suzu
dragomiricacristinel
  • Oraş:Constanţa
  • Maşina:Volkswagen
  • Model:Golf 4
  • Motorizarea:1.6 16V 105Cp
Posted 06.01.2015 @ 23:32
Ce Reprezinta erorile astea si cum se pot remedia?
Sunday,04,January,2015,18:00:37:40973
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN:    License Plate: FFFF
Mileage: 167220km-103905mi   Repair Order:
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
   Mileage: 167220km/103905miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 036 906 034 BH
   Component:  MARELLI 4MV       3773
   Coding: 00031
   Shop #: WSC 45217
   VCID: 59B96BE6C3B97FD6B3D-4B82
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 -  - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 E
   Component: ESP FRONT MK60      0104
   Coding: 0011266
   Shop #: WSC 01317 785 00200
   VCID: 2C57E2328CAB3A7E18B-5198
No fault code found.
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 1.0.0
   Coding: 01000
   Shop #: WSC 01317
   VCID: 21490306AB69E716BBD-51B6
            37-00 - Faulty
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 6Q0 909 605 A
   Component: 27 AIRBAG VW5  01   0006
   Coding: 12855
   Shop #: WSC 01317
   VCID: 3561C7560FE17BB6775-4B36
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J0 920 825 A
   Component: A4-KOMBIINSTR. VDO V09
   Coding: 01113
   Shop #: WSC 00186
   VCID: 2643101AC247002ECEF-5198
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: VWZ7Z0A3397844
   IMMO-IDENTNR: VWZ7Z0A3397844
4 Faults Found:
00779 - Outside Air Temp Sensor (G17)
            30-10 - Open or Short to Plus - Intermittent
            29-10 - Short to Ground - Intermittent
01176 - Key
01314 - Engine Control Module
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 01317
   VCID: F0EFB642B0039E9EE43-517A
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AH
   Component: 4E Zentral-SG Komf. 0001
   Coding: 04097
   Shop #: WSC 01317
   VCID: 8407EA9294BB923E30B-4B36
   Subsystem 1 - Part No: 1J1959801C
   Component: 4E Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 4E Tõrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811C
   Component: 4E Tõrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812C
   Component: 4E Tõrsteuerger. HR0002r
3 Faults Found:
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
00912 - Window Regulator Switch; Front Left (E40)
01334 - Door Control Module; Rear Right (J389)
            53-10 - Supply Voltage Too Low - Intermittent
End   ---------------------------------------------------------------------
am schimbat senzorul de presiune combustibil si tot imi apare aceeasi eroare
16577 - Fuel Pressure Sensor (G247): Short to Plus
        P0193 - 35-00 - -
Ce poate fi ?
o intrebare am fost sfatuit sa resetez revizia de filtre mai des decit la fiecare schimb
cica are influenta asupra consumului.
 Ati facut asa ceva?
Eu n-am inteles exact ce vrei sa spui, fii mai explicit. Cum adica "sa resetezi revizia de filtre mai des decat la fiecare schimb" ? :tuktuk:
La cat schimbi filtrele ? :sly:
Modificat de Deadly
deci schimb filtrele la revizie cind vine pe km sau cel mult la un an, si resetez din Vag com revizia.
imi spuneau ca la anuiti km de la revizie calculatorul masini calculeaza  uzura filtrului de aer,benzina,Ac  si schimba consumul????
Aia este la ulei in cazul in care il schimbi mai devreme decat este reglat din fabrica.
O resetezi cu vagul dar nu e permanenta resetarea o sa iti mai apara si la alte schimburi timpurii
Nu reusesc sa gasesc codarea pentru cornering la un passat CC.Ma poate ajuta?Masina este din 2009
MAsina are proiectoare? Sau xenon de fabrica ?
Am schimbat senzorul din prima imagine si tot imi apare eroarea (16577 - Fuel pressure sensor (G247) P0193-35-00-short to plus) dar la cautare in etka dupa (g247) imi indica si senzorii din imaginea 2 (la numerele 20 si 6). E posibil sa fii schimbat senzorul gresit ?
M-am lamurit. cel pe care l am schimbat are codul 03c 906 051 a si in etka imi pare si senzorul de presiune de la galeria de admisie cu codul 03c 906 051 (fara a). ce sa fac sa il schimb si pe acesta ?
Va multumesc !
g247.doc
Modificat de Messe25
...E posibil sa fii schimbat senzorul gresit ?...
Sigur ai schimbat senzorul gresit. G247-este senzorul de presiune mare montat pe partea inferioara a galeriei de admisie(este la poz. 20 din plansa 2 postata de tine).Intake Manifold-G247-Polo_1,4_FSI_AXU.pdf Vezi ca a fost inlocuit si codul actual este:06J 906 051 C.
P.S.
