suzu
Polo, motor AUC 2001, cu urmatoarele erori :
17852 - Potentiometer for EGR (G212): Implausible Signal
P1444 - 35-00 - -
17811 - EGR System: Regulation Divergence
P1403 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
Daca a mai intalnit cineva, macar pe ultimele doua, ca nu gasesc chiar nimic.
Va multumesc.
Am facut si eu o scanare si am urmatoarele erori:
00792 - A/C Pressure Switch (F129)
35-00 - -
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
37-10 - Faulty - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
Masina e G4 2002 1.6 azd.
plz help !
Modificat de Bronzatu
Salutare
Stie cineva o remediere la acest cod de eroare:
16955 - Brake Switch (F): Implausible Signal
P0571 - 008 - Implausible Signal
Tin sa precizez ca ABS imi este dezactivat din aceasta cauza.
E ceva legat de contact frana, dar nu stiu ce si cum sa verific.
16955/P0571/001393 - Brake Light Switch (F): Implausible Signal
Possible Symptoms
Malfunction Indicator Lamp (MIL) active
Brake Light(s) not working
Possible Causes
Wiring and/or Connectors faulty
Fuse(s) faulty
Wrong Brake Light Bulb installed (21W instead of 5/21W)
Brake Light Bulb(s) faulty
Brake Light Switch (F) faulty
Possible Solutions
Check Wiring or Connectors
Check/Replace Fuse(s)
Check/Replace Brake Light Bulb(s)
Check/Replace Brake Switch (F)
Special Notes
Brake Light Switches (F) have the reputation of breaking quite often.
Retrieved from "http://wiki.ross-tech.com/index.php/16955/P0571/001393"
Trebuie sa schimbi switchul d ela pedala de frana pentru ca e posibil sa nu ti se aprinde becurile de la stop pe frana sau este posibil sa se aprinda si sa ramana aprinse tot timpul chiar si dupa ce ai incuiat masina.
@Bronzatu
00792 - switchul de la aer stricat. trebuie schimbat
00779 - senzorul de temperatura G82. incearca in measuring blocks sa vezi daca functioneaza. daca nu functioneaza trebuie schimbat.
01274 - fa un output test la clima/aer si apoi un basic settings.
00928 - cumva nu-ti merge inchiderea centralizata pe usa soferului ? e posibil sa fie ceva stricat acolo.
Daca le stergi iti mai apar ?
Incercati intai sa stergeti erorile si la urma postati aici doar daca mai apar. Sa nu poluam topicul cu posturi aiurea!
Modificat de kostas
Mai exact:
Possible Symptoms
A/C System not working
Possible Causes
A/C System Malfunctions
Over or insufficiently charged
Refrigerant System blockage
Insufficient Air Flow to Condensor and/or Engine Radiator
Wiring to/from A/C Pressure Switch (F129) faulty
Possible Solutions
Check A/C System for Malfunctions
Check Wiring to/from A/C Pressure Switch (F129)
Check A/C Pressure Switch (F129)
00779 - Outside Air Temperature Sensor (G17)
00779 - Outside Air Temperature Sensor (G17): Open / Short Circuit to B+
Possible Symptoms
In the Instrument Cluster you see dashes (---) instead of a temperature
Possible Causes
Wiring between Outside Air Temperature Sensor (G17) and Instrument Cluster:
Open or Short Circuit
Possible Solutions
Check wiring between Outside Air Temperature Sensor (G17) and Instrument
Cluster
Check Measuring Block Value
Pe langa cele mentionate de kostas ,daca nu se rezolva, ar mai fi de verificat firele/contactele aferente + alte (posibile) cauze mecanice, care ar putea impiedica buna functionare a cestuia...avand in vedere caracterul intermitent al erorii. Desigur, nu trebuie exclus din ecuatie motorul (V71)
revin cu erorile mele daca le mai are cineva si ce ar trebui sa fac(nu mi-a raspuns nimeni)
mentionez ca erorile s-au resetat ..dar au aparut iar ....check engine se aprinde dupa ce motorul sta pornit 5 min dupa resetarea erorilor..asta s-a int la ultimile 2 resetari ..nu stiu daca este de la sonda...caci acea ma intereseaza ...
bafta
In primul rand trebuie sa schimbi switchul de la pedala de frana.
Apoi verificare si eventual curatare cu spray de contacte a mufelor de la sonda lambda. Daca nu da rezultate trebuie schimbata sonda.
(S-au mai discutat astea pe forum. Foloseste SEARCH)
Modificat de kostas
Azi la un drum de 60 de km am patit urmatoarele: din nou revine problema cu blocarea relantiului la 1000 de ture, dar eroarea pe vag-com la G71 (sper ca retin bine, e vorba de senzorul de pe galeria de admisie) nu mai apare, tind sa cred ca ramane clapeta blocata din cauza mizeriei.
