Webasto Touran
cristy_snacks
Poate sa-mi spuna si mie cineva ce are un  passat b6 caruia nu-i porneste webasto si la scanare imi da urmatoarele
                Address 18: Aux. Heat       Labels: None
Control Module Part Number: 1K0 815 071 H
  Component and/or Version: Zuheizer        031 1312
           Software Coding: 0000012
            Work Shop Code: WSC 00028 028 00001
                      VCID: 2A51730C85E436E
3 Faults Found:
01406 - No Flame
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 94
                    Mileage: 266650 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:54:14
             Freeze Frame:
                        Start
                    Temperature: 25.0°C
                    Temperature: 18.0°C
01412 - Glow-Plug with Flame Monitoring (Q8)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 94
                    Mileage: 266661 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:11:55
             Freeze Frame:
                        Start
                    Temperature: 57.0°C
                    Temperature: 51.0°C
01409 - Repeated Flame-Out
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 94
                    Mileage: 266661 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:12:03
             Freeze Frame:
                        Malfunction
                    Temperature: 56.0°C
                    Temperature: 51.0°C
  On 12.05.2007 at 12:55, cristy_snacks a scris:
Asa stiam si eu ca trebuia sa iasa ceva...la mine nu iesea asta era problema smile.gif
Buna, fumul de la WEBASTO  aproape ca nu o sa-l vezi daca nu esti atent mai ales daca afara sunt +4 sau 5 grade, moment in care porneste. in schimb are un miros diferit de gazele care ies din esapamentul masini, fumul de la WEBASTO  se vede cu adevarat cand afara sunt sub 0 grade.
Salutare...am si eu o problema cu sistemul asta de incalzire websasto...dupa ce pornesc motorul merge numai 5 minute si se opreste de tot......cine ma poate ajuta,..masina este un sharan.
Fara o scanare sa vezi ce erori ai nu se poate diagnostica ce are
Exista un topic dedicat in aria Sharan,dupa ce ii faci o diagnoza posteaza acolo.
am un sharan 2003,imi poate spune cineva cum si de unde se porneste.multumesc anticipat.
uite colegu aici ai toate informatiile legate de sharan
ma refer la un sirocol,cind lam cumparat nu stiam de existenta lui,miau zis la servis,are telecomanda
Va ma deranjez cu o intrebare...Daca as pune o rezistenta in loc de pompa de recirculare(sa nu simta computeru ca pompa este arsa,sa o simta functionand) care este f scumpa,si nu ma prea intereseaza functionarea webasto cu motorul oprit,singurul scop ar fi incalzirea mai rapida a motorului.Ar aparea ceva erori,ar avea ceva motive sa nu mearga?
Nu stiu eu nu am mai auzit asta. Incearca dar numai daca sti ce faci. Si mie sa ars pompa de recirculare e undeva la 600 ron am gasit. Dar acuma nu o mai cumpar la anul ca deja intr-o luna 2 schimbam cauciucurile de iarna
Eu acuma l-am desfacut sa vad care e treaba cu el,ca un meserias(cel din Baciu daca il stii) mi-a spus sa il arunc la gunoi ca e varza,si culmea ca l-am dat jos l-am alimentat cu,curent motorina si merge de rupe,doar ca pompa aceea de reciruclare e moarta,nu merge,am masurato si e 0...Si cu pompa arsa,sau fara pompa porneste sirocou,sau da eroare si nu porneste deloc?Nu stii pe cineva in Cluj care m-ar putea ajuta cu o scanare cand il pun sus sa vad ce erori apar?
Ba da vezi ca este colegul Moose , Humerg sau Tzaga. Nu stiu daca merge dar daca vrei sa il faci iti dau un nr de telefon din lona parca e baiatul si stiu ca rezolva. Eu la el am sa merg .
pai 6-700 ron e pompa noua pe original. Si sa mergi cu motor cald iarna e chiar recomandat. VW nu a pus webasto ca un lux ci ca o necesitate.
