suzu
Spuneti-mi si mie va rog ce trebuie sa verific la eroarea de mai jos:
17413 - Torque Difference Cylinder 2
            P1005 - 001 - Limit Value Exceeded
Golf 5 1.6 FSI BAG
Salut.
Am si eu o eroare si nu stiu ce este:00369 - Fuel Trim; Bank 1: System Too Lean
Ce ar trebui sa verific?
Modificat de alecsutzyu
Daca tineti neaparat, discutia poate fi purtata pe pm, telefon, etc.
Aici discutam despre interfete originale Ross Tech, nicidecum despre clone.
salut ma puteti lamuri in legatura cu urmaroarele erori:
Address 01: Engine        Labels: 038-906-012-AGR.lbl
   Part No: 038 906 012 M
   Component:  1,9l R4 EDC 0000SG  2813
   Coding: 00002
   Shop #: WSC 00046
   VCID: 1A3B34EA863FB4CE7A7-4B36
2 Faults Found:
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 -  - Intermittent
17965 - Charge Pressure Control
            P1557 - 35-00 - Positive Deviation
Readiness: N/A
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 E
   Component: ESP FRONT MK60      0103
   Coding: 0019458
   Shop #: WSC 00046 615 1234567
   VCID: 2C57E2328CAB3A7E18B-5198
2 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
            008 - Implausible Signal - Intermittent
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 6Q0 909 605 A
   Component: 0F AIRBAG VW5  01   0004
   Coding: 12358
   Shop #: WSC 00046
   VCID: 3561C7560FE17BB6775-4B36
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J0 920 825 B
   Component: KOMBI+WEGFAHRS. BOO V01
   Coding: 01112
   Shop #: WSC 00046
   VCID: 275D1D1EC54D1926F59-5198
   Subsystem 1 - Part No: Ident
   Component: Nr. WEGFAHRS.:VWZ6Z0Y2100423
   Ident.-Nr. WEGFAHRS.:VWZ6Z0Y2100423
01176 - Key
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 00046
   VCID: F0EFB642B0039E9EE43-5198
No fault code found.
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AH
   Component: 4H Zentral-SG Komf. 0001
   Coding: 00257
   Shop #: WSC 00046
   VCID: 8407EA9294BB923E30B-4B36
   Subsystem 1 - Part No: 1J1959801C
   Component: 4H Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 4H Tõrsteuerger. BF0002r
3 Faults Found:
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
            35-00 - -
00944 - Heated Exterior Mirror; Passenger Side (Z5)
            35-00 - -
End   ---------------------------------------------------------------------
Presiune prea mare, cauta rezolvarea dupa LIMP MODE
2 Faults Found:
Senzor ABS stanga spate cu probleme sau firele pana la el intrerupte
3 Faults Found:
            35-00 - -
            35-00 - -
Nu merg oglinzile incalzite, este arsa rezistenta lor si ai probleme cu un switch de la portiera soferului.
Danielvw2 ai aceeasi eroare ca mine la ABS roata din spate dreapta e senzorul dus sau probabil trebuie doar curatat la mine trebuie schimbat si cele cu heated exterior mirror e o eroare la oglinzile incalzite eu o sterg si apare la o saptamana sau 2 ar trebui oglinda desfacuta si verificate firele dar "comoditatea asta" mai bine sterg erorile mereu... Cel mai bine ar fi sa stergi tot si sa mai dai odata start :)
Multumesc pentru raspunsuri.Toate cele bune
buna ziua .cine ma poate ajuta si pe mine cu erorile astea.inainte nu apareau.mentionez ca aseara am derapat cu masina si am iesit de pe sosea cu ea in sant.
astea sunt erorile
00668-supply voltage terminal 30
16-10- signal outside specifications-intermittent
01274-air flow flap positioning motor (v71)
37-10-faulty-intermittent
Modificat de george golf 4
Salut. Sper sa nu gresesc postul, dar ma poate ajuta cineva cu cateva locuri (site-uri) de unde sa imi pot achizitiona o interfata cu care sa pot pune functia range, iluminare ceasuiri, roll up etc? Voi vorbiti despre cele originale, si nu de clone, eu nu stiu care sunt clone si care sunt bune. Toti le lauda marfa ca si cum ari fi toate originale si atunci teapa este a mea.
originale - sunt cele originale... la VCDS este cea produsa de Ross Tech - costa in jurul la 1600 lei.
pe forum este interzisa discutia despre clone, cf regulamentului.
ceea ce vrei tu, se realizeaza cu soft-uri si interfete diferite, proceduri diferite, nu exista una care sa le faca pe toate. Foloseste functia Search, ca sa aflii despre fiecare functie, cum se activeaza si cu ce.
Salut ma mai ajutati va rog cu "decifrarea" urmatoarelor erori :
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004522735
   Coding: E38A0F2F00041000001D00000000000000017F075C
   Shop #: WSC 06441 785 00200
   VCID: 2B55E12E8AA53D46111-807E
   Subsystem 1 - Part No: 1P0 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SE350  012  0403
   Coding: 00056272
   Shop #: WSC 06441
   Subsystem 2 - Part No: 1P0 955 559   Labels: 1P0-955-559.CLB
   Component: REGENLICHTSENSORH04 0090
   Coding: 00137517
   Shop #: WSC 06441
01333 - Door Control Module; Rear Left (J388)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 113
                    Mileage: 74564 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.55 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H12 0170
   Revision:   H12       Serial number: 3300106A088397
   Coding: 7F3F07C007000202
   VCID: 2F6DF53EBEBD41663D9-807A
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 113
                    Mileage: 74564 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:08:28
multumesc
Verifica alimentarea de la usa stanga spate.
