Webasto Touran
cristy_snacks
Calin postează erorile găsite complet.
Se pare ca pcb de la webasto nu mai răspunde interogații!
Acestea sunt erorile gasite cu vcds legate de webasto.Multumesc pentru raspuns.
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 L    HW: 1K0 937 049 L*
   Component: Bordnetz-SG 1.0 H30 0701
   Revision: 00030000    Serial number: 00000000551933
   Coding: A38B8F020004100000120C000000000000
   Shop #: WSC 12345 123 12345
   VCID: 38633833D2537EC2E750BE5-806C
   Subsystem 1 - Part No: 1T0 955 119 B  Labels: 1TX-955-119.CLB
   Component: Wischer WWS A-MPV   0201
   Coding: 16711828
   Shop #: WSC 12345
01207 - Control Module for Auxiliary Heater (J364)
            004 - No Signal/Communication
Address 18: Aux. Heat
Cannot be reached
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 2100104127DDA4
   Coding: 7D3F5348078002
   Shop #: WSC 01324 785 00200
   VCID: 2741EB4F0FEDE13A7EEA651-8072
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 85
                    Mileage: 205634 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:59:19
Salutare baieti!
Recent am avut ceva probleme la masina si am rugat un amic sa ma ajute cu o diagnoza, si am gasit urmatoarele:
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 AL    HW: 028 101 145 0
   Component: R4 2,0L EDC G000SG  5249
   Revision: 12345678    Serial number: VWZ7Z0C8618671
   Coding: 0000072
   VCID: 6DDBA24174742A49B4D-8038
8 Faults Found:
17057 - Cylinder 3 Glow Plug Circuit (Q12)
            P0673 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 54.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.44 V
                    Bin. Bits: 00101111
                    Temperature: 12.6°C
                    Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
            P0674 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 54.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.44 V
                    Bin. Bits: 00101111
                    Temperature: 12.6°C
                    Bin. Bits: 10110000
16618 - Boost Pressure Regulation
            P0234 - 000 - Limit Exceeded (Overboost Condition)
             Freeze Frame:
                    RPM: 3192 /min
                    Torque: 322.0 Nm
                    Speed: 101.0 km/h
                    Load: 78.8 %
                    Voltage: 14.29 V
                    Bin. Bits: 00101000
                    Absolute Pres.: 2244.0 mbar
                    Absolute Pres.: 2590.8 mbar
16725 - Camshaft Position Sensor (G40)
            P0341 - 000 - Implausible Signal
             Freeze Frame:
                    RPM: 756 /min
                    Torque: 86.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.02 V
                    Bin. Bits: 00101111
                    Idle Stabilization: 0.0°KW
                    (no units): 48.0
17978 - Engine Start Blocked by Immobilizer
            P1570 - 000 -  - Intermittent
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.54 V
                    Bin. Bits: 00001000
                    Bin. Bits: 11100000
                    (no units): 1.0
18051 - Please check DTC Memory of Electric Load Controller
            P1643 - 000 -  - Intermittent
             Freeze Frame:
                    RPM: 1008 /min
                    Torque: 52.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.36 V
                    Bin. Bits: 00101000
                    Load: 42.4 %
                    (no units): 1.0
16785 - EGR System
            P0401 - 000 - Insufficient Flow - Intermittent
             Freeze Frame:
                    RPM: 1386 /min
                    Torque: 50.0 Nm
                    Speed: 0.0 km/h
                    Load: 26.3 %
                    Duty Cycle: 14.7 %
                    Bin. Bits: 00101000
                    Mass Air / Rev.: 345.0 mg/str
                    Mass Air / Rev.: 480.0 mg/str
16990 - Internal Control Module
            P0606 - 000 - Processor Fault
             Freeze Frame:
                    RPM: 1260 /min
                    Torque: 96.0 Nm
                    Speed: 0.0 km/h
                    Load: 6.3 %
                    Voltage: 11.02 V
                    Bin. Bits: 00101100
                    (no units): 0.0
                    Torque: 2.0 Nm
   Component: Bordnetz-SG 1.0 H29 0701
   Revision: 00029000    Serial number: 00000000287266
   Coding: 018B8F020004100000120C000000000000
   Shop #: WSC 00000 000 00000
   VCID: 387543154BB65FE197B-806D
   Subsystem 1 - Part No: 1T0 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW358  012  0401
   Coding: 00063445
   Shop #: WSC 00000
3 Faults Found:
00985 - Right Tail Light (M2)
01064 - Terminal 58d; Interior Dimming
            012 - Electrical Fault in Circuit
01598 - Drive Battery Voltage
            000 -  -  - Intermittent
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 C    HW: 1T0 909 605 C
   Component: 07 AIRBAG VW62 0102 1500
   Revision: 10026000    Serial number: 0038BD0N15EZ
   Coding: 0012343
   Shop #: WSC 27227 141 03128
   VCID: 356B4A215CA4A2898CD-8060
01217 - Side Airbag Igniter; Driver Side (N199)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 1K0 815 071 M
   Component: Zuheizer        020 1312
   Revision:        A    Serial number: 09010046
   Coding: 0000011
   Shop #: WSC 48003 141 62543
   VCID: 2F677849BEF89859C61-807A
4 Faults Found:
00003 - Control Module
            014 - Defective - Intermittent
             Freeze Frame:
01406 - No Flame
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 264220 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:44:20
             Freeze Frame:
                        Start
                    Temperature: 33.0°C
                    Temperature: 23.0°C
00664 - Fuel gauge
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 16
                    Reset counter: 172
                    Mileage: 283012 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:35:11
01444 - Under-Voltage Shut-Off (Automatic)
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 16
                    Reset counter: 172
                    Mileage: 283012 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:35:11
   Revision: 08          Serial number: 2100103A070A58
   Coding: 3D3F13C0078002
   VCID: 275790699608C0190E1-8072
00469 - Infotainment Databus in Single Wire Operation
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Reset counter: 0
                    Mileage: 247425 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:04:50
Dupa stergerea tuturor erorilor au mai ramas erorile pe Aux.Heat, si cea cu Infotaintment!
