suzu
Stie cineva? Se poate instala Vag Com (VCDS) aceeasi versiune DAR pe doua laptopuri diferite?
Eu am o interfata Vag Com (VCDS) (buna si functionala) si o am instalata pe un laptop dar vreau sa o instalez pe alt laptop!
Daca o instalez si pe alt laptop se poate strica interfata sau nu are nimic daca o instalez?
Poti sa o instalezi pe cate calculatoare vrei.
Am si eu o problema ciudata...ideea este ca imi sta check engine aprins desi pe grupul de motor nu am nicio eroare. Stiu ca masina are soft (sau cel putin asa zicea fostul proprietar) si downpipe si catalizator sport.
Thursday,30,August,2012,21:51:44:20433
VCDS Version: Release 11.11.4
Data version: 20120807
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZ6W051834 Mileage: 122980km/76416miles
01-Engine -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 HW: 1K0 907 115
Component: 2.0l R4/4V TFSI G00 0070
Revision: --H01--- Serial number: VWZ7Z0E2578680
Coding: 0403000318070160
Shop #: WSC 10101 599 74661
VCID: E3CFD3C4221AE900DC7
No fault code found.
Readiness: 0110 0001
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0004738
Shop #: WSC 01279 785 00200
VCID: 4085BC4813CC1218615
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AT
Component: ClimatronicPQ35 066 0606
Shop #: WSC 00000 000 00000
VCID: 79F311AC309683D066B
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000031186
Coding: E78F0F26000418140016000014000000000B7F075C
Shop #: WSC 01973 973 01973
VCID: 2B5FFBE48A4AE140A47
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00065493
Shop #: WSC 01973
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00471077
Shop #: WSC 01973
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 45 AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD046N2Z
Coding: 0013365
Shop #: WSC 01269 785 00200
VCID: 2E59F2F0B9589468839
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 634 0070
Coding: 0002022
VCID: 77F71794068295A010F
Part No: XXXXXXXXXXX
Component: E0221 007 0050
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K6 920 862
Component: KOMBIINSTRUMENT VDD 1212
Coding: 0007103
Shop #: WSC 11111 111 11111
VCID: EDDBB5FCF4DEAF707A3
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001059020114
Coding: 7D3F0340070002
VCID: 2A51FEE085B0F8485F1
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1212
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2467
Coding: 0000182
VCID: 3777D794460255A0D0F
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 3261E680AD60B088E71
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 00C802487F2D8F0FC8CFC6F010CC
Part No: 1K0 951 605 B
Component: LIN BACKUP HORN H07 7001
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 1K0 951 177 A
Component: Innenraumueberw.005 0202
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1K0 959 702 L
Coding: 0000182
VCID: 3875D4A84B1C5AD8D95
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: F4EDA09897F47EB8B5D
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 P
Component: Radio BVX 017 0023
Coding: 0040402
VCID: 336FE384527AB980EC7
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2429
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 F
Coding: 0000144
VCID: 346DE0985774BEB8F5D
End ---------------------------------------------------------------------
Dar antenna 2 care este oare? cea tip bat sau este ceva in hayon de ex? ca nu stiu pe care sa o verific. Oricum..problema cu check engine nu o pot intelege
Codul de eroare spune că ai doar o antenă activă.
Masina are amplificator antena standard.
probail ai o navigatie pusa,nu a fost dotata masina initial cu ea.
asta este parerea mea din cate am mai vazut pe alte forumuri despre eroarea 00821 - Antenna 2 for Radio (R93)
http://vwnavi.com/volkswagen-factory-fit-navigation-systems/rns-510-mfd3-navi-system/11513-1-fault-found-00821-antenna-2-radio-r93-post44548.html#post44548
Am RCD 300...deci ce sa verific?ar trebui sa fie ambele antene active? Radio se aude destul de prost...este ff slab fata de calitatea track-urilor. La A3 aveam cd-playerul concert..si se auzea mult mai clar radioul.
In legatura cu aprinderea Check engine are cineva vreo idee?
