Sonda lambda
lbanias
cele mai groase doua fire sunt de la incalzire. (si de aceeasi culoare)
masurandu`le cu un multimetru trebuie sa ai aproximativ 6ohmi, la tine in mod sigur s`a intrerupt circuitul de incalzire ceea ce necesita alta sonda
salut o scanare la engine apar urmatoarele?
Address 01: Engine       Labels: 036-906-034-APE.LBL
   Controller: 036 906 032 P
   Component: ME7.5.10            3547
   Coding: 00031
   Shop #: WSC 31414
   VCID: 1D4D5A7784A9
5 Faults Found:
16525 -  Oxygen (Lambda) Sensor B1 S2; Heating Circuit: Malfunction
            P0141 - 35-00 -   -
16524 - Shareware Version. To Decode all DTCs
            P0140 - 35-00 - Please Register/Activate
16705 - Shareware Version. To Decode all DTCs
            P0321 - 35-10 - Please Register/Activate - Intermittent
17978 -  Engine Start Blocked by Immobilizer
            P1570 - 35-10 -   - - Intermittent
17574 - Shareware Version. To Decode all DTCs
            P1166 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0000 0001
si
Address 17: Instruments       Labels: 1J0-920-xx5-17.LBL
   Controller: 1J0 920 805 X
   Component: KOMBI+WEGFAHRS. BOO V20
   Coding: 00111
   Shop #: WSC 00665
   VCID: 3B09B4EF3A7D
   Ident.-Nr. WEGFAHRS.:VWZ6Z0A3730363
01176 -  Key
            07-10 -  Signal too Low - Intermittent
T8p !@5ss=MsoNormal>            P0140 - 35-00 - Please Register/Activate
a u fost sterse penele momentan sunt clear dar sigur vor aparea la loc
rog un coleg cu  ,,experienta,, ce este de facut ?
multam si spor
Din cate am citit pe aici nu sunt asa lamurit legat de sondele astea tampite:
Am urmatoarele erori:
VAG-COM Version: Release  311.2-N
Chassis Type: 1U - Skoda Octavia
Scan: 01,02,03,08,15,17,19,35,46,56
Address 01     -------------------------------------------------------
   Controller: 06A 906 033 DM
   Component: SIMOS33 1.6l 2V 00HS7290
   Coding: 00031
   Shop #: WSC 73430
   TMBDX41U978873442     SKZ7Z0G4096962
3 Faults Found:
16523 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
            P0139 - 35-10 - - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
            P0130 - 35-10 - - - Intermittent
16554 - Fuel Trim: Malfunction: Bank 1
            P0170 - 35-10 - - - Intermittent
Readiness: 0000 0000
Sonda B1 S1 este prima asa-i?
La asta imi tot da eroare, o sterg apoi dupa o perioada apare iar dar toate astea fara sa mi se aprinda martorul "check engine"
In schimb B1 S2 care inteleg de pe aici ca este sonda 2, am depistat eroarea ei dupa ce mi s-a aprins martorul la bord.
Eroarea 16554 - Fuel Trim: Malfunction: Bank 1
Are legatura cu cele doua sonde?
Si am inteles ca sondele mele au 4 fire. Care din ele trebuie sa le masor sa verific daca e buba pe ele?
Modificat de Helloween
nu prea ai ce sa masori
B1S1 sonda lambda inainte de catalizator
B1S2 sonda lambda dupa catalizator
avand in vedere eroarea ta "Malfunction in Circuit" iti trebuie sonda noua pentru ca semnalul pe care il scoate este mult inafara intervalului admis
 0.2 volti (amestec sarac) to 0.8 volts (amestec bogat)
doar sonda dinainte de catalizator este f importanta pentru ca prin ceea ce citeste ea se regleaza amestecul - altfel iti consuma mult si merge prost
sonda de dupa catalizator doar monitorizeaza eficienta catalizatorului
Multumesc frumos de promptitudine CrackerX!
Si care este echiparea originala pentru sonda 1? Sau care ar fi una mai de calitate? Adica daca tot dau un ban macar sa stiu o treaba... sa nu ma trezesc cum am mai citit pe aici ca dupa 6-6 luni apare iar eroare la lamda1... Rog fumos!
Serie caroserie este: TMBDX41U978873442
de calitate este BOSCH (dar ma feresc de asa ceva pt ca poate fi fake) si DENSO
pretul este intre 400 si 600 ron
ai lambda cu 4 fire?2albe unul gri si unul negru?
Am inteles ca e cu 5 fire cea din inaintea catalizatorului. (negru, gri, rosu, galben, alb)
Pai si cum sa-mi dau seama daca e originala Bosch?
