Electronic Parking Brake (Frana De Mana) si Auto-Hold
Mama Omide
F l o r i n
Un coleg cu ceva bunavointa ne poate ajuta cu pinout-ul butonului franei de mana pt consola de b7?
asta ai intrebat ?... eu zic ca nu.
tipic romanesc este sa nu intrebi ce trebuie dar sa ai pretentii sa primesti rapsunsul la care te gandesti.... - nu primim informatia la care ne-am gandit, aruncam cu pietre, nu ?
eu sunt de parere ca este elegant sa intrebam si sa asteptam un raspuns... sigur o sa vina de la cineva, mai devreme sau mai tarziu.
vezi ca sunt doua mufa, nu una.... daca la asta te-ai gandit.
in engleza - de pe site-uri straine.....
Installation - Wiring
Little side note: the start button I have not taken into account because it will not work in B6.
EPB adapter:
Remove the old EPB switch and pull the extension to the button bar on the left
EPB switch old -> counterpart
Pin1 ------------> Deleted
Pin2 ------------> Pin2
Pin3 ------------> Deleted
Pin4 ------------> pin4
Pin5 ------------> Pin5
Pin6 ------------> Pin6
Pin7 ------------> Pin7
Pin8 ------------> Pin8
Pin9 ------------> Deleted (ground lighting)
Pin10 -----------> Deleted (+ Bleuchtung)
EPB switch counterpart -> B7 button links
Pin2 ----------------------> Pin5
Pin4 ----------------------> Pin3
Pin5 ----------------------> Pin6
Pin6 ----------------------> pin4
Pin7 ----------------------> Pin10
Pin8 ----------------------> Pin9
ABS button --------------> B7 button links
Pin1 ----------------------> Deleted
Pin3 ----------------------> Pin7 (lighting +)
Pin4 ----------------------> Pin20
Pin5 ----------------------> pin19
Pin6 ----------------------> Pin8 (lighting -)
Auto Hold button ---------> B7 button links
Pin1 ----------------------> Pin12
Pin2 ----------------------> Pin11
Pin3 ----------------------> Deleted
Pin4 ----------------------> Pin14
Pin5 ----------------------> Pin13
Pin6 ----------------------> Deleted
In the right-hand button bar you have to decide which cable you use for lighting. I document the options in [square brackets]. The remaining must be insulated accordingly.
PLA button --------------> B7 button right
Pin1 ---------------------> Pin11
Pin2 ---------------------> Deleted (mass)
[Pin3 --------------------> Pin7]
Pin4 ---------------------> Pin13
Pin5 ---------------------> Pin12 (PDC button)
[Pin6 --------------------> Pin8]
---------------------------> Pin10 is for buttons PLA (PLA decides whether or PDC button)
If you want to use both buttons must have a cable from pin 10 to pin 16 PLA button STG draw (If PLA should go 2.0 times)
Button PDC 2006 -------> B7 button right
Pin1 ---------------------> Deleted (mass)
Pin2 ---------------------> Pin13
Pin4 ---------------------> Deleted (mass)
[Pin6 --------------------> Pin8] (mass
Button RDK -------------> B7 button right
Pin4 ---------------------> Pin14
Pin5 ---------------------> Deleted (mass)
Button C / N / S -----------> B7 button right
Pin2 ---------------------> Pin2
Pin4 ---------------------> Pin3
Pin5 ---------------------> pin4
Button blind -------------> B7 button right
Pin4 ---------------------> Pin5
Pin5 ---------------------> pin15
Key S & S -------------> B7 button right
Pin1 ---------------------> Pin9
Pin2 ---------------------> Pin5
Pin5 ---------------------> Pin6
piesele
Center console:
1x - 3AB 927 137 A WHS - Links button fully booked - € 37.78 (There are other versions)
1x - 3AB 927 238 CS WHS - Right button fully booked - € 42.78 (There are other versions)
2x - N 906 986 06 - Screw Button - € 0.24
2x - 7L6 972 726 - contact housing switch Blocks - € 5.24
1x - 3AB 863,243 1QB - Center Console Black - € 67.71 (There are other colors)
1x - 3AA 863 324 A PD4 - center console trim Aluminum gebürstet- € 32.67 (There are other colors)
1x - 3AA 857 351 A SOC - Ash brushed aluminum bezel - € 36.95 (There are other colors)
1x - 1K0 972 776 - flat contact housing EPB switch old - € 1.90
1x - 000 979 009E - cable car line Extra Hold - € 3.29 (For illumination of the old EPB switch)
3x - 000,979,012 EA - cable for flat contact housing old counterpart - € 11.12 (or 4x for illumination EPB switch old)
Other required parts:
1x cloth tape (eg 000,979,950 to 6.00 €)
Solder / crimp stuff, heat shrink tubing, power flow meter ....
popadaniel92
Am reusit sa rezolv problema cu motorasul..a fost desfăcut si curatat si acum functiineaza fara probleme..pret :200 lei..
