suzu
Nu am specificat ca am si DPF. Ar putea avea vreo legatura?
Sonda lambda 1 este de reglaj sau de diagnoza?
salut dupa cum am zis mai sus am instalat VCDS si imi da eroare.. nu imi gaseste cablul `Ross-Tech USB interface Not Found`.. ce alt soft pot folosi??
Sonda 1-inainte de catalizator care are rolul de reglaj pentru motor;
si alta -nr.2 - dupa catalizator care supravegheaza buna functionare a catalizatorului.
Salutare.Am si eu urmatoarea problema la un Golf 4,1.6 FSI,an 2002,dupa scanare cu vag -com,am erorile astea:
Thursday,21,August,2014,18:12:26:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ1JZ2W637709 License Plate:
Mileage: 207230km-128766mi Repair Order:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: WVWZZZ1JZ2W637709 Mileage: 207230km/128766miles
Address 01: Engine Labels: Redir Fail!
Part No: 036 906 013 D
Component: MED7.5.11 4496
Coding: 00031
Shop #: WSC 67237
VCID: 102F56CB5096A89E043-5000
WVWZZZ1JZ2W637709 VWZ7Z0B5008137
4 Faults Found:
17443 - Sensor for NOx (G295)
P1035 - 35-00 - Signal Implausible
17441 - Sensor for NOx (G295)
P1033 - 35-00 - Signal too Low
17428 - Fuel Pressure Regulation
P1020 - 35-10 - Control Range Exceeded - Intermittent
17700 - Map Controlled Engine Cooling Thermostat (F265)
P1292 - 35-10 - Open Circuit - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 F
Component: CLIMATRONIC C 2.0.0
Coding: 21010
Shop #: WSC 01391
VCID: 24470A1BB42E243ED0B-50E6
37-00 - Faulty
Sensor for nox e foarte frecventa la fsi,ma intereseaza 17428,17700 si 01274.Ceva pareri va rog.
Schimba termostatul.
Schimba motorasul v71 de la clima.
drinkboy am facut testul cu VCDS-ul, acum incerc sa uploadez poza...intre timp am dat si un faulty codes si mi-a aparut:
Tuesday,01,October,2013,19:02:56:40973
VIN:    License Plate: BN88AXW
Mileage: 145444   Repair Order:
                Address 01: Engine       Labels: 03C-906-056-BAG.lbl
Control Module Part Number: 03C 906 056 BA    HW: Hardware No
  Component and/or Version: MED9.5.10        00 5697
           Software Coding: 0000072
            Work Shop Code: WSC 00046 412 00000
                      VCID: 63C5490EA2F5B506E91-8036
4 Faults Found:
            P1033 - 002 - Signal too Low - Intermittent - MIL ON
18354 - Control Module 1 for Coolant Fan
            P1946 - 004 - Defective - Intermittent
18972 - Low Pressure Fuel Sensor (G410)
            P2540 - 008 - Implausible Signal - Intermittent - MIL ON
17479 - NOx Sensor (G295) Heater Control
            P1071 - 004 - Implausible Signal
Readiness: 0010 0001
Care e treaba cu low presssure fuel senzor?nu am m-ai avut-o pana acum...ms
Measuring Blocks pe canalul 208 - 209
Ai pe canalele acelea count 0, era masina pornita cand ai facut testul?
Daca da e problema ca nu numara  senzorii...
Stergele si vezi daca mai apar.
Salutare, Golf 4 1.6 16v AZD,
Imi apare :
17588 - Linear O2 Sensor; Pump Current: Short to Plus
P1180 - 35-10 - - - Intermittent
La pornire pana se incalzeste  putin, daca o turez, scoate fum negru, nu foarte mult dar scoate.
Apare 1data la 2-3 porniri, cateodata se aprinde Check , cateodata nu, dar daca scanzez cu Vag-Com pe engine, e acolo erroarea.
As fi dat vina pe pompa de benzina la inceput dar dupa ce am citit aici mi-am schimbat putin parerea.
Totusi , care sa fie cauza ? Sonda Lambda 1 are 5 luni , NGK cumparata noua, wideband, 650 lei, pe cod. M-am uitat la ea fara sa o demontez din nou, nu are vre-un fir intrerupt...
Va multumesc.
