suzu
Mda , ideea este ca , cablurile sunt ok , merge masina si dintr-o data apar erorile astea nu se mai acceleaza si merge cu max 30 km.
dragomiricacristinel
Ce Reprezinta erorile astea si cum se pot remedia?
Sunday,04,January,2015,18:00:37:40973
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN:    License Plate: FFFF
Mileage: 167220km-103905mi   Repair Order:
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
   Mileage: 167220km/103905miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 036 906 034 BH
   Component:  MARELLI 4MV       3773
   Coding: 00031
   Shop #: WSC 45217
   VCID: 59B96BE6C3B97FD6B3D-4B82
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 -  - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 E
   Component: ESP FRONT MK60      0104
   Coding: 0011266
   Shop #: WSC 01317 785 00200
   VCID: 2C57E2328CAB3A7E18B-5198
No fault code found.
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 1.0.0
   Coding: 01000
   Shop #: WSC 01317
   VCID: 21490306AB69E716BBD-51B6
            37-00 - Faulty
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 6Q0 909 605 A
   Component: 27 AIRBAG VW5  01   0006
   Coding: 12855
   Shop #: WSC 01317
   VCID: 3561C7560FE17BB6775-4B36
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J0 920 825 A
   Component: A4-KOMBIINSTR. VDO V09
   Coding: 01113
   Shop #: WSC 00186
   VCID: 2643101AC247002ECEF-5198
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: VWZ7Z0A3397844
   IMMO-IDENTNR: VWZ7Z0A3397844
4 Faults Found:
00779 - Outside Air Temp Sensor (G17)
            30-10 - Open or Short to Plus - Intermittent
            29-10 - Short to Ground - Intermittent
01176 - Key
01314 - Engine Control Module
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 01317
   VCID: F0EFB642B0039E9EE43-517A
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AH
   Component: 4E Zentral-SG Komf. 0001
   Coding: 04097
   Shop #: WSC 01317
   VCID: 8407EA9294BB923E30B-4B36
   Subsystem 1 - Part No: 1J1959801C
   Component: 4E Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 4E Tõrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811C
   Component: 4E Tõrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812C
   Component: 4E Tõrsteuerger. HR0002r
3 Faults Found:
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
00912 - Window Regulator Switch; Front Left (E40)
01334 - Door Control Module; Rear Right (J389)
            53-10 - Supply Voltage Too Low - Intermittent
End   ---------------------------------------------------------------------
          76
   Coding: 00031
   Shop #: WSC 45217
   Coding: 0011266
   Coding: 01000
   Shop #: WSC 01317
            37-00 - Faulty
   Coding: 12855
   Shop #: WSC 01317
   Coding: 01113
   Shop #: WSC 00186
4 Faults Found:
01176 - Key
   Coding: 00006
   Shop #: WSC 01317
   Coding: 04097
   Shop #: WSC 01317
3 Faults Found:
Tuesday,27,January,2015,15:47:25:40973
VIN: WVWZZZ1JZ3B147731   License Plate:
Mileage: 174530km-108447mi   Repair Order:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
          76
VIN: WVWZZZ1JZ3B147731   Mileage: 174530km/108447miles
Address 01: Engine        Labels: 038-906-019-AXR.lbl
   Part No: 038 906 019 DD
   Component: 1,9l R4 EDC 0000SG  1518
   Coding: 00002
   Shop #: WSC 00046
   VCID: 5CB772F2CC8B8AFEA8B-4B36
   WVWZZZ1JZ3B147731     VWZ7Z0C7168086
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 L
   Component: ABS FRONT MK60      0101
   Coding: 0001025
   Shop #: WSC 00046 615 1234567
   VCID: 3365F94E51956586591-517A
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 00046
3 Faults Found:
00792 - A/C Pressure Switch (F129)
            35-00 - -
            30-00 - Open or Short to Plus
            37-00 - Faulty
   Part No: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   00XX
   Coding: 12855
   Shop #: WSC 00046
   VCID: 224B0C0AAE6FFC0EA27-517A
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
            32-10 - Resistance Too High - Intermittent
   Part No: 1J0 920 826 C
   Component: KOMBI+WEGFAHRSP VDO V13
   Coding: 01112
   Shop #: WSC 00000
   VCID: 29591B26D3592F56E3D-517A