Am oprit in oras la un prieten si cand sa plec din parti curent. Nu se aprindea niciun bec la bord, usile se incuiau/descuiau aiurea. Am scos borna negativa la baterie pentru cateva secunde si apoi am reusit sa pornesc cu greu. Pe computeru de bord mi-a aparut " Alternator workshop", imediat mi-am dat seama ca bateria(care are doar 2 luni) s-a epuizat din cauza defectiunii la alternator.
Am primit urmatorile erori pe vag-com dupa ce am ajuns acasa:
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 01694
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J5 920 826 A
Component: KOMBI+WEGFAHRSP VDO V04
Coding: 03313
Shop #: WSC 00000
WVWZZZ1JZ2W050115 VWZ7Z0A3671267
2 Faults Found:
01314 - Engine Control Module
In timp ce mergeam mi-am dat seama ca am ramas si fara ABS, martorul clipind si ramanand aprins impreuna cu cel de airbag. Mi s-a aprins si martorul de ESP, chiar daca nu am ESP.
Bateria ii moarta complet, e vorba de o Varta Blue Dinamic. Sper sa nu o fi omorat de tot, si dupa reincarcare sa-si revina. Luni e programarea la service, sa vad ce are, pana atunci astept parerile voastre. Multumesc
Sunt "normale" atata timp cat ai probleme cu bateria.
N-am inteles prea bine ce vreti sa spuneti, daca puteti detalia va rog. Am incarcat azi bateria la redresor si am pornit. Am masurat cat incarca si valoarea e cam mica, 12.8 la relantiu, si 13 cu motorul un pic turat, deci clar am probleme cu alternatorul, ramane de vazut si care sunt.
@S C Foarte frumos descrisi pasii . Acum am inteles ce se intampla cu aceste erori. As mai fi vrut daca mai are ceva timp s c Cum se comporta motorul:
-cand este rece se aude toba cu mici rateuri (parca ar fi desprinsa si zangane de tabla)
-comsum mare si la viteza 130 km/h tendinte de intrerupere
-am curata MAFul si clapeta de acceleratie ,N80
-am schimbat filtrul de benzina si o sa continui cu bujiile
Poate totusi sa am sonda lambda defecta ? Iata erorile:
Address 01: Engine Labels: None
Part No: 071 906 018 R
Component: MOTRONIC M3.8.3 HS V01
Coding: 00000
Shop #: WSC 01317
6 Faults Found:
07-10 - Signal too Low - Intermittent
00518 - Throttle Position Sensor (G69)
30-10 - Open or Short to Plus - Intermittent
00525 - Oxygen (Lambda) Sensor (G39)
29-10 - Short to Ground - Intermittent
00553 - Mass Air Flow Sensor (G70)
31-10 - Open or Short to Ground - Intermittent
00561 - Mixture Adaptation
15-00 - Adaptation Limit (Add) Not Reached
01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
Readiness: 0000 1001
Dupa readaptare clapeta(am incercat si cu borna scoasa )au mai ramas doar astea:
12-10 - Adaptation Limit (Mul) Exceeded - Intermittent
Am incercat sa dau sonda lambda jos sa o curat si nu am reusit asa ca o sa incerc si cu bujiile.Poate totusi sa am sonda lambda defecta ?
Mii de multumiri!
pai stergele pe toate si vezi care mai revin....multe sunt pe intermintent
cam acum o luna am facut, cu ajutorul colegului oaspetele, o scanare cu VAG-ul si au iesit urmatoarele 4 erori:
17586 - Linear O2 Sensor: Pump Current: Open Circuit
P1178 - 35-10 - - - Intermittent
17972 - Throttle Actuator (J338): Under-Voltage during Basic Setting
P1564 - 35-10 - - - Intermittent
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1: Electrical Malfunction
P1196 - 35-10 - - - Intermittent
17563 - Manifold Pressure Sensor (G71): Short to B+
P1155 - 35-10 - - - Intermittent
de atunci am curatat clapeta de accel., am schimbat bateria si facut revizia cu tot ce inseamna ea. despre sonda lambda mi-a spus mecanicul ca e acel incalzitor de vina si degeaba imi curata contactele ca tot asa o sa faca.
acum, dupa o luna facut iarasi scanare si au ramas 3 erori...au ramas cele doua legate de sonda cred, dar a mai aparut acest 17961 care din cate am citit pe forum ar fi senzor presiune admisie daca nu ma-nsel.
17961 - Barometric / Manifold Pressure Signals: Implausible Correlation
P1553 - 35-10 - - - Intermittent
Readiness: 0010 0000
daca ma poate ajuta careva cu mai multe informatii !!!