Trebuie vazut daca sunt probleme la conectori sau antena.....
nu am idee,nu ma pricep asa bine,dar daca a fost rescris flash-ul de la ECU, remapat, trebuie sa incerci sa ii pun softul original.un soft virgin,nemodificat.
merge cu interfete gen KWP2000,k+can commander,galletto, etc.se gasesc peste tot
ii poti pune o intrebare fostului proprietar daca nu cumva a salvat softul original, de obicei asa se face
Softul original nu il are salvat. Nu am idee unde mi s-ar putea instala softul original..si cat ar costa. Teoretic stiu ca se asigura revenirea la softul original gratuit. O alta problema este ca eu nu mai pot afla nici cine a facut resoftarea :( . Fiind si evacuarea schimbata nu stiu daca nu cumva motorul va merge prost cu softul original.
macar intelegi chestia cu check engine.daca o fi fost vre-un soft dinala de 50 ron 3dvd-uri pline cu soft,imi e frica sa ma gandesc.
in acelasi timp nu cred ca softul pe care il ai acum a fost conceput de catre un tuner,special pentru masina ta.....
Eu stiam ca la schimbarea evacuarii cu una sport se anuleaza din soft sonda lambda de dupa catalizator...Eu probabil nu o am anulata...pana la urma nu inteleg cum de sta check engine aprins dar la scanare nu apar erori.
Aveti idee unde as putea pune softul original?si cam la ce pret ar fi?
Modificat de catalinmiti
probabil putem gasi.ce cod are ECU?
fa-i o poza daca nu ai nici un fel de posibilitate de a afla
pai in diagnoza postata mai sus nu apare codul ECU? daca nu presupun ca trebuie sa demontez grila stergatoarelor...ansamblul acestora si sa il gasesc sub ele.
Codul apare. Eu zic sa nu umbli nicaieri, atata timp cat nu ai eroare pe ECU.
Pai si atunci ce ar putea aprinde check engine-ul? ca teoretic ar trebui sa ramana stocata undeva.
Soft original pentru masina ta , 100E costa sa il rescrii.
Dar poti sa treci sa il citim si sa vedem daca ai soft modificat sau original pe masina .
Turbocip se ocupa cu softuri remapari,etc el stie mai bine ce si cum trebuie facut
@Turbocip : si aceasta scanare costa ceva in plus?
Vino maine .
Nu te costa nimic ;
Sa suni inainte (intre 16:30:1730 nu te pot ajuta )
ok..nu stiu sigur daca pot ajunge maine...ca momentan sunt la buzau..dar te contactez cand ajung acasa. Multumesc foarte mult!
Salut. Astazi mi-a aparut mesjul "emission garage".Am scanat masina cu vcds si am avut eroare "16785 -EGR SYSTEM- insufficient flow, P0401- 000 - -". Am tot citit pe forum si tot nu sunt lamurit. Trebuie schimbat sau nu EGR-ul?Supapa egr a fost curatata acum 1 an si jumate. eroare a aparut dupa un drum pe transfagarasan.Va rog sa ma lamuriti si pe mine.
Modificat de Pedy_golf 5
Verifica daca EGR-ul mai tine vacuum - posibil membrana sparta.
Daca am citit bine, vacuum-ul se verifica tragand aer prin acel mic stut de la capsula?Nu prin furtunelul care intra in stut.Ei bine, am verificat si trag usor aer.
Daca nu am procedat bine, te rog spune-mi cum pot sa verific altfel, ca sa-mi pot da seama daca membrana este sparta? Mersii mult
Buna seara !
16955 - Brake Switch (F): Implausible Signal
P0571 - 008 - Implausible Signal
Asta e codul de eroare , as vrea sa stiu daca din cauza acestei erori imi apare martorul EPC in bord cateodata si daca tot vei raspunde te-as ruga sa imi spui care ar fi defectul din toate acele cauze de pe "ross-tech".
Pot sa iti spun ca am schimbat de curand becul de stop stanga pentru ca mi s-a ars.
Masina : Golf 5 ,2005 , 1.4 FSI
Modificat de dr_junior1980
daca ai schimbat deja becul, ai sters eroare.... acum vezi daca mai reapare. Daca da, e de la switch-ul pedalei de frana. EPC-ul e si martor OBD si de aceea ti-l aprinde daca sunt probleme cu switch sau becurile de frana.
Atunci e membrana sparta si trebuie schim,bata capsula.
  • Aerofan pinned this topic
