suzu
din soft.... numai cu modificare eeprom ECU.
las-o asa, cum ti-au zis si colegii.... cand sunt fonduri, o inlocuiesti....
Modificare flash
Modificat de Turbocip
De aproape un an tot circul cu martorul de bec ars ba pornit ba oprit. Preconditia pentru ca acesta sa apara este sa pornesc luminile de drum si sa dau cheie.
Ca fapt divers odata ce am contactul pus (cu motorul oprit) si luminile de drum pornite, stopurile de pe haion nu se aprind. (nu stiu daca asa e by default sau mea culpa). In cazul in care dau cheie se aprind si stopurile de pe haion.
Tin sa precizez ca nu am LED la numar si nici stopuri LED.
Am tot cautat solutii si toti cei care au patit asa ceva sau similar au montat LED ba la numar ba au schimbat stopurile.
Am atasat si scanul de pe 09 in speranta ca cineva ma poate indruma spre o solutie.
Dorin
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
   Component: BCM PQ35  M   103 0537
   Revision: 00103 AC
   Coding: 46180A3A90251AC040000080100081E441010088724D8920148000200000
   Shop #: WSC 10133 599 00001
   VCID: 3064A7AA63F4459E3F5
   Subsystem 1 - Part No: 1K1 955 119 E
   Component: Wischer 25050  21  0501
   Coding: 009795
3 Faults Found
00907 - Intervention load Management
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 115
                    Mileage: 37454 km
                    Time Indication: 0
                    Date: 2119.14.21
                    Time: 22:55:53
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.70 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00984 - Left Tail Light (M4)
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 115
                    Mileage: 37454 km
                    Time Indication: 0
                    Date: 2119.14.21
                    Time: 22:56:11
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.50 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00985 - Right Tail Light (M2)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 115
                    Mileage: 37454 km
                    Time Indication: 0
                    Date: 2119.14.21
                    Time: 22:56:11
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.50 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Verifica firele dintre haion si caroserie.
Salut , am si eu o problema cu un Golf 5 1.4 FSI. De cateva zile am becul "check engine" aprins si masina are momente cand trage normal si cand urca foarte greu turatia. Am facut o scanare cu VAG-COM si am urmatoarele erori:
6 Faults Found:
16575 - Fuel Pressure Sensor (G247): Implausible Signal
            P0191 - 008 - Implausible Signal - Intermittent - MIL ON
17951 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Small
            P1543 - 002 - Lower Limit Exceeded - Intermittent
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
            P1172 - 002 - Lower Limit Exceeded - Intermittent
19490 - Intake Air Temperature Sensor 2 (G299): Signal too Large
            P3034 - 002 - Lower Limit Exceeded - Intermittent
17953 - Throttle Valve Controller: Malfunction
            P1545 - 008 - Implausible Signal - Intermittent
            P1545 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
a mai intalnit cineva aceasta problema si ma poate ajuta ?
Multe erori. Sterge si vezi care mai apar.
Am desfacut pe acolo recent deoarece becul de pe partea dreapta a haionului nu mai mergea de loc. De ars nu e ars si nici nu are filamentul rupt. Am schimbat becul dar tot acelasi martor.
Exista vreo cale sa aflu care e defapt codarea pe byte-ul 18 de ce centrala electrica? Momentan valorile reale sunt ascunse de 00 si nu m-a incumet sa mesteresc pe acolo.
Anul trecut in septembrie am resetat masina la valorile din fabrica (@Autoworld Cluj Napoca) deoarece au fost suficient de inspirati sa imi copieze cu copy paste setarile de pe un GTI doar pentru a activa spalatorile de faruri. Pe vremea resetului aveam si LED OEM la numar in spate (schimbasem bara). Acel lucru a cauzat la momentul acela niste anomali urate care s-au rezolvat dupa ce am schimbat lampile de la numar cu cele anterioare.
@Al Bundy mai ai alte sugesti?
Dorin
Totodata daca ne uitam la data cand e raportat incidentul e o aiureala totala.
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 115
                    Mileage: 37454 km
                    Time Indication: 0
                    Date: 2119.14.21
                    Time: 22:56:11
Nu conteaza formatul, dar nu avem nici luna 21 si ziua 14 si nici invers... ora raportata e ok totusi.
The current version is:
 Beta 14.4.2
Data Version 20140411
Imi apare urmatoarea eroare la scanare:
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 N    HW: 3C0 614 109 N
   Component: J104    C4 440 V1   0011
   Revision: --025---    Serial number: 00000786263061
   Coding: 0000262
   Shop #: WSC 05311 000 00000
   VCID: 2953E37D80E2031
01309 - Power Steering Control Module (J500)
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 6
                    Reset counter: 128
                    Mileage: 195829 km
                    Time Indication: 0
                    Date: 2124.14.29
                    Time: 16:19:12
             Freeze Frame:
                    Speed: 0.0 km/h
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 221
                    Hex Value: 0x0000
Aveti idee care ar fi cauza?
Si mai mult de atat, ce riscuri exista daca nu`i dau de cap si raman cu ea asa?
Scanul complet in attach, nicio alta eroare in rest
Final.txt
F l o r i n
da, am bagat-o de vreo 2-3 zile.
