suzu
verifica MAF-ul, pompa de combustibil, valorile injectoarelor
1. Care MAF la motorul in cauza? :rolleyes: MAP...
2. Valorile injectoarelor la "benzinar", unde le citesti? :rolleyes: Nu ai unde.
:icon_thumright:
Modificat de xxnelu
Corect d-nul Nelu - din graba de a traduce ce era pe wiki am omis ca era vorba de un benzinar. Mea culpa.
Poate cineva sa-mi zici ce inseamna erorile de mai jos :
Address 01: Engine
Control Module Part Number: 036 906 034 CN
Component and/or Version: MARELLI 4MV 3957
Software Coding: 00031
Work Shop Code: WSC 67601
Additional Info: WVWZZZ1JZ2W236536 VWZ6Z0A3761029
3 Faults Found:
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-10 - - - Intermittent
17566 - Manifold Pressure Sensor (G71): Implausible Signal
P1158 - 35-10 - - - Intermittent
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
Possible Symptoms
* Malfunction Indicator Light (MIL) active
Possible Causes
* Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
* Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
* Evaporative Emission (EVAP) Canister Sealing faulty
* Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
* Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
o Perform Output Test
* Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
o Perform Basic Setting
* Check Pipes between Tank Breathing and Throttle Body
17566/P1158 - Manifold Pressure Sensor (G71): Implausible Signal
Possible Causes
* Connections to / from sensor (G71) faulty
* Sensor (G71) faulty
Possible Solutions
* Check wiring and connections
* Check hoses
* Check / Replace Manifold Pressure Sensor (G71)
18058/P1650/005712 - Powertrain Data Bus: Missing Message from Instrument Cluster
Possible Symptoms
* Malfunction Indicator Light (MIL) ON
Possible Causes
* Fuse(s) faulty
* Databus Wiring and/or Connector(s) from/to Instrument Cluster (J285) faulty
* Instrument Cluster (J285) faulty
Possible Solutions
* Check Fuse(s)
* Check Databus Wiring and/or Connector(s) from/to Instrument Cluster (J285)
* Check/Replace Instrument Cluster (J285)
o Check Measuring Value Blocks (MVB)
Rescaneaza dupa o perioada de timp si vezi daca mai apar erorile pe Engine . Tine-ne la curent
Azi am scanat azi pe Engine si iara au aparut.
2 Faults Found:
00561 - Mixture Adaptation
14-10 - Adaptation Limit (Add) Exceeded - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
E cumva pe duca lambda? Scanul Original e aici. Nu simt nici odiferenta sa zic ca nu merge cum trebuie, sau consuma aiurea sau sa fluctueze relantiul, missfire, samd.. :unsure: Au legatura intre ele una cu alta?; adica mixture adaptation sa dea cea de pe lambda sensor?
Modificat de volnick1986
La un A6 1.8T 180cp quattro a dat urmatorul cod si eroare:
17953 P1545 Throttle valve control - malfunction
Cause :
Throttle valve tight/sticking,wiring,throttle control unit.
Ce poate fi?Cum se poate repara?
17953/P1545/005445 - Throttle Valve Controller: Malfunction
Possible Symptoms
Increased Idle Speed
Bucking at Load Change
Possible Causes
Throttle Body dirty
Throttle Body Wiring faulty
Throttle Body faulty
Possible Solutions
Clean Throttle Body
Check Throttle Body Wiring
Check Throttle Body
Special Notes
Use Meas. Blocks & Basic Setting for testing
When found in the NAR 2.0l TFSI: (BPY, CCTA and CBFA) check TSB 01-09-04 or 2018652 for a wiring repair at the Throttle Body.
Motorul e stabil la relanti,imi afecteaza cumva acceleratia?Pot sa o fac singur?Unde pot sa localizez aceasta valva,trebuie desfacut vreun capac ceva?M-am uitat da n-am gasit nimic
Ms frumos,o sa ma interesez de aditivu ala de curatare,iar daca nu reusesc cum scrie acolo,o duc la un service si explic treaba.
In legatura cu eroarea 00561 - Mixture Adaptation. Azi m-am uitat mai atent la indicatia voastra la furtune. Furtunul mare si gros (06A 145 708 B) de pe admisie avea o fisura de 1.5-2 cm. Dupa cum am mai zis eraorea nu aparea daca o stergeam, reporneam motorul si scanam iara. Cred ca doar la turatie mare aprarea eroarea; motorul tragand pe acolo aer fals.
Azi voi scana din nou fiindca ieri i-am dat un 5000 de ture si trebuie sa apara mai mult ca sigur. Am rezolvat provizoriu fisura in furtun. Daca v-a aparea si azi eroarea o voi sterge din nou si voi scana peste cateava zile sa vedem ce iasa cu taietura in furtun rezolvata.
LE: Scanata acuma! Intr-avevar aprause doar eraorea 00561 - Mixture Adaptation, fara 16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit.
