suzu
Salut! Are cineva sau a folosit careva acest model de interfata?
USB KKL VAG-COM 409.1
E buna de ceva?
pentru masina din semnatura - merge.
Ceva idei si pentru problema mea postata la postul 3739 va rog! :icon_cry:
01335 - Modul pozitionare scaun/oglinda sofer -J543-
            49-00 - Nu este comunicare
00476 - Modul comanda pompa combustibil -J538-
MUltumesc!
Eu zic sa faci o diagnoza cu o interfata mai buna. LA masina ta nu ai modulul de comanda a pompei de injectie.
Ma poate ajuta cineva ce erori am?
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
VIN: WVWZZZ1JZ2W468909   Mileage: 166050km/103178miles
Address 01: Engine        Labels:
   VCID: 55AA363EACD640B68C3
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 J
   Component: ABS FRONT MK60      0103
   Coding: 0001025
   Shop #: WSC 01391 785 00200
   VCID: 3162A2AEABFE4C9630B
No fault code found.
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0004
   Coding: 12855
   Shop #: WSC 01391
   VCID: 22405DE2AE18E70EB91
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J5 920 806 B
   Component: KOMBI+WEGFAHRSP VDO V11
   Coding: 01113
   Shop #: WSC 00000
   VCID: 2B5EB0C6D9D226460A7
   WVWZZZ1JZ2W468909     VWZ7Z0A4541356
1 Fault Found
01336 - Data Bus for Comfort System
            80-10 - Single-Wire Operation - Intermittent
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 01391
   VCID: F0E4E7AAB074859EFF5
1 Fault Found
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799
   Component: 1F Komfortgerát HLO 0001
   Coding: 00259
   Shop #: WSC 01391
   VCID: F4ECEBBAC46CB9BE1BD
   Subsystem 1 - Part No: 1C1959801A
   Component: 1F Tõrsteuer.FS KLO 0002
   Subsystem 2 - Part No: 1C1959802A
   Component: 1F Tõrsteuer.BF KLO 0004
   Subsystem 3 - Part No: 1C0959811A
   Component: 1F Tõrsteuer.HL KLO 0002
   Subsystem 4 - Part No: 1C0959812A
   Component: 1F Tõrsteuer.HR KLO 0004
2 Faults Found
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
End   ------------------------------------
1-Verifica firele de CAN bus care leaga calculatorul de comfort (J393) de celelalte controlere. Unul din fire este intrerupt/nu face contact.CAN bus Network.pdf
2-Verifica Inchiderea centralizata de la pasager (F221).Contacte imperfecte/lipituri reci/fire intrerupte.Golf & Bora Convenience system (2).pdf
The current version is:
Beta 14.6.1
Data Version 20140601
E chiar culmea ross tech-ul. In aceasi zi vad ca au scos doua versiuni beta. Se lucreaza nu gluma :p. Azi fac si eu update-ul. Ms Cristi.
Am si eu o intrebare, se potriveste yala de golf 5 cu cea de audi a3 8p1? Erorile sunt urmatoarele...
-01331 - Door Control Module; Driver Side (J386)
-00929 - Locking Module for Central Locking; Front Passenger Side (F221)
inchiderea nu-mi merge din telecomanda, din cheie si butonul interior merge. Daca as schimba yala de pe dreapta se poate rezolva inchiderea din telecomanda sau are legatura si cu prima eroarea. daca schimb yala mai trebuie configurat ceva sau va merge direct? Multumesc.
008 - Implausible Signal - Intermittent
salutare!
de ceva timp, cam un an, ma confrunt cu urmatoarele erori si nu stiu cum as putea sa le rezolv intr-un mod mai "profesionist", si de aceea postez aici in ideea unui ajutor sau a unei idei.
masina in cauza: Skoda Octavia II an 2005 cod motor BJB
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 DJ    HW: 028 101 188 3
   Component: R4 1,9L EDC G000SG  6250
   Revision: 12345678    Serial number: SKZ7Z0D2468169
   Coding: 0000071
   Shop #: WSC 73430 000 00000
   VCID: 6ED9D061798C249
3 Faults Found:
19464 - Camshaft Position Sensor (G40)
            P3008 - 000 - Signal Out of Range - Intermittent
             Freeze Frame:
                    RPM: 1008 /min
                    Torque: 12.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.16 V
                    Bin. Bits: 00101100
                    Idle Stabilization: 0.0°KW
                    (no units): 35.0
17055 - Cylinder 1 Glow Plug Circuit (Q10)
            P0671 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 756 /min
                    Torque: 140.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.10 V
                    Bin. Bits: 00001100
                    Temperature: 8.1°C
                    Bin. Bits: 01110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
            P0672 - 000 - Electrical Fault - Intermittent
             Freeze Frame:
                    RPM: 945 /min
                    Torque: 28.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.78 V
                    Bin. Bits: 00001100
                    Temperature: 9.0°C
                    Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 D
   Component: ClimatronicPQ35 083 0303
   Shop #: WSC 00000 000 00000
   VCID: 377735054656A51
2 Faults Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
            000 -  -
00716 - Air recirculation Flap Positioning Motor (V113)
            000 -  -  - Intermittent
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 L    HW: 1K0 937 049 L*
   Component: Bordnetz-SG 1.0 H29 0701
   Revision: 00029000    Serial number: 00000001205301
   Coding: 01880F220004500046110D000000000000
   Shop #: WSC 73430 790 12345
   VCID: 387536394B48AA9
   Subsystem 1 - Part No: 1Z1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 73430
00526 - Brake Light Switch-F
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 2100104508169A
   Coding: 3D0F0340071302
   Shop #: WSC 73430 790 00000
   VCID: 2757E54596F6351
2 Faults Found:
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 24
                    Reset counter: 141
                    Mileage: 225552 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:10:54
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 21
                    Reset counter: 129
                    Mileage: 225828 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:44:52
multumesc anticipat!
