Electronic Parking Brake (Frana De Mana) si Auto-Hold
Mama Omide
salut Florin uite scanarea
uite si pe 53 gresisem postarea
Thursday,30,July,2015,20:25:18:62939
VCDS Version: Release 11.11.6 (x64)
Data version: 20121223
                Address 53: Parking Brake       Labels: 5N0-907-801.clb
Control Module Part Number: 3C8 907 801 A    HW: 3C8 907 801 A
  Component and/or Version: J540 EPB3  VW-10498 0003
           Software Coding: 0000057
            Work Shop Code: WSC 05311 000 00000
                      VCID: 285F1E2B9B06C05848B
4 Faults Found:
01087 - Basic Setting Not Performed
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Status: 11110000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 0.00 V
                    Count: 43
                    Hex Value: 0x4040
                    Hex Value: 0x00A2
                    Hex Value: 0x1010
00003 - Control Module
            014 - Defective - MIL ON
             Freeze Frame:
                    Fault Status: 11101110
                    Fault Priority: 2
                    Fault Frequency: 34
                    Reset counter: 253
                    Mileage: 164135 km
                    Time Indication: 0
                    Date: 2011.14.16
                    Time: 15:42:31
             Freeze Frame:
                    Voltage: 12.10 V
                    Count: 46
                    Speed: 0.0 km/h
                    Hex Value: 0x1251
                    Hex Value: 0x0021
                    Hex Value: 0x1010
01542 - Yaw Rate Sensor (G202)
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 34
                    Reset counter: 253
                    Mileage: 164135 km
                    Time Indication: 0
                    Date: 2011.14.16
                    Time: 15:42:31
             Freeze Frame:
                    Voltage: 12.10 V
                    Count: 92
                    Speed: 0.0 km/h
                    Hex Value: 0x1251
                    Hex Value: 0x0021
                    Hex Value: 0x1010
01279 - Longitudinal Acceleration Sensor (G251)
            005 - No or Incorrect Basic Setting / Adaptation - MIL ON
             Freeze Frame:
                    Fault Status: 11110101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 0.00 V
                    Count: 101
                    Hex Value: 0x4040
                    Hex Value: 0x00A2
                    Hex Value: 0x1010
salut !
asa cum am vb si la telefon, daca nu te mai lasa sa faci setarile de baza, atunci pare sa ai probleme la modulul franei de mana - se rezolva prin inlocuirea modulului, dupa care se refac setarile de baza la senzorii de mai sus.
FA o diagnoza si vezi unde este problema: la buton sau la motorase.
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 M    HW: 3C0 614 095 M
   Component: ESP 440 C2     H015 0001
   Revision:  H015       Serial number: 0657510117
   Coding: 0013602
   Shop #: WSC 00499 211 93964
   VCID: 2C57E23B8FFEEC7E18B-8079
2 Faults Found:
02840 - Wake-Up Line from Central Convenience Module
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 9
                    Time Indication: 0
00650 - Clutch Pedal Switch (F36)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 174787 km
                    Time Indication: 0
                    Date: 2015.07.26
                    Time: 13:30:58
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3C0 959 433     HW: 3C0 959 433
   Component:    IMMO         038 0347
   Revision: 00038000    Serial number: VWZCZ000000000
   Shop #: WSC 131071 1023 2097151
   VCID: E7DDDD17D6988F26B59-80B2
   Subsystem 1 - Part No: 3C0 905 861 A
   Component:    ELV          021 0350
   3C0905861A     ELV          021 0350
3 Faults Found:
02823 - Requirements for Locking the Steering Column Lock not met
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 7
                    Fault Frequency: 2
                    Reset counter: 9
                    Mileage: 0 km
                    Time Indication: 0
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 40
                    Time Indication: 0
02815 - Steering Column Lock; Supply Voltage for Locking Motor
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 174783 km
                    Time Indication: 0
                    Date: 2015.07.26
                    Time: 12:56:10
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 G    HW: 3C0 907 801 G
   Component: EPB  VD8HC005   013 0005
   Revision:   013
   Coding: 0000011
   VCID: 264310139112D62ECEF-8073
2 Faults Found:
02443 - Control Head
            008 - Implausible Signal - MIL ON
             Freeze Frame:
                    Fault Status: 11101000
                    Fault Priority: 2
                    Fault Frequency: 41
                    Reset counter: 215
                    Mileage: 174920 km
                    Time Indication: 0
                    Date: 2015.07.29
                    Time: 19:56:16
             Freeze Frame:
                    Voltage: 14.18 V
                    Count: 46
            012 - Electrical Fault in Circuit - MIL ON
             Freeze Frame:
                    Fault Status: 11101100
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 213
                    Mileage: 174920 km
                    Time Indication: 0
                    Date: 2015.07.29
                    Time: 11:58:08
             Freeze Frame:
                    Voltage: 14.18 V
                    Count: 44
Sunt in ceata complet  :tuktuk: .
