suzu
The current version is:
 Beta 14.8.1
Data Version 20140905
ok mersi pentru sfaturi . o sa incerc sa verific si vad dupa
Salut baieti! Ma poate ajuta cineva cu citirea urmatoarelor erori?
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1Z0 907 044 AB    HW: 1Z0 907 044 AB
   Component: ClimatronicPQ35 120 0600
   Revision: 00120022    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 76E300530132E6AEBEF-8023
00716 - Air recirculation Flap Positioning Motor (V113)
            000 - -
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000005601988
   Coding: E18E0F111016141443110D000000000000297F065C000008000000000000
   Shop #: WSC 73430 790 00000
   VCID: 71E9334F685CC1966BD-8024
   Subsystem 1 - Part No: 1Z1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 120308 022  0601
   Coding: 00055223
   Shop #: WSC 73430
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     180308 046  0204
   Coding: 00471077
   Shop #: WSC 73430
2 Faults Found:
02071 - Local Databus
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 200
                    Mileage: 70803 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 12.30 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
01520 - Rain and Light Recognition Sensor (G397)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 200
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 12.30 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0192
   Revision:   H16       Serial number: 2500K083080893
   Coding: E9817F0E5006021302
   VCID: 3467FA5B57CEB4BE40B-8061
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 205
                    Mileage: 70928 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:38:18
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 205
                    Mileage: 70928 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:38:18
 Mentionez ca radio si navigatia functioneaza fara probleme. Va multumesc anticipat!
Dar senzorul de lumina/ploaie ?
Daca stergi erorile, mai apar ?
Daca le sterg apar din nou dupa o perioada. Cea de la climatronic a aparut pentru prima data...am dat bassic settings am sters-o si nu a mai aparut. O sa verific si zilele urmatoare. Senzorul de lumina/ ploaie functioneaza: farurile se aprind (daca sunt pe auto) cand se insereaza sau ploua.
In urma scanarii cu VAG-COM am urmatoarea eroare:
Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
   Part No SW: 03C 906 016 E    HW: 03C 906 016 C
   Component: MED17.5.5       G   8178
   Revision: LCH12---    Serial number:
   Coding: 0000077
   Shop #: WSC 73430 790 00129
   VCID: 214252EEF81EFC16A0B
1 Fault Found
012398 - Glow Ignition
               P306E - 000 - Short Output Reduction - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 30978 km
                    Time Indication: 0
                    Date: 2101.14.27
                    Time: 13:16:05
             Freeze Frame:
                    RPM: 1546 /min
                    Load: 62.7 %
                    Speed: 15.0 km/h
                    Temperature: 93.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.589 V
Readiness: 0000 0000
Manifestari motor: Lipsa putere  in treapta a 2-a (motorul nu trage si intra in trepidatii/vibratii mari pana cand schimba a 3-a -cutie DSG). Simptomul apare la plecarile de pe loc si nu este unul permanent. In momentul cand a aparut prima oara mi s-a aprins si lampa EPC in bord. Imediat s-a stins si nu a mai aparut.
Ce componenta este defecta ? La ce ma pot astepta ?
Salut,am martorul check engine aprins in bord.Un prieten a facut o scanare cu vag com si a iesit urmatoarea eroare
Tuesday,01,October,2013,16:51:42:40973
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
Address 01: Engine        Labels: Redir Fail!
   Part No: 036 906 034 BH
   Component:  MARELLI 4MV       3773
   Coding: 00031
   Shop #: WSC 26476
   VCID: 59B96BE6C3B97FD6B3D-4B68
17588 - Linear O2 Sensor; Pump Current
            P1180 - 35-10 - Short to Plus - Intermittent
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 J
   Component: ABS FRONT MK60      0103
   Coding: 0001025
   Shop #: WSC 50300 551 00000
   VCID: 3169F346AB8957962BD-5198
No fault code found.
