Webasto Touran
cristy_snacks
Ma poate ajuta cineva cu erorile astea la un vw touran 2006?
Tuesday,29,December,2015,16:09:27:62939
VCDS Version: Release 12.12.0 (x64)
                Address 18: Aux. Heat       Labels: 1K0-815-071.clb
Control Module Part Number: 1K0 815 071 P
  Component and/or Version: Zuheizer        031 1312
           Software Coding: 0000011
            Work Shop Code: WSC 01324 785 00200
                      VCID: 326BFC43ADDABA8E527-8067
4 Faults Found:
01406 - No Flame
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 197
                    Mileage: 160104 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:59:39
             Freeze Frame:
                        Start
                    Temperature: 65.0°C
                    Temperature: 59.0°C
01489 - Over-Temp Sensor (G189)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 200
                    Mileage: 160172 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:09:23
             Freeze Frame:
                        Start
                    Temperature: 48.0°C
                    Temperature: 28.0°C
02251 - Heater Unit Locked
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 200
                    Mileage: 160172 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:09:23
00664 - Fuel gauge
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 4
                    Reset counter: 140
                    Mileage: 172545 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:46:59
Deblocheaza unitatea si sterge erorile. Evita pe viitor sa mergi cu motorina pe rosu.
Verifica si pompa de recirculare daca merge.
Corect Cristi-poate de acolo are eroarea de over temp.
cum sterg niste erori de la webasto gen fuel tank sau no flame si sa deblochez unitatea? cu vagcom!!!!! vreau sa incerc eu cu putin ajutor de la voi. Merci
Salvezi val 1 in canal 42 apoi poti sterge erorile
am fost acum la masina sa vad ce pot face cu webasto si nu am reusit. Aveti ideie de ce nu pot modifica din valoarea 0 in 1? erorile le-am sters. nu imi mai apare  nimic la webasto
Pai unitatea e blocata sau nu? Numai cand e blocata poti face modificarea in adaption. Daca nu era deblocata nu puteai sterge erorile...deci pana la urma cum era? Blocata sau nu? Sau doar postam asa...de control.
Salutare, daca ai nevoie de ajutor iti pot lasa nr. de telefon si ma poti suna sa te ajut.doar sa-mi spui
Vezi ca poate fi si vag com de vina sa nu iti salveze modificarea. Si mai oamenilor mai citiți si ce sa scris mai in urma nu așteptați raspuns la aceleasi erori deja expuse de nu stiu cate ori
Salut am un vw touran din 2006 1.9 TDI model 1T
Stie cineva sa ma lamureasca cu webasto nu am delecomanda la el nu are consolo in bord nu porneste singus cand temperatura este mai mica de 4 grade care ar fi solutia sa vad daca functioneaza in afara de reprezentanta de la webasta caci nu prea am nici una in zona unde stau
Cand e frig afara de la +4 grade in jos, dai drumul la A/C,trebuie sa se stinga ledul galben la ECON ,ar trebuii sa iasa un fum pe la jumatatea masini in 2-3 minute. La mine in aceasta dimineata la -15 grade a trebuit sa merg 14 km in 10 minute ca sa imi ajunga apa la 87 grade. Precizez ca al meu este CLIMATIC. La Multi Ani in 2016.
Modificat de bogdansv02lah
Geo un search aici in acest topic ai dat? Vad ca chiar nu ne intelegem. Se pun aceleași intrebari de n ori. Cititi va rog topicul complet
14km in 10 minute mi sa parut mult la -15 grade asa ca am bagat vcds si am gasit o eroare de genul (no flame) dar mi-a fost lene sa o salves si am sters eroarea, ii mai fac o proba mai tarziu poate porneste iar sobita. Un nou an fericit tuturor.
Ca re poate sa imi zica ce e cu eroarea asta?
Control Module Part Number: 1K0 815 071 R
  Component and/or Version: Zuheizer        050 2302
                      VCID: 346084FF5728C89E89-8060
01406 - No Flame
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 7
                    Mileage: 263380 km
                    Time Indication: 0
             Freeze Frame:
                        Start
                    Temperature: 36.0°C
                    Temperature: 30.0°C
                    Voltage: 14.45 V
Bujie sau camera de ardere murdara. E chiar atat de greu de citit cateva posturi mai in urma?...sau eroarea ta e mai diferita de a celorlalti colegi???
Acum 2 zile functiona perfect si dintr-o data nu mai vrea. Remediul ar fi sa o dau jos cred?
Salut! Detin un Touran din 2004 cu webasto din fabrica. Pana de curand a functionat webasto normal acuma nici nu ma mai pot conecta pe canalul 18 aux heat deloc. Imi zice no response from controler. Imi poate zice cineva ce sa putut intampla. Va multumesc!
Da. Verifica siguranta din compartiment motor. Una de 20 arsa
Modificat de pronet
Am și eu o problema cu webasto. Am touran 2.0tdi din 2003. Am modul de comanda programabil. Când apăs butonul de pornire se aude un ticait ca un ceasornic de sub bord și cam atât. Nu încălzește nimic. Nu pornește nici ventilația. Motorina este, bateria am verificato la service mi-a spus ca e ca noua, buton econ nu este activat. Încă nu am pus vag-com ul.
Știe cineva ce fel de simptome sunt acestea?
Mulțumesc anticipat.
Pune vcds-ul pe masina. Altfel, fara un cod de eroare discutam pe langa si doar presupunem eventualele pb.
Trebuie vazut ce anume iti da la diagnoza altfel sunt doar speculatii.
Acum m-am intors de la masina in ideea de a mai incerca o data sa deblochez webasto. Acelasi procedeu,pe canal 42 aveam 0 la valoare si sa pun 1 ca sa o salvez dar nu vroia sa se salveze. Am mai intrat iar si tot 0 era ,am facut din nou in acelasi fel adica 1 la new value apoi test si ramanea la fel daca intram din nou adica 0. Am zis totusi sa sterg erorile sa vad daca se sterg si am constatat ca se sterg. Am pornit masina si tand la volan ,cand privesc spre dreapta vad un fum dens dinspre roata. Atunci am constatat ca mi-a pornit webasto :) ,s-a incalzit in masina in 5 minute la o temperatura exterioara de -11 grade.
Fumul acela dens o sa-mi apara asa de fiecare data? Nu de alta dar se uita astia la masina ca la circ. Din cauza ca nu a fost curatata sau asa scoate de obicei?