Modificat de selvinnio
NU se potrivesc yalele de la a3 la g5.
Salutare, imi apar si mie la un Polo 9N, 1.2 benzina, urmatoarele erori:
Address 01: Engine        Labels: Redir Fail!
   Part No: 03E 906 023 B
   Component: SIMOS91 1.2l 4V     1891
   Revision: --H04---    Serial number: VWZ7Z0H0063713
   Coding: 0000071
   Shop #: WSC 00788 785 00200
5 Faults Found:
17088 - Clutch Switch (F36): Implausible Signal
            P0704 - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    RPM: 2624 /min
                    Mass Air / Rev.: 408.8 mg/str
                    Speed: 80.0 km/h
                    Bin. Bits: 00000100
                    RPM: 3168 /min
                    Mass Air / Rev.: 103.6 mg/str
                    Speed: 59.0 km/h
                    Bin. Bits: 00000100
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
            P0420 - 006 - Short to Plus - Intermittent
             Freeze Frame:
                    RPM: 2528 /min
                    Hex Value: 0x00F3
                    Speed: 46.2 km/h
                    Temperature: 760.0°C
                    RPM: 2656 /min
                    Hex Value: 0x00F3
                    Speed: 48.2 km/h
                    Temperature: 744.0°C
16587 - Injector: Cylinder 3 (N32): Circuit Malfunction
            P0203 - 009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    RPM: 768 /min
                    Mass Air / Rev.: 109.0 mg/str
                    Temperature: 73.5°C
                    Bin. Bits: 00000100
16585 - Injector: Cylinder 1 (N30): Circuit Malfunction
            P0201 - 009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    RPM: 800 /min
                    Temperature: 73.5°C
                    Bin. Bits: 00000100
16555 - Fuel Trim; Bank 1: System Too Lean
            P0171 - 006 - Short to Plus - Intermittent
             Freeze Frame:
                    Voltage: 0.460 V
                    Voltage: 0.420 V
                    Lambda: 0.0 %
                    Bin. Bits: 00001000
                    Voltage: 0.080 V
                    Voltage: 0.060 V
                    Lambda: 0.0 %
                    Bin. Bits: 00001000
Readiness: N/A
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 6Q0 035 152 G    HW: 6Q0 035 152 G
   Component: Radio LG3           0018
   Revision: 00009000    Serial number: VWZCZ5I0097294
   Coding: 0010400
3 Faults Found:
01042 - Control Module; Not Coded
            000 -  -
00872 - Bass Speaker Rear Left (R15)
            011 - Open Circuit
00873 - Bass Speaker Rear Right (R17)
            011 - Open Circuit
End   ---------------------------------------------------------------------
Din ce am mai citi pe forum banuiesc ca ar fi probleme la una din sondele lambda sau la catalizator, dar nu stiu ce sa verific mai intai, eroarea cu Clutch Switch nu am gasit ce inseamna si nici pe cea cu radio.
Sterge-le, mergi cu masina si vezi care mai apar.
LA radio: e pus de curand pe masina?
Le-am sters si imi apar imediat ce pornesc motorul. Problema este dimineata la rece porneste foarte greu, trebuie sa ii dau mai multe chei ca sa porneasca. Radioul e cel original al masinii.
Am verificat si temperatura la motor si imi apar 105 grade. E posibil sa imi apara toate erorile de la motor de la senzorul de temperatura a apei? Sa fie acela defect?
Modificat de getodacu
Verifica firele de la injectoare.
verifica firele si boxele de pe spate (daca ai) si codeaza corespunzator radioul.
Mersi, o sa verific, boxele cred ca nu sunt pe spate.
Salut! Imi oscileaza relantiul si am urmatoarea eroare:
Address 01: Engine        Labels: 036-906-014-AHW.lbl
   Part No: 036 906 014 P
   Component:  MARELLI 4CV       2859
   Coding: 00031
   Shop #: WSC 01317
   VCID: 1D313FFF974415F69F5-4A3A
00519 - Intake Manifold Pressure Sensor (G71)
            31-10 - Open or Short to Ground - Intermittent
Readiness: N/A
De la ce ar putea fi? Multumesc anticipat!
Senzorul de presiune de pe galerie. Verifica firele. Daca sunt ok, schimba senzorul.
Salutare, am nevoie de putin ajutor din partea dvs,  Un VW Polo 2001 , dupa ce s-a refacut motorul a ramas cu erroarea ,care nu se sterge : 17748/P1340/004928 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
Masina merge foarte bine a fost facuta in service, iar distributia la prima vedere pare ca e pusa ok, nu aiurea. (Asta a fost prima mea impresie)
daca inainte de a desface motorul ,nu erau aceste erori ,verifica distributia ,nu trebuie sa "para" ,trebuie sa "fie" pusa la punct .
Exact ! Sa vada si a "doua vedere"
   Coding: 00031
   Shop #: WSC 01317
Readiness: N/A
nu ar fi rau sa verifici si daca ai aer fals inainte de inlocuire senzor MAP
Multumesc pentru sfaturi!
Am facut o diagnoza si la altcineva, mi-a curatat clapeta si acum relantiul e stabil, meseriasul fiind de parere ca senzorul inca e bun. Oricum dadusem inainte comanda de senzor ca eram presat de timp si poate nu strica sa il schimb.
eroarea pe senzor este de natura electrica, nu are legatura cu aerul fals.
Daca pe senzor era eroare de gen "semnal implauzibil" , atunci era altceva.
VCDS Beta 14.7 de ieri.
  • Aerofan pinned this topic
    • bogdan_vw_11
