suzu
Cineva a rezolvat eroarea:
Address 01: Engine       Labels: Redir Fail!
Control Module Part Number: 3B0 907 557
  Component and/or Version: 1,6l R4/2V SIMOS HS D03
           Software Coding: 04001
            Work Shop Code: WSC 00000
01177 - Engine Control Unit
        37-10 - Faulty - Intermittent
Readiness: N/A
Daca da, cum? Mentionez ca nu simt diferente, masina merge, porneste, dar are eroarea respectiva.
salut!
am si eu 2 erori la golf 4, 1,6 bcb 16v:
16555- sistem sarac bank 1
          - permanent
si cateodata,
16786- valva recirculare gaze debit excesiv
          - permanent.
ma puteti ajuta?
va multumesc!
debit excesiv nu are cum, doar sa fi ramas egr pe deschis.
Stai ca nu am vazut ca e la benzinar, se schimba clapeta EGR sau se poate incerca curatarea ei.
17584 - Bank1: O2S (Lambda) Correction Behind Catalyst: Control Limit Reached
        P1176 - 35-10 - - - Intermittent
ce inseamna mai exact?
salutare, am si eu o problema cu golful5 al lui tata, din senin nu ii mai merg geamurile din spate.
o fi de la modulul de confort° unde e localizat°
Thursday,25,July,2013,13:30:21:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ5P053031   Mileage: 119640km/74340miles
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 036-906-032-AXP.lbl
   Part No SW: 036 906 032 AM    HW: xxxxxxxxxxx
   Component: BOSCH ME7.5.10      6441
   Revision: 00000000    Serial number: VWZ7Z0D1176724
   Coding: 0000071
   Shop #: WSC 00028 028 00001
   VCID: 5BBF89B59A3EA11
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0019073
   VCID: 3A712C317544B89
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 1K0 820 047 EF
   Component: Climatic PQ35   084 0404
   Shop #: WSC 00000 000 00000
   VCID: 6CDDDA694F90D69
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 M    HW: 1K0 937 049 M*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001217352
   Coding: 008D0F0600041800001400001400000000087B075C
   VCID: 3973333D7042B31
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
2 Faults Found:
01333 - Door Control Module; Rear Left (J388)
            004 - No Signal/Communication
01334 - Door Control Module; Rear Right (J389)
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 C    HW: 1K0 909 605 C
   Component: 07 AIRBAG VW8   013 2100
   Revision: 02013000    Serial number: 0033HD0232UU
   Coding: 0012343
   VCID: 2C5D1A698F10169
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 E    HW: 1K0 953 549 E
   Component: Lenksäulenmodul 021 0050
   Coding: 0000002
   VCID: 346D020957204E9
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 851 F
   Component: KOMBIINSTRUMENT VDD 0716
   Coding: 0003103
   Shop #: WSC 00999 444 64523
   VCID: 2B5F19758A1E111
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104B120405
   Coding: 3D3F0340070002
   VCID: 2953E37D80E2031
2 Faults Found:
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 29
                    Mileage: 119642 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:24:49
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 29
                    Mileage: 119642 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:24:49
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0716
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0147
   Coding: 0000052
   VCID: 30650E19A338729
2 Faults Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
            012 - Electrical Fault in Circuit
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            008 - Implausible Signal - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.0       1502
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 80C802087F2D8404084F01E010
   VCID: 7BFFE9353AFE411
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
3 Faults Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   VCID: 31630B1DA8327B1
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 L
   Component: Radio GR0       012 0018
   Revision: 0001201S    Serial number: VWZ2Z2D1528891
   Coding: 0020200
   VCID: 2F670D65BE066D1
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
End   ---------------------------------------------------------------------
Verifica siguranta pentru geamurile spate.
le-am verificat pe toate si am sa le mai verific din nou :)
Imi poate explica si mie cineva ce inseamna acesti parametri?
Readiness: 0 0 1 1 1
Am cautat eu pe google dar nu prea am inteles.
Address 01: Engine
Control Module Part Number: 03C 997 056 M
  Component and/or Version: MED9.5.10       G00 9265
           Software Coding: 0000072
            Work Shop Code: WSC 77364
1 Fault Found
17441 - Sensor for NOx (G295): Signal too Low
        P1033 - 002 - Lower Limit Exceeded
motorul este 1,6 bag pe un golf 5
am gasit aceasta eroare la scanare cu vag com, in bord nu se aprinde becul de noxe ,imi puteti spune la ce sa ma astept?
Inlocuire piesa sau noi il anulam din soft la multe masini , fara influente negative asupra functionarii motorului
Modificat de Turbocip
cine ma poate ajuta sa activez sonorul alarmei. inainte margea dar acum se aprind doar luminile ma poate ajuta cineva?