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 1.0.0
   Coding: 01000
   Shop #: WSC 01317
   VCID: 21490306AB69E716BBD-51D4
            37-00 - Faulty
Mentionez ca sonda lambda 1 am schimbat-o anul trecut cu una NGK.Daca se poate un sfat.Merci
Tot sonda lambda. daca e in garantie, sa o schimbe iarasi.
Salut, postez pt o prietena care nu are cont. Ceva  sfaturi pentru urmatoarele erori?
19490 intake air temperature senzor 2(g299)
     002  P3034 - Signal too Large intermittent
17748 - Camshaft Position Senzor (G40)/ Engine Speed Senzor (G28)
        P1340 -001- Incor.Corr)elation Intermittent
17850 - Potentiometer for EGR (G212)
        P1442- 001 - Signal too High - Intermittent
16785 EGR System
       P0401- 002 - Insufficient Flow - MIL ON
18354 - Control Module 1 for Coolant Fan
       P1946 - 004- Defective Intermittent
16825 - EVAP Emission Control Sys
       P0441 - 002 - Incorrect Flow - Intermittent
16955 Brake Switch (F)
      P0571 - 008 Implausible Signal - Intermittent
Golf 5, anul 2004, 1.6  nu stiu codul la motor!
S-a aprins in bord senzorul cu check engine, da a sters toate erorile si momentan nu mai apare nimic.
Modificat de GinelSB
Sa le stearga si sa vada care reapar si fff important sa mentionzi ce masina,an de fabricatie si motorizare,cod motor are.
Salut, intentionez sa cumpar pentru cineva din familie o bora 1.6, 77 kW, motor BCB, din 2004.
Masina arata foarte bine si merge la fel de bine, cel putin pe distanta de 30 km cat i-am facut proba.
Problema e ca la scanare am gasit erorile de mai jos. M-ar interesa cam la ce costuri s-ar ridica remedierea lor, ca stiu cat mai trebuie sa negociez.
______________________________________
_________________________________________________
            37-00 - Faulty
__________________________________________________
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
            30-10 - Open or Short to Plus - Intermittent
01336 - Data Bus for Comfort System                            - aparuta si pe can si pe instruments
            80-10 - Single-Wire Operation - Intermitten
_______________________________________________________
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00931 - Locking Module for Central Locking; Rear Right (F223)
________________________________________________________
PAi ai asa: o sonda lambda, un motoras de recirculare, un senzor de temperatura, 2 broaste de usi, cu piese noi OEM te duce 1200+500+200+1400=muult
cu piese AM 300+motorasul il blochezi pe deschis+150+200 reparatia celor 2 broaste.
Mi s-a intamplat azi intr-o depasire in forta sa imi taie acceleratia si sa palpaie check engine. In urma scanarii vag au rezultat urmatoarele erori. Mentionesc ca este vorba de un Passat B6 2.0 TFSI cu instalatie gaz cu injectie directa. Nu arata nimic de bujii sau injectoare pe tester. Ce poate fi ?
000768 - Random/Multiple Cylinder Misfire Detected
               P0300 - 001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 159978 km
                    Time Indication: 0
                    Date: 2014.10.01
                    Time: 15:22:32
             Freeze Frame:
                    RPM: 5277 /min
                    Load: 91.7 %
                    Speed: 70.0 km/h
                    Temperature: 59.0°C
                    Temperature: 19.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.351 V
000772 - Cylinder 4: Misfire Detected
               P0304 - 001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 159978 km
                    Time Indication: 0
                    Date: 2014.10.01
                    Time: 15:22:32
             Freeze Frame:
                    RPM: 5277 /min
                    Load: 91.7 %
                    Speed: 70.0 km/h
                    Temperature: 59.0°C
                    Temperature: 19.0°C
                    Voltage: 14.351 V
000770 - Cylinder 2: Misfire Detected
               P0302 - 001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 159978 km
                    Time Indication: 0
                    Date: 2014.10.01
                    Time: 15:22:32
             Freeze Frame:
                    RPM: 5277 /min
                    Load: 91.7 %
                    Speed: 70.0 km/h
                    Temperature: 59.0°C
                    Temperature: 19.0°C
                    Voltage: 14.351 V
PAi si alea de mai sus ce sunt ? cum nu arata nimic pe tester? in blocurile de masura te-ai uitat ?