De precizat este ca am o pierdere de vacuum (ca si simptom pedala de frana are momente cand e  'tare', si cred ca eroarea de pe turbina este si datorita acestei pierderi.
Referitor la erorile de pe Aux.Heat voi incerca astazi sa fac adaptarea pe canalul 18, intrabarea persistand la eroare de pe CAN Gateway, are cineva vreo idee de unde ar putea fi?
Am reusit sa pornesc webasto-ul. Am fost la un electrician care la desfacut, la curatat, la montat inapoi si apoi la "activat" in softul masinii. Electricianul mi-a spus ca se blocase o pompa de la webasto.Totusi mai am o mica nelamurire si anume faptul ca webastoul care este montat pe masina porneste odata cu motorul, dar doar daca ai comutatorul de la aeroterma si el pornit indiferent de pozitie sau viteza.
Este normal sau mai trebuie setat ceva din computerul masinii?
Va salut domnilor
Acum 6 luni am cumparat Touranul din semnatura fara sa stiu ca are incalzire stationara.La o diagnoza mai amanutita mi-am dat seama ca are webasto ,dar ca acesta este nefunctional.Avea erori de "fame time-out" si "unit locked".Avand in vedere ca nu stiam mare lucru despre el am hotarat sa il demontez si de aici a inceput distractia:
-am curatat camera de ardere care era ancrasata cu funingine
-am verificat cei doi sezori si bujia(la bujie daca nu o puteti masura cu aparatul pentru ca are valoare sub 1ohm probati-o direct pe baterie)
-am gasit pompa de recirculare apa webasto blocata si ruginita(nu se mai putea repara)
am inlocuit-o cu una sh de mercedes(era mai ieftina) la care am inseriat o rezistenta de 1Kohm ca sa o poata vedea ttv
Am montat totul la loc si am tras 2 fire de pe pinul 2 si 8 al lui webasto in ideea ca pe viitor sa il transform in incalzire stationara.
L-am deblocat cu vagcomul si a pornit din prima.
Intre timp am achizitionat un modul W-bus si o inchidere speciala care tine cu 2 relee 12 v permanent la o apasare(nu se pot folosi inchideri centralizate normale findca au doar impuls de 2 sec).Le-am montat si am taiat cablurile de can pentru webasto.
Concluzie:Jucaria porneste independent de masina si in 11 min duce antigelul la 90 gr practic cum am pornit masina baga caldura.
Ce nu stiu:
1.Mai trebuie facute codari cu vagul?
2.Cum pornesc ventilatorul masinii avand in vedere ca am climatronic(am inteles ca la ventilator comanda se face PWM si ca am nevoie de un releu Ipcu )sau sunt si alte metode de pornire climatronic without ignition?
Va multumesc anticipat.