Sonda Lambda trebuie schimbata din cate am inteles eu
si posibil sa traga aer fals sau sa fie bulit senzoru de presiune din admisie
la sonda este de vina incalzitorul ei care nu se gaseste separat...deci, da, trebuie sa schimb sonda.
nedumerirea mea era legata de senzorul de presiune (G71). La prima scanare imi spunea clar ca ceva nu era in regula cu senzorul G71, iar la ultima scanare imi zice, din cate am citit eu, ceva legat de presiunea din admisie. Sa fie oare tot din auza acelui senzor?
Din cate stiu acel senzor este localizat in ECU si nu stiu daca s-ar putea verifica. Daca stie careva un pret aproximativ sa vedem daca il schimb indiferent daca e defect sau nu.
Modificat de Miky_xXx
Sal! Va salut pe toti si imi pare rau ca va scriu in asa imprejurari.Inca un amanunt sunt nou pe aici si o sa ma straduiesc sa nu fac nici o gresala.
Am un golf4 din 2000,benzina,75cp,APE,am facut motorul(segmentare,distributie,rectificare vilbrochen) si dupa ce l-am facut am urmatoarele erori:
17748- Camshaft Position Sensor (G40) / Engine Speed Sensor (G28) Incor. Correlation
P1340 -35 10 .....Intermitent
16712- Knock Sensor 1 (G61) . Signal too High
P0328 - 35 -10 .....Intermitent
16525- Oxygen (lambda) Sensor Heating B1 S2 .Open Circuit
P0141 - 35 - 10 ....Intermitent
18010- Power Supply Terminal 30.Voltage too Low
Motorul merge bine,nu bate,se infige,dar la relanti oscileaza turatia intre 500 si 1100,iar intre 60 si 110km/h imi da in nas,iar cand plec de pe loc daca nu o accelerez imi moare motorul si face mereu indiferent ca e incalzit motorul sau nu.Am fost la 2 mecanici si mi-au spus ca distributia e 100% bine,cel care mi-a "facut" masina a zis ca daca gresea distributia si cu un dinte facea ca toti draci.Nu stiu ce sa ma mai fac,sa mai merg asa cu ea.Se poate intampla ceva rau?
VA MULTUMESC ANTICIPAT!
Trebuie sa verifici senzorul ax cu came si senzorul de viteza. Trebuie sa vezi daca senzorul Hall de la axul cu came e pozitionat corect.
De la acesti senzori ai problemele astea.
Help!
Cine ma poate ajuta cu aceste erori?
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Address 01 -------------------------------------------------------
Controller: 3B0 906 018 P
Component: 1.6L R4/2VSIM3 00HS0002
Coding: 06031
Shop #: WSC 05314
WVWZZZ3BZ4E222353 VWZ7Z0C8694385
4 Faults Found:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
17909 - Fuel Pump Relay (J17): Short to Ground
P1501 - 35-10 - - - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
16555 - Fuel Trim: System Too Lean: Bank 1
P0171 - 35-10 - - - Intermittent
Readiness: 0000 0000
Le-am sters o data si iar au aparut!
:Driver:
@golfulet
16804, verifica-ti catalizatorul
16804/P0420/001056 - Catalyst System; Bank 1: Efficiency Below Threshold
Possible Causes
Leakage in Intake and/or Exhaust System
Catalyst faulty
Oxygen Sensor(s) faulty
Oxygen Sensor(s) Control faulty
Possible Solutions
Check Intake and Exhaust System for Leaks
Check Catalyst
Check Oxygen Sensor(s)
Check Oxygen Sensor(s) Control
Perform Oxygen Sensor(s) Aging Check
16555/P0171/000369 - Fuel Trim; Bank 1: System Too Lean ,
Amestec sarac, ti-a taiat alimentarea.
Possible Causes
Mass Air Flow Sensor (G70) defective
Possible Solutions
Check Mass Air Flow Sensor (G70)
Check Fuel Pressure Regulation
Check Fuel Pump
Check Injectors
Check Intake System for Leaks
Check Exhaust System for Leaks
Check Secondary Air System for Leaks
Check Vacuum Pipes for Leaks
16518, sonda Lambda cred ca trebuie verificata, eventual schimbata.
17909, pompa de motorina are un scurt circuit, mergi la service.
Modificat de kostas
Domnilor am o problema la masinuta mea :vaidecapulmeu: 1.4 AXP.
Imi moare masina la relantii. Turatia scade pana pe la 500 RPM si fluctueaza pe acolo pana moare. Cu vag com am urmatoarea eroare ( chiar daca o sterg apare la loc ).
Daca merg turata cu ea merge fara nici o problema. Pliz help me.
  • Aerofan pinned this topic