Stau in expectativa.
Pentru 00561 - Mixture Adaptation Autodata zice possible causes: fuel level low, fuel pressure/pump, intake/exhaust leak, misfire, MAP Sensor, MAF Sensor filament burn of f, HO2S, EVAP canister plunge valve, injectors, excessive fuel in engine oil. Se apre ca ar fi intake leak... :icon_thumright:
@Turbocip Mersi de pont... :)
Multumesc din nou pentru raspuns
Aseara (supa ora 9) am reusit doar sa fac testul sondei si mia dat S1 B1 ok.
Asa am inteles si eu ca EGR la pornire este inchis.
Sper sa reusesc simbata sau miine sa ii fac verificarea cu voltmetru sa vad daca ajunge 12V la mufa pentru incalzirea sondei (stiu ca pe pinul 1 + 2 la mine este incalzirea (sonda cu 5 fire)).
Am facut si adaptarea clapetei de acceleratie la cald (80-90 grade). Am refacut adaptare EGR la cald (80-90 grade).
Dimineata mia aparut din nou eroare dar nu a variat turatia. Acum seara din nou a variat dar mai putin (1100-900).
Poate sonda lambda daca nu este incalzita la pornire la rece dimineata si la pornire din nou dupa 8 -10 ore sa dea ceva aiurea si sa trepideze?
Repet in mers nu am probleme.
Poate fi de la clapeta de acceleratie cu toate ca am curatato si am adaptato?
Atentie variatiile apar dupa 10-20 secunde de la pornire si dureaza 2-3 secunde.
Benzina de 95 are vreo problema la motoarele astea? trebuie 98?
Multumesc de raspuns, sincer intreb mai multe pentru ca nici nu am o zi intreaga la dispozitie sa stau sa iau la puricat toate.
Multumesc anticipat
Pina la urma rezolvarea sta cam asa la SONDA LAMBDA 1:
Am verificat cu VAG si cu multimetrul toate valorile, au iesit cum trebuie mai putin valoarea de 0.45 care nu prea se modifica.
Probabil la rece si din cind in cind se intimpla ceva in ea.
Se inlocuieste SONDA.Eu am montat NTK.
Valabil pentru toti cei care au problema asta.
La mine de 3 zile de cind am inlocuito nu mai trepideaza la relanti la rece si nici nu imi mai apare eroarea.
Succes si multumesc tuturor celor care mi-au raspuns si m-au ajutat si nu numai.
In cazul meu cu trepidatii la rece la relanti rezolvarea a fost cam asa:
Am masurat cu VAG si cu multimetrul toate valorile si am depistat ca valoarea de 0.45 nu prea se modifica.
Astfel am trecut la inlocuirea ei.
Am pus tot una NTK.
Dupa inlocuire la 3 zile :
Nu mai trepideaza la rece si nu mai imi apare eroare.
Concluzie:
La rece sonda lambda 1 da anumite date ECU-ului. Astfel daca ea nu fct cum trebuie pot aparea varatii ale turatiei la rece (adica cu soc).
Atentie este un caz mai particular nu e valabil pentru toata lumea.
La mine de exemplu cu toate ca eroarile erau:
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1: Electrical Malfunction
P1196 - 35-10 - - - Intermittent
17589 - Linear O2 Sensor; Reference Voltage: Open Circuit
P1181 - 35-10 - - - Intermittent
Am masurat circuitul de incalzire si era super OK R=4ohmi si tensiune12 V pentru alimentarea rezistentei de incalzire.
Vreau sa multumesc tuturor celor care au scris pe acest forum si sper sa ajute pe cineva problema si rezolvarea ei ca in cazul meu
Cu stima
Inginer Musteata Florin
Am din nou problema cu :
16785 - EGR System: Insufficient Flow
P0401 - 35-10 - - - Intermittent
Poate ma ajuta cineva cu ceva idei. Am curatat si testet in gr 74 Basic Setings.
Skoda fabia 1.4 16V, motor AUB
Cu stima si va multumsc anticipat.
16785/P0401/001025 - Exhaust Gas Recirculation (EGR) System: Insufficient Flow Detected
Possible Symptoms
* Reduced Exhaust Gas Recirculation (EGR)
* Reduced Power Output/Engine running rough
* Increased Emissions
Possible Causes
* Exhaust Gas Recirculation (EGR) Flow restricted/clogged
* Exhaust Gas Recirculation (EGR) Valve stuck closed/leaking/faulty
* Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve faulty
* Exhaust Gas Recirculation (EGR) System faulty
Possible Solutions
* Check/Clean Exhaust Gas Recirculation (EGR) System
* Check/Replace Exhaust Gas Recirculation (EGR) Valve
* Check Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve
Daca ne luam dupa asta, dupa curatare si adaptare, mai ai de verificat cabluri sau inlocuire.Sau poate vrei sa o anulezi daca banii lipsesc.
