suzu
Procedura pe care am incercat-o (descrisa mai sus) cu VCDS 14.10 este gresita.
Cea descrisa pe stemei.de este corecta si functioneaza. http://www.stemei.de/pages/coding/audi-a4-8k/batterieladezustand.php
5.  [07 - Control Head]
6.  [Adaptation - 10]
7.   canal 02
8.   creste valoarea cu +3
9.   reset MMI
Va multumesc
Modificat de alex_
Cu placere. Treci acum si fa-ti si ptr hybrid ;)
Am scanat si eu Golf-ul meu si am 5 erori, ma puteti ajuta cu interpretarea lor? Am lasat doar log-ul unde apar erorile.
01-Engine -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 CG    HW: Hardware No
   Component: MED9.5.10        00 7001
   Revision: --H01---    Serial number: VWZ7Z0E2440062
   Coding: 0000072
   Shop #: WSC 00028 028 00001
   VCID: 6ADB242A45DFE44E2A7-803F
3 Faults Found:
012408 - Throttle Control
               P3078 - 002 - Airflow at Idle too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 10200 /min
                    Load: 100.0 %
                    Speed: 255.0 km/h
                    Temperature: 215.0°C
000152 - Intake Air Temperature Sensor 2 (G299)
               P0098 - 002 - Signal too Low - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 18.0°C
001089 - EVAP Emission Control Sys
               P0441 - 008 - Incorrect Flow - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 104331 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:30:41
             Freeze Frame:
                    RPM: 680 /min
                    Load: 16.9 %
                    Speed: 0.0 km/h
                    Temperature: 83.0°C
Readiness: 0000 0000
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2303
   Coding: 0000180
   VCID: 3663C05A41E770AE7EF-8063
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Coding: 0000180
   VCID: 377DCD5E46ED89A6659-8062
00933 - Electric Window Motor; Passenger Side (V148)
Sterge si revino cu scanul din nou .
Iar la geamuri fa adaptarile tinand apasat pe butoanele consola pana urca geamurile respective , dupa care iei mana si apoi dupa 1 sec le actionezi iar circa 3 secunde .
Salut! Am probleme cu bateria (noua). In aceasta iarna m-a lasat bateria veche si am schimbat-o cu una noua Varta, dar supriza mea a fost ca dupa 1 saptamana in care nu am pornit-o, iar nu mai are curent. Am masurat voltajul la incarcare si imi arata 14 V (la diagnoza am masurat 13,83, banuiesc ca nu era voltmetru calibrat), am facut o diagnoza cu Vag com si mi-au rezultat urmatoarele:
Thursday,29,January,2015,14:15:11:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWZZZ3BZXP306278   License Plate:
Mileage: 203360km-126362mi   Repair Order:
Chassis Type: 3B - VW Passat B5 (1997 > 2005)
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
   Mileage: 203360km/126362miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 038 906 018 P
   Component:  1,9l R4 EDC   00SG  1629
   Coding: 00002
   Shop #: WSC 00028
   VCID: 23450907B1202306A91-4A3A
2 Faults Found:
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-00 -
00741 - Brake Pedal Monitoring
Readiness: N/A
Address 03: ABS Brakes        Labels: 8E0-614-111-EDS.lbl
   Part No: 8E0 614 111 B
   Component: ABS/EDS 5.3 FRONT   D00
   Shop #: BB 24332
   VCID: 1D313FFF974415F69F5-5072
No fault code found.
