suzu
Am si eu o eroare, cred ca a aparut dupa ce am schimbat bujiile sau dupa ce am activat coming/leaving home:
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0191
Revision: H16 Serial number: 2000K07A238406
Coding: E9801F060002021302
Shop #: WSC 73430 790 00000
01312 - Powertrain Data Bus
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 202
Mileage: 52152 km
Time Indication: 0
Date: 2000.00.00
Time: 13:38:13
Pe wiki.ross-tech zice asa:
01312 - Powertrain Data Bus: Faulty
Possible Symptoms
* Malfunction Indicator Light (MIL) ON
Possible Causes
* Databus Wiring and/or Connector(s) faulty
Possible Solutions
* Check Databus Wiring and/or Connector(s)
Pe unde as putea sa gasesc mufele/firele de care e vb?
Multumesc anticipat!
Modificat de nervoss
Imi puteti spune si mie ce inseamna eroarea asta.La ce se refera?
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 P
Component: Radio BVX 017 0023
Coding: 0020200
Shop #: WSC 01392 785 00200
1 Fault Found
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-00 - Implausible Signal
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermitten
In ordinea importantei ai:
16500/P0116/000278 - Engine Coolant Temp. Sensor (G62): Implausible Signal
Possible Symptoms
* Starting the engine when engine is warmish or warm, idle rpm immediately is 1200 - 3000 rpm.
o Diesel: an indication is extreme long time burning time of the glow indication light.
* With all engine temperatures seldom idle rpm will vary between 900 - 1000 rpm.
* With engine warm (90
Salutare.Mi-a aparut urmatoare eroare la o scanare cu vag-com:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 03E 906 033 P
Component and/or Version: 1.2l/4V SIMOS3 00HS4729
Software Coding: 00071
Work Shop Code: WSC 06402
Additional Info: VSSZZZ6LZ3R258552 SEZ7Z0C2078229
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-00 - -
Masina este un Seat Ibiza an 2003,motor 1.2 si merge in parametri normali...trage,relantiul stabil.
Aveti vreo idee ce ar putea fi?Am cautat pe internet eroarea insa scrie mai mult in engleza si nu prea inteleg termenii tehnici.
Ca idee am schimbat in urma cu 2 luni distributia.
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
Evaporative Emission (EVAP) Canister Sealing faulty
Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
Perform Output Test
Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
Perform Basic Setting
Check Pipes between Tank Breathing and Throttle Body
Special Notes
When found in the NAR 1.8T Audi A4 1.8T check TSB 24-08-78 or 2010268/3 or Pass-Thru equivalent TSB
When found in the NAR 1.8T VW Passat 1.8T check TSB 01-09-09 or 2005554 or Pass-Thru equivalent TSB
Note: The Passat 26E5 or "R5" recall includes the same software update
Pe scurt, verifica canistra de carbon si conectivitatea catre aceasta.
Ma poate ajuta si pe mine cineva cu o solutie pentru urmatorul raport de diagnoza:
3 Faults Found:
16575 - Fuel Pressure Sensor (G247): Implausible Signal
P0191 - 008 - Implausible Signal - Intermittent
18354 - Control Module 1 for Coolant Fan: Defective
P1946 - 004 - No Signal/Communication - Intermittent
17441 - Sensor for NOx (G295): Signal too Low
P1033 - 002 - Lower Limit Exceeded - Intermittent - MIL ON
Martorul check engine este aprins iar daca scot borna de la baterie ramane stins pentru aprox 400km dupa care iar apare.
Multumesc anticipat.
16575/P0191/000401 - Fuel Pressure Sensor (G247): Implausible Signal
Possible Symptoms
Possible Causes
High/Low Fuel Pressure implausible
Low Fuel Level or Fuel Tank empty
Wiring and/or Connector(s) from/to Fuel Pressure Sensor (G247) faulty
Possible Solutions
Check Fuel Tank Level
Check Fuel Pressure
Check Wiring and/or Connector(s) from/to Fuel Pressure Sensor (G247)
Check/Replace Fuel Pressure Sensor (G247)
Special Notes
When found in VW Polo (9N) with 1.4l FSI (AXU), check TPI 2009218 which describes a problem with the Fuel Pump.
Poate parea o intrebare stupida dar...canistra de carbon e rezervourul nu?