Le schimbi cui cele de pe 1 si 3 si vezi unde se muta erorile.
Am avut eroare si pe cilindru 3 in urma cu o luna . O sa le schimb intre ele sa vad daca se muta erorile. Problema este ca mai am si intreruperi in mers.
Modificat de walker99
Va salut , am o skoda fabia, fab 2000,50kw ,motor ATZ, 170400 km si am urmatoarele erori:
16555 - Fuel Trim; Bank 1
P0171 - 35-10 - System Too Lean - Intermittent
16554 - Fuel Trim; Bank 1
P0170 - 35-00 - Malfunction
Readiness: 0010 0001
 Ambele sonde lambda sunt noi. Are cineva vreo idee?
Vezi ca s-a mai discutat de erorile tale . Da-i search pe forum ca gasesti mai multe topic-uri cu ce te intereseaza .
005480 - throttle actuator (j338)
 P1568 - 002 - mechanical failure - intermittent
 Fault frequency: 2
 Mileage: 94.556
005728 - coolant fan control 1
 P1660 - 008 - short to ground - intermittent
 Fault frequency: 9
 Mileage: 94.553
000546 - angle sensor 2 for throttle (g188)
 P0222 - 008 - signal too low - intermittent
 Fault frequency: 5
 Mileage: 94.553
005465 - throttle body (j338)
 P1559 - 008 - fault in basic settings - intermittent
 Fault frequency: 1
 Mileage: 94.550
01314 - engine control module
 013 - check dtc memory - intermittent
 Fault frequency: 13
 Mileage: 94.553
De vreo 2-3 saptamani ma confrunt cu o mica problema. Mi s-a intamplat de vreo 4-5 ori sa imi apara "esp fault - check manual", moment in care masina intra in limp mode (se comporta ca si cum nu ar mai avea turbina), iar martorii de esp/asr raman aprinsi. Cel mai mult au stat vreo 10min aprinsi, de obicei dispareau dupa 2-3min sau dupa ce opream masina si reporneam. Erorile gasite sunt cele de mai sus, din cate observ 2 dintre ele au aparut de 9, respectiv 13 ori. Cam pe unde poate fi problema? Multumesc!
Nici o idee? Am primit o recomandare din partea colegului golfix, nu am apucat inca sa o verific, eram curios daca s-a mai lovit cineva de erorile astea. Multumesc!
Clapeta de acceleratie cu probleme.
MAi ai si un ventilator care nu merge OK,
Salut , am facut si eu o scanare la masina mea . Este un Golf 5 din 2004 , motor 1.4 benzina . Ce imi puteti spune ? Multumesc .