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 B
   Component: CLIMATRONIC     V 1.0.0
   Coding: 02000
   Shop #: WSC 00028
   VCID: 204F060BA036381EB43-4A3A
00603 - Footwell/defroster Flap Positioning Motor (V85)
            35-10 - - - Intermittent
Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
   Part No: 1J0 909 607 A
   Component: AIRBAG VW3 S        V04
   Coding: 00065
   Shop #: WSC 00028
   VCID: 2B55E127D9F0EB46111-4A3A
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 3B0-919-xxx-17.lbl
   Part No: 3B1 919 880 C
   Component: B5-KOMBIINSTR. VDO V01
   Coding: 04140
   Shop #: WSC 00000
   VCID: 2C57E23BDCFEEC7E18B-5000
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: VWZ7Z0W1126263
   IMMO-IDENTNR: VWZ7Z0W1126263
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AH
   Component: 3C Zentral-SG Komf. 0001
   Coding: 04097
   Shop #: WSC 00028
   VCID: 8407EA9B94EE443E30B-49D8
   Subsystem 1 - Part No: 1J1959801D
   Component: 3C Tõrsteuerger. FS0001r
   Subsystem 2 - Part No: 1J1959802E
   Component: 3C Tõrsteuerger. BF0001r
   Subsystem 3 - Part No: 1J4959811D
   Component: 3C Tõrsteuerger. HL0001r
   Subsystem 4 - Part No: 1J4959812D
   Component: 3C Tõrsteuerger. HR0001r
12 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
            53-10 - Supply Voltage Too Low - Intermittent
01331 - Door Control Module; Driver Side (J386)
            62-10 - No or Incorrect Adjustment - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            27-00 - Implausible Signal
00943 - Heated Exterior Mirror; Driver Side (Z4)
            35-00 - -
00912 - Window Regulator Switch; Front Left (E40)
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00944 - Heated Exterior Mirror; Passenger Side (Z5)
            35-00 - -
01333 - Door Control Module; Rear Left (J388)
00930 - Locking Module for Central Locking; Rear Left (F222)
01334 - Door Control Module; Rear Right (J389)
00931 - Locking Module for Central Locking; Rear Right (F223)
End   ---------------------------------------------------------------------
              Credeti ca vreo una din erorile de mai sus poate duce la un consum de curent in masura sa nu imi mai porneasca deloc? (electromotorul invarte dar slab, cand pun clesti de la alta baterie dupa cateva minute "zbarnaie")
Bateria noua nu tine curent,ai un consumator care o descarca sau alternatorul nu incarca.
Modificat de EEXCALADE
Masoara si vezi ce consum de curent ai cu masina incuiata .
Am sters erorile si am facut si adaptarea la geamuri. Mai scanez maine seara sa vad daca mai apare ceva la motor...
Am si eu trei erori daca ma poate ajuta cineva din ce cauza or aparut? erorile or aparut dupa ce mi sa oprit masina in mers.
Adresa 01: Motor        Eticheta: ROJ\036-906-034-AZD.clb
   Numar VAG: 036 906 034 DR
   Componenta comandata:  MARELLI 4MV        5163
   Codare: 00031
   Atelier: WSC 31414
   VCID: 65CBDA61FF846B30B2A
   WVWZZZ1JZ4D017288     VWZ7Z0C8214335
1 cod a gasit:
16705 - Senzor turatie motor -G28-  semnal neplauzibil
            P0321 - 35-10 -  - intermitent
Gata de functie: 0000 0000
Adresa 03: ABS frâne        Eticheta: ROJ\1C0-907-37x-ABS.lbl
   Numar VAG: 1C0 907 379 L
   Componenta comandata: ABS FRONT MK60      0101
   Codare: 0001025
   Atelier: WSC 31414 000 00000
   VCID: 336F743951D0C580ECE
2  coduri de defecte:
00668 - Tensiune linia 30
            008 - semnal neplauzibil - intermitent
01314 - Modul de comanda motor
            013 - Cititi vã rog memoria de defecte - intermitent
Schimba senzorul de turatie motyor.
Verifica sig de alimentare de la ABS.
adica siguranta din panaoul de sigurante?
Salut, am un Golf IV 1.6 16 V din 2001 full dotari, si am o problema cu martorul  ABS.
Sa jucat un prieten cu interfata... A facut un test cred la ABS, si sa blocat etrieru. Am fost la service, la degripat dar degeaba si l-am inlocuit cu altul care functioneaza perfect.
Acum mai trebuie doar sa sting martorul ABS.
Am facut acel test pe care l-am gasit in alt topic, dar degeaba.
"01486 - Test de functionare sistem activat"
Multumesc, O zii Buna!
Nu va mai jucati pe ce nu stiti , e doar un sfat prietenesc. Va faceti de lucru aiurea.