Versiune: VCDS-ROJ ROJ 11.11.5
Versiune date: 20130131
Luni,18,August,2014,21:34:31:58797
Tip ºasiu: 1K0
Adrese de scanat: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 69 76 7D
Numãr VIN: WVWZZZ1KZ7P005697   rulaj: 188040km
00-Senzor unghi volan -- Status: OK 0000
01-Motor -- Status: Malfuncþie 0010
03-ABS frâne -- Status: OK 0000
08-Clima automatã -- Status: OK 0000
09-Electronica centralã -- Status: Malfuncþie 0010
15-Airbaguri -- Status: OK 0000
16-Electronicã volan -- Status: OK 0000
17-Instrumente bord -- Status: OK 0000
19-Poarta CAN  -- Status: Malfuncþie 0010
25-Blocare pornire -- Status: OK 0000
42-Uºa electr. ºofer -- Status: OK 0000
44-Asistenþã direcþie -- Status: OK 0000
46-Confort -- Status: Malfuncþie 0010
52-Uºa electr.pasager -- Status: Malfuncþie 0010
56-Radio -- Status: OK 0000
69-Tractare -- Status: Neautorizat 0001
76-Asistenþã parcare -- Status: OK 0000
7D-Încãlz. Aux. -- Status: Malfuncþie 0010
Adresa 01: Motor        Eticheta: ROJ\03G-906-021-BMM.clb
   Numãr VAG SW: 03G 906 021 JG    HW: 03G 906 021 AB
   Componenta comandatã: R4 2,0L EDC G000SG  9392
   Revizie: --H02---    Numar serial: VWZ7Z0F8068131
   Codare: 0000072
   Atelier: WSC 00028 028 00001
   VCID: 6DDBA24174745370FAA
1 cod a gasit:
001139 - Senzor 1 presiune gaze evacuare-G450-  semnal prea mare
               P0473 - 000 -
             împrejurãri cod:
                    Starea defectului: 01100000
                    Priorit.defectului: 2
                    Frecv. defectului: 1
                    rulaj: 188047 km
                    Indicator de timp: 0
                    Data: 2000.00.00
                    timp: 21:25:54
             împrejurãri cod:
                    RPM: 0 /min
                    vitezã: 0.0 km/h
                    sarcinã: 0.0 %
                    tensiune: 12.69 V
                    rulaj: 260 km
                    temperaturã: 108.0*C
                    pres.absolutã: 999.6 mbar
Gata de funcþie: 0 0 0 0 1
Adresa 03: ABS frâne        Eticheta: ROJ\1K0-907-379-MK60-F.lbl
   Numãr VAG SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Componenta comandatã: ESP FRONT MK60      0101
   Revizie: 00H11001
   Codare: 0023170
   VCID: 73EFB439125085802CE
Nu a gãsit coduri.
Adresa 08: Clima automatã        Eticheta: ROJ\1K0-907-044.clb
   Numãr VAG SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
   Componenta comandatã: ClimatronicPQ35 090 0909
   Revizie: 00090016    Numar serial: 00000000000000
   Atelier: WSC 00000 000 00000
   VCID: 70E5BB356346BE98D1C
Nu a gãsit coduri.
Adresa 09: Electronica centralã        Eticheta: ROJ\3C0-937-049-23-H.lbl
   Numãr VAG SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Componenta comandatã: Bordnetz-SG     H37 1002
   Revizie: 00H37000    Numar serial: 00000005948202
   Codare: 018B8F2700041500001400001400000000097F075C
   VCID: 2B5F6C598AE09D40A4E
   Subsistem 1 - Numãr VAG: 1K1 955 119 E  Eticheta: ROJ\1KX-955-119.CLB
   Componenta comandatã: Wischer 080706 020  0501
   Codare: 00038805
   Atelier: WSC 00028
1 cod a gasit:
00924 - Releu spalare faruri-J39-
            009 - întrerupt sau scurt la masa
             împrejurãri cod:
                    Starea defectului: 01101001
                    Priorit.defectului: 4
                    Resetare contor: 7
                    rulaj: 183154 km
             împrejurãri cod:
                        Con.
                    tensiune: 12.20 V
                        Con.
                        Con.
                        Dec.
                        Dec.
                        Dec.
Adresa 15: Airbaguri        Eticheta: ROJ\1K0-909-605.lbl
   Numãr VAG SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Componenta comandatã: 37 AIRBAG VW8   020 2300
   Revizie: 05020000    Numar serial: 0038PD0LYTDH
   Codare: 0013111
   VCID: 3D7B5201649403F00AA
Nu a gãsit coduri.
Adresa 16: Electronicã volan        Eticheta: ROJ\1K0-953-549-MY8.lbl
   Numãr VAG SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Componenta comandatã: Lenksäulenmodul 035 0070
   Codare: 0000042
   VCID: 74EDB725175E82B8354
Nu a gãsit coduri.
Adresa 17: Instrumente bord        Eticheta: ROJ\1K0-920-xxx-17.clb
   Numãr VAG SW: 1K0 920 873 B    HW: 1K0 920 873 B
   Componenta comandatã: KOMBIINSTRUMENT VDD 1610
   Revizie: V0003000    Numar serial: VWZ7Z0F8068131
   Codare: 0007103
   Atelier: WSC 11111 111 11111
Nu a gãsit coduri.
