razvan.ac
Am gasit informatia pe un forum din DE. Daca poate cineva sa verifice/confirme, ne-ar ajuta mult.
Additional work:
- Change brake fluid every 2 years
- Only change AdBlue if mileage is less than 15,000 km in 4 years (TDI)
- Change all-wheel drive oil every 2 years
- Change 6-speed DSG oil every 60,000 km
- Change 7-speed DSG oil every 120,000 km
- Check DPF at 210,000 km, then every 30,000 km (TDI)
- Pano function check after 2 years or 30,000 km
- Clean and grease Pano (not provided)
- Check Pano water drains after 2 years or 30,000 km
- Clean air filter box and replace filter every 90,000 km or 6 years
- Change interior filter every 2 years or 60,000 km
- Replace camshaft drive timing belt every 210,000 km (TDI)
- Replace V-ribbed belt every 210,000 km (TDI)
- Replace fuel filter every 90,000 km (TDI)
- Spark plugs every 4 years or 60,000 km (TSI)
Oil change:
petrol engines
diesel engines
as of 08/2024
Modificat de razvan.ac
  • razvan.ac changed the title to Intretinerea si costurile service Kodiaq 2
  • 10 months later...
florin.23mai
Salutare, am fost la revizie la 15000 km (ceruta de mine).
Motor 2.0 tsi, 204CP.
Schimb ulei si filtru ulei.
Cost 1111 lei
