suzu
Salut,si la multi ani.Imi poate explica si mie cineva pina la urma cum se face o diagnoza corecta? se da drumul la laptop,se conecteaza interfata la laptop si masina,si apoi se pune contactu?Sau se pune intii contactu apoi se conecteaza interfata la mufa masinii si la laptop?Am un vag com 908,clona bineinteles,si cind lam cumparat odata cu cd cu programul de instalare,am primit si niste instructiuni de folosire,in care scria ca intii se pune contactu si dupa aia se conecteaza interfata.Aici pe forum cineva mia spus ca se face tocmai invers...asa ca sint cam in ceata si nu mai inteleg nimic
0
Salut la toata lumea si la multi ani pe 2011!
Am un prieten cu un un A4 B6 AFV din 2004.
Postez scanarea facuta:
Sunday,02,January,2011,13:29:34:26365
VCDS Version: Release 805.0
Data version: 20080730
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 LJ
Component: 1,9l R4 EDC G000AG 4910
Coding: 00001
Shop #: WSC 63351
WAUZZZ8E34A091358 AUZ6Z0C0267788
4 Faults Found:
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 35-10 - - - Intermittent
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
P1699 - 35-00 - -
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E0 910 155 C HW: 01J 927 156 HH
Component: V30 01J 1.9l PD RdW 3120
Revision: 00000004 Serial number: 00000000448328
Coding: 0000001
Shop #: WSC 63351 000 00000
3 Faults Found:
17090 - Transmission Range Sensor (F125): Implausible Signal
P0706 - 000 - -
Freeze Frame:
RPM: 96 /min
RPM: 0 /min
RPM: 0 /min
(no units): 1.0
Torque: -32.0 Nm
Temperature: 28.0
sterge tot si revino cu erorile din nou .
pentru bord - vezi pinii in prima faza (contact imperfect)
Revin cu noutati...
Am curatat pinii de la instrument cluster si nu mai sunt probleme.
Multumesc lui TURBOCIP pentru sfaturi.
Am pornit-o si am dat o tura apoi in timp ce vag-ul scana am turat-o putin in pozitia P. La un momentdat am simtit o mucitura si trecand in pozitia D am observat ca nu mai vrea sa plece.
Masina are o eroare mai veche de care nu stie mai nimeni nimic, si anume:
Coding: 0000001
P0706 - 000 - -
Freeze Frame:
RPM: 864 /min
RPM: 0 /min
RPM: 0 /min
(no units): 2.0
Torque: -8.0 Nm
Temperature: 30.0
Salut,cod eroare 17480,probleme cu sonda lambda,de circuit,trebuie verificate mufele conexiunile.Intrebarea mea este ;Scap fara sa inlocuiesc sonda,daca o dau jos si o curat?Este vb de sonda de dupa catalizator?
Salut,imi poate spune si mie cineva care este procedura de verificare cu VAG COM a sondelor lambda ?Ce trebuie facut pentru a vedea daca sint ok?
engine, grup 34, 36, 43, 46 basic settings cu frina apasata pt activare a testului.
200 grade minim pt primele 3 si 400 pt ultimul.
Ea se tureaza cind apesi frina la 1400, dar daca vezi ca nu ridica temp la ultimul temp, iesi din basic o turezi sa treaca de 400 si dupa aia basic si frina apasata.
Bafta...
Testele nu reprezinta siguranta 100% ca ele sint beton.
Ca nus' varza da ...e ok...daca sint imbatrinite ies testele bine dar pot da erori de genul 16514, 16555 etc...
in urma unui test cu vag som ul mi au aparut urmat erori:
19490 - Intake Air Temperature Sensor 2 (G299): Signal too Large
P3034 - 002 - Lower Limit Exceeded - Intermittent
16985 - Internal Control Module: Memory Check Sum Error
P0601 - 001 - Upper Limit Exceeded - MIL ON
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 002 - Lower Limit Exceeded - MIL ON
17478 - NOx Sensor (G295) Heater Control: Short to Plus
P1070 - 001 - Upper Limit Exceeded - MIL ON
16575 - Fuel Pressure Sensor (G247): Implausible Signal
P0191 - 004 - No Signal/Communication - Intermittent
cel mai mult ma ingrijoreaza 16985 - Internal Control Module: Memory Check Sum Error ca nu se sterge...ma ajuta si pe mine cineva sa mi spuna cate ceva de aceste erori?masina e un golf 5 1.6 fsi...si recent i am schimbat un piston...
