Montare Xenon Aftermarket Pe B6
laur
  On 17.11.2010 at 6:54, qqq a scris:
Sunt curios cum sunt becurile de zicea pronet HIR sau HOD. Ar fi interesante dar sa aiba intensitate ca lumea, peste halogenul obisnuit, culoarea chiar nu prea este interesanta si cred ca pentru a nu "bate la ochi" tot 4300k sunt cele mai bune.
Salut, Sper sa nu fiu "prea tare" :offtopic: si sa nu supar pe nimei, dar pentru cei care nu stiu ce inseamna HIR sau HOD cred ca nu strica aceste precizari pe care le-am gasit scotocind pe net.
H.I.R = Halogen lamp with Infrared Reflective films
H.O.D = High Definition Olive Lamp (presupun ca Olive vine de la forma becului)
Preturile aproximative (luate tot de pe net) sunt intre 50 si 60 ron setul de 2 becuri H7
HOD advantages:
1) Quartz bulbs – Will not explore like glass bulbs.
2) Germany filament – High quality ; will not burn easily.
3) Pressured mixed gas – Reduce heat while increasing brightness to maximum.
4) Ceramic socket – Avoid heat to melt factory's plastic socket & provide sufficient power with thicker wires.
Distance: The lux of HID(xenon) is shorter than the lux of our HOD. Lux determines the distance for comfortable vision. For example: the low-beam/high-beam is 150~200/500~600 meter on HID, but the low-beam/high-beam on our HOD bulbs is 550~650/950~1000meter.
Ability to pass through to rain/fog: HOD's wavelength is larger than HID's, so our HOD has better ability passing through rain/fog & therefore, provide better driving comfort.
H.I.R.
Double the intensity of other bulbs with the same power 55w
Perfect UV cut
Increase efficiency by reflecting coating of infrared
Increase life by fill up with Xenon gas 100%
To complete power up for brightness and color performance the filament must be re-heated by reflected infrared.
Mai jos aveti si o comparatie intre H.I.R. si X-treme power de la philips
Modificat de simplu_dj
apropo cu politia ca iti da amenda, daca ai xenon AM. eu tocmai mi-am montat, si sambata seara ma intorceam de la un botez, m-a oprit politia, si erau vreo 2 echipaje, si au venit la masina si prima data mi-a spus "da-ti faza scurta" si eu i-am spus ca asa am, si el stiti ce a raspuns? a zis "foarte tare!" si nu m-a pus sa desfac ceva, sa ii arat ca am sau nu am xenon, a verificat actele, a fost totul ok, si am plecat mai departe, deci xenonul AM montat nu-ti aduce probleme, mai ales ca vorbim aici despre passat b6 si nu despre bmw sau fiat din 1900 toamna cu faruri care te orbesc, poate pe alea le-ar controla, dar asa la ce masini avem, nu pot sa iti zica nimic pentru ca-si dau seama ca tot ce ai pe masina e din fabrica, e original, samd.
Foarte bine explicata diferenta intre HOD/ HIR si becurile halogen sau HID. O singura adnotare as vrea sa fac insa: HOD-urile nu sunt chiar asa de rezistente pe cat se spune. Eu le-am folosit in jur de 6-7 luni, si s-au ars. Am avut atat crystal blue cat si crystal white. Se vad super bine, numai ca cele asa zise white bat inspre verde - si au o temperatura peste 6500K - problema cu acestea era ca incalzeau destul de mult farul, asa ca le-am mutat pe faza lunga.
Xenonul HID este sfant si nimic nu se compara cu lumina lui. HIR si HOR au aplicat cel film albastru care, pentru ochiul uman face ca lumina sa para alba si doar atat. De fapt luminozitatea este mai mica ca la un halogen normal iar pe asfalt nergu si mai ales ud este crima curata. Iar cei care le compara cu Philips sunt foarte departe de subiect.