Adresa 19: Poarta CAN         Eticheta: ROJ\1K0-907-530-V2.clb
   Numãr VAG SW: 1K0 907 530 H    HW: 1K0 907 951
   Componenta comandatã: J533__Gateway   H12 0150
   Revizie:   H12       Numar serial: 3100106707871C
   Codare: 3D0F0F4007000002
   VCID: 2C5D6F458FEE9A78AD4
1 cod a gasit:
01044 - Modul de comanda: codare incorecta
            000 - -
             împrejurãri cod:
                    Priorit.defectului: 1
                    Resetare contor: 216
                    rulaj: 183154 km
                    Data: 2000.00.00
                    timp: 20:13:11
Adresa 25: Blocare pornire        Eticheta: ROJ\1K0-920-xxx-25.clb
   Componenta comandatã: IMMO            VDD 1610
Nu a gãsit coduri.
Adresa 42: Uºa electr. ºofer        Eticheta: ROJ\1K0-959-701-MAX3.lbl
   Numãr VAG SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Componenta comandatã: Tuer-SG         005 0971
   Codare: 0000180
   VCID: 3973461170BC3FD0262
Nu a gãsit coduri.
Adresa 44: Asistenþã direcþie        Eticheta: ROJ\1Kx-909-14x-44.clb
   Numãr VAG: 1K1 909 144 L
   Componenta comandatã: EPS_ZFLS Kl.069 H07 1806
   VCID: 346D772557DEC2B8F54
Nu a gãsit coduri.
Adresa 46: Confort        Eticheta: ROJ\1K0-959-433-MAX.clb
   Numãr VAG SW: 1K0 959 433 CB    HW: 1K0 959 433 CB
   Componenta comandatã:    KSG PQ35 G2  020 0202
   Revizie: 00020000    Numar serial: 00000000000000
   Codare: 009002085103087F2D0484056008CB01E0BC00
   VCID: 72E1B13D6D4A8C88278
   Componenta comandatã:   Sounder n.mounted
   Componenta comandatã:       NGS n.mounted
   Componenta comandatã:      IRUE n.mounted
1 cod a gasit:
00896 - Mecanism închidere haion-F256-
            008 - semnal neplauzibil - intermitent
             împrejurãri cod:
                    Starea defectului: 00101000
                    Resetare contor: 38
                    rulaj: 187687 km
                    Data: 2000.00.00
                    timp: 09:44:44
Adresa 52: Uºa electr.pasager        Eticheta: ROJ\1K0-959-702-MAX3.lbl
   Numãr VAG SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Codare: 0000436
   VCID: 3A71591D75BA34C82F8
2  coduri de defecte:
00097 - Motor inchidere centrala fata-Safe- -V162-  pasager
            012 - Defect de circuit electric - intermitent
00929 - Unitate inchidere centrala-F221-pasager
Adresa 56: Radio        Eticheta: 1K0-035-1xx-56.lbl
   Numãr VAG: 1K0 035 186 R
   Componenta comandatã: Radio GR0       019 0023
   Revizie: 0001905S    Numar serial: VWZ2Z2F1759754
   Codare: 0020201
   VCID: 356B4A215CA4DBB0C2A
Nu a gãsit coduri.
Adresa 69: Tractare (J345)       Eticheta: ROJ\1K0-907-383-MY8.clb
   Numãr VAG SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Componenta comandatã: Anhaenger     H09 0100
   Revizie: 3A001001    Numar serial: 00000164304942
   Codare: 0100000100000000
   VCID: 30657B3563C6FE9891C
Nu a gãsit coduri.
Adresa 76: Asistenþã parcare        Eticheta: ROJ\1K0-919-283.lbl
   Numãr VAG: 1K0 919 283 A
   Componenta comandatã: 22 Einparkhilfe     0101
   VCID: 2D5B6241B4F49370BAA
Nu a gãsit coduri.
Adresa 7D: Încãlz. Aux.        Eticheta: ROJ\1K0-963-235.lbl
   Numãr VAG SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Componenta comandatã: PTC-Element         0404
   Revizie: 00800000    Numar serial:
1 cod a gasit:
00361 - Element încalzire pentru încalzire suplimentara-Z35-
            014 - defect
Sfârºit   -----------------------------------------------------------------
1.G450 senzor gaze evacuare(schimbat) REZOLVATA!
2.Releu faruri(e de inteles)
3.Adresa 19 Poarta Can ,Modul de comanda Incorect,chiar m-am chinuit cu omul respectiv ,nu am gasit problema!
