Webasto Touran
cristy_snacks
ppaarroollaa
Si asta este adevarat
ma ajuta careva cu informatia solicitata mai sus?   :icon_rendeer:
Daca modulul Telestart este montat pe masina este posibil ca el sa nu comunice pe CAN? trebuie si un update la CAN? Daca comunica ar trebui sa fie vizibil pe o diagnoza undeva?
Sunt un posesor de un touran 2,0 tdi de o sapt si am facut o scanare cu vcds 11.2 si as vrea sa imi interpreteze si mie cineva erorile, in mare am idee dar poate ma ajuta cu un sfat ceva.
Thursday,24,July,2014,23:25:58:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 37 42 44 46 52 56 62 72 77
VIN: WVGZZZ1TZ5W084886   Mileage: 204020km/126772miles
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 BQ    HW: 028 101 190 6
   Component: R4 2,0L EDC G000SG  9971
   Revision: 12345678    Serial number: VWZ7Z0D0909971
   Coding: 0000072
   Shop #: WSC 72851 123 87121
   VCID: 73E1DBFF6975
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0023238
   Shop #: WSC 01324 785 00200
   VCID: 3A7F36DB0E9F
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AG
   Component: ClimatronicPQ35 066 0505
   Shop #: WSC 00000 000 00000
   VCID: 6CD3C083344B
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 L    HW: 3C0 937 049 L
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000003573106
   Coding: 018B8F020004100000120C000000000000087F075C0000
   Shop #: WSC 20052 123 84706
   VCID: 326F1EFBD6EF
   Subsystem 1 - Part No: 1T0 955 119 C
   Component: Wischer VW358  012  0401
   Coding: 00065493
   Shop #: WSC 20052
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 225
                    Mileage: 203912 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 14.20 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 C    HW: 1T0 909 605 C
   Component: 02 AIRBAG VW62 0506 1500
   Revision: 09025000    Serial number: 0038BD09YVVB
   Coding: 0012338
   VCID: 356525E72781
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 500 0030
   Coding: 0000042
   VCID: 306B14F3D8E3
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1T0 920 871 A
   Component: KOMBIINSTRUMENT VDD 0812
   Coding: 0007103
   Shop #: WSC 00011 888 96745
   VCID: 316D11F7D3E9
Address 18: Aux. Heat        Labels: None
   Part No: 1K0 815 071 H
   Component: Zuheizer        031 1312
   Revision:        A    Serial number: 09010046
   Coding: 0000011
   Shop #: WSC 20052 123 91603
   VCID: 2A5F069BFE3F
5 Faults Found:
01411 - Temperature Sensor (G18)
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 0
                    Reset counter: 124
                    Mileage: 198962 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 24:14:53
             Freeze Frame:
                        Malfunction
                    Temperature: 205.0°C
                    Temperature: 12.0°C
02251 - Heater Unit Locked
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Reset counter: 124
                    Mileage: 198962 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 24:14:53
00664 - Fuel gauge
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 210
                    Reset counter: 49
                    Mileage: 197188 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 31:51:27
01444 - Under-Voltage Shut-Off (Automatic)
             Freeze Frame:
                    Fault Priority: 0
                    Reset counter: 49
                    Mileage: 197188 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 31:51:27
00003 - Control Module
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Reset counter: 49
                    Mileage: 197188 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 31:51:27
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104A180890
   Coding: 3D3F13C8078002
   VCID: 295DF997FB39
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0812
   VCID: 316D11F7D3E9
Address 37: Navigation        Labels: 1T0-919-887.lbl
   Part No: 1T0 919 887 D
   Component:      Navigation     0421
   Coding: 0000002
   Shop #: WSC 46051 123 02705
   VCID: 43814B3F7955
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1T0 959 701
   Component: Tuersteuergeraet 09 0157
   Coding: 0000116
   VCID: F4E358E3EC7B
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K1 909 144 G
   Component: EPS_ZFLS Kl.0       1401
   VCID: 2F69178FC5DD
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No SW: 1K0 959 433 J    HW: 1K0 959 433 J
   Component: 01 KSG PQ35 G2  031 0308
   Revision: 00031000    Serial number: 00000000000000
   Coding: 80E802087F2D8404084F016001
   VCID: 37792FEF3D8D
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1T0 959 702
   Coding: 0000116
   VCID: F5E565E7E701
2 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
            008 - Implausible Signal
Address 56: Radio        Labels: 1T0-035-095.lbl
   Part No: 1T0 035 095
   Component:        Radio        0421
   Coding: 0001400
   VCID: EBD1439FB145
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 B
   Component: Tuersteuergeraet 06 0214
   Coding: 0000048
   VCID: 2F69178FC5DD
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 B
   Coding: 0000048
   VCID: 306B14F3D8E3
Address 77: Telephone        Labels: Redir Fail!
   Part No: 1K0 035 729 E
   Component: CIB PAH  HW 202 SW  0308
   Coding: 0000364
   VCID: 2B51039FF1C5
End   ---------------------------------------------------------------------
Sterge erorile si vezi ce mai ramane. Deblocheaza unitatea prin salvarea valorii 1 in canalul dedicat. Din ce cred s-ar putea sa fie dusa unitatea, dar vedem ce apare la noua scanare. Senzorul de temp e dus.
