suzu
Buna,
Am scanat masina unui amic , un Skoda Fabia 1 si am urmatoarele erori:
VCDS Version: Beta 912.0
Data version: 20091201
Friday,06,August,2010,15:48:30:46862
Chassis Type: 6Y - Skoda Fabia I
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: TMBJC26Y933810525 Mileage: 98840km/61416miles
Address 01: Engine Labels: 036-906-034-APE.lbl
Part No: 036 906 034 CB
Component: MARELLI 4MV 4831
Coding: 00071
Shop #: WSC 13765
TMBJC26Y933810525 SKZ7Z0C1950299
4 Faults Found:
16517 - Oxygen (Lambda) Sensor B1 S1: Response too Slow
P0133 - 35-10 - - - Intermittent
17550 - Load Calculation Cross Check: Lower Limit Exceeded
P1142 - 35-10 - - - Intermittent
17961 - Barometric / Manifold Pressure Signals: Implausible Correlation
P1553 - 35-10 - - - Intermittent
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6Q0-907-37x-ASR.lbl
Part No: 6Q0 907 379 H
Component: ABS/ASR 5.7 FRONT V30
Coding: 00124
Shop #: WSC 13765
01314 - Engine Control Module
79-10 - Please Check Fault Codes - Intermittent
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Y0 820 045
Component: Klimaanlage X0830
6 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
30-10 - Open or Short to Plus - Intermittent
01596 - Motor for Outside/Recirculated Air Flap (V154)
29-10 - Short to Ground - Intermittent
28-10 - Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 25738
Shop #: WSC 13765
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: 05 AIRBAG VW51 08 0008
Coding: 12341
Shop #: WSC 13765
Address 17: Instruments Labels: Redir Fail!
Part No: 6Y1 920 880 G
Component: KOMBIINSTRUMENT VDO V13
Coding: 16141
Shop #: WSC 10142
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 34 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 13765
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 R
Component: LenkhilfeKYO V913
Coding: 10140
Shop #: WSC 13765
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 2S Komfortger
Din cate observ toate erorile sunt intermitente ceea ce ma duce cu gandul la contacte imperfecte. Verifica conexiunile in special la mufe (sa nu fie contacte oxidate, legaturi la masa bine facute,) apoi sterge erorile si vezi daca mai apare ceva. Verifica si contactul de la pedala de frana.
Dupa ce ai sters erorile au aprut iar?Care?
Am si eu o eroare scanata cu VAG-COM 908:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Control Module Part Number: 1C0 959 799 B
Component and/or Version: 1C Komfortger
Sterge eroarea si fa adaptarea aceasta:
Pinch Protection Adaptation
Make sure the window in question is completely closed.
Use the driver door window buttons to operate the window(s).
Roll down the window and keep holding the button down for 2 additional seconds after the window is already fully opened.
Roll up the window and keep holding the button up for 2 additional seconds after the window is already fully closed.
Now test the window automatic.
Cred ca nici ridicarea automata nu iti merge .
Ba da, merge...de coborat coboara fara probleme, la urcat ii mai greu, se ridica foarte incet. Am sa incerc ce mi-ai sugerat si am sa revin cu un raspuns.
Salut, dupa ce am cumparat o interfata vag-com (clona) si am facut o scanare cu vag-com 311.2 am obtinut urmatoarele
Tin sa mentionez ca sunt novice ;)
VAG-COM Version: Release 311.2-N
Chassis Type: 1H - VW G/J/V Mk3
Scan: 01,02,03,08,15,25,56
Address 01 -------------------------------------------------------
Controller: 032 906 026 D
Component: 1,6l R4 MONO 1.3 D71
Coding: 00000
Shop #: WSC 00000
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1H0 907 379 D
Component: ABS TEVES 04
10 Faults Found:
00274 - ABS Inlet Valve: Left Rear (N134)
35-00 - -
00532 - Supply Voltage B+
35-00 - -
00283 - Front Left ABS Wheel Speed Sensor (G47)
35-00 - -
00285 - ABS Wheel Speed Sensor: Front Right (G45)
35-00 - -
00290 - ABS Wheel Speed Sensor: Rear Left (G46)
35-00 - -
16-00 - Signal Outside Specifications
04-00 - Mechanical Malfunction
01276 - ABS Hydraulic Pump (V64)
Skipping Address 15-Airbags
Address 25 -------------------------------------------------------
Controller: 1H0 953 257 B
Component: IMMO VWZ3Z0S0281966 V00
Coding: 09600
Shop #: WSC 60844
End -------------------------------------------------------
m-am documentat putin si dupa ce am masurat cu multimetrul ce imi spune manualul legat de ABS a rezultat ca nu merg urmatoarele :
Voltage Supply Test (Traction Control)
Turn ignition off. Using voltmeter, check voltage between ECU
harness connector terminals No. 1 and 35. See Fig. 3. Voltage should
be 10.0-14.5 volts. If voltage is not as specified, check battery,
ground, ABS fuse, relay and wiring. Repair as necessary. See WIRING
DIAGRAMS.