In primul rand ai sters erorile si au aparut iar sau sunt stocate de ceva timp?
Asta e ce am gasit eu.
16985/P0601/001537 - Internal Control Module: Memory Check Sum Error
Possible Symptoms
MIL illuminated
Possible Causes
Engine Control Unit (ECU) defective
Flash ROM (used in aftermarket "chips") defective
Possible Solutions
Replace ECU
Contact aftermarket chiptuner for repair of their chip
17748/P1340/004928 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
Possible Causes
Timing Belt/Chain incorrectly installed
Timing Chain probably lengthened
Camshaft Position Sensor (G40) faulty
Engine Speed Sensor (G28) faulty
Possible Solutions
Check Timing Belt/Chain installation
Use Measuring Value Blocks (MVB) to Check Timing Chain
Check/Replace Camshaft Position Sensor (G40)
Check/Replace Engine Speed Sensor (G28)
16575/P0191/000401 - Fuel Pressure Sensor (G247): Implausible Signal
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
High/Low Fuel Pressure implausible
Low Fuel Level or Fuel Tank empty
Wiring and/or Connector(s) from/to Fuel Pressure Sensor (G247) faulty
Possible Solutions
Check Fuel Tank Level
Check Fuel Pressure
Check Wiring and/or Connector(s) from/to Fuel Pressure Sensor (G247)
Check/Replace Fuel Pressure Sensor (G247)
Modificat de didus
dupa stergere imi mai raman doar astea 2:
eroare asta o am de mai mult timp...de prin aprilie
stiti cumva pe unde se afla pozitionat senzorul de viteza si cel de la benzina?
pentru axa cu came am dat comanda in germania pt o piesa care este uzata.ar trebui sa mi ajunga undeva pe 12..si dupa sa vad daca se mai schimba ceva.
@didus
am inteles ca intr o comuna de pe langa iasi sunt niste mesteri care se ocupa numai de vw...stii ceva?
Vezi daca distributia este bine pusa la punct.
Am tot cautat prin topic-uri dar nu am gasit un manual de utilizare a vag com-ului 908 in limba romana. Nu il are nimeni sa mi-l trimita si mie? In limba engleza il am dar ar fi mai util in romana. Va multumesc
distributia e bn pusa la punct...am verificat o de 3 ori si e bn pusa...si totusi eroarea persista...referitor la 16985 trebuie sa schimb calculatorul motor.am fost la o reprezentanta vw si solutia pe care au dat o ei este inlocuirea...
MasinaPoporului
O problema la un golf 4. S-a aprins Check Engine in bord. S-a curatat EGR. Dupa 25 km s-a aprins iar cu erorile:
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 036 906 032 P
Component and/or Version: ME7.5.10 3547
Software Coding: 00031
Work Shop Code: WSC 00000
4 Faults Found:
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
P1118 - 35-10 - - - Intermittent
17560 - Long Term Fuel Trim Additive Air; Bank 1; Range 2: System too Lean
P1152 - 35-00 - -
17559 - Long Term Fuel Trim Additive Air; Bank 1; Range 1: System too Lean
P1151 - 35-00 - -
16525 - Oxygen (Lambda) Sensor B1 S2; Heating Circuit: Malfunction
P0141 - 35-00 - -
Readiness: 1110 0001
Am sters erorile, am facut o plimbare si a aparut :
17811 - EGR System: Regulation Deviation
P1403 - 35-00 - -
Readiness: 1110 0101
Consumul in bord e ciudat tare: 30-50 %
N'o fi implicat si MAF'u in treaba asta?Se simte putere mai scazuta?Sau n18?
Modificat de zebrocksky
MasinaPoporului
Masian trage normal. Are vlaga. Doar ca se simt niste mirosuri ciudate...de gaze nearse.
Pai inainte de curatare EGR ce erori aveai? Ca ziceai ca era aprins CHECK-ul.
Tot legat de EGR?
  • Aerofan pinned this topic