Cei din reprezentanta VW au zis ca sondele lambda sunt duse. Nu mi-au dat codurile de eroare insa am facut un diag cu vag-com (prima diagnoza):
Readiness Status: 1010 0001
Exhaust Gas Recirculation: Failed or Incomplete
Oxygen Sensor Heating: Passed
Oxygen Sensor(s): Failed or Incomplete
Air Conditioning: Passed
Seconday Air Injection: Passed
Evaporative Emissions: Passed
Catalyst Heating: Passed
Catalytic Converter(s): Failed or Incomplete
Sunt sau nu duse sondele lambda? Poate careva sa imi zica cum as putea sa le testez/verific functionalitatea lor cu vag-com?
Modificat de TheSame
Ce ai postat nu este rezultatul unei scanari. Posteaza codurile de eroare identificate in urma diagnozei.
Nu am coduri de eroare, tocmai am zis ca cei de la reprezentanta nu mi-au dat erorile, au zis doar ca is duse. Scanarea am facut-o eu cu vag-comul personal.
Am inteles ce ai spus anterior. Iti sugerez sa faci o scanare corecta si sa postezi rezultatele aici. Foloseste autoscan .
Modificat de pronet
OK, am sa o fac zilele urmatoare. Poti sa imi zici cum as putea verifica parametrii sondelor (un document/howto e suficient chiar daca e in engleza)? Tot caut pe acest forum insa nu gasesc :) .
OK, merci mult!
Ieri s-a aprins pentru a 3-a oara martorul de motor pe bord dupa ~ 80km de mers.
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-00 - -
Readiness: 0000 0001
Dupa ce am facut testul de mai sus (Testare MAF, senzori O2 si catalizator cu VAG-COM) am mai rulat diagnoza sa vad daca mai apare eroare:
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
Readiness: 1000 0001
Se pare ca lambda de dupa catalizator e kaput :).
Am o mare rugaminte la domniile voastre, daca ma poate ajuta si pe mine cineva cu o solutie pentru urmatorul raport de diagnoza:
3 faults Found:
17586 - Linear O2 Sensor ; Pump Current: Open Circuit
P1178 - 35-10 - - - Intermittent
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1: Electrical Malfunction
P1196 - 35-10 - - - Intermittent
17589 - Linear O2 Sensor; Reference Voltage: Open Circuit
P1181 - 35-10 - - - Intermittent
Stima.
Cine ma poate ajuta cu o sugestie la urmatoarea eroare:
- la inceput a fost: 17700 - Map Controlled Engine Cooling Thermostat (F265): Open Circuit
P1292 - 35-10 - - - Intermittent
-iar acum: 17700 - Map Controlled Engine Cooling Thermostat (F265): Open Circuit
P1292 - 35-00 - -
L-am identificat ca fiind poz. (12) din imagine. Am verificat mufa si e in regula, am o tensiune de aprox. 9V cu motorul oprit si 11V cu motorul pornit la mufa.
Se poate intampla ceva grav daca merg cu el asa? Ce rol are senzorul asta? In bord imi sta aprins "check engine".
salut
ma poate ajuta cineva cu o rezolvare la problema urmatoare?
martorul de esp ramane aprins mereu.
imi cer scuze daca a mai aparut asa ceva inainte dar nu am timp sa caut, trebuie sa o rezolv urgent
mersi
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019458
Shop #: WSC 00046 615 1234567
01542 - Yaw Rate Sensor (G202)
012 - Electrical Fault in Circuit
Urgent: Senzor inclinatie
Are probleme electrice .
In caz ca o sa iti trebuiasca si codarea de Basic Settings:
Prerequisites:
Ignition ON
Engine OFF
System voltage at least 11.0 V.
[select]
[01 - Engine]
[basic Settings - 04]
Group 063
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
Press the pedal to the floor and hold it their for at least 2 seconds.
Observe Field 4, once the adaptation is successfully done it should show "ADP. O.K.".
[Done, Go Back]
[Close Controller, Go Back - 06]
Switch Ignition OFF
salut ...s-a aprins check engine , am scanat si mi-au dat urmatoarele:
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 036 906 032 L
Component and/or Version: ME7.5.10 3758
Software Coding: 00031
Work Shop Code: WSC 01120
Additional Info: WVWZZZ1JZ2U020032 VWZ6Z0A3781796
4 Faults Found:
17524 - Oxygen (Lambda) Sensor Heating; B1 S1: Open Circuit
P1116 - 35-10 - - - Intermittent
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
P1118 - 35-10 - - - Intermittent
16525 - Oxygen (Lambda) Sensor B1 S2; Heating Circuit: Malfunction
P0141 - 35-00 - -
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-00 - -
Readiness: 0010 0101
  • Aerofan pinned this topic