Eu am obtinut 0V, Poate cineva sa imi spun cum/de unde sa masor firele catre modulul de abs, am verificat sigurantele pt abs care sunt singurele exact deasupra de relee, la modelul meu cel putin.releele merg deoarece le-am verificat si pe ele dupa indicatiile din manual.
Right Front Wheel Speed Sensor Resistance Test
Turn ignition off. Using ohmmeter, check resistance between
ECU harness connector terminals No. 29 and 47. See Fig. 3. Resistance
should be 1.0-1.3 k/ohms. If resistance is not as specified, check
related wiring from ECU harness connector to wheel speed sensor for
opens, shorts or loose connections. Also disconnect wheel speed sensor
connector and check sensor. Repair/replace as necessary. See WIRING
DIAGRAMS.
Eu aveam 0 ohm
Am masurat firele care duc catre senzor si nu sunt intrerupte deci senzorul e dus, nu?
Left Front Wheel Speed Sensor Shielding Resistance Test
ECU harness connector terminals No. 1 and 30. See Fig. 3. Resistance
should be at least 2 megohms. If resistance is not as specified, check
chafing, loose connections or other damage. Repair/replace as
necessary. See WIRING DIAGRAMS.
Eu aveam cateva sute de kohm, dar culmea ca rezistenta senzorului de abs era in parametrii, eu deduc ca nici scurt nu face ca atunci nici rezistenta senzorului nu ar mai fi fost ok
Si inca ceva de ce imi zice: 17978 - Engine Start Blocked by Immobilizer
Modificat de cr33py2000
Immo iti taie motorul - nu iti recunoaste cheia (cateodata)
Eroarea 17978
@Turbocip am incercat treaba cu geamu 2sec up/2sec down dar nu a functionat, tot urca greu(incet). Cred ca e o cadere de tensiune undeva ... :)
Buna Ziua, am si eu urmatoarea problema am facut o scanare si mi-au rezultat urmatoarele erorii:
4476 Circuit incalzire sinda lambda ( banc 1, senzor 2) intrerupere
408D Circuit incalzire sonda lambda ( banc 1, senzor 2 ) Defect electric
4074 Senzor temperatura agent racire Semnal neplauzibil
Astept un raspuns cu o indrumare, ce as putea sa fac.
Salut ... la un golf 5 1.6 FSI din 2004 cod motor BAG da urmatoarea eroare . S-a schimbat senzorul G247 si eroarea persista ! ... ma puteti ajuta sa deslusim misterul?
Multumesc !
16575 - Fuel Pressure Sensor (G247): Implausible Signal
P0191 - 008 - Implausible Signal - Intermittent
Modificat de davides
@Turbocip am incercat treaba cu geamu 2sec up/2sec down dar nu a functionat, tot urca greu(incet). Cred ca e o cadere de tensiune undeva ... :wub:
Acolo ai facut adaptare - ca urca greu este alta problema - adica de natura mecanica ; geamul intampina rezistenta pe urcare.
Nu am facut nici o adaptare ca nu stiu ce adaptare sa fac, am facut doar treaba cu geamu` sus/jos+2 sec. si am sters eroarea...ciudat e ca in eroare scrie "rear right" dar eu am probleme la geamul pasagerului fata (fata dreapta) :huh: :offtopic: nu mai inteleg nimic
Modificat de batr
Aia cu 2 sec inseamna adaptare, invatarea de catre motora a pozitiilor de maxim sus si minim jos, la geamul care urca greu tb desfacut si vazut ce se intampla cu chederele sau poate fi altceva.