Multumim !
acum cateva zile am facut o scanare cu VAG COM deoarece nu imi mergea butonul de recirculare aer si din cand in cand baga aer cald in loc de rece. Am obtinut urmatoarele:
VCDS Version: Release 12.12.0
                Address 08: Auto HVAC       Labels: 6Q0-820-045.lbl
Control Module Part Number: 6L0 820 045
  Component and/or Version: Klimaanlage        X0840
           Software Coding:
            Work Shop Code:
                      VCID: E5C1D7167FC14B36875-517A
3 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
            30-10 - Open or Short to Plus - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
            41-00 - Blocked or No Voltage
            29-10 - Short to Ground - Intermittent
dupa ce am studiat pe forum-uri erorile m-am apucat de rezolvarea problemei motorasului v154. dupa ce am scos motorasul si l-am desfacut i-am curatat cu spray pt contacte potentiometrul (acela albastru) i-am pus mufa si fara sa-l introduc la loc m-am jucat cu el inchis deschis si am vazut ca functioneaza dupa care am apasat "basic settings". L-am montat inapoi si eroarea nu a disparut, din contra a mai aparut una:
   Part No: 6L0 820 045
   Component: Klimaanlage        X0840
3 Faults Found:
            30-00 - Open or Short to Plus
            55-00 - Adaptation Not Successful
Ma puteti va rog ajuta cu aceasta ultima eroare? m-am uitat la cursa motorasului am citit pe undeva ca la minim val trebuie sa fie 0 si la maxim 255. La mine sunt 46 si 216 daca imi aduc bine aminte....sau ceva de genul.
Va multumesc
cred ca nu l-ai angrenat bine pe cele 2 pinioane de la clapetele de recirculare, una e sus una e jos, mie mi-au dar multe batai de cap fata de v68 la care a fost mult mai dificil accesul nu montajul
sterge erorile si incearca o adaptare cu el demontat, daca totul e ok nu mai ramane decat sa il angrenezi bine, ca sa vezi cum lucreaza poti sa pui contactul si sa apesi recircularea, la v68 ma jucam cu butonul de caldura (climatic)
si la mine tot de la 0 la 255 merg ambele clapete
cand ai curatat potentiometrul albastru sper ca ai dat la o parte protectia acea neagra (se creapa putin dar nu cade si se poate plia la loc) si ai dat cu spray de contacte sau de curatare in interiorul potentiometrului
Modificat de SergiuD
Mersi de ajutor
Da i-am desfacut plasticul acela negru si am dat cu spray inautru unde e sarmulita aceea. am sters erorile si degeaba. am aceleasi erori si cu el demontat. le sterg si apar din nou aceleasi. si eu m-am chinuit vreo 30 de min, imi amortise si mana pana sa reusesc sa-l pun la loc. Prima oara l-am pus gresit ca il auzeam cum mergea dar acum cred ca e pus bine. Merge f usor si inchide si deschide complet clapet\a de jos. Pe cea de sus nu pot sa o vad :(. Daca ai o idee cum pot sa-i modific eu valorile sau sa-l pun pe el sa mearga in punctele de maxim si sa si le invete singur.
De ce imi da       01596 - Motor for Outside/Recirculated Air Flap (V154)
si cu el demontat si cu el montat.  Ce vrea sa insemne?
Mersi
Dragi colegi, insfarsit mi-am luat inima in dinti si m-am hotarat sa achizitionez o interfara vcds originala, am si facut comanda aici http://www.sculeprofesionale-shop.ro/interfata-diagnoza-pentru-grupul-vag-99580.p.html
Vroiam sa o ridic personal astazi dar se pare ca cei ce ar fi trebuit sa raspunda la telefon sunt la gratar, doar e 2 mai..
Va rog sa-mi spuneti..si-a luat careva vcdsu de la ei?
Vroiam sa stiu daca sunt seriosi si daca vand vcds-ul original
Chiar si numele siteului lor e banal..e sinonim de exemplu cu cheimisto.ro
Imi intelegeti ingrijorarea..e vorba totusi de bani..si multi..nu vreau sa lucrez o luna doar pe bonuri :)
Modificat de Julwere
daca nici demontat nu se adapteaza cred nu mai ai ce face cu el din cauza potentiometrului
DAR s-ar putea sa fi montat invers cursorul potentiometrului pe pinion, verifica asta
nu poti modifica acele valori, nu au importanta, ai o intrerupere pe circuit, mai curata potentiometru, eu aveam doar wd40 atunci dar a mers am dat din abundenta si am plimbat putin cursorul...
da, de ce?
Beta 14.4.2
Poate 14.5. Ca a aparut azi.
Eu am cumparat un spray special de potentiometer, lasa in urma un strat foarte fin uleios. Daca nu au importanta valorile nu mai imi bat capul.....merge perfect. M-am uitat la clapeta si imi inchide si deschide complet ( cel putin cea de jos pe care o vad pt ca la cea de sus nu stiu cum as putea avea acces).
O alta intrebare:  Am vreo sansa cu celalalt motoras(V68) daca il vede blocat sau fara tensiune?
01271 - Positioning Motor for Temperature Flap (v68)
Ce are in plus fata de vers anterioara ?
NU stiu. Nu am testat inca.
Ohoo...acum fac si eu update-ul. In plus cred ca are optiuni ptr hex-net. Nu ne ajuta pe noi :(
Ala trebuie schimbat.
Hex net a aparut cu precedenta versiune.
  • Aerofan pinned this topic
    • k4b00
