suzu
UPDATE :( :D :D
mai bine nu reuseam sa fac interfata sa mearga.......
asa nu m-as fi ales cu o durere de cap
help:
Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.067 H08 1901
00750 - Warning Lamp
013 - Check DTC Memory - Intermittent
Freeze Frame:
Mileage: 24680 km
Temperature: 24.0
Ma poate ajuta cineva am aceste erori. Ieri am scanat cu vagul si am avut aceasta eroare l-am sters si apoi iara a aparut !!!
17912 - P1504 Intake Air System: Leak Detected
17746/P1338/004920 - Camshaft Position Sensor (G40): Open or Short to Plus
Scaneaza pe 01-Engine si cu motorul pornit si vezi daca iti mai apare G40
Pentru codul 17912 cred ca ar trebui sa verifici daca nu ai pierderi de aer pe la admisie, sistemul EGR, clapeta de acceleratie etc.
Asa am scanat. Am sters eroarea. Am oprit motorul apoi am pornit si am scanat si a aparut din nou cu motorul pornit !!! .......... pierderi de aer pe la admisie, sistemul EGR, clapeta de acceleratie etc.- cum sa verific ???
Modificat de xxnelu
Te rog sa nu mai dai QUOTE/REPLY la mesajul anterior. Foloseste Add Reply.
Am si eu urmatoarea eroare:
001089 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 002 - Lower Limit Exceeded - Intermittent
Ce credeti ca este? filtrul de benzina posibil ?
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
Possible Symptoms
* Malfunction Indicator Light (MIL) active
Possible Causes
* Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
* Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
* Evaporative Emission (EVAP) Canister Sealing faulty
* Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
* Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
o Perform Output Test
* Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
o Perform Basic Setting
* Check Pipes between Tank Breathing and Throttle Body
Multumesc, dar nu prea inteleg termenii in engleza. Poti sa ma ajuti?
VW Beetle 1.6 2006 am gasit urmatoarele erori la motor
3 Faults Found:
17925 - Main Relay (J271): Electrical Malfunction
P1517 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-10 - - - Intermittent
Orice idei sunt binevenite .Multumec
Immobilizer reader coil - D2
Sporadic
01176 007
Key
Signal too low
Sporadic
Posibil sa ai probleme cu bobina imobilizatorului (din zona contactului) sau comunicare IMMO cu aceasta bobina.
Daca ai o a doua cheie, foloseste un timp aceasta cheie si vezi daca mai apar erorile.
salut
am de ceva vreme 3 probleme , 3 erori mai bine spus , 2 stiu de la ce sunt dar nu stiu cum sa le rezolv , a treia nici cei de la porsche nu sunt lamuriti
deci prima este
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 2620
Revision: 91H10262 Serial number: 0036M0001DMO
Coding: 0033622
Shop #: WSC 06335 000 00000
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 99
Time Indication: 0
nu am schimbat nimic legat de airbaguri sau controlere la masina
cred ca trebui facut un reset sau ceva de genul cu vcds-ul dar nu prea stiu cum
am gasit ceva oficial de la audi legat de treaba asta dar i-mi este sila sa ma duc la porsche stiind aproape sigur ca o sa refuze
audi.tb.01_05_02.pdf
a doua eroare , tot pe airgag
Address 46: Central Conv. Labels: None
Part No: 8E0 959 433 BJ
Component: Komfortger�t T23 2331
Coding: 06768
Shop #: WSC 06335
Part No: 8E1959801B
Component: T�rsteuer.FS BRM 0205
Part No: 8E1959802B
Component: T�rsteuer.BF BRM 0205
Part No: 8E0959801A
Component: T�rsteuer.HL BRM 0205
Part No: 8E0959802A
Component: T�rsteuer.HR BRM 0205
01366 - Opened Due to Crash Signal
36-10 - Open Circuit - Intermittent
banuiesc ca este una din mufele de sub scaune , am luat noi , le-am schimbat si la fel .
o practica prin service-uri pe la noi am vazut ca este eliminarea mufelor si legare direct fire intre ele .
are cineva idee despre o altfel de rezolvare ???