Buna ziua si multumesc lui pronet pt indicaţii insa nu ma descurc cu "Intervalul de service il setezi pe flexibil sau fix "- m-am tot uitat pe interfată insă nu stiu ce anume să selectez. Am văzut ceva de genul ca selectarea se face la un nr fix de km sau perioada de timp insa nu m-am descurcat. Se poate să imi indicaţi pas cu pas etapele? Nu de alta dar nu vreau să fac cine stie ce prostii după care sa fiu nevoit sa resoftez tot calculatorul. Am mai scos o siguranţă si am ramas fără motor in plina strada intr-o duminică spre seara si pâna cand nu mi-a sters erorile ce apărusera nu a vrut să porneasca masina...... Costurile au fost destul de piperate...chiar si pentru un deranj duminica seara.. Multumesc!
si cum se anuleaza din soft? se anuleaza sonda sau becul?
Soft - si becul se va aprinde la pornire normal
Sal. Am si eu o problema cu becul de la check engine nu se aprinde deloc. Sa incep cu inceputul, cand am luat masina am observat ca nu mergea esp si am auzit de metoda de masluiala cu acoperirea martorului. Am desfacut ceasurile si avem banda izolatoare pe orificiu de la martoru de esp pe check engine nu aveam fiind langa. Dupa ce am achizitionat un cablu vagcom si am dat scan am vzt ca am probleme si cu sonda lambda 2 pe incalzire era dusa rezistenta de incalzire si automat sonda dadea valori aiurea dar becul tot nu s-a aprins si nu se aprinde nici cand pun contact. Acu am schimbat sonda cu una noua dar becul dupa cum am spus (check engine) nu se aprinde nici cand pun contact. Ar putea fi dezactivat din soft martoru??
Modificat de ovidiu94
Becul e bun ?
Intra pe instruments si da un output test...vezi ce becuri se aprind ...
o sa incerc treaba asta ca nu am incercat si nu stiu daca merge becu dar nu e bec e led smd
In 2000 se puneau SMD-uri ? :)
Si ala poate fi dus, sau nu e lipit cum trebuie...
daca se puneau in 2000 nu stiu o fi schimbat ce e clar ca e smd ca l-am vzt
Verifica-l si vezi daca clipoceste :) poate fi ars, pus pe dos etc...
andrei.laviniu
Buna seara tuturor , la un passat din semnatura dupa o scanare mi-au aparut urmatoarele erori  rog pe cineva sa ma ajute daca stie :
Monday,07,April,2014,17:30:04:40973
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ3CZ6P089548   License Plate: PASSAT
Mileage: 168380km-104626mi   Repair Order:
                Address 01: Engine       Labels: 03G-906-018-BKP.clb
Control Module Part Number: 03G 906 018     HW: 03G 906 018
  Component and/or Version: R4 2.0l PPD1.1 G    9722
            Work Shop Code: WSC 00684 210 82067
                      VCID: E2CBCC0A3DEF3C0E627-80B7
2 Faults Found:
17978 - Engine Start Blocked by Immobilizer
            P1570 - 008 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 4
                    Fault Frequency: 28
                    Reset counter: 145
                    Mileage: 167984 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:11:14
             Freeze Frame:
                    RPM: 0 /min
                    Text:      0    Nm
                    Speed: 0.0 km/h
                    Text:  0.0    %
                    Voltage: 11.53 V
                    Bin. Bits: 00011001
                    Bin. Bits: 00000000
18061 - Please check DTC Memory of ABS Controller
            P1653 - 008 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00001000
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 168251 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:14:07
             Freeze Frame:
                    RPM: 0 /min
                    Text:      0    Nm
                    Speed: 0.0 km/h
                    Text:  0.0    %
                    Voltage: 11.64 V
                    Bin. Bits: 00000100
                    Text:   1016    Nm
Readiness: N/A
Monday,07,April,2014,17:34:12:40973
                Address 25: Immobilizer       Labels: 3C0-959-433-25.clb
Control Module Part Number: 3C0 959 433 K    HW: 3C0 959 433 K
  Component and/or Version:    IMMO         038 0367
           Software Coding:
            Work Shop Code: WSC 131071 1023 2097151
           Additional Info: 3C0905861C     ELV          023 0350
           Additional Info: Geraet 2097151
                      VCID: 326BFC4AAD8F6C8E527-8067
6 Faults Found:
02861 - Electronic Steering Column Lock Check Sum Error
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 223
                    Mileage: 168019 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:22:57
02815 - Steering Column Lock; Supply Voltage for Locking Motor
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 4
                    Fault Frequency: 5
                    Reset counter: 223
                    Mileage: 168019 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:22:57
02817 - Steering Column Lock; Enabling Wire from Steering Wheel Electronics
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 223
                    Mileage: 168019 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:22:57
02818 - Steering Column Lock; Enabling for Electronic Ignition Lock
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 223
                    Mileage: 168019 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:22:57
            006 - Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00100110
                    Fault Priority: 2
                    Fault Frequency: 11
                    Reset counter: 246
                    Mileage: 168019 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:22:57
02811 - Control Module for Electronic Steering Column Lock (J764)
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 1
                    Fault Frequency: 23
                    Reset counter: 248
                    Mileage: 168019 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:22:57
Monday,07,April,2014,18:19:00:40973
Va multumesc frumos pentru ajutor
cel mai probabil, te va lasa blocatorul de volan/contactul.
andrei.laviniu
Mersi frumos Florin
  • Aerofan pinned this topic
    • k4b00