schimba butonul franei de mana, sterge erorile si vedem daca si ce iti mai ramane
salut! am schimbat calc franei de mana intr-unul cu codul 3C8 907 801 B al meu era cu A  si dupa ce l am pus pe masina mi-au aparut erorile astea :
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.075 0502
   Revision: 1AH02240    Serial number: 00081910039202
   Coding: 0000258
   Shop #: WSC 05311 000 00000
   VCID: 3979CB6F70AC49D0275
02546 - Steering Limit Stop
             Freeze Frame:
                    Fault Status: 11100101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 164796 km
                    Time Indication: 0
                    Date: 2011.14.24
                    Time: 11:55:01
             Freeze Frame:
                        Term 15 On
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    (no units): 4.0
                    Voltage: 12.20 V
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 B
   Component: J540 EPB3  VW-10498 0003
   Revision:   010       Serial number: 00000000001384
   Coding: 0000057
   Shop #: WSC 00123 001 00012
2 Faults Found:
02434 - Supply Voltage for Control Module for Left Channel
            009 - Open or Short to Ground - MIL ON
             Freeze Frame:
                    Fault Status: 11101001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 164796 km
                    Time Indication: 0
                    Date: 2011.14.24
                    Time: 11:53:57
             Freeze Frame:
                    Voltage: 11.80 V
                    Count: 16
                    Speed: 0.0 km/h
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 3
                    Mileage: 164715 km
                    Time Indication: 0
                    Date: 2011.14.23
                    Time: 12:11:58
             Freeze Frame:
                    Voltage: 12.00 V
                    Count: 43
                    Speed: 0.0 km/h
                    Hex Value: 0x1250
                    Hex Value: 0x0001
                    Hex Value: 0x0101
am verificat frana de mana si nu mi recunoaste motorasul de pe stanga...acelasi lucru l-am intampinat acum jumatate de an si la celalat calculator care l -am avut...am dat roata jos am verificat motorasul cu o baterie ..merge ..firul e in regula numai ca nu ii baga curent pe el calculatorul si nu cred ca as fi avut ghinionul sa nu mi mearga ambele calculatoare fix pe partea stanga? ce ar mai putea fi in afara de motoras frana si calculator ? sa fie de vina firele care intra in calculator? la calc vechi ii facusem o improvizatie ...legasem un fir din partea dreapta a calculatorului in partea stanga,,,,si imi mersese perfect(crezand ca este calc de vina)...acu nu as mai face acelasi lucru ca nu stric calculatorul
faci adaptarea la servo, setare de baza pe 53 - si verifica cablajul pana la etrier
adaptarea la servo cum o fac? am incercat faza cu rotirea volanului stanga dreapta toate etapele alea si nu mi dispare..trebuie facut altfel?
am mers mai mult si tot nu si revine ..si merge si greu volanul .se observa ca nu mai am servo
FA intai adaptarea lui G85.
porneste motorul, invarte volanul la stanga si tine-l la maxim 3 secunde... dupa care rotesti spre dreapta, aceeasi procedura - si pleci cu ea 50m.
vezi si ce erori ai stocate pe 03 ABS - daca ai de setare de baza g85, atunci intai faci setarea acestuia, dupa care faci procedura de adaptare a limitei de forta la servodirectie - cea de mai sus.