   Coding: 00006
   Shop #: WSC 00046
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: 1E Komfortgerát HLO 0003
   Coding: 00065
   Shop #: WSC 00046
   VCID: 3663C05A12E770AE7EF-4B36
   Subsystem 1 - Part No: 1C1959801A
   Component: 1E Tõrsteuer.FS KLO 0009
   Subsystem 2 - Part No: 1C1959802A
   Component: 1E Tõrsteuer.BF KLO 0009
5 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
            37-00 - Faulty
00913 - Window Regulator Switch; Front Right Driver (E81)
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Address 03: DTCs cleared
Address 08: DTCs cleared
Imi poate spune si mie cineva daca trebuie sa ma ingrijorez pentru vreo eroare? Multumesc. Stima «
 Depinde de preferintele tale. Poti circula si asa fiind numai probleme de comfort:
La AC:- verifica/schimba switchul de presiune - F129;
           - verifica/schimba senzorul/circuite/mufe de temperatura exterioara G17
           - Verifica/schimba motorasul clapetei de dirijare a aerului - V71
La Airbag - Verifica/schimba capsa pirotehnica a centurii de la sofer - N153
La Comfort- Verifica/schimba modulul comfort - J393
                  - Verifica/schimba butoanele de control ale geamurilor pe stg & dreapta fata
                  - Verifica/schimba Switchurile din usile fata stg & dr
Eu zic să începi cu primul cod de eroare care indică o cădere a tensiunii pe regleta 30, adică circuitul de plus permanent. Pe partea de management al motorului el alimentează permanent ECU pe pinul 54 şi releul de combustibil (releul 12, colţul dreapta jos). Verifică mufele la aceste componente şi curăţă-le cu spray de contacte.
Am verificat absolut tot ce tine de contacte, continuitate, ....Nici un rezultat. Am schimbat releul de la pompa de benzina, la fel fara rezultat. Am verificat si senzorul de vilbrochen, sondele lambda,si nu ma stiu cite (chiar daca aparent nu ar putea influenta fenomenul asta). La modulul de comanda al admisiei de aer variabila am gasit un condensador pocnit (eroare de montaj din partea celui care a instalat), si credeam ca gata, am solutionat....Dar, nu era nici asta. Dupa mai mult de o saptamina de nervi, ne-am dat batuti si am dus masina la VW. La ei am pornit-o, si s-a oprit la aprox. 5min. Am repornit-o si nu s-a mai oprit. Cum era vineri dupa amiaza, a  ramas la ei sa continuie investigatiile luni dimineata. O sa revin cu rezolvarea (daca o gasesc cei de la VW) poate ajuta pe altcineva in viitor.
Salut din nou! Raspunsul dat de VW este ca problema opririi motorului in mers provine de la ECU. Au o istorie cu multe cazuri asemanatoare la motoarele VR6 din acea generatie.O sa o trimitem la reparat maine dimineata. Sper sa nu se insele, ca reparatia este vreo 200€.
da pe mine nu ma ajuta nimeni?ca nu se mai intelege care cui raspunde
Modificat de dragomiricacristinel
        Pentru un audi a6 c6 an2005 2.0tdi ce pachet de diagnoza recomanda-ti sa achizitionez?
        Mentionez ca am probleme cu coloana volan care se blocheaza cand ti-e lumea mai draga si poti sa ramai langa masina pieton.
        Multumesc anticipat
Ai sters erorile si reapar toate?Ia trage un ochi aici,iei fiecare cod in parte si citesti:http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
Unde scrie search introduce codul si ai acolo explicatii sau rasfoiesti acest topic si sigur gasesti raspuns la toate.
Rezolva cu coloana si scapi de problema .
Altfel , eu recomand originala rosstech
Din pacate erorile au revenit :
17989 - Throttle Actuator (j338)
P1581 -35 - 00 Basic Setting Not Performed
17953 - Throttle Valve Controller
P1545 - 35 - 10 - Malfunction - Intermitent
Aseara am curatat clapeta , in dimineata asta aceleasi probleme , cand ajunge la 90 de grade apar check engine si epc si se decalibreaza , e cazul sa o schimb , sa poate genera alta piesa aceste erori?
Schimba clapeta de acceleratie.
no, nu ti-am zis de aseara ca trebuie sa o schimbi ? eu zic ca da  :sly:
A mschimbat senzorul de inalta presiune, am verificat cablul , tensiune 4,97 V , tot imi apare eroarea :
16577 - Fuel pressure sensor (G247) P0193-35-00-short to plus
Nu am masurat cablul pe firul care duce la ECU pentru ca nu am stiut cum.