VCDS Version: Release 12.12.0
Tuesday,07,October,2014,19:24:03:40973
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WVWZZZ1KZ4W033923   Mileage: 134090km/83319miles
01-Engine -- Status: Malfunction 1010
08-Auto HVAC -- Status: Sporadic communication error 1000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
25-Immobilizer -- Status: Sporadic communication error 1000
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 036-906-032-AXP.lbl
   Part No SW: 036 906 032 AA    HW: xxxxxxxxxxx
   Component: BOSCH ME7.5.10      5442
   Revision: 00000000    Serial number: VWZ7Z0C8678959
   Coding: 0000071
   Shop #: WSC 01279 785 00200
   VCID: 4FAD95BEDE7D21665D9-801A
18043 - Powertrain Data Bus
            P1635 - 008 - Missing Message from A/C Controller - Intermittent
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 N
   Component: ASR FRONT MK70      0103
   Coding: 0017025
   VCID: 3D71DF7664D1A3F6BF5-8068
   Part No: 1K0 907 044 K
   Component: ClimatronicPQ35 063 0201
   VCID: 2F6DF53EBEBD41663D9-807A
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 L    HW: 1K0 937 049 L*
   Component: Bordnetz-SG 1.0 H29 0701
   Revision: 00029000    Serial number: 00000000280624
   Coding: 018D0F0600041800001400001400000000
   VCID: 387FCE624BF386DE6C3-806D
   Subsystem 1 - Part No: 1Q1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 170113 026  0512
   Coding: 00038805
   Shop #: WSC 00000
2 Faults Found:
01049 - Supply Voltage Term 50
            006 - Short to Plus - Intermittent
00979 - Lamp for Low Beam; Right (M31)
            007 - Short to Ground - Intermittent
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
   Component: 06 AIRBAG VW8   022 0500
   Revision: 04022000    Serial number: 0033FD050TK2
   Coding: 0012342
   Shop #: WSC 01268 785 00200
   VCID: 2A5BE42A855F244EEA7-807F
   Subsystem 1 - Serial number: 6332MSME665B0501
   Subsystem 2 - Serial number: 6342MSME02010401
   Subsystem 3 - Serial number: 6351HSME10446B00
   Subsystem 4 - Serial number: 6361HSME50016F00
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549     HW: 1K0 953 549
   Component: Lenksäulenmodul 012 0030
   Coding: 0000002
   VCID: EFEDB53EFE3D8166FD9-80BA
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 850 P
   Component: KOMBIINSTRUMENT VDD 3550
   Coding: 0001101
   Shop #: WSC 11111 111 11111
   VCID: 3467FA52579B62BE40B-8061
00003 - Control Module
            014 - Defective
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 2100103A2157BC
   Coding: 3D0F0340070002
   VCID: 275D1D1E964D1926F59-8072
5 Faults Found:
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 254
                    Reset counter: 196
                    Mileage: 132339 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:22:59
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 196
                    Mileage: 132339 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:23:02
01314 - Engine Control Module
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 207
                    Mileage: 132401 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:26:36
01320 - Control Module for Climatronic (J255)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 221
                    Mileage: 132504 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:13:16
00474 - Control Module for Immobilizer
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 208
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:42:30
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO                3550
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0102
   Coding: 0000052
   VCID: 306FF642A3835E9E243-8065
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 E
   Component: EPS_ZFLS Kl.0       1202
   VCID: 2D51EF36B4B133760F5-8078
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 C
   Component:    KSG              0545
   Coding: 00E802087F2D8404084B0100
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   VCID: 3169F346A88957962BD-8064
Address 56: Radio
Cannot be reached
End   ---------------------------------------------------------------------
Ai un radio AM< climatronicul a mai fost dat jos de pe masina, ai o problema cu IMMO, faza scurta, etc.
Sterge-le vi vezi care mai apar.
hmm... ma manca undeva si am luat o interfata kkl pt 409.1 cu 50 de RON inclusiv transport. Am un Audi A6 Allroad din 2002 su un leon din 2003. Merge la ambele, am dat lovitura...
pana acum am facut ceva teste pe leon.
Instalarea OK
Detectare interfata OK
Conectare la modulul de motor OK dupa ce am modificat baud rate la 9600
AUTO- Scan nu merge, output test nu merge, zice ca nu e inregistrat.
Cautat versiune cu crack, rulat crack(care copiaza fisiere), la about zice inregistrat, dau doua click-uri, zice ca nu mai e inregistrat...rahat
dupa niste cautari dau de xstarter si il programez sa copieze fisierele respective la 5 secunde
Auto Scan a mers dupa asta(dar am incercat numai odata), am reusit chiar si un  Output test la motor.
Dar unde ma arde pe mine, nu am reusit, adica la instruments - output test
Poate e problema de timing, cine stie....
Dar sper sa existe si un mod mai bun de a face treaba... Stie cineva? Are cineva?
  • Aerofan pinned this topic