Am fost la reprezentanta si am luat un alt buton si tot nu a functionat. Am fost la un electrician, mi-a bagat testerul lui si mi-a spus ca masina nu-mi recunoaste nici butonul nici ambii etrieri.
Am dat jos ambele motorase si cand le-am dat jos, a curs foarte mult lichid (nu stiu ce lichid era, dar semana cu apa) si in interiorul motoraselor era totul ud. Cred ca au mai fost reparate/reconditionate pentru ca pe margine erau date de jur imprejur cu silicon pentru geamuri.
atunci, daca amandoua sunt deterioarate, trebuie sa cauti altele
Andrei1993
Apa,lichid in motorase insemna moartea lor.Lipituri cu silicon.....cred ca iti trebuie alte motorase sau reparate deca se mai poate.Daca acel lichid e de frana atunci ai nevoie si de o revizie capiatala a etrierilor sau inlocuiti.
Modificat de EEXCALADE
De asta imi era frica...  :(
merita sa cumpar din dezmembrari daca gasesc motorase care n-au fost reconditionate?
Depinde de pret.. la 300-400 lei pt 2 bucati care arata ok, fara fisuri si cu garantie macar pana le probezi, m-as risca. Dar de obicei cei de la dezmembrari cer intre 250-450 lei pe bucata. Noi sunt 1000-1200 lei. Decizia iti apartine.
Pot scapa cumva de bipaitul ala enervant + avertizarea "Release parking brake manually" prin Vag?  :(
Nu poti scapa de avertismente decat prin remedierea problemei.
Daca gasesc doua motorase functionale, le pun pe masina si retrag frana de mana cu ajutorul butonului si pe urma le dau jos, o sa mai primesc pe urma avertizarea cu "Release parking brake manually"?
Sincer, frana de mana/buton nu o folosesc si m-as putea lipsi de ea pentru cateva luni pana fac rost de bani...
Orice improvizatie va vine in cap ca sa scap de sunetul ala enervant imi puteti spune  :lol: . Ma gandeam sa iau si sigurantele la rand poate nimeresc una care ma scapa de chinul asta  :lol: .
Nu scapi de avertizare. Decupland siguranta nu vei avea abs si esp.
Salut ca tot suntem la frana de mana. Eu am avut in primăvara eroarea de fail. Am oprit am pornit si de atunci nu am mai folosit-o. Am dat masina la cumnata. Nu a reclamat nimic. Dar are 2 obiceiuri ciudate. Când pun frana îmi pune cu întreruperi (ca si cum ar activa ABS). Dar e la frana moderată. Si azi mi-a dat din nou eroarea la frana de mana. Care a dispărut după oprit pornit dezactivat.
Ar putea fi legate cele două comportamente?
10x
10x
mi a disparut martorul cu servo...si-a revenit in acelasi timp si servo ...dupa ce am facut procedura cu rotitul volanului dar tot mai am eroarea la parking brake (p ul taiat ) ( nu fuctinoeaza motorasul pe stanga)
oricum multumesc pt sfaturile cu servo ! ! !
Sal.,
Poate cineva sa-mi spuna daca acel calculator de sub cotiera centrala fata are vreo legatura cu FRANA DE DEGET ?
Am o eroare la frana de deget si mie sa nu fie de la el .
Eventual si ceva coduri de piesa pentru el .
Multumesc .
Modificat de @DRI@N
Da. Ala e calc de frana de deget. Ce eroare ai ?
ce erori ai stocate ?
Sal.,
Multumesc .
daca ai eroare pe control head - atunci este de la buton - pentru restul, trebuie sa postezi exact ce iti apare, sa iti zicem ce poti verifica.
Florin, nu știu cum aflu erorile. Dacă îmi trebuie echipament specific, nu am.