si ultima erore cea despre care mecanicii de la Porsche au spus ' este posibil sa fie pompa de joasa '
ddress 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8E0 910 115 J HW: 8E0 907 115 C
Component: 2.0l R4/4V TFSI 0080
Revision: --H02--- Serial number: XXXXXXXXXXXXXX
Coding: 01040003180F0020
Shop #: WSC 00191 264 15243
2 Faults Found:
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
P310B - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 2
Mileage: 55871 km
Time Indication: 0
Freeze Frame:
RPM: 1291 /min
Load: 40.8 %
Speed: 0.0 km/h
Temperature: 25.0�C
Temperature: 24.0�C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
este curios , deoarece eroarea apare doar dimineata la prima pornire , si nu de fiecare data .Am testat presiunea , am schimbat senzorul de pe pompa de inalta si din pacate nicio rezolvare .
cam despre astea este vb ,
o zi \ seara \ noapte buna
p.s. nu puneti citate de pe wiki.ross-tech.com ca am cam studiat si citit tot ce se poate
Modificat de dan28
autoemocion57
VAG-COM Version: Release 704.1
Address 01: Engine Labels: None
Part No: 036 906 034 BD
Component: MARELLI 4LV 3550
Coding: 00031
Shop #: WSC 00046
3 Faults Found:
17586 - Linear O2 Sensor; Pump Current: Open Circuit
P1178 - 35-10 - - - Intermittent
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1: Electrical Malfunction
P1196 - 35-10 - - - Intermittent
17961 - Barometric / Manifold Pressure Signals: Implausible Correlation
P1553 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 17: Instruments Labels: None
Part No: 1M0 920 821 A
Component: S5-KOMBIINSTR. VDO V03
Coding: 04106
Shop #: WSC 10176
Part No: IMMO
Component: IDENTNR: SEZ7Z0Y0935127
IMMO-IDENTNR: SEZ7Z0Y0935127
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
01314 - Engine Control Module
la alto sincro mi-au recomandat schimbarea sondei lambda 1. am scos-o si verificat-o singur si cele 5 fire au continuitate. mai mult de atat nu cred ca pot sa fac, decat sa cumpar alta. presupun ca asta ar duce la rezolvarea primelor doua erori la motor (sper). stie cineva ce e cu a treia ?
iar pt cea de la instruments - imi mai face figuri acul de la temperatura, deci probabil ca trebuie sa schimb senzorul (care am inteles ca nu e asa scump).
Modificat de gamer555
VAG-COM Version: Release 311.2-N
Control Module Part Number: 036 906 013 D
Component and/or Version: MED7.5.11 G 5129
Software Coding: 00031
Work Shop Code: WSC 46892
Additional Info: WVWZZZ1JZ2W675033 VWZ7Z0B5009314
17413 - Torque Difference Cylinder 2 Limit Value Exceeded
P1005 - 35-00 - -
Mi-a aparut eroarea asta, am sters-o si mi-a aparut din nou dupa o luna jumate (cam 1000 km facuti).
I-a mai aparut cuiva eroarea asta? Cum ati rezolvat ?
Posibil sa ai probbleme la injectorul nr. 2. Injector murdar sau chiar poti pierde compresie pe acolo.
Din ce cauza as putea pierde compresie ?
Modificat de gavrochem
autoemocion57
cu postul #870 ma poate ajuta cineva cu sugestii ? sau macar sa confirmati ce am scris la urma ?
Revin si eu cu erori recente.
Friday,21,August,2009,17:05:57:21461
Address 01: Engine
Control Module Part Number: 1P0 907 115 C
Component and/or Version: 2.0l R4/4V TFSI 0020
Software Coding: 0303000318070160
Work Shop Code: WSC 06441
4 Faults Found:
000291 - Throttle Position Sensor (G69): Signal too High
P0123 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 32996 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 30.0
Chassis Type: 9C - VW Beetle
Scan: 01,02,03,08,15,17,19,26,35,46,54,56
Address 01 -------------------------------------------------------
Controller: 06A 906 018 BQ
Component: MOTRONIC M3.8.5 HS V01
Coding: 00000
Shop #: WSC 00066
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 G
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 00000
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1C0 919 800 J
Component: KOMBI+WEGFAHRS. M73 V04
Coding: 02341
Shop #: WSC 00000
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 K
Component: 07 Zentral-SG Komf.0002
Coding: 00256
Shop #: WSC 00066
7 Faults Found:
01331 - Door Control Module: Driver Side (J386)
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
01179 - Incorrect Key Programming
35-00 - -
00932 - Electric Window Motor: Drivers Side (V147)
62-00 - No or Incorrect Adjustment
00928 - Locking Module for Central Locking: Front Driver Side (F220)
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
End -----------------------------------------------
pareri?