Modificat de edisor
Salut, am si eu un Touran 2005 1.9 136 cp, si vreau sa stiu cum aflu daca am webasto? Daca ma poate ajuta cineva va multumesc
Poti afla citind acest topic de la inceput. Hai ca nu e greu
Salut! Poti verifica daca ai Webasto pe masina uitându-te daca ai abțibild cu inscripția Webasto pe partea centrală - între cele 2 faruri sau sa virezi rotile spre stanga, iar sub masina, lângă roata din dreapta fata ar trebui sa fie evacuarea de la Webasto. Daca o ai si vrei sa știi daca funcționează pornește masina si apoi pune degetul la evacuare si ar trebui sa simți cum sufla aer rece mai întâi pe acolo. Succes
va rog sa ma ajutati cu urmatoarele erori
Wednesday,28,December,2016,15:35:55:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: WVGZZZ1TZ6W182524   License Plate:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56
VIN: WVGZZZ1TZ6W182524   Mileage: 191180km-118793miles
   Part No: 1K0 815 071 R
   Component: Zuheizer        050 2302
   Revision: 00050000    Serial number: 09009839000000
   Coding: 0000011
   VCID: 346776B657FA45E274-8060
4 Faults Found:
02251 - Heater Unit Locked
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 169375 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 90
                    Mileage: 165685 km
                    Time Indication: 0
01406 - No Flame
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 39
                    Reset counter: 125
                    Mileage: 166376 km
                    Time Indication: 0
             Freeze Frame:
                        Start
                    Temperature: 30.0°C
                    Temperature: 25.0°C
                    Voltage: 14.45 V
01407 - Flame Extinguished
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 104
                    Mileage: 167864 km
                    Time Indication: 0
             Freeze Frame:
                        Start
                    Temperature: 74.0°C
                    Temperature: 72.0°C
                    Voltage: 14.53 V
Dar nu trebuia sa pui tot carnatul asta. Sau macar sa-l fi pus intr-un fisier txt atasat.
Momentan incalzitorul tau e blocat, dupa cateva tentative esuate de pornire, printre care si tensiunea scazuta in baterie. Dar asta pe la km 167.000. Acum vad ca ai peste 200.000.
Deblocheaza-l, sterge erorile si vezi daca porneste.
Salut! Același lucru îmi da si mie acum. S-a blocat cam de 1 sapt. Cum se poate debloca? De șters eroarea nu ma lasa.
Citeste topicul ca scrie. Nu asteptati doar raspuns direct. Nu e greu. Chiar sunt toate detaliile despre ce si cum se face
Salut baieti! A schimbat cineva panoul de la clima normal cu unul cu buton destinat special pentru webasto?
Alin Stoiculescu
On 11/12/2016 at 7:16 PM, ioanidis84 said:
    Problema pe care o ai tu poate sa fie si de la circuitul de monitorizare a bujiei de pe placa de baza. aceiasi problema am avut o si eu si sa rezolvat prin schimbarea unor piese de pe placa de baza. Din pacate la modelul tau de webasto (thermotop v) nu am vazut pe nicaieri discutii legate de reparatia placii. La thermo top c se mai poate repara cate ceva.
Salut Ionut. Poti spune te rog ce componente au fost defecte? Aceeasi problema am si eu. Q8 implausible signal. Masurata pare ok. Multumesc!
Salutare. Pana ceva zile in urma webasto a functionat fara probleme. Am facut o diagnoza dar nu reusesc sa accesez unitatea webasto, practic nu o mai 'vede' unitate centrala.
Scuzati formularea dar nu prea ma pricep asa de bine,folosesc diagnoza doar pe masina pers cand ceva nu mai functioneaza. Am atasat erorile ma jos. Astept sfaturile voastre. Va multumesc!
webasto.txt
Buna seara pana la urma am achizitionat un Touran 2007 1.9 cu filtru de particule am scris aici pentru ca Webasco nu functioneza si as vrea sa intreb daca este cineva in zona cluj dej bistrita cunoscuti voua pt ca si eu cunosc electricieni dar... lasa-ma sa te las, multumesc mult.
Salutare colegi!
Ma poate ajuta cineva sa imi explice care ar fi problema?
   Coding: 0000011
   VCID: 3467FA5B57CEB4BE40B-8061
3 Faults Found:
00664 - Fuel gauge
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 111
                    Mileage: 212918 km
                    Time Indication: 0
01489 - Over-Temp Sensor (G189)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 213015 km
                    Time Indication: 0
             Freeze Frame:
                        Start
                    Temperature: 60.0°C
                    Temperature: 60.0°C
                    Voltage: 13.73 V
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 213016 km
                    Time Indication: 0
deblocheaza unitatea, nu mai merge cu motorina putina si verifica pompa de recirculare.
Este vreo procedura de deblocare cu VCDS sau trebuie sa merg la un service?
da, cu VCDS-ul, pe 18 - in Adaptari. Ai Heater unlock
Si gaseai procedura in topic doar daca cautai ca e scrisa si la inceputul topicului.
A disparut si meniul din maxi dot cu setarile aferente webasto. Cred ca ma depaseste problema. Mai raman sigurantele de verificat.
01207 - Modul pentru comandă încălzire auxiliara-J364-
            004 - Nu este semnal / nu comunica
exista vreo posibilitate de a-l reactiva cu vcds. multumesc
daca nu comunica atunci:
-nu are alimentare
-fire intrerupte
-modul defect
dupa ce remediezi problema o sa comunice din nou.