Daca este cineva interesat pot recomanda acesti mecanici din bucurești
Buna ziua,
Aceiasi problema o am si eu, mi-a gasit mecanicul capacul crapat dupa cum se poate observa si in poze, a ramas blocat dupa actionarea franei si a intrat in avarie. L-am rugat sa mi-l dea jos, aveti idee daca se poate reconditiona si daca da unde in Bucuresti? Am cautat pe epiesa si autokarma si am gasit kit-ul de reparatie etrier dar nu stiu exact ce contine <100lei, stiti cumva daca este ok?
post-79362-0-03155600-1431322736_thumb.j
post-79362-0-29867700-1431322736_thumb.j
post-79362-0-79168800-1431322736_thumb.j
F l o r i n
trebuie sa-l vedem, ca sa iti zicem daca e bun....
Carcasa crapara = reductor gripat (sau urmeaza) Kit-ul de reparatie etrier e doar pentru etrier nu si pentru motoras.Contine cateva garnituri.
Off topic.
Daca tot esti in Buc.si ai motorasul dat jos de mecanic/care nu stie ce are de facut/schimbat ia legatura cu Florin/altii ca el, daca nu...poti sa l faci pachet si sa l trimiti lui Excalade.
Kitul pt etrier e una pt.motoras e altul(Excalade stie/multum. si eu pt ajutorul dat colegilor pe care i am indrumat spre el).
A NU se considera reclama ci doar ajutor.
Modificat de romytaxy
Multumesc pentru sfaturi.
Am gasit codul motorasului  - 3C0998281B si o sa-l schimb eventual cu unul nou, sa ma interesez totusi mai intai cat costa. Etrier nou cu totul - 790lei cu piesa la schimb Lauber, SH ~100EUR, nici nu stiu ce sa fac. :)
In jurul valorii de 1100/1300 lei e pretul motorasului asa ca...alegerea iti apartine.
popadaniel92
Eu am trecut cel.mai recent prin asta probabil..daca masina este 2007 reprezentanta face o reducere a motorasului de la 1600la 1200 lei...sau poti comanda un etrier cu tot cu motoras TRW cu 900 lei...eu am rezolvat in Bucureati cu 200 lei..mi a desfacut etrierul si motorasul si totul fu ctioneaza perfect..au disparut si erorile din bord...am postat mai sus ca pot recimanda mecanicul respectiv dar se pare ca nu ai citit mai nimic din posturi
Voi merge pe varianta nou - AM etrier cu totul: 790lei inclusiv TVA de la epiesa.
La Porsche motorasul este aproximativ 1300lei si varianta etrier cu totul 2300lei, inclusiv discount 20%.
Sa vad intr-un final ce fac cu calibrarea/update-ul de soft, am inteles ca si asta ar fi o mare bataie de cap... :)
popadaniel92
La mine s a muncit cam 4 ore la el..din cate am inteles update de soft face reprezentanta..eu am fost la ei si au cerut 250 de lei doar ca sa mi spuna ca e motorasul defect..am.jurat ca nu ma mai duc la ei..la mine nu a fost necesar update..din ce mi a mai spus cineva daca un motoras este nou si altul vechi va exista o diferenta de tensiune intre ele si automat cel vechi va cadea imediat...acum.fiecare cum stie...
Off topic.
@Costel.
Cu 200 de lei ti a schimbat totul in motoras, sau doar ti a degripat/lipit carcasa ??
Vezi ca se deblocheaza foarte usor, nu merita sa cumperi altul. Trebuie sa-l decapsezi, sa degripezi angrenajul ( eu l-am degripat prin miscari successive de rotatie stanga-dreapta, tinindu-l in mina) si apoi il ungi cu vaselina, dupa care lipesti carcasa la loc. Crapatura din capac o etansezi tot cu adeziv cu care lipesti carcasa. Dupa montare din din vag-com resetare la parametrii de baza.