Ia lamuriti-ma voi ca nu mai inteleg, am vb cu diversi vanzatori de xenon si toti spun altceva, numai ca sa iau de la ei. Mi s-a ars un bec xenon 6000k (a explodat in tubul lui), balastul este de 55w. Unii zic ca toate becurile sunt la fel, altii nu ca alea de 55 sunt diferite de 35. Eu am vazut si una si alta si nu mi s-a parut nici o diferenta. Ei doar ca au preturi diferite la asa ceva, nu dau doar 1 buc/bec. De unde am cumparat eu nu mai este valabil nr tel. Poate imi dati o sugestie de unde iau un bec de 6000k.
Nu stiu daca gasesti doar un bec, iti pot spune ca eu am cumparat un set cu 100 ron. Desi pretul mi s-a parut suspect de mic vad ca pana acum totul este ok, le am de aprox 2 luni pe masina si merg "non-stop" ( inclusiv ziua )
Modificat de D@ny
  On 18.11.2010 at 15:03, qqq a scris:
nu sunt la fel cele 2 becuri,cel de 55w e facut sa aiba acelasi consum ca si halogenele care vin pe masina iar cel de 35w consuma mai putin,sigur daca pui un bec de 35w pe transformatoare de 55 o sa-l arda de cum il pornesti
Esti sigur de afirmatie? DAca consuma cat halogenul de ce mai e nevoie de anulator de eroare?
Modificat de Al Bundy
Eu am balasturi cipuite la vreo 60-65W si la faza scurta si la proiectoare iar becurile sunt de 35W si se comporta foarte bine. Urmeaza si faza lunga.
nu sunt sigur pentru ca eu nu am probat,cea ce zic mi-au spus alte persoane care au incercat.acum daca m-au mintit si eu va mint pe voi
Becurile sunt la fel, difera doar balastul, uitati-va la caracteristicile tehnice ale celor 2 balast-uri, de 35 si 55w insa la 55w becul nu va mai avea aceeasi durata de viata ca la 35w.
Becurile nu sunt la fel. Am vazut cu ochii mei diferenta fizica intre cel de 35w si 55w. Mi-a aratat baiatul de la care am luat, iar in urma a ceea ce am vazut am optat pentru 55w balast si bec.
Modificat de Caal-Shto
Asta fiindca in rest bulbul si soclul sint standardizate .
Bulbul este mai mare la becul de 55w ;)
  On 19.11.2010 at 19:59, Al Bundy a scris:
Eu stiam ca eroarea apare din cauza ca nu exista filament care sa inchida circuitul si de-aia da eroarea de bec ars, nu din cauza consumului.
Pot sa am consum fara sa a,m filament si nu da eroare.
Am reusit pana la urma sa montez un set de becuri Xenon H7 in locul celor vechi.Dupa lungi cautari am gasit cu soclu metalic.Calitatea acestora este mult sub a celor vechi.Cel putin lumina dispersata e undeva la 70 % intensitate fata de cele vechi care aveau deja 3 ani.Acum am o mica problema.Unul dintre becuri blitz-uieste cand il pornesc de 2-3 ori pana ajunge la intensitate maxima.Aveti idee de la ce ?
Cam ciudat sa aiba asa ceva cand este nou,nu? Are cineva idee ce diferenta fizica este intre becurile xenon de 55W si cele de 35?
Modificat de TheOne06
ne este nici o diferenta fizica, eu am avut initial balasturi de 35w, dupa care am montat de 55w, becul ramanand acelasi, dar luminind mai puternic, si de aprox. 1 an si 6 luni merg fara probleme
Am si eu o mica problema.Vreau sa mut kitul xenon de pe proiectoare pe faza lunga.Problema este ca daca dau flash mi se sting si imi dau eroare.Are cineva idee ce trebuie sa le pun ca sa nu se mai stinga?
Anulator de eroare avea,asta stiam si eu ca trebuie sa aibe.Nu de la anulator e problema.
Ia incearca sa lasi halogenul pe dreapta si pe stanga pune xenon si 2 becuri de 21W toate in paralel sa vezi cum se comporta.
