Electronic Parking Brake (Frana De Mana) si Auto-Hold
Mama Omide
Eu circul de peste 1000 de km..cu acel piuit m am.obișnuit deja:)) el nu poate fi anulat nici prin interfata vagcom...eu l as fi anulat ca frana de parcare oricum nu prea o folosesc...
Imi poate spune cineva, care este problema aici:
Address 53: Parking Brake       Labels: 5N0-907-801.lbl
Control Module Part Number: 3C8 907 801 A    HW: 3C8 907 801 A
  Component and/or Version: J540 EPB3  VW-10498 0003
           Software Coding: 0000056
            Work Shop Code: WSC 05311 000 00000
                      VCID: 2854FAFEA4A90D5C
2 Faults Found
03200 - Switch for Electric Parking Brake (E538)
            012 - Electrical Fault in Circuit - MIL ON
             Freeze Frame
                    Fault Status: 11111100
                    Fault Priority: 1
                    Fault Frequency: 5
                    Reset counter: 142
                    Mileage: 212751 km
                    Time Indication: 0
                    Date: 2006.14.03
                    Time: 07:58:18
             Freeze Frame
                    Voltage: 12.50 V
                    Count: 10
                    Speed: 0.0 km/h
                    Hex Value: 0x1170
                    Hex Value: 0x0008
                    Hex Value: 0x0101
16352 - Control Module - Electrical Error
            014 - Defective - MIL ON
             Freeze Frame
                    Fault Status: 11101110
                    Fault Priority: 1
                    Fault Frequency: 5
                    Reset counter: 142
                    Mileage: 212751 km
                    Time Indication: 0
                    Date: 2006.14.03
                    Time: 07:58:18
             Freeze Frame
                    Voltage: 12.50 V
                    Count: 42
                    Speed: 0.0 km/h
                    Hex Value: 0x1160
                    Hex Value: 0x0008
                    Hex Value: 0x0101
inseamna ca problema apare si la modele mai noi, in cazul meu 2009.
......a inceput sa faca de ceva vreme, insa sporadic, nu tot timpul
Modificat de cridaia
Eu voi merge la jumatatea lunii Mai in tara si voi merge la un electrician si voi vedea ce si cum ca aici ma omoara la pret.
Ce spuneti pot circula cu masina asa vreo 600 km fara sa se intample ceva ma refer la frane?
Cum pot scoate acel piuit din bord?
din can gateway, dezactivati frana de mana electronica - 53 - imi pare ca nu mai piuie dupa aia....
2 Faults Found
             Freeze Frame
                    Fault Priority: 1
                    Fault Frequency: 5
                    Reset counter: 142
                    Mileage: 212751 km
                    Time Indication: 0
                    Date: 2006.14.03
                    Time: 07:58:18
             Freeze Frame
                    Voltage: 12.50 V
                    Count: 10
                    Speed: 0.0 km/h
                    Hex Value: 0x1170
                    Hex Value: 0x0008
                    Hex Value: 0x0101
             Freeze Frame
                    Fault Priority: 1
                    Fault Frequency: 5
                    Reset counter: 142
                    Mileage: 212751 km
                    Time Indication: 0
                    Date: 2006.14.03
                    Time: 07:58:18
             Freeze Frame
                    Voltage: 12.50 V
                    Count: 42
                    Speed: 0.0 km/h
                    Hex Value: 0x1160
                    Hex Value: 0x0008
                    Hex Value: 0x0101
Cristi, sa cumperi unul original, la reprezentanta in jurul la 170 -200 lei. Cele facute in China... sau after-market, ori nu merg din prima.... ori cedeaza foarte repede.
Am dat doar de  unele care tot piue chiar daca debifezi frana din can.
Modificat de EEXCALADE
Cum pot verifica un motoras cu etrier cumparat SH? Pot sa aplic o tensiune direct din baterie pe el?
cam da... dar doar sa il vezi ca misca putin, sa nu-l strici.
da, unele da, altele nu... altele dupa cativa km de la debifare nu mai fac....