Am o skoda fabia pe benzina(1,4mpi) si mi s-a aprins un indicator pe bord. nu stiu care pt ca sotia era cu masina. cand a ajuns acasa nu mai era aprins. oprise si pornise din nou motorul. in fine, masina a mers ok, cica nu a facut figuri. i-am facut un test cu vag com acasa si am gasit eroarea asta
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 K
Component: LenkhilfeKYO X908
Coding: 00140
Shop #: WSC 13765
00816 - Power Steering Sensor (G250)
30-10 - Open or Short to B+ - Intermittent
am sters-o si am facut testul iar si nu a mai aparut. ma gandesc ca masina e ok acum daca nu mai apare dar as vrea sa stiu de la ce e eroarea asta??
Mersi!
00816 - Power Steering Sensor (G250): Short to Ground
00816 - Power Steering Sensor (G250): Open or Short to Plus
00816 - Power Steering Sensor (G250): Faulty
Possible Symptoms
* Steering stiff
* Power Steering in Emergency Mode
Possible Causes
* Wiring/Connectors from/to Power Steering Sensor (G250) faulty
* Power Steering Sensor (G250) faulty
Possible Solutions
* Check Measuring Value Blocks (MVB)
* Check Wiring/Connectors from/to Power Steering Sensor (G250)
* Check Power Steering Sensor (G250)
Hmm si unde o fi senzorul ala?? cum sa-l verific? merge cu vag com sau cum? mersi!
Modificat de adonis75
Il gasesti pe caseta de directie, pe coloana volanului. Verifica mufa, contactele...
Buna Ziua, am si eu urmatoarea problema am facut o scanare si mi-au rezultat urmatoarele erorii:
4476 Circuit incalzire sinda lambda ( banc 1, senzor 2) intrerupere
408D Circuit incalzire sonda lambda ( banc 1, senzor 2 ) Defect electric
4074 Senzor temperatura agent racire Semnal neplauzibil
Astept un raspuns cu o indrumare, ce as putea sa fac.
Ma poate ajuta si pe mine cineva ?
Aici pentru primele 2 erori.
Iar la sonda de apa verificat contacte cabluri sau schimbata sonda.
Modificat de divinewind
M-am uitat dar nu am vazut nici un raspuns concret ce ar putea fi, am mai schimbat o sonda(cumparata de la volksman de aici de pe forum, originala bosch) si eu sper sa nu fie tot sonda. Vreau sa stiu ce as putea sa fac ca de "mesteri" sunt satul ma duc in 5 locuri si aud 5 pareri diferite si nu prea as mai lua o sonda noua si dupa nici un an sa pice si aia. Va multumesc.
Verifica conectica / iar daca e ok Schimba Sonda !
Modificat de Turbocip
din cind in cind la masina consoartei apare eroarea:
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 35-10 - - - Intermittent
sa ii fi cazut si la asta catalizatorul? ca nu are asa de multi km.... (in comparatie cu bora de care aminteam acu vero 2 pagini...)
un amic are pe motorul de 1,4 eroarea:
17573 - Long Term Fuel Trim Additive Air; Bank 1; Range 1: System too Rich
P1165 - 35-00 -
uneori i se aprinde becul de motor, alteori nu....
16804/P0420/001056 - Catalyst System; Bank 1: Efficiency Below Threshold
Possible Causes
Leakage in Intake and/or Exhaust System
Catalyst faulty
Oxygen Sensor(s) faulty
Oxygen Sensor(s) Control faulty
Possible Solutions
Check Intake and Exhaust System for Leaks
Check Catalyst
Check Oxygen Sensor(s)
Check Oxygen Sensor(s) Control
Perform Oxygen Sensor(s) Aging Check
17573 P1165
Combustibil com schema 1 termen lung, de la 1 la limita cilinderrij bogate depăşit
du 1 Banca, 1 Gemischadaption Bereich Fettgrenze
Salutare!
Sunt nou pe acest forum.
Am cautat, am dat si search, sa aflu si eu mai multe despre ce inseamna eroarea la calculatorul de motor 18011 cu P1603, probabile ECM defective.
Tin sa precizez si problemele masinii: golf V 2006. Asta vara mi-se oprea motorul in mers cand aveam aerul pornit. Pe bord imi arata gresit consumul instant, ajunge si la 99%, Si ultima problema: daca o pornesc direct fara sa las sa dispara beculetele de pe bord imi da chix, nu porneste.
Masina are 62000km.
Nu am gasit unde e mai corect sa postez aceasta intrebare. Si nici nu imi permit sa-i schimb calculatorul de motor(5000lei).
Liviuplaton, multumesc stiu sa caut pe rosstechwiki (de eroarea aia am zis ca am scris mai sus si am primit raspuns; in cazul de fata acelasi raspuns ma nemultumeste :D )
  • Aerofan pinned this topic
