Computer bord
cris dea
Eu mi-am luat altu high , marti imi vine si il montez, sper sa mearga !
mai mult ca sigur o sa mearga.
Buna seara. Am cumparat recent un golf 5 si observ ca dupa ce nu mai merg cu masina, mi se reseteaza consumul mediu, nici nu am a doua memorie pe calculator. Computer-ul de bord este maxidot. Credeti ca cineva s-a jucat cu vag com ?
EDIT: Am rezolvat..eram eu prea noob... :))
Modificat de Empire
nu... dar invata sa folosesti BC-ul... :winter:  ai buton sa treci ci BC1 (cel care se reseteaza), in BC2 - cel care stocheaza informatiile pe termen lung. :icon_thumleft:
Buna seara .De curand am schimbat ceasurile de la minidot la maxidot (golf 5) totul pare ok m-ai putim faptul cu meniul de setari dim mfa tin apasat pe butonul de la maneta de la stergatoare si nu intra in acel meniu daca stiti care ar fi cauza .Atasez si o scanare
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 JG    HW: 03G 906 021 AB
   Component: R4 2,0L EDC G000SG  9392
   Revision: --H07---    Serial number: VWZ7Z0G8129169
   Coding: 0000072
   Shop #: WSC 64271 142 83004
   VCID: 6DDBD76D748ADF1
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0023170
   Shop #: WSC 00028 028 00001
   VCID: 73EFC11512AE091
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BN    HW: 1K0 907 044 BN
   Component: ClimatronicPQ35 110 1010
   Revision: 00110021    Serial number: 00000000000000
   Shop #: WSC 131071 1023 2097151
   VCID: 74EDC20917A00E9
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006966231
   Coding: E78B8F2700041517471400001400000000097F075C0001
   VCID: 6CDDDA694F90D69
   Subsystem 1 - Part No: 1K1 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 100407 021  0501
   Coding: 00038805
   Shop #: WSC 00028
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     130407 020  0105
   Coding: 00208933
   Shop #: WSC 00028
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 37 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD15K41.
   Coding: 0013111
   VCID: 3D7B272D646A8F1
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000042
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K0 920 874 B    HW: 1K0 920 874 B
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWZ7Z0G8129169
   Coding: 0007103
   Shop #: WSC 12345 123 12345
   VCID: 2C5D1A698F10169
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 040407F1001681
   Coding: 7D3F074007000002
   VCID: 2F670D65BE066D1
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1216
   Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         005 0985
   Coding: 0000180
   VCID: 3973333D7042B31
00096 - Drivers Door Central Locking (Safe) Motor (V161)
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
   VCID: 346D020957204E9
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 989002005103487F2D0484056008CF03E0FC00
   VCID: 830F11D5C20EB91
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000436
   VCID: 3A712C317544B89
Address 55: Xenon Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000003
   VCID: F4ED420997A08E9
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 T
   Component: Radio GR0       020 0023
   Revision: 0002006S    Serial number: VWZ2Z2G3232881
   Coding: 0040402
   VCID: 377735054656A51
2 Faults Found:
00857 - CD Changer Unit (R41)
            004 - No Signal/Communication
00856 - Radio Antenna
            011 - Open Circuit
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         005 0913
   Coding: 0000144
   Shop #: WSC 00028 028 1012545
   VCID: 387536394B48AA9
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
   VCID: 2D5B176DB40A1F1
End   ---------------------------------------------------------------------
BT - parca este pe 19 Bytes. Intra la 46-convenienta, la long coding si bifeaza optiunea pentru afisare.
daca nu, scoate si borna pt cateva minute sa vedem ce zice.
Nu poti accesa deloc sau nu vezi meniul Lights & Vision si Convenience?
Nu pot intra in meniul acela tinand tasta apasata ,consumul si celelalte functi sunt ok.
@mfm71-nu o sa poti intra in convenience sau audio decat cu volan multifunctional.Probat pe masina mea...am scos calculatorul coloana higline si am pus un midline.L-am codat si totul e ok,nu am erori dar a disparut convenience si audio.
@Hayate-el nu are erori pe maneta ca cel din postul indicat...acolo era problema de maneta.
Deci...volan cu butonase scrie pe tine.
La mine merg functiile (consum instant,mediu cata motorina mai am etc eu nu pot intra in acel meniu in care se pot face anumite setari.
Pt spido Mai am un passat b6 fara comenzi pe volan si acel meniu functioneaza perfect.
Da...se pare ca alta e cauza...am mai studiat problema.Cred ca e de vina calc coloana.Am avut un midline AF pe masina-totul functiona ok.Apoi am schimbat cu un BG highline-totul ok,inclusiv comenzi volan.Acum am un BC midline-si nu mai merge decat meniul MFA.Toate codate corect,fara erori.Desi BC e generatie mai noua decat AF-ul initial...
Modificat de spido
masina lui este 2007 - deci. Garantat din ceasuri nu este, modulul confort pe 19bytes, maneta e ok - ramane doar calculatorul de coloana.
normal ca sunt fara erori, atata timp cat este vorba doar de o problema de comunicatie - cel mai probabil.
trebuie sa vedem - o sa incercam alta combinatie.... sunt sigur ca il facem.
Exact ce ziceam mai sus...deci nu toate midline au acces la toate meniurile...nasoala treaba.
verificam si vedem daca este asa - daca nu pot accesa meniul suplimentar - nu sunt multe in acesta situatie....
Am verificat eu pe masina mea...cu AF-ul mergea cu BG-ul da,iar acum cu BC-nu merge Convenience/de Audio nici nu vb...asta merge pe highline.
Af-ul observ ca are 5 mufe bt-ul are 4 deci la mine nu cred ca merge
Nu stiu despre ce bt vorbesti tu...daca e vb de 1k0953549BT-asta e lowline.
1k0959433bt
Scuze tu ziceai de calculator coloana eu ma gandeam la cel de confort.
Salutare. Ca si cei dinaintea mea, as fi interesat de adaugarea computerului de bord, insotit de ceasuri, dar nu stiu exact ce ar trebui sa schimb, vreau sa fac un mini-total, pentru a decide daca merita sau nu investitia.
Am datele urmatoare despre masina, sper sa fie de folos, am vazut ca unii colegi au dat niste estimari, sau au mentionat ce anume trebuie schimbat pentru aceasta operatiune. Va multumesc!
WVWZZZ1KZ9W053262.pdf
Modificat de tzeus
daca masina are tempomat, iti mai trebuie maneta de stergatoare cu butoane de BC plus alte ceasuri.
daca nu are tempomat, trebuie inlocuit si calculatorul de coloana.
pretul variaza in functie de costul pieselor SH - calculator de coloana, in jurul la 200 lei, maneta 100 lei, ceasuri - intre 300 si 600 lei, in functie de varianta minisot/maxidot, starea acestora, etc.
Nu are tempomat. Deci piese in valoare de 800-1000 de lei(Daca tot schimb, as trece pe maxidot). Manopera e scumpa? E nevoie de compatibilitate? Am citit ca ceasurile de dupa 2006 parca, nu sunt mereu compatibile si pot aparea probleme legate de ele. Ma pot asigura cumva ca nu o sa intampin probleme de acest gen?
depinde de cel care le monteaza - daca stie, le poate adapta si pe cele dupa 2006.
manopera... acum, depinde de la om/atelier... etc....
Salut baieti. La vw golf 5 climatronic nu am functia de DUAL pe butonul din mijloc si e destul de enervant ca trebuie sa reglez temperatura si in stanga si in dreapta. Se poate activa cumva functia DUAL ? Am maxidot.
Modificat de Empire
