension range 03 installation control only no requirement forecast;
QG2 = No possibility of activating service interval prolongation;
0YC = Weight range 3 installation control only no requirement forecast.
Dar nu mota-mo, ca asta stiu engleza si cunost si translate.google.com.
Ce inseamna "range 03", ce inseamna "service interval prolongation", ce inesamna "no requirement forecast"
Multumesc anticipat.
Pt. Razvan, ar fi corect si frumos sa se explice de ce primesti un avertisment la o astfel de intrebare.
Va salut, la masina din semnatura am doua coduri pe care nu le pot afla: D91 si TG3.  La ambele imi arata ceva informatii despre motor (2.0, turbo diesel 4-cyl), dar la final, "code not found"
  • 5 weeks later...
D91 = 4-cyl. turbo diesel engine 2.0 l/103 kW (4V) TDI common rail; Base engine: TG3/ TJ3/TU3/TU4/TL4/TP4/TM3/TW3/TR4/TS1/TN5
TG3 = 4-cylinder diesel engine 2.0 L unit 03L.A
  • 6 months later...
6BB = Inlaid work design 1
8HD = Second alternator 120 A
2B3 = Additional exterior noise suppression (hood capsule and dash panel)
G24 = Front shock absorption
Care are idee despe ce este vorba la aceste coduri?
Buna ziua,
Doar acest topic l-am gasit referitor la explicatiile descrierii codurilor, va rog sa ma lamuriti ce inseamna urmatoarele:
0EG - Installation differentiation for vehicle components: Installation differentiation for dual-clutch transv. transmission DQ200 -- vehicle components
0YA - Weight range 1 installation control only, no requirement forecast
1D0 -  without tow bar
1EX  - Special identification label for EC for M1 passenger vehicles
2G7 - Filler neck module 1 with insert
Multumesc, dar nu sunt explicate...
Eu asta intrebam, deaorece in primele posturi au fost colegi care le-au explicat.
Modificat de R_a_z_v_a_n
Renunta la QUOTE
  • 4 years later...
salut!
ma poate ajuta cineva cu un vin decoder?
multumesc!