Ai zis Florine , ai zis ...tu cu gura ta aurita .....:)) , ma pun sa caut una , multumesc pentru ajutor.
Pai din dezmembrari , undeva, unde pot primi si garantie, pentru ca noua nu-mi permit.
Am si eu o problema (stiu ca nu e sectiunea absolut potrivita dar nu crea posturi ), avand in vedere ca astea sunt singurele erori si cred ca nu au absolut nici o legatura.
17573 - Long Term Fuel Trim Additive Air; Bank 1; Range 1
            P1165 - 35-00 - System too Rich
17526 - Oxygen (Lambda) Sensor Heating; B1 S2
            P1118 - 35-10 - Open Circuit - Intermittent
16525 - Oxygen (Lambda) Sensor B1 S2; Heating Circuit
            P0141 - 35-10 - Malfunction - Intermittent
Mi se aude un sunet ciudat in partea stanga a motorului ( in partea opusa curelei de distributie, acolo unde este bobina de inductie - ca sa inlaturam orice dubiu ) , ca un zumzait, sasait, ceva electric.. daca bag capul acolo pare sa se auda din Bobina de inductie (nu am nici un missfire). Ce sa verific? Inainte de a se defecta ceva grav. Calc frana, tot se aude, calc ambreiaj tot se aude..
Va salut,
Ma puteti va rog ajuta cu o codare pentru afisarea nivelului bateriei in MMI pentru Audi A4 8K?
Am incercat procedura, ''Battery and oil level for radio Chorus/Concert/Symphony" , expusa aici http://www.audizine.com/forum/showth...M-codes/page12
56 - Radio, Adaptation, Car menu Options 1 add +16 to the value there to enable battery level in the CAR menu.
Nu merge probabil fiindca eu am MMI 2G high cu CD-changer, nu radio Chorus/Concert/Symphony.
Nici din meniul ascuns nu se poate.
Modificat de alex_
atunci fa codarea cu un VCDS, daca ai.
Battery meter nu se face prin adaugare de valoare. Vezi prpcedura ptr 8k de pe stemei.de
Pentru eroarea 17573 - verifica cu un VCDS in 01 group 032 valorile din primul camp (-10% - +10%). Daca sunt in afara specificatiilor verifica pe unde iti trage aer fals (garnitura corp clapeta/furtunul care duce la servofrana sa nu fie crapat/ & tot ce are legatura cu aer fals in admisie).
Pentru 17526 & 16525 verifica rezistenta la sonda lambda 2 (sonda dupa kat). Daca rezistenta e arsa schimbi sonda.
In ceea ce priveste sunetul ciudat verifica cu atentie bobina de inductie sa nu prezinte fisuri sau eventual vreo fisa care da la masa.
Multumesc de raspuns Ionel. voi verifica 1753;
Problema cu Sonda lambda sta in felul urmator: am avut probleme cu amandoua sondele, am pus S2 nou, si datorita faptului ca nu aveam simptome urate am mers asa (cu S1 defect si check engine aprins non stop) timp de aproximativ 4-5 luni. Recent, acum 2 sapt aprox, am schimbat si S1, dar surpriza se pare ca S2 a avut de suferit. Avand in vedere ca e oarecum nou, ma gandesc ca nu s-a defectat de tot, dar inainte sa ma apuc sa caut elevator/canal sa o pot demonta putin sa o curat, unde verific mai exact sigurantele de la sonde (la 1.4 16V AXP)?
Si am inteles ca ar mai fi o varianta sa resetezi aceasta sonda? se poate? cum?
Iar despre sunetul ciudat, pe care am specificat eu ca s-ar putea auzi mai tare langa bobina de inductie, e continuu si destul de tare. E posibil sa faca ea asa? (nu se aude un tacanit ca si cum ar da socuri, stiu cum face cel care pierde curent prin fise, sigur nu e asa)
...unde verific mai exact sigurantele de la sonde (la 1.4 16V AXP)?...
Nu e siguranta de vina (Sig 43-incalzire ambele sonde lambda). Verifica cu un multimetru rezistenta sondei.(s-a tot postat procedura). Despre anularea sondei (eu nu recomand) s-a mai discutat (inlocuirea sondei cu o piesa facuta pe strung/rescrierea ECU/...)
Despre sunet nu stiu ce sa zic...
Modificat de ionel.d.2007
  • Aerofan pinned this topic
    • k4b00
