suzu
unday,16,October,2011,00:01:53:36838
VCDS Version: Release 10.6.2
Data version: 20101123
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
Mileage: 193170km/120030miles
Address 01: Engine Labels: 078-907-551-ACK.lbl
Part No: 4D0 907 551 AF
Component: 2.8L V6/5V MOTR AT D01
Coding: 05152
Shop #: WSC 02324
VCID: 6AD0DE2C3C03
No fault code found.
Readiness: N/A
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156
Component: AG5 01V 2.8l5V RdW D03
Coding: 00000
Shop #: WSC 00000
VCID: E4CC30145E27
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 8E0 614 111 C
Component: ABS/ASR 5.3 FRONT D00
Coding: 00003
Shop #: WSC 02315
VCID: 1E38C2FCB0CB
No Faults Found
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 G
Component: A6-Klimavollautomat D55
Coding: 00060
Shop #: WSC 02324
VCID: 1E38C2FCB0CB
No Faults Found
Address 15: Airbags Labels: 4B0-959-655-AI7.lbl
Part No: 4B0 959 655 J
Component: Airbag 7 Audi 0501
Coding: 00106
Shop #: WSC 02324
VCID: 377637583F31
No Faults Found
Address 17: Instruments Labels: 4B0-919-xxx-17.lbl
Part No: 4B0 919 860 L
Component: C5-KOMBIINSTR.UN4 D01
Coding: 01062
Shop #: WSC 76619
VCID: 336E03482B49
Part No: IMMO
Component: IDENTNR: AUZ8Z0V6230044
IMMO-IDENTNR: AUZ8Z0V6230044
No Faults Found
Address 18: Aux. Heat Labels: None
Part No: 4B0 265 105 B
Component: Standheizung Benzin D48ˆ
Coding: 00001
Shop #: WSC 00000
VCID: 1B3ECBE8A3D9
No Faults Found
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 B
Component: Zentralverrieg.,DWA D28
Coding: 04682
Shop #: WSC 02324
VCID: 2854E424E28F
No Faults Found
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D02
Coding: 00001
Shop #: WSC 02324
VCID: E0C43C044A3F
No Faults Found
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D000
Coding: 00005
Shop #: WSC 02324
VCID: E5CA2D10551D
No Faults Found
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186
Component: Radio D01
Coding: 00203
Shop #: WSC 02324
VCID: DDBA05F07D4D
Address 76: Park Assist Labels: 4B0-919-283.lbl
Part No: 4B0 919 283
Component: Parkingsystem A6 RDW D15
Coding: 01106
Shop #: WSC 02324
VCID: E6C82A1CA81B
No Faults Found
End ---------------------------------------------------------------------
are cineva idee daca intr-adevar nu sunt erori sau nu comunica bine interfata aia...tre sa mai fac ceva?...mentionez ca am xp fresh instalat si programele de rigoare..
salutare, de curand am achizitinat un VAG COM 11.3 si nu imi functioneaza cu softul din cd 11.3 beta.pot sa folosesc VCDS ROJ 10.6 pentru scanare si cititre module?este compatibil?
Daca ai clona, nu poti folosi alt soft decat cel cu care a venit interfata.
Salutare ! Am si eu un Seat Cordoba 1.4 8valve , fabricatie 2000 la care am urmatoarea problema:
Il pornesc , porneste , trage foarte bine insa odata lasat la ralanti se opreste motorul. In bord se aprinde martorul motor si EPC
Am pus vag-com pe el si imi da eroare pe senzorul MAP(manifold air pressure sensor ) - implausibile signal .
Cumpar senzor nou , il pun pe masina si se manifesta la fel , nicio schimbare.
Scot mufa de la senzor , motorul merge putin mai turat ( datorita lipsei senzorului ) , eroare este de tipul - open or short to ground (evident datorita lipsei senzorului) , ralantiul tot rau merge si pana la urma tot se opreste motorul .
Ma uit la clapeta de acceleratie , observ ca la pornire nu face cursa completa . Dau sa ii fac adaptare ( canalul 60 pe engine) insa porneste sa faca adaptarea , face numai un sefert de cursa apoi motorasul incepe sa traga de clapeta inspre inchidere si bazaie cu greu ca si cum ar forta sa inchida clapeta si mai tare dupa care imi afiseaza ADAPT OK.
Repet , clapeta NU face cursa completa. Daca pornesc motorul si accelerez , motorul se tureaza , pe vag com imi arata corect pozitia senzorilor si motorul trage de rupe , cu exceptia ralantiului care moare.
Am curatat clapeta , este una mai rudimentara fara IAC . Totodata nu gasesc debitmetrul acestei masini . Unde naiba este?
Pareri , idei?
Nu are debitmetru. Verifica firele de la senzor MAP la ecu.
