Golf V 2.0 Tdi
jeansucprigat
salut. am si eu o problema cu un golf 5 2.0 tdi ... in relanti masina se tureaza singura uneori pana la 900 -1000 rpm dela 800 cat este acum normal setata .. turatia nu variaza ci ramane turata la valoarea care se ridica. am facut o scanare cu un vag com si mi au aparut aceste erori.
6 Faults Found:
17057 - Cylinder 3 Glow Plug Circuit (Q12)
            P0673 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 840 /min
                    Torque: 44.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.36 V
                    Bin. Bits: 00001111
                    Temperature: 15.3°C
                    Bin. Bits: 10110000
17055 - Cylinder 1 Glow Plug Circuit (Q10)
            P0671 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 216.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.86 V
                    Bin. Bits: 00001011
                    Temperature: 0.9°C
                    Bin. Bits: 00110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
            P0674 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 182.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.08 V
                    Bin. Bits: 00001100
                    Temperature: 4.5°C
                    Bin. Bits: 00110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
            P0672 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 144.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.39 V
                    Bin. Bits: 00001000
                    Temperature: 8.1°C
                    Bin. Bits: 00110000
18051 - Please check DTC Memory of Electric Load Controller
            P1643 - 000 -  - Intermittent
             Freeze Frame:
                    RPM: 1008 /min
                    Torque: 24.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.06 V
                    Bin. Bits: 00001000
                    Load: 37.6 %
                    (no units): 1.0
16618 - Boost Pressure Regulation
            P0234 - 000 - Limit Exceeded (Overboost Condition)
             Freeze Frame:
                    RPM: 3843 /min
                    Torque: 302.0 Nm
                    Speed: 96.0 km/h
                    Load: 100.0 %
                    Voltage: 14.06 V
                    Bin. Bits: 00001000
                    Absolute Pres.: 2131.8 mbar
                    Absolute Pres.: 2499.0 mbar
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 BA
   Component: ClimatronicPQ35 066 0606
   Shop #: WSC 00000 000 00000
   VCID: 67DD5D1756980F26359-8032
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 L    HW: 1K0 937 049 L*
   Component: Bordnetz-SG 1.0 H30 0701
   Revision: 00030000    Serial number: 00000000459633
   Coding: E58B8F0600041800001400001400000000
   VCID: 387FCE6B4BA650DE6C3-806D
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 K  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 002  0505
   Coding: 00217125
   Shop #: WSC 00000
3 Faults Found:
00526 - Brake Light Switch-F
            008 - Implausible Signal - Intermittent
01496 - Bulb for Fog-Lamps; Left (L22)
            010 - Open or Short to Plus
01598 - Drive Battery Voltage
            000 - - - Intermittent
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Part No: 1K0 920 870 L
   Component: IMMO                3354
   VCID: 326BFC43ADDABA8E527-8067
00381 - Databus Instrument Cluster
            014 - Defective - Intermittent
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 C    HW: 1K0 963 235 C
   Component: PTC-Element         0404
   Revision: 00600000    Serial number:
   VCID: 2B55E1278AF0EB46111-807E
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
Multumesc frumos , astept raspuns
Cum e motorul 2.0TDI BKD ?
Am inteles ca trebuie sa fie cu, chiulasa C (e un an anume de fabricatie?).
Cum sta cu pompa de ulei ?
Am inteles ca este la fel ca motorul 1.9TDI (injectoare, pompa de ulei), dar are 2 axe cu came.
Stiu ca are consum mare de ulei, turbina este cam slabuta. Am vazut multe probleme specifice acestui motor, pe care la 1.9tdi nu le-am vazut. Ce ziceti ?
Ce pret are un injector ?
Proaspăt posesor de bkd, eu unul pot sa-ti zic sa iti iasa din cap ideea in cazul in care nu vrei sa bagi bani in el .. chiulasa in C si tot sunt probleme .. sincer, prea multi bani am băgat în masina ca sa mai sfătuiesc pe cineva sa-si ia acest cod motor .. succes !
