Intretinerea si costurile service Kodiaq 2
razvan.ac
Am gasit informatia pe un forum din DE. Daca poate cineva sa verifice/confirme, ne-ar ajuta mult.
Additional work:
- Change brake fluid every 2 years
- Only change AdBlue if mileage is less than 15,000 km in 4 years (TDI)
- Change all-wheel drive oil every 2 years
- Change 6-speed DSG oil every 60,000 km
- Change 7-speed DSG oil every 120,000 km
- Check DPF at 210,000 km, then every 30,000 km (TDI)
- Pano function check after 2 years or 30,000 km
- Clean and grease Pano (not provided)
- Check Pano water drains after 2 years or 30,000 km
- Clean air filter box and replace filter every 90,000 km or 6 years
- Change interior filter every 2 years or 60,000 km
- Replace camshaft drive timing belt every 210,000 km (TDI)
- Replace V-ribbed belt every 210,000 km (TDI)
- Replace fuel filter every 90,000 km (TDI)
- Spark plugs every 4 years or 60,000 km (TSI)
Oil change:
petrol engines
diesel engines
as of 08/2024
Modificat de razvan.ac
  • razvan.ac changed the title to Intretinerea si costurile service Kodiaq 2
  • 10 months later...
Salutare, am fost la revizie la 15000 km (ceruta de mine).
Motor 2.0 tsi, 204CP.
Schimb ulei si filtru ulei.
Cost 1111 lei
Surubul de golire cu garnitura 50 lei...Frumos!
Oare nu puteau sa-ti factureze 4.7L de ulei si sa-ti pune litrul primit cadou? Ma gandesc ca nu ai nevoie de el