@BZ79DNL:
Vad ca ai o defectiune la Throttle Valve Controller, care e pe corpul clapetei de acceleratie.
Apoi mai sunt senzorii: unul de la pedala de acceleratie, cel de-al doilea de pe corpul clapetei.
Ar trebui sa verifici clapeta de acceleratie, eventual conectica firelor.
Masina se accelereaza bine? Daca ai cate 2 senzori, nu cred ca ai vreo problema in mers.
La mine "citirea" comenzii de acceleratie se face redundant: sunt 2 senzori la pedala de acceleratie, 2 pe corpul clapetei, care dirijeaza miscarea clapetei.
Investigheaza corpul clapeta, sfatul meu.
Kiar daca esti inginer,nu o sa te prinzi repede deloc.
Apropo de "prins" vin si eu cu o intrebare. Stiu ca nu e nici topic-ul dar poate nici momentul necesar, dar e cam urgent. Rog admin-ii sa ma ierte pentru aceasta postare "inutila" pentru unii, dar eu imi prin urechile! Este vb de masina varului meu, o Skoda Octavia `99 1.8 benzinara, pe care am pus-o pe diagnoza vag-com VCDS 805 (cumparata de mine si testata, chiar face toti banii). Ei bine, aici m-am confruntat cu foarte multe probleme, si anume (imi permit sa dau un copy-paste a grilei cu erori citite de interfata):
VCDS Version: Release 805.0
Data version: 20080529
Monday,24,August,2009,18:49:22:26365
Chassis Type: 1U - Skoda Octavia I
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
Mileage: 141630km/88004miles
Part No: 06A 906 018 DJ
Component: 1,8l R4/5V MOTR HS V01
Coding: 04000
Shop #: WSC 31480
4 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-00 - -
17916 - Idle Control Sys: Upper Regulation Limit Reached
P1508 - 35-10 - - - Intermittent
00561 - Mixture Adaptation
12-10 - Adaptation Limit (Mul) Exceeded - Intermittent
15-10 - Adaptation Limit (Add) Not Reached - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 H
Component: ABS/EDS 20 IE CAN 0001
Coding: 13504
Shop #: WSC 31480
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 603 A
Component: AIRBAG VW3 - V04
Coding: 00065
Shop #: WSC 31480
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1Ux-919-xxx-17.lbl
Part No: 1U1 919 033 C
Component: A+-KOMBIINSTR. VDO V19
Coding: 02142
Shop #: WSC 10137
Part No: IMMO
Component: IDENTNR: SKZ7Z0W0133192
IMMO-IDENTNR: SKZ7Z0W0133192
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 L
Component: 0W Zentral-SG Komf.0002
Coding: 04097
Shop #: WSC 31480
Part No: Steuerger
Component: t Fahr. antwortet nicht
Part No: Steuerger
Component: t Beif. antwortet nicht
Part No: Steuerger
Component: t HL antwortet nicht
Part No: Steuerger
Component: t HR antwortet nicht
9 Faults Found:
01328 - Convenience System Data Bus
01334 - Door Control Module; Rear Right (J398)
49-00 - No Communications
01333 - Door Control Module; Rear Left (J388)
01332 - Door Control Module; Passenger Side (J387)
01331 - Door Control Module; Driver Side (J386)
00930 - Locking Module for Central Locking; Rear Left (F222)
54-00 - Incorrectly Equipped
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
End ---------------------------------------------------------------------
Ce as putea sa fac? Rog pe cineva, daca a patit sau daca oarecum cunoaste erorile sa-mi explice ce si cum trebuie facut, vreau pe cat posibil sa evit un service pana nu stiu si eu macar VAG despre ce e vorba. Raspund la orice intrebare, de orice natura, doar va rog ajutati-ma!
Clapeta a fost data jos si verificata. O sa verific firele si corpul. Multam.
Modificat de BZ79DNL
nu stiu daca este aria corespunzatoare, dar tot caut si nu gasesc raspuns la o intrebare :( :
Am un vag-com 3.11 si vreau sa masor valori instantanee ale masinii (rpm, pozitia clapetei de acceleratie la diferite turarii...) dar nu stiu cum sa fac acest lucru :( , daca poate sa imi faca cineva o scurta lectie.... :icon_thumright: Am vazut pe forum mai demul niste tabele cu muulte date de unde puteai vedea daca este ceva inneregula cu masina, cum erau obtinute? :rolleyes:
  • Aerofan pinned this topic