Pai asta ziceam si eu . Baiatul din lona mi-a zis 120€ cu factura si garantie montata de el data jos curatat etc deci 120€ plus manopera cred care nu stiu cat e
ca sa montezi acele bujii incandescente -3 sau 4-plus pompa de recirculare trebuie sa ai si acumulatorul plus instalatia electrica pe masura consumului
salutare tuturor!
am achizitionat si eu un touran 2004 si am vazut ca la motor, are eticheta webasto, asta inseamna ca are, nu?
daca da, oare se poate achizitiona si o telecomanda ulterior?
multumesc
Webasto e dotare standard la Touran. Deci il veti gasi pe fiecare masina.
Ca sa i-i montezi telecomanda te va costa ceva . Din cate am inteles undeva pe la 350 - 500 €. Si eu am pe touran si ma gandeam sa pun cu telecomanda, daca afli pretul si locul unde se poate monta sa postezi sa aflam si noi
  On 10.03.2014 at 7:43, padrefloryn a scris:
salutare tuturor!
multumesc
se poate monta telecomanda impreuna cu modulul telestart . Vezi ca telecomanda gasesti pe mercador la un baiat din Craiova , 200 lei , sau se mai poate pune si telecomanda aftermarket dar numai sa ai pornire pe pinul 1 sau pinul 3 la webasto , daca ai comunicare can va trebui obligatoriu telecomanda si modul telestart .
http://mercador.ro/oferta/telecomenzi-webasto-telestart-t90-si-t91-ID1t07L.html#04926f6c94
Modificat de gabiopel
Telecomanda casesti la Mivarom Alexandia, la 50 lei
Salutare, am o intrebare vis-a-vis de montarea unui ceas programator sau montarea unui kit Telestart pentru incalzire habitaclu in sezonul rece, iar conform zicalei "iarna faci car si vara sanie" m-am hotarat sa demarez operatiunea din timp.
Detin un Touran 2004 iar pe ethicheta de sub capota (langa eticheta cu info AC) am urmatoarele informatii.
https://imageshack.com/i/ba71f4aej
https://imageshack.com/i/604c3d88j
Si cateva imagini cu panoul de la climatronic mai jos.
https://imageshack.com/i/4e3125dcj
https://imageshack.com/i/1ldbd280j
https://imageshack.com/i/3tf8bc9bj
Intrebarea mea este daca stie cineva daca la modulul meu (conf eticheta TT-V) se poate atasa acel programator sau kit-ul Telestart.
Am luat legatura cu cineva care are de vanzare un modul telestart la 150 Euro si imi zicea ca daca "soba" mea e un anume model (am citit din scoarta in scoarta posturile de aici si am inteles ca doar anumite modele permit acest upgrade - cele cu 007) se poate conecta, si ca pot vedea modelul mai precis prin conectarea la un diagnoser. Bara fata inca nu am dat-o jos din lipsa de timp, si dupa cum se vede si in pozele cu modulul de control climatronic nu am nici butonul acela "plita incinsa" cum il denumea un coleg intr-un post mai sus.
Raman recunoscator pentru orice sfat sau indicatie.
Din cauza ca sunt membru nou si nu pot face un topic nou conform instructiunlor din sectiunea Manuale, rog moderatorul sa mute postarea.
Manual in limba engleza complet, inclusiv parte de service - http://webasto-russia.ru/TTV_en_manual.pdf
Modificat de fburaga
Am mai gasit ceva interesant pe un site de prin polonia (http://volkswagen.auto.com.pl/forum/viewtopic.php?t=28035&sid=96ff2425682fe9e6b3e8a98cd855f0d9 - chiar in primul post) niste imagini conform carora se poate programa din bord incalzirea auxiliara. Stie careva ceva despre asta?
ppaarroollaa
Fburaga o mica problema ar fi ca nu prea ai cum sa il si probezi sa vezi daca merge , ca la cat de cald este afara.....
Banui ca din diagnoser se poate da comanda pentru o testare.
