suzu
dany@TuningCars
Masina este stock...
inseamna un set de teste pe sistemele anitpoluare pe care trebuie sa le treaca motorul. Daca toti parametrii sunt corecti adica.... si totul merge in parametrii
http://www.google.ro/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0CEQQFjAD&url=http%3A%2F%2Fwww1.snapon.com%2FFiles%2FDiagnostics%2FUserManuals%2FVolkswagenAudiReadinessCodeCharts.pdf&ei=2_FnU6_HIcmuyAO_oYDgCA&usg=AFQjCNHb1eYMQUaLF3o5GajKTq2FV5cbaA&bvm=bv.65788261,d.bGQ&cad=rjt
Modificat de andrei_221
Pune originala
Originala costa 1100 ron
Am gasit Ngk la 610 ron. Am intrebat de Bosch si mi s-a spus ca nu fac sonda pt modelul meu de motor
Imi cam vibreaza masina la relanti (mai ales daca e pozitionata in panta) si azi am facut o diagnoza, stie cineva la ce anume se refera mai exact erorile de mai jos?:
Multumesc anticipat de raspuns
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 AS HW: ÿÿÿÿÿÿÿÿÿÿÿ
Component: MARELLI 4HV G 8564
Revision: --H06--- Serial number: VWX7Z0H03NS0JD
Coding: 0000071
Shop #: WSC 10101 599 108911
VCID: 6FED35377E68D7667D9-803A
28812 - Body Control Module (Central Electric)
U0140 - 000 - No Communications - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 15
Mileage: 0 km
Time Indication: 0
Readiness: 0000 0000
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 864 HW: 1K0 920 864
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0H03NS0JD
Coding: 0003103
Shop #: WSC 10184 599 62057
VCID: E9D9DB2FC08CB956A3D-80BC
01312 - Powertrain Data Bus
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 146
Mileage: 0 km
Time Indication: 0
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1219
Coding: 0000180
Shop #: WSC 00028 028 00001
VCID: 387FCE6B4BA650DE6C3-806D
2 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
01321 - Control Module for Airbags (J234)
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.067 H08 1901
VCID: 3561C75F5CB4ADB6775-8060
Freeze Frame:
Mileage: 0 km
Temperature: 32.0°C
Voltage: 12.50 V
Voltage: 12.30 V
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000180
VCID: 3979CB6F70AC49D693D-806C
2 Faults Found:
Foarte posibil sa fie PCV-ul de vina.
Bogy.
Clar ca nu are EGR ?? Atunci iti spun.."clar iti trebuie pe cineva langa tine/masina ta, adica pe cineva care stie despre ce e vorba.
Ps.sa nu fi suparat pe mine.
Zi frumoasa tuturor.
F l o r i n
ceva probleme de comunicatie cu can gateway si modulul airbag-urilor.
si nu comunica cu BCM-ul....normal, ca masina ta nu are asa ceva,.... deci, incearca cu alta interfata - una originala - clona respectiva nu face treaba buna....
Mersi mult Florin. Concluzia e sa nu-mi fac griji.
dany@TuningCars
romy din cate stiu eu EGR au opelurile..poate gresesc...dar la seat sigur nu se numeste EGR...
Hoonigan: tot ce se poate..stiu ca este o boala al lor, a 2.0 TFSI-urilor ca sa cada PCV-ul...sa vad azi cand voi ajunge la un alt service...
prunaionutz
Daca a picat pcv-ul cauta un kit de pcv off.
Bogy.
Ca sa fiu corect se numeste"supapa EGR" pt modelul tau de motor e in jur de 700/800 lei.
Poti sa mi iei sfatul in considerare sau nu, o simpla cautare pe net o sa te lamureasca ce e"supapa EGR si rolul ei.
dany@TuningCars
Tu te referi la clapeta de acceleratie cand zici EGR, cred ca vorbim amandoi de acelasi lucru, dar diferit :)
Miane dimineata se vor apuca de masina....cred ca este PCV-ul pana la urma, dar inainte de verdict trebuie verificat inca o data...va anunt "defectul".
Multumesc ptr. sprijin!
Modificat de BOGY26
Bogy.
MAF e una EGR e alta iar clapeta de acceleratie(care de fapt e un motoras pas cu pas) e altceva.
Atata timp cat este o eroare pe motor , ar trebui sa-ti faci griji. Sau macar pana stii sigur ce eroare este. Aia din scanul tau nu are cum sa fie.
prunaionutz
PCV fisurat ar explica turatiile la relanti.
dany@TuningCars
Vedem maine :)
eu chiar cautam incepator fiind sa aflu cum se instaleaza si ce fac butoanele pe akolo dar vad ca sa deviat de la subiect si sa lasat totul balta ...eu daca o sa fac ceva rau sau bun o sa filmez totul :)
dany@TuningCars
Se pare ca de vina este PCV-ul, nu isi mai face treaba cum trebuie...inchide si deschide cand vrea...azi s-a comandat la reprezentanta - 194 lei, maine va ajunge si tot maine se va si schimba...
Multumesc! Drumuri bune.
Modificat de BOGY26
dany@TuningCars
PCV failure...s-a inlocuit, s-au sters erorile, s-a mers cu masina si totul este ok..
Multumesc frumos ptr. sprijin.
prunaionutz
Cu mare placere.
Bafta!
MRomanowski
am fost la un service .. si au gasit urmatoarele erori :
post-135887-0-66829800-1399907567_thumb.
post-135887-0-81752500-1399907569_thumb.
post-135887-0-48762900-1399907747_thumb.
post-135887-0-94566500-1399907805_thumb.
Si daca le stergi care mai raman? ce probleme ai pe masina?
MRomanowski
nu ramane nimic
Atunci, care este problema?
MRomanowski
problema e ca are momente cand motorul nu merge normal... adica accelerez si nu "trage"..ca si cum nu ar deschide clapeta de acceleratie ... sincer nu ma pricep.. se intampla la 100km sa imi apara in bord "check engine" si dupa 100 km se stinge de la sine .. merg 100 km reapare "check engine"
  • Aerofan pinned this topic
    • bogdan_vw_11