pentru davides
16575/P0191/000401 - Fuel Pressure Sensor (G247): Implausible Signal
Possible Symptoms
* Malfunction Indicator Light (MIL) ON
Possible Causes
* High/Low Fuel Pressure implausible
* Low Fuel Level or Fuel Tank empty
* Wiring and/or Connector(s) from/to Fuel Pressure Sensor (G247) faulty
* Fuel Pressure Sensor (G247) faulty
Possible Solutions
* Check Fuel Tank Level
* Check Fuel Pressure
* Check Wiring and/or Connector(s) from/to Fuel Pressure Sensor (G247)
* Check/Replace Fuel Pressure Sensor (G247)
la ce faci referire cand zici Check Fuel Presure? Cum se verifica asta ? :icon_cheesygrin:
16522 - Oxygen (Lambda) Sensor B1 S2: Signal too High
P0138 - 35-10 - - - Intermittent
Nu am gasit niciunde o explicatie de la ce ar putea fi iar la wiki ross tech nu apare acest cod de eroare ca sa imi dea ceva solutii si cauze. Daca stityi voi careva cum pot remedia aceasta problema ar fi super ok.
Eroare gasita la ultima scanare cu Vagcom:
16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
P0011 - 35-10 - - - Intermittent
Stie cineva despre ce e vorba ? Mc.
Ai explicatia erorii AICI
si un pic tradusa AICI
Verifica alimentarea sondei si continuitatea rezistentei de preincalzire la sonda 2 -vezi in AUTODATA
Dupa cum mai spunea cineva: "precis ai problema din circuitul sondei(undeva frecat/julit sau chiar topita izolatia de caldura esapamantului"
Sper sa te ajute.
Domnu' lasa sonda in pace ca e buna :icon_cool:
E de la instalatia GPL. Cumpara-ti interfete VAG si GPL imprumuta un laptop daca nu ai, mai ia un amic cu tine si treci la reglat instalatia in mers...
Si eu am avut kkt-ul asta de eroare... si inca vreo 2...ma speriasem putin ca e sonda belita...am mers pe benzina o bucata de vreme, sonda mergea f bine , toate testele trecute la Readlines...
Dupa o tura de 2h prin oras , si prin parcarea goala de la un supermarket am ajuns sa merg bine, fara erori, singura chestie ca se pare ca a cam crescut consumul...
Trebuie sa o mai bibilesc putin...
Bafta coane :o
andrei.toledo
La un Golf 4 1.6 16v cod motor BCB a aparut de curand o problema.
Variaza turatia de relanti si motorul merge neregulat.Astazi s-au aprins si martorii EPC si motor.
Eroarea aparuta este :
Masina are montat un filtru de aer sport , dar am incercat si cu un capac motor cu filtru de aer normal in el si face la fel.
Ce ar trebui sa verific ? Clapeta de acceleratie este adaptata ok , altceva important ce ar mai fi de facut?Multumesc!
Te ajuta ASTA?
In autodata ai ca posibile cauze pentru alarma 17961:Intake/exhaust leak, EGR system, EVAP canister purge valve, throttle control unit, wiring, MAP sensor, BARO sensor;
Modificat de divinewind
salutare. poa' cineva sa imi spuna de unde pot sa iau si eu un manual sau o lista cu codurile de erori diagnosticate de vag com 908? mersi mult.
Cine ma ajuta si pe mine cu cele de la Engine:
VCDS Version: Release 908.0
Data version: 20090911
Wednesday,18,August,2010,20:27:13:13314
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 144630km/89868miles
Address 01: Engine Labels: 06A-906-018-AGU.lbl
Part No: 06A 906 018 CG
Component: 1.8L R4/5VT MOTR HS D02
Coding: 04000
Shop #: WSC 00046
2 Faults Found:
00561 - Mixture Adaptation
14-10 - Adaptation Limit (Add) Exceeded - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13504
Shop #: WSC 00046
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 0.7.0
Coding: 01000
Shop #: WSC 00046
37-10 - Faulty - Intermittent
Part No: 6Q0 909 605 A
Component: 02 AIRBAG VW5 0004
Coding: 12338
Shop #: WSC 00046
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 821 A
Component: KOMBI+WEGFAHRS. BOO V28
Coding: 07142
Shop #: WSC 44598
Part No: Ident
Component: Nr. WEGFAHRS.:VWZ6Z0Y1630319
Ident.-Nr. WEGFAHRS.:VWZ6Z0Y1630319
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00000
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 4R Zentral-SG Komf. 0001
Coding: 00257
Shop #: WSC 00046
Part No: 1J1959801C
Component: 4R T
  • Aerofan pinned this topic