BKD-ul e un motor f bun cauta unul cu km reali cu istoric service 2007-2008 si nu ai probleme. Consumul de ulei nu e mare,  la mine papat 750 ml in primii 15 000 km in perioada de rodaj consumul este mai mare oricum iar ulterior am completat intre revizii 350 ml , 900 ml, 500 ml depinde cum mergi cu el, poate daca nu aveam masina de noua comentam si eu la consumul de ulei.Din 2008 pana in prezent a servit doar motorina si revizii normale, merge perfect
salut am si eu un bkd si imi scoate un fum albastrui dupa ce se incalzeste ,iasa de obicei in trptele 1,2,3 la turatie joasa intre 1300 si 2000 tpm.Ma ajtati si pe mine cu un sfat a mai patit cineva aceasta problema!!!Ms
fa o diagnoza ca in fum albastru nu cred ca ghiceste nimeni pe aici
Salutare tuturor
Imi cer scuze daca s-a mai discutat pe aceasta tema, sunt posesorul unui golf 5 bkd 2004 16v care papa antigel la greu si nici nu prea mai suna ok.
Recent am fost sfatuit ca cea mai buna solutie ar fi nu schimbarea chiulasei ci a motorului complet.
Este posibila schimbarea motorului bkd 16v 140cp 2004  cu bmn 170cp 2008 (doar motorul fara ecu ,  etc?)
Se pot monta injectoarele de pe bkd pe bmn si pastrat ecu de pe bkd ?
Bmn 170cp este tot 16v ?
Mii de scuze daca s-a mai discutat acest subiect dar sunt in dubii rau de tot...
Cel de 170 e 16v, bmm-ul e 8v. :)
Schimba chiulasa, aceeasi problema am avut-o si eu, iar cu ocazia schimbarii am servisat corect motorul.
Bkd-ul e un motor bun si nu merita sa il schimbi.
  On 07.09.2016 at 8:10, cristi511 a scris:
Expand
servisat corect motorul in ce sens ce ai mai facut la el ?
S au schimbat tacheti, arcurile de la supape si absolut toate garniturile posibile. Piesele au fost mutate de pe o chiulasa pe cealalta luandu-se în funcție de uzura.
Nu cred ca are rost sa vorbim de faptul ca s-a făcut planeitatea, s-a pus o garnitura de chiulasa de grosime adecvată, s-au schimbat toate șuruburile, s-au schimbat oringurile si șuruburile injectoarelor după care s-a efectuat reglajul acestora, s-a schimbat cureaua de distribuitie, s-a pornit motorul folosind uleiul vechi si apoi s-a făcut schimbul cu motul + filtru, s-au schimbat bujiile....
A fost o operațiune destul de costisitoare dar a meritat.
Expand
Salut. Asa informativ... inseamna foarte mult acel "destul de costisitoare"?
Modificat de trd002200
Pai depinde ce înțelegi prin costisitoare. Eu am considerat ca merita altfel nu o făceam.
Caută pe olx preturi pt chiulase (ca sa îți faci o idee) iar restul operațiunilor diferă în funcție de starea pieselor de pe mașina ta + manopera.
Sincer nu mai stiu exact cât m-a costat dar stiu sigur ca a fost în jurul a 1000e.
:emthup: spor la treaba.
1800 ron m-a costat chiulasa sh iar restul au fost bani cu care plătit testul de etanșeitate, garnituri, șuruburi, diverse alte materiale, ulei + filtru, antigel, curea + role de distributie, manopera. Am găsit niște notițe prin calculator si costul total a fost 5500 ron. (Inclusiv demontat si testat chiulasa veche si schimbat oringurile+reglat injectoare).
Modificat de cristi511
Aha, merci de info.
As avea o intrebare legata de BKD. Pana la urma e cu Bosch sau cu Siemens? Unii zic una, altii alta. Sau s-au pus si cu, si cu?
Mentionez ca ma intereseaza pentru cele din prima tura, an 2004.
Cele din prima tura au de obicei chiulasa in A, rar gasesti una schimbata, sau daca e schimbata a schimbat tot cu A sau B. Te intereseaza cele din ultima tura.
  On 21.09.2016 at 10:52, deenman a scris:
Expand
Evident ca alea ma intereseaza. Am formulat eu putin incorect. Ma interesa informatia legata de ECU/injectoare pentru un Golf din 2004:P
  On 21.09.2016 at 13:53, GTD a scris:
@trd002200 pe BKD exista doar injectie Bosch
Expand
Merci.
Saptamana asta vreau sa achizitionez un Golf 5 2.0 TDI 140 cai din 2008 cu un ax deci cod BMM din cate am inteles. Aveti ceva sfaturi? E o varianta buna? La ce sa ma astept?
  • 11 months later...
Mi-a aparut aceasta eroare dupa ce am pus vag com-ul pe masina, deoarece pornea greu la temperaturi mai joase: "Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault".
Intrebarea mea este, citeste bine ca este bujia de pe cilindrul 1, sau este de fapt cea de pe 4?
Golf V, 2.0 TDI 4Motion 16v, an 2005.