La webasto vezi ca este o metoda de deblocare. Cred ca sa blocat pentru ca ai umblat cu motorina putina. Citește topicul si ai sa vezi cauzele posibile cand si nu funcționează webasto.
poate ma si ajutati in ce canal sa salvez valoarea 1 dar cred ca este dus g18 pt ca am sters odata erorile si asta este la a doua scanare
Uite asa trebuie procedat si v3zi daca se sterge eroarea. Daca nu e dus
trebuie sa faceti urmatoarea adaptare,in modul 18 (Aux.HEAT), adaptation 10 canal 42 - daca este 0 tre sa modificati si puneti 1 apoi save si sterge erorile din nou
ms ms am sa incerc maine
Salutare! De unde se pot cumpara senzorii de pe webasto G18 si G189 , am cautata dar nu am gasit nimic concret. Ms!
Salutare, vad ca e un pic mai multa activitate pe aceasta sectiune in ultima vreme, asa ca as vrea sa aduc in atentia voastra intrebarea mea vis-a-vis de montarea unui ceas programator cu modul de comanda pentru incalzire stationara la Touran.
Daca aveti ceva experienta poate imi dati cateva indicatii, am expus mai sus detali despre ce as vrea sa fac.
fburaga , cu aceeasi problema ma confrunt si eu, am dat telefoane am trimis emailuri la 1 service autorizat webasto si la un furnizor de piese webasto:
Ambii mi-au spus acelasi lucru: daca varianta de pe touran din fabrice Termotop V are mufa de conectare a receptorului ptr telecomanda sau a unui programator atunci e simplu, dar daca nu se pare ca trebuie inlocuita placa de la webasto, sau inlocuit de tot :)
  Daca are mufa ptr conectare :  cu telecomanda - Modul telestart T90 sau T91 - 350euro
                                                    cu programator  -  Modul programator  - 70 euro
Offtopic: dimineata am gasit bateria descarcata rau de tot, a trebuit sa o pun la incarcat ptr pornire, erau 2 grade si se pare ca pornise webasto peste noapte.
  Am intrat cu diagnoza in auxiliary heating si am setat  de la 10,2V la 11,5V low voltage OFF, am setata ca sa nu mai porneasca decat cu motorul pornit si sunt curios daca maine dimineata o sa mai gasesc bateria descarcata.
buna informatia, multumesc de reply.
In legatura cu mufa aceea, daca este sau nu fizic pe masina, stii cumva despre ce mufa este vorba? cum arata? se poate vedea pe diag?
Asa eu am gasit ceas cu modul comanda prin germanica la 299 euro, cu free shipping, dar nu stiu daca se potriveste....
Daca stii cum arata mufa aceea, poate ai o poza ceva, da-mi si mie de veste.
si este vizibila cand dai bara fata jos? mai trebuie desfacut ceva pentru a ajunge la la ea?
pe langa bara si aparatoarea de la roata, cred ca trebuie si el demontat, nu sunt sigur 100% , mufele sunt sub un capac de plastic.
si un link ff util, explica fiecare mufa in parte, dati traducere din germana in RO  http://www.mytouran.de/html/thermo_top_v_diesel.html
din cate imi dau seama , daca se da un +12V la pinul 1 de la mufa B din linkul de mai sus, ar trebui sa porneasca webasto.
Conector B:Pin 1: Semnal de pornire (+12 V)
Modificat de adrian touran
Mda, deci trebuie sa ma apuc de treaba si sa dau bara jos, am sa incerc sa fac asta sambata.
Am sa incerc sa revin cu mai multe detalii dupa....
Merci inca o data pentru detalii.
uite aici daca vrei sa desfaci  http://www.mytouran.de/html/standheizung.html
ai aici suruburile exact unde sunt http://www.mytouran.de/html/stossfanger.html
In primul link , este prezentata inlocuirea panoului de la clima, cu unul ce are buton de pornit webasto (buton rotund centru,jumatatea de jos)
Asteptam cateva poze daca se poate si informatii de la tine!
Important e sa aiba mufa cu 8 pini , si Pinul2:W-bus ,din cate am citit, pe el se face comanda din comp masinii si tot prin el se face si diagnoza.
Deci Pinul2 s-ar putea sa fie ocupat, in cazul asta cred ca se va anula comanda din comp masinii prin deconectarea firului de la Pinul2, iar pornirea se va face manual dintr-un timer sau o telecomanda cu modulul aferent T90/T91 legate la  Pinul2.
Vazusem deja ambele posturi, dar e diferit ceea ce vreau sa fac eu.
Eu vreau sa pun un ceas programator in masina, fara a mai schimba (cel putin in faza incipienta) si modulul de control climatronic. Vreau doar sa pot programa incalzirea auxiliara si sa porneasca singura cu aprox 30 min inainte de a porni motorul, astfel ca motorul sa fie pornit "la cald".
Da, postul de mai sus era informativ,  asteptam vesti bune!
Buna seara
un cod de bujie ptr webasto turan 2004 cel fara telecomanda daca stiti cei care ati schimbat?
Va rog
Am rezolvat bujia nu are cod.ptr tipul nostru de webasto thermo top v.
Bujie nu este separat numai cu tot cu arzator complet (120e)
De unde se pot cumpara senzorii G1 si G2?  ma poate ajuta careva?
Cauta la magazin de piese care aduc piese pe original sau la firmele care se ocupa cu reparații webasto
nu pot fi asa de scumpi
bafta
salutare, am un touran si am webasto pe el, nu am nici o telecomanda, care aveti idee cum functioneaza webasto de pe el???