Pai o sa ii dau un simplu impluls doar sa vad daca merge. Daca nu merge il duc inapoi la dezmembrare de unde l-am achizitionat.
Baieti am rezolvat problema.
Am incercat motorasul care l-am cumparat SH direct pe baterie si a mers fara probleme. Am schimbat mufa de pe cablul ce vine de la Modul si totul e ok.
Am facut recalibrarea motoraselor si e totul ok.
Au disparut si errorile din bord. E totul ok.
Pai si nu ai incercat si cu motorasul vechi sa vezi daca merge? Poate era doar cablul de vina...
la Timisoara la reprezentanta, cost 172lei
nu are cum sa fie cablul, atata timp cat a pus alt etrier si merge.
este ok.
Motorasul vechi nu merge. L-am incercat exact la fel si nu face nimic.
2 Faults Found
             Freeze Frame
                    Fault Priority: 1
                    Fault Frequency: 5
                    Reset counter: 142
                    Mileage: 212751 km
                    Time Indication: 0
                    Date: 2006.14.03
                    Time: 07:58:18
             Freeze Frame
                    Voltage: 12.50 V
                    Count: 10
                    Speed: 0.0 km/h
                    Hex Value: 0x1170
                    Hex Value: 0x0008
                    Hex Value: 0x0101
             Freeze Frame
                    Fault Priority: 1
                    Fault Frequency: 5
                    Reset counter: 142
                    Mileage: 212751 km
                    Time Indication: 0
                    Date: 2006.14.03
                    Time: 07:58:18
             Freeze Frame
                    Voltage: 12.50 V
                    Count: 42
                    Speed: 0.0 km/h
                    Hex Value: 0x1160
                    Hex Value: 0x0008
                    Hex Value: 0x0101
NU doar butonul, pare a fi si modulul de frana de parcare.
momentan functioneaza, nu a mai facut figure........ ma gandeam ca poate fi si modulul.....la un coleg cu acelasi model ca al meu, i-a cazut si lui subit.
poate fi din cauza "incercarii" esuate de montaj AH ? ....stiti ca la cele cu start/stop nu se poate monta, iar la mine au ramas legaturile acolo, fara buton si fara codare.
sigur nu are treaba.
daca erorile s-au sters, problema a fost doar de la buton.
s-au sters si le pot sterge fara probleme........ cel putin pana acum.
atunci da-i pace, asta fu problema
mi-e teama sa nu ma lase cand mi-e lumea mai draga...... in concediu.
Cristi-desfa si refaci cablajul fara AH. Ai experiente cu concediul-stii tu..pb cu capsula vacumatica-:)
ce sa desfaca, atata timp cat nu are nicio problema... ? lasa masina linistita.. da-i pace.
Va salut,
Am avut problema cu modotasul pe partea stanga si m-am incumetat sa imi bag nasu pentru o reparatie e am reusit aceasta operatiune.Erau intepenite rotitele, am rezolvat-o si am testat motorasul si functioneaza.A urmat montajul si aici a venit alte probleme, cum ar fi: eroarea nu dispare si bord, iar functionarea lui nu e buna, adica: atunci cand actionez butonul, motorasul merge intr-un sens vro 2 secunde si automat isi schimba directia si merge pana la aproape 10 sec si se opreste. Trebuie calibrat ? Unde as putea s-a ma duc?
Va multumesc
Modificat de Yonwt
Ciprian2106
Salut.
Cu o interfata VCDS trebuie sa faci calibrare a motorasului.
Uite aici cam ce ar trebui sa faci.
Motorasele sunt identice intre sedan si variant ? As vrea sa caut pe la dezmembrari  si imi trebuie cateva detalii . Cu un cod de piesa me poate ajuta cineva ?