Salutare la toti forumistii :D , dupa lungi cautari pe net am aflat ca pot sa imi codez i.c-ul sa bipaie la deschisul usilor ca atunci cand arata ca e polei si anume chime-ul ala frumos. Ei tipu zicea mergi in instum17 apoi coding07 .. pana aici e in regula si apoi sa selectez canada sau usa.... Boonn dar acuma problema e ca am un cod de 5 numere parca ..eu de unde stiu ce sa modific :( Stie careva ce trebuie modificat ca sa nu gresesc nimic pe acolo ? Am oleak de morcov sa nu fac vreo prostie :) Mc mult baieti si orice sfat ajuta !!! Stau cu ochii pe topic ca abia astept cum se face :)
Modificat de Mr VW
Am rezolvat treaba pe jumatate doar , adica mi-am dat seama cum sa codez dar nu a mers ... nu mi-a activat decat de centura in rest afisajul piesei pe minidot nu merge si nici dongul de canada :(((
Gongul de Canada merge cand deschizi usa....mereu, nu numai cand ai farurile aprinse. In rest, tradu ce ai vrut sa zici legat de afisajul piesei....
salut, revin iar cu o problema.am facut o scanare zilele trecute. am o singura eroare, la climatronic.
problema e ca nu imi merge martorul in bord pt usi deschise. nici plafoniera nu se aprinde la 2 usi. deci alea sigur au probleme cu switchul.
dar din cate stiu martorul in bord ar trebuii sa se aprinda pt oricare usa deschisa nu?
atasez si logul.
Log-132450km-82300mi.txt
Modificat de RazvanBlade
Depinde de anul de fabricatie al masinii. La unele nu se aprinde martorul, decat la deschiderea portabagajului.
an 2001, bc mic, immo2...
nici buzzerul nu porneste daca las farurile aprinse si deschid usile.
buzzerul l-am verificat ( mers cu frana de mana trasa ) si ii ok...
@florin , cand dau scan la rc meu imi spune incorect coding ,si inca doua chestii prima ca nu e magazie de cd prezenta , si a doua ca nu are outputdisplay/indash panel display parca not active sau ceva in genu . Si am gasit dupa multe sapaturi ca se poate modifica tot in bitii de la instrumente adugand +16 dashpanel suport parca. Ei acuma ma gandesc oare ce face asta ? imi afiseaza numele piesei pe minidot ? exista asa ceva pe vre-un minidot ?!
Cum pot sa resetez mesajul cu service ce aparare cand trebuie sa faci schimbul de ulei?pot sa il setez sa imi apara la interval de 12.000 de km?
Folosesc vag com 311
Din butoane stiu sa il restez,dar vreau sa stiu cum il resetez cu vag com
Sunt incepator si as vrea sa stiu daca e bine pentru motorul meu ce arata diagnoza!
Si de ce mi-a scanat cu auto-scan doar atatea module ?nici macar pe acela cu Adresa 01 Engine?!
Si daca am eroare la oglinzi si la motorasele de la clima mai exact pe partea electrica dar nu la motor cum sterg erorile pe ce canal intru.mersi frumos
Log-Log.txt
Log-WVWZZZ1JZ1W068112-186250km-115730mi-1.txt
Modificat de bigstar
Pai, a fost doar o scanare....ca sa vezi mai multe - turbina, debitmetru - trebuie facut un log in mers.
in rest, totul ok - injectoarele par ok (se masoara cand temp lichidului de racire este peste 80 grade), si in rest - probleme la incalzirea oglinzilor.
@ bigstar daca folosesti cumva varianta de vag com 409 nu vei reusi sa faci un auto-scan complet deoarece pe Engine trebuie setata valoarea 9600 la BaudRate, iar pentru celelalte module valoarea 0.
Folosesc vag com 11.2 abdatat versiunea10.6,si daca am eroro si la partea electrica a masini nu la motor de exemplu la incidere ,la motorasele de la clima ,oglinzi......cum sterg erorile?
Intra pe 46-Convenience
Poate 10.6, update la 11.2
te-am mai intrebat si in alt post topic: cat e avansul, cum e reglat? Injectorul 1 e pe duca.
Salut! sunt nou aici si am si eu o problema care sper sa nu fie majora ,daca ma poate ajuta cineva cu un sfat: la o scanare in engine basic setting la grupul 003 se aprinde in bord engine workshop si bujia incandescenta
basic settings group 003 1407'min (speed engine 820-900) egr cand on cand off maf specified 230-420 ( 150-328 mg'str) maf actual 19.9% 64.5 egr duty cycle 10-95 %
group 004 1092/min (speed engine 820-900) Late (spec start of inj 1 BTDC-2ATDC) 5.6-5.1 KW (spec inj duration 5-7 ck) 0.3-0.0 KW( sinchro. angle -3...plus3 ck)
In paranteze valori care ar trebuii sau cel putin care sunt sub ceea ce arata deasupra. MULTUMESC ANTICIPAT SI SCUZATI daca nu am scris corect sunt nou pe forum
si imi mai apare si asta mode 03:emision related fault codes
am scanat cu vag com 11.2 daca are vreo importanta
Modificat de John_John2
In primu lrand, ai gresit topic-ul. Vezi ca exista un topic similar in aria TDI. In al doilea rand, ce anume vrei sa faci? Pentru verificari/masuratori, ai "measuring blocks". In "basic settings" nu este indicat sa lucrezi daca nu stii ce vrei sa faci, daca nu ai/ nu cunosti procedurile necesare operatiunilor; poti sa produci singur defectiuni.
imi cer scuze nu am fost atent
  • Aerofan pinned this topic