Intr-o ora vo-i repeta testare... O sa vad ce rezolv.
Al Bundy
unde gasesc senzorul turatie motor la masina din semnatura?
am verificat siguranta ABS din tablou de pe pozitia F9 si este ok
Salut! Imi poate spune si mie cineva unde se afla mufa de diagnoza la un Passat 1.9 TDI 2001 ?
Deasupra pedalei de ambreiaj.
Am gasit acum cateva zile o aplicatie pt. android cu o baza de date (in dezvoltare) privind localizarea mufei OBD (diagnoza). Din ce am experimentat obsv. ca nu este numai pt. grupul VAG si nu sunt toate modele incluse, insa interesant este ca fiecare poate participa cu poze si o scurta descriere in engleza pt. a completa baza de date.
Link
https://play.google.com/store/apps/details?id=com.outilsobdfacile.obd.connecteur
Modificat de alexm1
Am si eu o problema (stiu ca nu e sectiunea absolut potrivita dar nu crea posturi ), avand in vedere ca astea sunt singurele erori si cred ca nu au absolut nici o legatura.
17573 - Long Term Fuel Trim Additive Air; Bank 1; Range 1
            P1165 - 35-00 - System too Rich
17526 - Oxygen (Lambda) Sensor Heating; B1 S2
            P1118 - 35-10 - Open Circuit - Intermittent
16525 - Oxygen (Lambda) Sensor B1 S2; Heating Circuit
            P0141 - 35-10 - Malfunction - Intermittent
Mi se aude un sunet ciudat in partea stanga a motorului ( in partea opusa curelei de distributie, acolo unde este bobina de inductie - ca sa inlaturam orice dubiu ) , ca un zumzait, sasait, ceva electric.. daca bag capul acolo pare sa se auda din Bobina de inductie (nu am nici un missfire). Ce sa verific? Inainte de a se defecta ceva grav. Calc frana, tot se aude, calc ambreiaj tot se aude..
Revin cu un reply la aceasta problema. S-ar parea ca sunetul sa fie de la clapeta de acceleratie. Care ar putea fi cauzele? Ceva sfaturi ? (in afara de faptul ca am de gand sa-i dau o curatare, si nici erori nu am )
Sa nu fie canistra de carbon activ aia are un ticait , daca ea este, e normal sa se auda asa.
Canistra de carbon este in stanga. Aia intradevar tacane, eu am specificat clar ca se aude din partea dreapta a motorului, si cel mai sigur de la clapeta de acceleratie. E ca si cum BAZERUL ar fi ramas activat:( cu cat accelerez se aude mai tare. :(
Eu am schimbat clapeta acum cateva zile cu una din dezmembrari , insa mie imi dadea erori , mi se aprindeau epc si check engine in bord , daca la scanare nu ai erori si ea functiuneaza las-o asa .
Salut tuturor , la o scanare recenta la modelul din semnatura mi-au aparut si 2 erori : Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Component: Tuer-SG         024 2366
   Coding: 0000693
   Shop #: WSC 05311 000 00000
3 Faults Found:
01552 - Motor for Central Locking; Drivers Door (V56); Lock
            012 - Electrical Fault in Circuit
            008 - Implausible Signal
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Part No SW: 3C0 959 433 M    HW: 3C0 959 433 M
   Component:    KSG PQ46 ELV 042 0472
   Revision: 00042000    Serial number: VWZCZ000000000
   Coding: 00910A0801864E763004941570085FCE103CA0
   Shop #: WSC 01089 210 97503
   VCID: 3467FA52579B62BE40B-8061
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 2 - Part No: 3C0 951 171 A
   Component: Neigungssensor  002 0508
   Subsystem 3 - Part No: 3C0 951 171 A
   Component: Innenraumueberw.002 0508
01038 - Central Locking Thermal Protection
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 4
                    Fault Frequency: 13
                    Reset counter: 73
                    Mileage: 192122 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:53:10
Cand deschid masina din cheie inauntru ramane blocat modul de siguranta adica ma refer la butonul de inchidere  de langa sofer stie cineva ce are ?
  • Aerofan pinned this topic