4.Mecanism Inchidere Haion (Rezolvat)
5.Adresa 52(Rezolvat)
6.Adresa 7D incalzirea auxiliara(eu am masina de 10 luni si nu stiam sa am asa ceva)Trebuia sa am vreun buton ceva,pentru acest lucru?Ca idee iarna pana la facultate un drum de 10 minute exact cand ajung de abia incepe sa bage putin cald,foarte putin,o fi asta cauza?
Am postat tot logoul ca sa stiti exact ce sa cititi.Multumesc!
Z35 se repara - vezi ca este in spatele bordului - acea rezistenta mare. Da-i un search si o sa gasesti.
Modificat de pronet
 Mersi pronet!
Si  acesta:?
1 cod a gasit:
            000 - -
             împrejurãri cod:
                    rulaj: 183154 km
                    Data: 2000.00.00
                    timp: 20:13:11
De curand am achizitionat o interfata (clona) VCDS 12.12.0 , dar care din pacate in afara de erorile de pe engine altceva nu-mi arata,pentru ca nu sunt familiarizat !
Cine poate ajuta cu niste detalii in romana ,mai exacte cum sa o folosesc...
-mai exact vreau sa stiu cum vad parametri reali ai masini
-cum activez/dezactivez diferite functii,gen avertizor centura
-cu pot verifica/activa service/inspectie la VW Golf 4 1,6 (sau nu are functia asta?)
Si alte detalii care pot fii necesare unui posesor de VW (masina proprie)
Imi cer scuze,sunt incepator in chestia asta,iar de fiecare data cand am facut o diagnoza la colegi ,nu am fost multumit,si vreau sa invat,va rog frumos sa ma ajutati si raman dator  :hainoroc:
Ai citit si tu cateva pagini din acest topic si topicurile din aria deG4 ?
Adauga adresa 69 carlig tractare in instalation list la CAN.
Multumesc frumos....
Da,sa stii ca am citit,dar nu am inteles foarte bine si de aceea am indraznit sa mai intreb odata!
Poate totusi ma ajuta un coleg sa-mi explice putin pas cu pas...
Ce nu ai inteles? Unde ai citit si chiar nu ai inteles ?
Ce parametri reali vrei sa vezi ?
Toate acestea sunt trecute pe topicurile forumului, crede-ma
Salut. Vreau sa'mi iau si eu un cablu vagcom si am cateva intrebari. Am observat ca sunt 2 versiuni 11.11 si 12.12. Care e diferenta intre cele 2. Preturile sunt asematoare 99-130lei. Cum diferentie un cablu/soft original de o clona.
Toate sunt clone , la pretul asta !
Ce sa mai diferentiezi?
simplu - cea originala Ross Tech, costa 1600 lei.
VCDS 14.8.0 , se face si update de firmware de la 1.92 la 1.93, deci cred ca se pregateste un release cu ceva modificari.
Thx Cristi. Acum fac si eu update. In mod cert va fi un nou release. Mi se pare util in mod special UDS adaptation now handles single and multi byte hex values
that are part of a larger block
A iesit.
The Current version is:
Release 12.12.3
Data Version 20140822
ceau.
caut sa le iau la ai mei un golf pentru plimbari de "duminica". am gasit un g4 1.4 16V si i-am facut o scanare cu vag-ul si avea erorile de mai jos. dupa ce le=am sters nu au mai aparut imediat. cat de grave sunt si ce costuri de reparatie ar implica daca ar mai aparea?
PS: relatiul nu e constant, din ce cauza?
mersi anticipat
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01     -------------------------------------------------------
   Controller: 036 906 032 P
   Component: ME7.5.10            3547
   Coding: 00031
   Shop #: WSC 00046
2 Faults Found:
16785 - EGR System: Insufficient Flow
            P0401 - 35-10 - - - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
            P0134 - 35-00 - -
Address 03     -------------------------------------------------------
   Controller: 1C0 907 379 E
   Component: ESP FRONT MK60      0103
   Coding: 0011266
   Shop #: WSC 00046
00778 - Steering Angle Sensor (G85)
            014 - Defective - Intermittent
Address 46     -------------------------------------------------------
   Controller: 1J0 959 799 AH
   Component: 4E Zentral-SG Komf. 0001
   Coding: 04097
   Shop #: WSC 00046
4 Faults Found:
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
00932 - Electric Window Motor: Drivers Side (V147)
            62-10 - No or Incorrect Adjustment - Intermittent
00943 - Heated Exterior Mirror: Driver Side (Z4)
            35-00 - -
00944 - Heated Exterior Mirror: Passenger Side (Z5)
            35-00 - -
End   -------------------------------------------------------
Modificat de ioio_viola
  • Aerofan pinned this topic
