Keyless
dintzauru
Keyless Access and Kessy are the automatic locking and starting systems from Volkswagen. They offer the driver maximum convenience: he merely has to carry the key on his person but not necessarily in his hand.
The most important components of keyless systems are the ID sender in the car key, the electronic ignition lock, the starter button, the control unit, the electric steering column lock and the aerials and sensors in the door handles.
The key is identified via proximity sensors in the door handles and a radio pulse generator in the key housing as soon as the driver is within approximately 1.50 metres of the car. The vehicle is automatically unlocked as soon as the door handle (or boot lid) is actuated. The steering and ignition can also be released completely electronically and without use of the key before setting out. Provided the driver has the key on his person while inside the car, the engine can be started simply by pressing the starter button down fully. But the car key can also be used like a conventional key to operate the central locking . When leaving the car, it suffices to press the small locking button on the door handles in order to lock the vehicle.
Adica nu ai unde sa bagi cheia ca sa pornesti masina, o vei porni din buton:
http://www.youtube.com/watch?v=FxM-fN0xLAE
 exista si dotare optionala Kessy inclusiv buton pornire. Probabil ca standard se refera doar la accesul in masina fara buton de pornire ceea ce face cumva useless dotarea standard pentru ca oricum trebuie sa scoti cheia ca sa pornesti masina
Modificat de Serban F
Atunci nu inteleg. Standard pe highline scrie 2 chei keyless si nu kessy. Deci banuiesc ca nu e si cu buton de pornire
 B6/Passat CC - nu are buton separat pentru pornire - are Kessy - care sta in contact - pe ea se apasa pt pornire/oprire - nu are buton separat
Salut !! Am si eu pe masina aceasta optiune numai ca la ultima scanare a masinii a aparut asa
Address 46: Central Conv.        Labels: 3C0-959-799-46.clb
   Part No SW: 3C0 959 799     HW: 3C0 959 799
   Component:    KESSY PQ46   067 0336
   Revision: 00067000    Serial number: VWZCZ000000000
   Coding: 00910A0801C60E76380494157008CFCE70390003242480
   Shop #: WSC 64998 123 181942
   VCID: F6E9C6C58172D491C57-80A3
   Subsystem 1 - Part No: 1K0 951 605 B
   Component: LIN BACKUP HORN H07 7001
   Subsystem 2 - Part No: 3C0 951 171 A
   Component: Neigungssensor  002 0508
   Subsystem 3 - Part No: 3C0 951 171 A
   Component: Innenraumueberw.002 0508
2 Faults Found:
00190 - Driver's Door Handle Touch Sensor (G415)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 214
                    Mileage: 171052 km
                    Time Indication: 0
                    Date: 2015.01.06
                    Time: 15:35:29
00192 - Rear Left Door Handle Touch Sensor (G417)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 203
                    Mileage: 171052 km
                    Time Indication: 0
                    Date: 2015.01.06
                    Time: 15:35:29
stie cineva de unde sa iau senzorii ? Va multumesc!
   Coding: 08910A0801C60E763804941570084F0E70380003242480
   Shop #: WSC 00028 028 00001
   VCID: F6E3805A8167B0AE3EF-80A3
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
5 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 148
                    Mileage: 193970 km
                    Time Indication: 0
                    Date: 2015.04.18
                    Time: 10:48:20
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 148
                    Mileage: 193970 km
                    Time Indication: 0
                    Date: 2015.04.18
                    Time: 10:48:20
00191 - Passenger's Door Handle Touch Sensor (G416)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 148
                    Mileage: 193970 km
                    Time Indication: 0
                    Date: 2015.04.18
                    Time: 10:48:20
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 148
                    Mileage: 193970 km
                    Time Indication: 0
                    Date: 2015.04.18
                    Time: 10:48:20
00193 - Rear Right Door Handle Touch Sensor (G418)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 148
                    Mileage: 193970 km
                    Time Indication: 0
                    Date: 2015.04.18
                    Time: 10:48:21
nu stiu exact de cand e cu problema asta ca asa am luat masina, dar as vrea sa o fac functionala.
portbagajul merge, doar usile nu...
de unde sa incep ?
unde gasesc antena R134?
Mersi.
Stie careva pe unde trec firele de la senzori manere si atena r134 si unde gasesc modulul central convenience ?
Mulțumesc anticipat.
