suzu
Deci ventilatoarele la ce temperatura pornesc?Si dupa ce pornesc mai trece de 100 de grade temperatura?
E cam off topic discutia deja dar ma miram un pic de temperatura asa mare.Sa ne mutam la G62 cu discutia.
Modificat de divinewind
Pai dupa neuronul meu ar trebui sa porneasca atunci cind termostatul e deschis la maxim si temperatura tinde sa creasca.
Banui ca se opresc cind temp scade putin sub 90, adica pe la 85-87 cind cica termostatul se inchide/deschide...
nu mai facusem demult o scanare,si azi am gasit urmatoarele erori...cood eroare16486 mass air flow sensor g70 signal too low.....intermitent 18080 coolant ton control open or short to ground,intermitent..asta in engine.iar in canalul 17 instrument,01039 coolant temperature senzor g2 open or short to plus intermitent....si ce ma ingrijoreaza mai tare este asta...013144..engine control module no comunication intermitent..aceasta din urma,am mai avuto acum un an am sterso si nu a mai aparut...acum o saptamina am uitat farurile aprinse si am ramas fara curent,am pornito de la bateria unui prieten...sa aiba aceasta vreo legatura cu ultima eroare?
Acuma e acuma. Idei la eroarea cu airbagul...
VCDS Version: Release 908.0
Data version: 20090911
Wednesday,13,October,2010,20:01:18:13314
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Address 01: Engine Labels: 06A-906-018-AGU.lbl
Part No: 06A 906 018 CG
Component: 1.8L R4/5VT MOTR HS D02
Coding: 04000
Shop #: WSC 00046
3 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
00561 - Mixture Adaptation
14-00 - Adaptation Limit (Add) Exceeded
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13504
Shop #: WSC 00046
No fault code found.
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 0.7.0
Coding: 01000
Shop #: WSC 00046
37-10 - Faulty - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 02 AIRBAG VW5 0004
Coding: 12338
Shop #: WSC 00046
01218 - Side Airbag Igniter; Passenger Side (N200)
32-10 - Resistance too High - Intermittent
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 821 A
Component: KOMBI+WEGFAHRS. BOO V28
Coding: 07142
Shop #: WSC 44598
Part No: Ident
Component: Nr. WEGFAHRS.:VWZ6Z0Y1630319
Ident.-Nr. WEGFAHRS.:VWZ6Z0Y1630319
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00000
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 4R Zentral-SG Komf. 0001
Coding: 00257
Shop #: WSC 00046
Part No: 1J1959801C
Component: 4R T
Mufa oxidata, putin sprei de contac si se rezolva problema, bafta.
Sunt 2 mufe implicate . ambele sub scaunul pasagerului.
am mers cu masina vreo 50km,am facut din nou o scanare si mia aparut iar eroarea legata de senzoru g70, ce o fi este ceva legat de debimetru?ma puteti lamuri si pemine?am sesizat o usoara crestere a consumului
MasinaPoporului
ddress 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1Z0 907 115 HW: 1Z0 907 115
Component: 2.0l R4/4V TFSI 0010
Revision: --H14--- Serial number: SKZ7Z0F3509595
Coding: 0203000318070060
Shop #: WSC 73430 790 00000
4 Faults Found:
001537 - Internal Control Module: Memory Check Sum Error
P0601 - 001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 2
Mileage: 137137 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 36.0
Modificat de MasinaPoporului
Eroare de memorie sau ecu.Iei legatura cu un chip tuner daca apare din nou eroarea, poate rescriere soft in prima faza.
Rica_42 e plin forumul de subiecte legate de debitmetru.Verifici sa nu ai aer fals pe admisie sa fie cablurile in regula si apoi eventual, daca ai posibilitatea, faci un test cu alt maf.
Daca nu, cumperi alt maf ptr ca nu se repara.
MasinaPoporului
Si acesta sa fie motivul pentru care nu trage masina? S-au asa s-ar rezolva problema? Prin rescrierea ECU-lui?
Ai destule eroari care pot genera ca efect putere scazuta.Insa cea mai mare pb ma gandesc ca este ecu, hardware sau software.Apare des eroarea?
MasinaPoporului
Pai...se sterge...si dupa 30 de minute de mers apare din nou. Sa inteleg ca sonda lambda(a 2 a) sare din schema.
A doua sonda vede doar starea sistemului de reducere a noxelor si nu are o influenta atat de mare in functionarea motorului.Daca scoti ambele sonde motorul trebuie sa traga doar ca o sa consume mai mult.
Dar ce insemana ca "nu trage masina"?Bineinteles ca trebuia sa traga masina mai prost sau mai bine fara debitmetru.Deci poti avea si debitmetrul cu pb si fara eroare.
Vreau sa stiu,dacascoaterea sigurantelor din tabloul de siguranta,si punerea lor la loc,pot genera anumite erori,cind se face testu.Am cautat acum ceva timp siguranta de la farul din dreapta,si scotindule pe rind una cite una,la un moment dat am scos una dintre ele si sa oprit motorul.....probabil,cred eu ca asa sa intimplat si cu cea de la debimetru,si care zic eu ..parerea mea(cunascatorii sa ma contrazica),mia dat erorile de mai sus.Aceste erori leam sters si nu au mai aparut,cu exceptia celei de la MAF,care a reaparut din cauza caam scos mufa,si apoi am puso inapoi,azi am sters eroarea si nu a mai reaparut
Normal ca apar erori daca scoti sigurantele.Erorile intermitente se sterg si apoi vezi cand reapar.
Eroare gasita la scanarea cu Vag-com : 17746 - Camshaft Position Sensor (G40) Open or Short to Plus
P1338 - 35-10 - - - Intermittent
Unde se afla pozitionat acest senzor ?
Multumesc anticipat !
Sal ti-am explicat pe mes cum sa faci sa-l identifici.
Nu doar pornirea este afectata ci si performantele motorului.
am facut o scanare la un g5 si mia aparut o eroare la AC
18049-Please check DTC Memory of A/C controler
P1641-ooo---
poate sa imi spuna cineva ce inseamna asta?
Multumesc divinewind pentru ajutor !
Modificat de Marmonu
Salut,am si eu o Fabia 1.4 16v 74kw si am ceva probleme cu ea de cand am achizitionat-o.Ultima si cea mai disperanta problema esta ca imi pica in nas in timpul accelerarii, am fost la test si imi da 2 erori p1348 si p1349 stiti cumva cum as putea remedia problema?
numi merge stergatorul de la luneta,eu banuesc ca e de vina maneta,in acest caz nu ar trebui sa-mi dea o eroare cu ceva contact imperfect,in instrument cluster?
Diagnoza asta este un noroc daca iti ofera niste alarme cand ai pb dar nu e batut in cuie sa ai alarme neaparat cand ai un defect. Senzorii totusi costa si sunt pusi in zonele importante ale masinii nu peste tot.
salut,am si e o problema la masina din semnatura,imi moare motorul la relantiu si in timpul mersului in da in nas pe la 80 daca o tin constant,pe vag nu da nici o eroare ce ar putea fi?:screwy:
  • Aerofan pinned this topic
    • bogdan_vw_11