The Current version is:
Release 14.10.1
Data Version 20150130
Tocmai  am facut un test pe o skoda fabia 6y care are o singura cheie si am vrut sa intru cu codul login (aflat prin Eeprom reader) pe instruments 17/login a si acceptat codul de ex 08098 dar nu a mers mai departe nici dupa 5 minute ca sa pot sa selectez grupul 21 pentru adaptare chei  dar pe bord a ramas  martorul masina cu cheie aprins :((. Nu este nici un faultcodes si totusi martorul nu se mai stinge. Ce putem sa facem?
prin faultcodes a mai aparut sonda lambda a 2 a.
oare trebuie inlocuita daca conexiunea e ok?
2 Faults Found:
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
            P0140 - 35-10 - - - Intermittent
17526 - Oxygen (Lambda) Sensor Heating: B1 S2: Open Circuit
            P1118 - 35-10 - - - Intermittent
 Multumim!
S-a tot vorbit despre aceasta sonda in ultima perioada, ca sa-ti faci o0 idee, citeste vreo 5-10 pagini in urma. Sigur gasesti informatii care sa te lamureasca.
Avand in vedere "16524 - Oxygen (Lambda) Sensor B1 S2: No Activity" No activity = Dead => Change it; DAR, daca nu ai probleme, nu e urgenta.
salut, am facut si eu un scan la masina si am urmatorul log, nu stiu prea multe despre acest interpretari
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
VIN: WVWZZZ1JZ2W  Mileage: 166050km/103178miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 036 906 034 CN
   Component:  MARELLI 4MV        5164
   Coding: 00031
   Shop #: WSC 00000
   VCID: 60CF460BE0B6781EF43-4A9C
   WVWZZZ1JZ2W429673     VWZ6Z0A4051387
Readiness: 0000 0000
   Part No: 1C0 907 379 G
   Component: ESP FRONT MK60      0102
   Coding: 0011266
   Shop #: WSC 01317 785 00200
   VCID: 2E53E833BAE29E6E36F-5000
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 01317
   VCID: 2149030FAB3C3116BBD-5072
   Part No: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0004
   Coding: 12855
   Shop #: WSC 01266
   VCID: 224B0C03AE3A2A0EA27-5072
   Part No: 1J0 920 826 A
   Component: KOMBI+WEGFAHRS. RB8 V11
   Coding: 01113
   Shop #: WSC 00050
   VCID: 275D1D17C518CF26F59-5000
   Coding: 00006
   Shop #: WSC 01317
   VCID: F0EFB64BB056489EE43-5000
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: 1C Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 01317
   VCID: 3663C05312B2A6AE7EF-4A3A
   Subsystem 1 - Part No: 1C1959801A
   Component: 1C Tõrsteuer.FS KLO 0002
   Subsystem 2 - Part No: 1C1959802A
   Component: 1C Tõrsteuer.BF KLO 0002
   Subsystem 3 - Part No: 1C0959811A
   Component: 1C Tõrsteuer.HL KLO 0002
   Subsystem 4 - Part No: 1C0959812A
   Component: 1C Tõrsteuer.HR KLO 0002
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00934 - Electric Window Motor; Rear Left (V26)
Ai probleme cu modulul de inchidere centralizata pe stanga fata (F220) si cu motorasul de la geam de pe stanga spate (V26). Ambele erori sunt intermitente asa ca eu suspectez contacte imperfecte. Verifica circuitele & conectorii (curata conectorii cu spray de contacte), sterge erorile si vezi daca mai apar. .
Modificat de ionel.d.2007
NU pot decat sa-ti spun asemanarea dintre ele, sunt CLONE. Una originala este 1600 lei. Si acum este la vers 14.2.0
Salut puteti sa ma lamuriti si pe mine in legatura cu urmatoarea problema :In urma verificari km la 2 masini diesel acestea au fost cu 400 km mai putin fata de cei din bord e normal sa fie asa?
multumesc
Da poate sa fie o dif. de 5% intre ele(scrie si in mesajul vdcs).
NU ca poate, chiar trebuie sa fie o diferenta. daca nu sunt diferente, atunci apar semne de intrebare.
Readiness: 0000 0001Address 01: Engine        Labels: 036-906-032-AXP.lbl
   Part No: 036 906 032 D
   Component: ME7.5.10            3398
   Coding: 00031
   Shop #: WSC 44644
   VCID: 112953C65BC977960BD-5198
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
            P0300 - 35-10 -  - Intermittent
16687 - Cylinder 3
            P0303 - 35-10 - Misfire Detected - Intermittent
18010 - Power Supply Terminal 30
            P1602 - 35-00 - Voltage too Low
              Address 01: Engine  (036 906 032 D)
Ajutati-ma va rog sa decifrez  eroarea e de la masina mea si poate sa imi dati solutii pentru remedierea ei.Nu o da la pornire ci numai in mers cand bag piciorul dintr-o data in acceleratie .I-am schimbat bujiile de 5 saptamani cu unele la fel (ma refer la marca ).I-am facut si un test in mers si vedeti rezultatul
22:18:26
  48.0°C   Coolant Temperature (G62)
  0   Misfire Counter Cylinder 1
  0   Misfire Counter Cylinder .
  7   Misfire Counter Cylinder 3
  0   Misfire Counter Cylinder 4
Care e cilindru 3  ?Am gasit pe net mai multe variante de numerotare si nu stiu pe care sa o cred.
  • Aerofan pinned this topic