Am comandat si eu un maner dar nebunii astia de la dezmem. mereu gresesc codul, din cate mi-a spus baiatul care sa ocupat antena este in usa stanga. Su la mine se comporta identic numai porbagajul se deschide manerele sunt din pacate inseriate ca si senzorii de parcare la mine este dus senzorul de pe manerul stanga fata.
Un maner nou este cam 700 la dez este 120 daca ai pe cineva sa ti le aduca din Germania este mai bine.
  • 7 months later...
Daca dau jos modulul kessy pt reparat, masina merge si fara el ? Sau e nevoie neaparat de el pt functionare ? Stiu ca e legat de imobilizator parca ...
Ok, deci am aflat ca modulul kessy si comfort e 1 si acelasi modul. 3C0 959 799 D
Am banuiala ca problema e in modul din cate am citit pe net. Adica exista niste rezistente fuzibile care se ard si ar trebui inlocuite, de asta m-am gandit sa il dau jos si eventual sa le inlocuiesc.
Problema este ca daca dau jos modulul, pana nu il pun la loc masina nu va porni, plus nu il pot inlocui cu un alt modul pentru ca ar trebui recodat partea de imobilizator si inrolez cheile in noul modul. Pentru asta e nevoie de alt cablu decit cel Vag-com care il am, care sa citeasca datele din modulul vechi ca sa se poata recoda modulul nou....
Modulul se afla in spatele torpedoului...
A mai schimbat cineva module de comfort mai ales care au si kessy ?
Nu prea cred ca toate manerele sa fie defecte. Plus nici nu am cum sa testez manerele si daca le dau jos. Sa ma apuc sa cumpar manere fara sa stiu 100% ca sunt defecte ...e cam aiurea.
Ceva idei ?
da, kessy este in modulul confort - asa ai cumparat masina, s-a stricat, etc ?... da mai multe detalii.
Da asa am luat masina. As vrea sa il repar.
Merge partea de pornire cu cheia de plastic. Merge portbagajul. Doar manerele de la usi nu merg, ce apare si in log.
Acum.. cand am luat masina avea 5 errori la kessy, 1 la antena maner sofer si cei 4 senzori.
Am decinectat mamerul șofer si a disparut erroarea cu antena, dar restul au ramas. Ma gandesc ca senzorul e ok din moment ce la fel zice si fara mufa pusa inseamna ca e cablajul sau modulul.
da, una dintre ele....
In final am aflat ce era...
toate 4 manerele erau defecte.
Pentru cei care mai au probleme...
la montarea unui nou maner, el nu va fi activ decit dupa ce s-a sters erorile si s-a inchis 1 data din cheie masina. Dupa inchiderea masini daca manerele sunt ok, sistemul va fi functional.
Atentie! In momentul in care 1 maner are o problema, nu mai merge nici unul ! Toate 4 trebuie sa fie functionale.
Daca aveti deschis VAG-COM in modulul de confort si e afisata erroare la vreun maner si inlocuiti manerul, nu se va sterge eroarea indiferent de cite ori incercati pana nu iesiti din modul si intrati din nou.... asta pt ca eu am tot dat stergere si nu disparea eroarea si am crezut ca si manerul nou e defect...pana la urma am aflat ca nu e defect...
Daca aveti eroare cu instalare incorecta la manere, inseamna ca nu e la locul potrivit. Fiecare maner are locatia lui. Stg fata, Stg spate, etc.... nu se pot schimba intre ele chiar daca ele fizic se potrivesc.
Marcajul
  • HL - Spate Stanga
  • VL - Fata Stanga
  • HR - Spate Dreapta
  • VR - Fata Dreapta
Marcajele sunt langa cod, s-ar putea sa nu se vada pentru ca se sterg foarte usor prin atingere.
Merge de pe orice masina Passat > 2006 indiferent de model inclusiv CC, deci B6, B7, Passat CC, CC oricare din acestea care au system kessy.
Daca mai aveti intrebari ...incerc sa raspund.
O seara buna
mai rar sa le gasesti pe toate defecte - cate unul... am gasit de multe ori.
stiu...
Poate nu s-au defectat toate odata... eu asa am luat masina cu toate 4 "no signal/communication" + inca 1 erroare. Si eu am crezut la fel...