Incearca sa-l schimbi cu cel bun plus diferenta
P.S. 2
Inainte de a schimba senzorul verifica cablajul/tensiunea lui sa fie Ok
(Firul colorat cu verde sa nu faca contact cu firul colorat cu rosu:G247-Polo_1,4_FSI_AXU.pdf)
Modificat de ionel.d.2007
Salut! imi poate spune si mie cineva ce inseamna codurile acestea de eroare:
VCDS Version: Release 12.12.0 (x64)
                Address 01: Engine       Labels: 06A-906-033-BGU.lbl
Control Module Part Number: 06A 906 033 GG
  Component and/or Version: SIMOS71 1.6l 2VG    1025
           Software Coding: 0004071
            Work Shop Code: WSC 00066 000 00000
                      VCID: 6AD1DAE84581284E2A7-803F
2 Faults Found:
17987 - Throttle Actuator (J338)
            P1579 - 008 - Adaptation Not Started - Intermittent
             Freeze Frame:
                    Bin. Bits: 00000000
                    Voltage: 6.43 V
                    Load: 22.4 %
                    Load: 82.4 %
                    Bin. Bits: 00000000
                    Voltage: 6.22 V
                    Load: 13.3 %
                    Load: 89.8 %
17976 - Throttle Actuator (J338)
            P1568 - 007 - Mechanical Failure - Intermittent
             Freeze Frame:
                    RPM: 0 /min
                    Voltage: 12.04 V
                    Load: 18.4 %
                    Load: 82.4 %
                    RPM: 0 /min
                    Voltage: 12.55 V
                    Load: 22.0 %
                    Load: 82.4 %
Monday,26,January,2015,13:26:57:65217
                Address 03: ABS Brakes       Labels: 1K0-907-379-MK70M.clb
Control Module Part Number: 1K0 907 379 AF    HW: 1K0 907 379 AF
  Component and/or Version: MABS MK70M          0104
           Software Coding: 0000257
                      VCID: 76E9FE980139FCAEBEF-8023
            013 - Check DTC Memory - Intermittent
Multumesc anticipat!
Adapteaza clapeta de acceleratie: Contactul pus, motorul oprit, engine, Adapt.
La fel poti face un test si pentru ABS (si mie imi persista o eroare la ABS, dar dupa finalizarea testului am scapat de ea)
Buna seara,am efectuat o diagnoza la VW TOURAN 1.9TDI si am obtinut urmatoarele erori:Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 1K0 815 071 F
   Component: Zuheizer        030 1009
   Revision:        B    Serial number: 09008374
   Coding: 0000011
   Shop #: WSC 01324 785 00200
   VCID: 28544FCA9B240D5EE75
4 Faults Found
01415 - Recirculating Pump (V55)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 0
                    Reset counter: 26
                    Mileage: 184534 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:16:24
             Freeze Frame:
                        Malfunction
                    Temperature: 30.0°C
                    Temperature: 33.0°C
01409 - Repeated Flame-Out
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 16
                    Mileage: 181493 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:45:38
             Freeze Frame:
                        Malfunction
                    Temperature: 49.0°C
                    Temperature: 49.0°C
02251 - Heater Unit Locked
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 16
                    Mileage: 181493 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:45:38
00664 - Fuel gauge
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 26
                    Mileage: 183737 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:10:28
Imi poate explica cineva,ce defecte sunt .
Modificat de tabi
Nici nu cred ca ai citit ca e pentru motoare pe benzina si tu ai diesel.
Imi cer scuze,pt. neatentie,de aceea rog moderatorul s-a ma ajute la mutarea in locul adecvat. :exclaim:
Salut ma poate ajuta cineva cu o parere? Motor 1.6 Avu benzina
P0303-35-10 Cylinder 3 misfire Detected intermittent
Merge in 3 pistoane la relanti se stinge cateodata check si reapare in sarcina (motorul trepideaza)
Totul s.a intamplat dupa ce am dat curent cuiva prin cabluri dar cred ca e o coincidenta; cablurile
Au fost montate corect
Multumesc mult!
Verifica Bujie, fisa, bobina la pistonul 3. S-ar putea sa fii surprins.
La o scanare am gasit urmatoarele erori :
17989 - Throttle Actuator (j338)
P1581 -35 - 00 Basic Setting Not Performed
17953 - Throttle Valve Controller
P1545 - 35 - 10 - Malfunction - Intermitent
Acum o luna clapeta a fost curatat si adaptata , ieri dupa ce imi facea figuri , am adaptat-o iar , numai ca in dimineata asta dupa un drum scurt mi-au aparut iar erorile , le-am sters , dupa adaptare , adaptarea am facut-o in grupul 060 trebuie sa mai umblu pe undeva ?
Eu am motor AVU, nu am bobina pe fiecare - stiam ca bobinele sunt pe fiecare piston doar la motoare cu 16 valve. Sunt motoare AVU si cu 16 v?
P.s.- Nu e nici o ironie doar intreb.
...adaptarea am facut-o in grupul 060 trebuie sa mai umblu pe undeva ?...
Daca adaptarea ai facut-o conform http://wiki.ross-tech.com/wiki/index.php/Throttle_Body_Alignment_%28TBA%29 atunci este Ok. Verifica clapeta/circuitele (de la clapeta la ECU)/conectorul,
...Sunt motoare AVU si cu 16 v?...
Evident ca NU. @LMR cred ca nu a realizat pe moment ca motorul AVU are decat o bobina. Ideea era sa verifice tot ce are legatura cu lipsa scanteii pe cilindrul 3: bujie/fisa/bobina/injector/supape.
  • Aerofan pinned this topic
    • Hayate