Salut baieti,imi puteti spune daca sonda lambda functioneaza cum trebuie,pe vag-com zice ca trebuie sa fie intre 20 si 70%,la mine este 89,8%...masina 2,0 tdi bkp.Sper ca am facut test unde trebuie.
lambda.txt
baieti am si eu o problema ...acum 2 luni m-ia iesit fum din bobina 3, (s-a topit chiar in capul bobinei  unde intra firele de alimentare ), am schimbat-o , si deatunci nu a mai pornit . am schimbat si baterie , am pus si testarul si ia dat eroare la sonda 2 , si la cilindrul 3 ,. sau sters erorile , s-a incercat iar pornirea masini si tot nu merge . si am zis sa cumpar sonda 2 , daca nu e de la ea , sa cumpar sonda 1 ... a mai patin cineva asa ceva ???sau cunoaste cineva cauza ??
eroare pe sonda a doua este din cauza ca a fost rateu/benzina nearsa la pistonul trei.trebuie verificat daca la bobina pistonului in cauza vine semnal/tensiune sau daca bujia mai este buna.
Modificat de R Z F
nu mai vine semnal / tensiune la niciuna dintre cele 4 bobine , bateria e buna ( am schimbat-o cu a altuia sa fiu sigur ca nu e bateria ) pompa de benzina functioneaza , electromotorul invarte , bordul masini se aprinde ....ideea e de ce a trosnit bobina aia , s-a topit pana a ajuns la cadrul ala de metal aproape ..testarul a dat sonda 2 , si pistonul 3 sau cilindrul 3
verifica sigurantele
17604 - oxygen (lambda) sensor heater circuit b1 s1 electrical malfunction P1169 - e o skoda fabia de 1.4 16V, i-am schimbat prima sonda cu una bosch (nu universala), eroare persista, dupa 10 sec de pornire a motorului, am verificat firele si au continuitate, sigurantele sunt ok...ce ma sfatuiti sa mai fac ?
ghitaTSI
1.
sonda are 4 fire ?
2.vezi ca exista un releu din cate stiu eu care este comandat de catre ecu si alimenteaza incalzirea sondei lambda
Modificat de CrackerX
Daca ai verificat firele de la mufa sondei pana la mufa ECU (sa nu fie intrerupte sau in scurt) verifica/curata contactele din mufe apoi verifica si rezistenta de incalzire a sondei Bosch si daca este buna nu mai ramane de verificat decat ECU.
discdisc verifica ECU. Modificat de ionel.d.2007
@cracker X - E cu 5 fire - unde e releul si cum il pot verifica ? eu stiu doar de siguranta
cum verific aceasta rezistenta ? pe ce pini si ce trebuie sa am continuitate ???
Si la un motor BFQ cu urmatoarele erori:
3 Faults Found:
16825 - EVAP Emission Control Sys: Incorrect Flow
            P0441 - 35-10 - - - Intermittent
Cum pot verifica cu vag-comul?
Prima eraore apare frecvent. O sterg si reapare. Inteleg din asta ca trebuie schimbata sonda S1?
Imi puteti intrerpreta erorile de mai sus,  va rog?
curata mufele la sonde desi nu cred ca rezolvi nimic, prima e importanta de schimbat, ea face amestecul
la eroarea despre EVAP problema de obicei vine de la electrovalva N80, se poate spala praful de carbune din ea, exista deja topic-uri
2 Faults Found
16517 - Oxygen (Lambda) Sensor B1 S1
            P0133 - 35-10 - Response too Slow - Intermittent
16524 - Oxygen (Lambda) Sensor B1 S2
            P0140 - 35-10 - No Activity - Intermittent
Astazi mi-au aparut pe la 3500rpm. Apoi am sters erorile si nu au mai apaurt deocamdata.. Sa fie semn ca trebuie sa inlocuiesc vreo sonda?
Parerea mea: schimba sonda lambda B1S1 (sonda dinainte de kat) si verifica/curata contactele (eventual testeaza/schimba) sonda B1S2 (sonda dupa kat).
- Long Term Fuel Trim Additive Air; Bank 1; Range 2
            P1166 - 35-10 - System too Rich - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1
            P0134 - 35-10 - No Activity - Intermittent
o parere va rog?
Verifica cu atentie sa nu-ti traga aer fals pe undeva (furtune de vacum,,clapeta,etc); Verifica/curata/testeaza  circuitele/contactele sondei lambda B1S1,Daca este necesar schimba sonda B1S1 (sonda dinainte de kat).
Dupa ce ai efectuat cele de mai sus sterge erorile dai o tura cu masina si vezi care mai apar.
