suzu
NU ai unde face o diagnoza cu VCDS?
KTS-ul ala de la bosch si mai ales traducerea in romana. .....
MRomanowski
6 Faults Found:
16575 - Fuel Pressure Sensor (G247): Implausible Signal
            P0191 - 008 - Implausible Signal - Intermittent - MIL ON
17951 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Small
            P1543 - 002 - Lower Limit Exceeded - Intermittent
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
            P1172 - 002 - Lower Limit Exceeded - Intermittent
19490 - Intake Air Temperature Sensor 2 (G299): Signal too Large
            P3034 - 002 - Lower Limit Exceeded - Intermittent
17953 - Throttle Valve Controller: Malfunction
            P1545 - 008 - Implausible Signal - Intermittent
            P1545 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
asta a fost prima scanare facuta cu VCDS
Si revin cu intrebarea: daca masina merge acum OK, care este problema ?
floro_st205
acolo ai cam 5 componente diverse care-ti dau eroare ,fiind situate toate cam in aceeasi zona a motorului ,uitate dupa un fir ros/frecat care da la masa sau mufa la ecu desi cred ca e mai putin posibil .
MRomanowski
asta e problema . nu merge ok ..
vineri cel mai probabil o sa verific firele cand o sa ajung acasa .. momentan sunt la facultate si nu am timpul necesar. mersi de sfat!
Modificat de MRomanowski
Poate sa ma ajute si pe mine cineva la astea doua erori?
Deci la prima, e defect senzorul...? Ca tot se porneste termocupla, cand pornesc masina, chiar daca apa nu e la 90 grade.
La a doua, tot imi da cand pornesc masina dar nu tot timpul, si se opreste masina.
000278 - Engine Coolant Temp. Sensor (G62): Implausible Signal
               P0116 - 008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 0
                    Fault Frequency: 6
                    Mileage: 102487 km
                    Time Indication: 0
                    Date: 2014.05.07
                    Time: 13:42:39
             Freeze Frame:
                    RPM: 720 /min
                    Load: 34.1 %
                    Speed: 2.0 km/h
                    Temperature: -40.0°C
005488 - Engine Start Blocked by Immobilizer
               P1570 - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 3
                    Mileage: 102674 km
                    Time Indication: 0
                    Date: 2014.05.14
                    Time: 06:49:00
             Freeze Frame:
                    RPM: 1280 /min
                    Load: 45.5 %
                    Speed: 0.0 km/h
                    Temperature: 12.0°C
Log-SM01DEN.txt
Am urmatoarea eroare:
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105B1810FA
   Coding: 3D3F0B40070002
   Shop #: WSC 01279 785 00200
   VCID: 2A511C7185E4089
01332 - Door Control Module; Passenger Side (J387)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 247
                    Mileage: 160964 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:29:40
Mentionez ca imi arata pe display(maxidot)  usa pasager deschisa chiar daca este inchisa. Si cand o inchid din telecomanda la fel imi arata. In rest totul este ok geamul functioneaza, semnalizarea din oglinda fuctioneaza, usa se inchide normal din telecomanda. Am avut sirena electronica defecta si am inlocuit-o. In momentul cand am conectat-o nu am avut siguranta 35 pusa, cea care este pentru senzorul de inclinare, senzorul monitorizare interioara si alarma. Din momentul ala imi apare eroarea. Sirena functioneaza si bipuie de 2 ori cand deschid masina din telecomanda, dar cand o inchid nu se aude nimic si nu semnalizeaza. Adaptarile in 46 confort cu vcds-ul pe bitul 10 si 11 sunt ok(adica bifate). Motorizare 1.9 BKC 2006 Comfortline. Daca ma puteti ajuta cu o parere ar fi bine si scuze daca sunt off topic.
ionel.d.2007
Pentru eroarea 01332 - verifica continuitatea firelor de can bus (firele portocaliu/maro-T20b/9 si portocaliu/verde-T20b/8) care leaga controlerul din usa soferului de celelalte controlere.Vezi sa nu fie contacte oxidate.Convenience_system_Golf_1,9_TDI_77_Kw.pdf.
Verifica cu VCDS in 09 (centrala electrica) daca iti functioneaza switchul din usa pasagerului. Daca nu functioneza trebuie sa dai jos si sa-l remediezi. Cauta ca este topic separat cu schimbare switch.
Buna dimineata!