Multumiri colegului mvr care m-a incurajat si ajutat pentru a lua 4 manere de test.
salutare .
am o intrebare daca cumva stiti :
am VW CC 2012 , dsg automat , 2 l TDI .( nu am butonul de keyless go si nici keyless entry )
Tinand cont ca e model cu facelift , e posibil ca acei senzori de keyless sa ii aiba incorporati in usi ?
un sistem keyless entry + GO  cam la ce pret s-ar estima ?
trebuie schimbata si cheia ? (sau doar cip-ul din cheie )
cam cat dureaza instalarea ? ( ca si instalare presupune deranj mare : adica sa imi dezmembreze o gramada din masina ( ca la ce service-uri si reprezentante avem :)) ? )
multumesc
Nu sunt incorporati.
Trebuie alta cheie.
Instalarea presupune deranj mare.
Costuri, vezi aici:
Trebuie alta cheie.
Costuri, vezi aici:
mersi ,
nici nu stiu ce sa aleg , varianta de genu keyless sau sa optez ca buget aceiasi bani pt varianta viper smartstart , cu pornire din telefon si oprire si deschidere dar presupune sa bag cheia in contact :(
Daca alegi varianta Kessy, o parte din piese nu poti decit print reperezentata sa le rezolvi. Modulul comfort care contine si partea de kessy din cate stiu nu se poate decit in reprezentanta... chiar daca cumperi modulul din dezmembrari, va trebui sa treci pe la reprezentanta sa iti cupleze cheile.
Daca nu vrei sa faci totul deodata... se poate si partial. De exemplu iti montenzi antenele interioare si modulul kessy ca sa nu trebuiasca sa scoti cheia din buzunar cand vrei sa pornesti masina. Ulterior poti monta si manerele exterioare, si antenele din portbagaj+bara spate ca sa se descuie masina fara sa apesi buton.
Nu stiu varianta cu viper smartstart cum functioneaza pt ca nu am avut de a face cu ea.
Modulul comfort cu kessy nu e scump in dezmembrari... nu stiu daca cheia care o ai nu merge si la sisteme kessy. Cheile au deja incorprat radiotransmisie... doar ca la masinile fara kessy nu exista acele antene si modulul care sa comande deschidere/acces pornire.
Eu personal as merge pe varianta kessy. Din tot sistemul cel mai mult ajuta (ordinea importantei functiilor) pornirea motorului, portbagaj, deschidere usi si cel din urma care nu mi se pare foarte fiabil si eficient inchiderea din manare. Inchiderea nu merge asa de bine pe cat ma asteptam. De exemplu daca stau mai catre portbagaj si ating manerul de la o usa spate, nu merge. Trebuie sa ma dau mai in dreptul usii ca sa simta cheia (poate sunt slabe bateriile...).
Deschiderea in schimb e destul de bine pusa la punct. Trebuie sa pui cel putin 3 degete pe interiorul manerului ca sa functioneze, ce a ce oricum nu e problema ca 99% asa deschid usa. Ulterior mi-am dat seama de ce e asa facut... pt ca daca vrei sa verifici inchiderea masini si esti cu cheia in apropiere, nu ai avea cum sa o faci daca merge la cea mai mica atingere. Asa tragi cu 1 deget de maner si poti verifica daca chiar s-a incuiat.
La mine se deschide si daca pun 1 deget pe interiorul manerului.
Nu poti sa imperechezi un modul comfort de kessy SH la reprezentanta cu ODIS, de aceea trebuie cumparat unul nou. (are deja seria de sasiu scrisa in el si ODIS nu stie sa o modifice).
E nevoie de alta cheie pentru kessy, nu o poate folosi pe cea veche.
Salutare baieti! :cheers:
Se poate instala butonul de keyless de pe passat B7, pe passat B6???
Este mult mai ok ca nu mai trebuie sa tragi de cheie si cred ca scapam de inconvenientele mentionate de colegi mai sus.
A facut cnv acest retrofit sau este imposibil din cauza centralei? -_-
Va salut baieti,
Am si eu o problema cu una dintre chei la passat b7, mai exact nu functioneaza de fiecare data keyless entry, nu o recunoaste, cateodata nici nu vrea sa porneasca cu toate ca introduc cheia in contact, chiar si din butoane daca apas se deschide greu.
Am inlocuit bateria la cheie... fara nici un rezultat.
Cealaltă cheie functioneaza perfect dar fiind 2 utilizatori ai masinii as vrea sa fac cumva sa o fac functionala pt a nu ma trezi ca ramane unul din noi cu ochii in soare.
Stie cineva daca se poate repara cheia sau fac un drum la reprezentanta si ma scutur de 600 ron am vazut mai sus si cumpar o cheie noua?