.Nu ai ce pierde in cazul ca vrei unul nou, ai numai de castigat, daca reusesti, scutesti niste bani.
Modificat de nilf40f
popadaniel92
Nu am stat langa ei sa vad ce fac..am lasat pe altcineva acolo si din cate mi au zis mi l a scos..curatat,degripat..si calibrat ulterior..plus sters eroarea din bord...eu sunt multumit...
Ok, asa se justifica pretul dar...sa ne tii la curent si cat tine"multumirea" ta in urma DOAR a degriparii fara inlocuirea rulmentilor.
Scuze de off topic.
popadaniel92
Inlocuirea cu unul sh nu cred ca este o solutie avand in vedere ca majotitatea au cazut..ai ocazia sa ti cada imediat...sincer eu nu o sa mai abuzez de frana de parcare..sa fim seriosi..in treapta 1 e suficient..daca esti intr o panta mare da..dar daca o tii in fata blocului nu e necesara si frana de parvare..asa ca eu o sa o menajez serios:)))
L-am desfacut, motorasul in sine functioneaza l-am testat, dar pinioanele sunt deformate erau incalecate ca sa zic asa... :)
Pentru cei din Bucuresti, aveti idee unde le pot gasi separat? Altfel o sa fiu nevoit sa cumpar un alt motoras cu totul si termin povestea.
Explica ce inseamna pinioane incalecate.Pune o imagine.Nu se gasesc separat
andrei.laviniu
Salut tuturor , ma poate ajuta si pe mine cineva la eroriile urmatoare ?
Thursday,14,May,2015,16:18:59:40973
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ3CZ6P089548   License Plate:
Mileage: 175810km-109243mi   Repair Order:
                Address 53: Parking Brake       Labels: 3C0-907-801-53.clb
Control Module Part Number: 3C0 907 801 G    HW: 3C0 907 801 G
  Component and/or Version: EPB  VD8HC005   013 0005
           Software Coding: 0000012
            Work Shop Code: WSC 00248 210 93576
                      VCID: 2643101A9147002ECEF-8073
3 Faults Found:
02432 - Supply Voltage for Left Parking Brake Motor (V282)
            011 - Open Circuit - MIL ON
             Freeze Frame:
                    Fault Status: 11111011
                    Fault Priority: 1
                    Fault Frequency: 33
                    Reset counter: 182
                    Mileage: 173280 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:04:19
             Freeze Frame:
                    Voltage: 14.70 V
                    Count: 84
01087 - Basic Setting Not Performed
            000 - - - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 4
                    Fault Frequency: 254
                    Reset counter: 183
                    Mileage: 168248 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:14:09
             Freeze Frame:
                    Voltage: 11.70 V
                    Count: 170
02844 - Lamp for Automatic Parking Function
            009 - Open or Short to Ground - MIL ON
             Freeze Frame:
                    Fault Status: 11101001
                    Fault Priority: 4
                    Reset counter: 183
                    Mileage: 168248 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:14:26
             Freeze Frame:
                    Voltage: 11.70 V
                    Count: 64
O problema la motorasul stanga, necesita reparatie/inlocuire Ai umblat cu vag-ul si din cauza motorasului defect nu poti face Basic Setting; Becul de la butonul franei nu se aprinde
andrei.laviniu
Butonul se aprinde si cand nu este pusa frana licareste si imi bipaie intr-una , dar de mers merge doar ca imi arata erorile si bipaie
LA diagnoza ce apare ?
Ca sa faci ceea ce vrei tu iti trebuie o interfata VAG COM ca sa faci o calibrare a motoraselor.
Eu am desfacut motorasul, era gripat angranajul, l-am deblocat si a urmat toate operatiunile de reconditionare, montat pe etrier si actionat butonul, si-a anulat automat eroarea de failure break.Pentru cei care vor sfaturi in legatura cu aceasta procedura trimiteti un PM.
Modificat de Yonwt
Asa trebuie sa fie pentru ca prin rotatia celor 2 rotite cu pinioane la fiecare apropriere fac o tura mica.
Tu trebuie sa deblochezi aceea rotita care e cu rulment.
Deblocheaz-o,ungeo cu vaselina sau ceva si apoi monteaza totul inapoi si sigur va merge.
Repet....acele 2 pinioane nu sunt deformate.....asa sunt ele si asa trebuie sa fie.