Am si eu urmatoarea eroare care chiar daca o sterg reapare:
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J0 920 826 A
   Component: KOMBI+WEGFAHRSP VDO V13
   Coding: 05113
   Shop #: WSC 00046
   WVWZZZ1JZ3B111249     VWZ7Z0B6582053
01336 - Data Bus for Confort System
    80-00 - Single Wire Operation
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 00046
01336 - Data BUs for Confort System
Am mai avut ceva intermitent tot pe instruments  "Coolant Temperature Sensor (G2) 30-10 - Open or Short to Plus - Intermittent" care insa nu a mai aparut.
De la ce sa fie data bus, mufele de la "ceasuri"?
Modificat de virus
F l o r i n
trebuie verificat cablajul intre modulul confort si ceasuri
exista ceva parametrii pe care le pot vedea cu VagCom-ul referitor la supape/cilindri sa vad ca functioneaza ok.
am observat ca una din bujii se innegreste si am schimbat atat bujia cat si bobina si dupa 30 de min de mers la fel o innegreste ceea ce inseamna ca am ceva la cilindru/supape.
Gasesc ceva cu VagCom-ul referitor la compresie, etc?
La o simpla scanare nu am gasit nici un fel de problema.
Compresie nu, dar misfire DA.
Misfire nu am
Compresia o voi verifica cu aparatul
Pacat ca in cauzl asta Vagcom-ul nu prea este folositor
Am si eu o eroare, desi masina porneste ok (legat de alte manifestari nu am gasit erori, desi intre 2000 si 3000 RPM imi smuceste la mers constant):
Address 01: Engine        Labels: Redir Fail!
   Part No: 036 906 034 BB
   Component:  MARELLI 4LV       3408
   Coding: 00031
   Shop #: WSC 01317
   VCID: 53A599C7A1009386791-4A9C
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 -  - Intermittent
Readiness: 1010 0001
Trebuie sa ma ingrijorez?
Inca nu am sters eroarea sa vad daca mai apare.
La o fabia de 1.4 16V, e sporadica treaba, nu tot timpul are simptomele de a nu trage si oscilatii la relanti, cu aparitia martor motor in bord, am curatat clapeta de acceleratie, inlocuit senzor presiune galerie, verificat furtun ce vine la clapeta si tot asa face. ce pot sa ii mai fac/verific. multumesc
Control Module Part Number: 036 906 034 KE
  Component and/or Version:  MARELLI 4TV        7450
           Software Coding: 00071
            Work Shop Code: WSC 13765
                      VCID: 5FCD45FEDD9D91E6CD9-4B36
2 Faults Found:
17961 - Barometric / Manifold Pressure Signals
            P1553 - 35-10 - Implausible Correlation - Intermittent
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
            P0106 - 35-10 - Implausible Signal - Intermittent
Readiness: 0000 0100
ionel.d.2007
Verifica distributia. Vezi sa nu fie sarita de la punct.
Nu e vorba de vag com ci de faptul ca nu exista senzor pe motor pt a masura compresia
Multumesc pentru info, dar de ce trebuie sa verific controlerul din usa soferului cand problema este la usa pasagerului.
Cine a zis ceva de sofer ?
Al Bundy,  ionel.d 2007 a postat ceva in legatura cu problema mea si nu am inteles de ce trebuie sa verific controlerul din usa soferului cand problema este la usa pasagerului.
@ionel.d.2007 Daca era distributia sarita nu trebuia sa dea senzorul de la axa cu came sau vilbrochen?
   Coding: 00031
   Shop #: WSC 01317
am patit la fel a fost egr, nici al meu nu dadea eroare
2 Faults Found:
pe undeva trage aer fals, chiar si in zona egr poate fi buba sau zona servofranei
Modificat de SergiuD
ionel.d.2007
mary999ro - scuza-ma, era vorba de controlerul din usa pasagerului.
ghitaTSI - am citit ca ai verificat daca iti trage aer fals, ai inlocuit senzorul MAP (am banuit ca ai pus unul nou/functional), firele MAP-ECU-posibil dar putin probabil, ECU-posibil dar putin probabil, asa ca eu suspectez distributia sarita de la punct.
O intrebare scurta si stupida..tocmai ce am terminat de montat cruise controlul si vreau sa-l activez din vcds problema e ca nu ma mai tine bateria deloc la laptop, as avea posibilitatea sa fac codarea cu motorul pornit? Deoarece am invertor de 220V pe masina :) Multumesc.
Am sa verific si la servofrana cum a spus colegul SergiuD si apoi o sa mai vedem, ma apuc si de verificat fire, ceea ce nu cred fiindca nu apare imediat eroare, chiar si dupa 50 km
  • Aerofan pinned this topic
